ZXT-120
greenwitch
Re: ZXT-120
Post by greenwitch »
Ben0it wrote: Friday 30 December 2016 20:53 ecific="6" type="General Thermostat V2" listening="true" frequentListening="false" beaming="true" routing="true" max_baud_rate="40000" version="4" sleep_after_send="20000" secured="true" query_stage="Complete">[/code]
I have crashes all the time when using this instruction. I cannot get it stable
2018-06-14 22:36:17.118  Error: Domoticz received fatal signal 11 !...
2018-06-14 22:36:17.180  Error:   /home/pi/domoticz/domoticz() [0x263630]
2018-06-14 22:36:17.180  Error:   /home/pi/domoticz/domoticz(_Z14signal_handleri+0x4c) [0x2636e8]
2018-06-14 22:36:17.180  Error:   /lib/arm-linux-gnueabihf/libc.so.6(__default_sa_restorer+0) [0x76c6d6b0]
2018-06-14 22:36:17.180  Error:   /home/pi/domoticz/domoticz(_ZN9OpenZWave9ValueList8WriteXMLEP12TiXmlElement+0xbc) [0x7e6f78]
2018-06-14 22:36:17.180  Error:   /home/pi/domoticz/domoticz(_ZN9OpenZWave12CommandClass8WriteXMLEP12TiXmlElement+0x3c4) [0x822354]
2018-06-14 22:36:17.180  Error:   /home/pi/domoticz/domoticz(_ZN9OpenZWave12CentralScene8WriteXMLEP12TiXmlElement+0x14) [0x813c50]
2018-06-14 22:36:17.180  Error:   /home/pi/domoticz/domoticz(_ZN9OpenZWave4Node8WriteXMLEP12TiXmlElement+0xe7c) [0x808ac0]
2018-06-14 22:36:17.180  Error:   /home/pi/domoticz/domoticz(_ZN9OpenZWave6Driver11WriteConfigEv+0x218) [0x7f1a00]
2018-06-14 22:36:17.180  Error:   /home/pi/domoticz/domoticz(_ZN9OpenZWave7Manager11WriteConfigEj+0x1c) [0x7cf624]
2018-06-14 22:36:17.180  Error:   /home/pi/domoticz/domoticz(_ZN10COpenZWave21WriteControllerConfigEv+0x1c) [0x504584]
2018-06-14 22:36:17.180  Error:   /home/pi/domoticz/domoticz(_ZN10COpenZWave19OnZWaveNotificationEPKN9OpenZWave12NotificationE+0x1264) [0x517cdc]
2018-06-14 22:36:17.181  Error:   /home/pi/domoticz/domoticz(_ZN9OpenZWave7Manager14NotifyWatchersEPNS_12NotificationE+0x74) [0x7da808]
2018-06-14 22:36:17.181  Error:   /home/pi/domoticz/domoticz(_ZN9OpenZWave6Driver14NotifyWatchersEv+0xcc) [0x7f8b28]
2018-06-14 22:36:17.181  Error:   /home/pi/domoticz/domoticz(_ZN9OpenZWave6Driver16DriverThreadProcEPNS_5EventE+0x2a0) [0x801550]
2018-06-14 22:36:17.181  Error:   /home/pi/domoticz/domoticz(_ZN9OpenZWave10ThreadImpl3RunEv+0x20) [0x84ba98]
2018-06-14 22:36:17.181  Error:   /home/pi/domoticz/domoticz(_ZN9OpenZWave10ThreadImpl10ThreadProcEPv+0x8) [0x84bab4]
Any hints?
Ok, please verify my theory.
diff --git a/config/zwcfg.xsd b/config/zwcfg.xsd
index ed9d20f..e32c9be 100644
--- a/config/zwcfg.xsd
+++ b/config/zwcfg.xsd
@@ -67,6 +67,7 @@
    <xs:attribute name='version' type='xs:string' use='optional'/>
    <xs:attribute name='query_stage' type='xs:string' use='optional'/>
    <xs:attribute name='security' use='optional'>
+   <xs:attribute name='sleep_after_send' use='optional'/>
     <xs:simpleType>
      <xs:restriction base='xs:string'>
       <xs:enumeration value='true'/>
+ <xs:attribute name='sleep_after_send' use='optional'/> is in wrong place. It should be before security line as next lines are describing possible values of security parameter.
Last point for me is to add manually line
after line
in domoticz/Config/zwcfg.xsd file. It seems that this corrections might take an effect. I will report in few days if crashes stopped.
Adam
greenwitch
Re: ZXT-120
No it was not it:
2018-07-04 06:17:02.402  Error: Domoticz received fatal signal 11 !...
2018-07-04 06:17:02.428  Error:   /home/pi/domoticz/domoticz() [0x262fa0]
2018-07-04 06:17:02.428  Error:   /home/pi/domoticz/domoticz(_Z14signal_handleri+0x4c) [0x263058]
2018-07-04 06:17:02.428  Error:   /lib/arm-linux-gnueabihf/libc.so.6(__default_sa_restorer+0) [0x76be96b0]
2018-07-04 06:17:02.428  Error:   /home/pi/domoticz/domoticz(_ZN9OpenZWave9ValueList8WriteXMLEP12TiXmlElement+0xbc) [0x7dff78]
2018-07-04 06:17:02.429  Error:   /home/pi/domoticz/domoticz(_ZN9OpenZWave12CommandClass8WriteXMLEP12TiXmlElement+0x3c4) [0x81b354]
2018-07-04 06:17:02.429  Error:   /home/pi/domoticz/domoticz(_ZN9OpenZWave12CentralScene8WriteXMLEP12TiXmlElement+0x14) [0x80cc50]
2018-07-04 06:17:02.429  Error:   /home/pi/domoticz/domoticz(_ZN9OpenZWave4Node8WriteXMLEP12TiXmlElement+0xe7c) [0x801ac0]
2018-07-04 06:17:02.429  Error:   /home/pi/domoticz/domoticz(_ZN9OpenZWave6Driver11WriteConfigEv+0x218) [0x7eaa00]
2018-07-04 06:17:02.429  Error:   /home/pi/domoticz/domoticz(_ZN9OpenZWave7Manager11WriteConfigEj+0x1c) [0x7c8624]
2018-07-04 06:17:02.429  Error:   /home/pi/domoticz/domoticz(_ZN10COpenZWave21WriteControllerConfigEv+0x1c) [0x4fed6c]
2018-07-04 06:17:02.429  Error:   /home/pi/domoticz/domoticz(_ZN10COpenZWave19OnZWaveNotificationEPKN9OpenZWave12NotificationE+0x1264) [0x51304c]
2018-07-04 06:17:02.429  Error:   /home/pi/domoticz/domoticz(_ZN9OpenZWave7Manager14NotifyWatchersEPNS_12NotificationE+0x74) [0x7d3808]
2018-07-04 06:17:02.429  Error:   /home/pi/domoticz/domoticz(_ZN9OpenZWave6Driver14NotifyWatchersEv+0xcc) [0x7f1b28]
2018-07-04 06:17:02.429  Error:   /home/pi/domoticz/domoticz(_ZN9OpenZWave6Driver16DriverThreadProcEPNS_5EventE+0x2a0) [0x7fa550]
2018-07-04 06:17:02.429  Error:   /home/pi/domoticz/domoticz(_ZN9OpenZWave10ThreadImpl3RunEv+0x20) [0x844a98]
2018-07-04 06:17:02.429  Error:   /home/pi/domoticz/domoticz(_ZN9OpenZWave10ThreadImpl10ThreadProcEPv+0x8) [0x844ab4]
Again the same crash.I will troubleshoot more
greenwitch
Re: ZXT-120
And another crash.
2018-07-04 23:43:25.081 Detail, Node012,   Received: 0x01, 0x0b, 0x00, 0x04, 0x00, 0x0c, 0x05, 0x31, 0x05, 0x01, 0x01, 0x18, 0xd5
2018-07-04 23:43:25.081 Info, Node012, Received SensorMultiLevel report from node 12, instance 1, Temperature: value=24C
2018-07-04 23:43:25.082 Detail, Node012, Refreshed Value: old value=24, new value=24, type=decimal
2018-07-04 23:43:25.082 Detail, Node012, Changes to this value are not verified
2018-07-04 23:43:25.082 Detail, Node012, Notification: ValueChanged
2018-07-04 23:43:37.149 Detail, Node013, Polling: COMMAND_CLASS_SWITCH_BINARY index = 0 instance = 1 (poll queue has 0 messages)
2018-07-04 23:43:37.149 Detail, Node013, Queuing (Poll) MultiChannel Encapsulated (instance=1): SwitchBinaryCmd_Get (Node=13): 0x01, 0x0d, 0x00, 0x13, 0x0d, 0x06, 0x60, 0x0d, 0x01, 0x01, 0x25, 0x02, 0x25, 0x9c, 0x19
2018-07-04 23:43:37.149 Info, Node013, Sending (Poll) message (Callback ID=0x9c, Expected Reply=0x04) - MultiChannel Encapsulated (instance=1): SwitchBinaryCmd_Get (Node=13): 0x01, 0x0d, 0x00, 0x13, 0x0d, 0x06, 0x60, 0x0d, 0x01, 0x01, 0x25, 0x02, 0x25, 0x9c, 0x19
2018-07-04 23:43:37.157 Detail, Node013,   Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2018-07-04 23:43:37.157 Detail, Node013,   ZW_SEND_DATA delivered to Z-Wave stack
2018-07-04 23:43:37.175 Detail, Node013,   Received: 0x01, 0x07, 0x00, 0x13, 0x9c, 0x00, 0x00, 0x02, 0x75
2018-07-04 23:43:37.175 Detail, Node013,   ZW_SEND_DATA Request with callback ID 0x9c received (expected 0x9c)
2018-07-04 23:43:37.175 Info, Node013, Request RTT 26 Average Request RTT 26
2018-07-04 23:43:37.175 Detail,   Expected callbackId was received
2018-07-04 23:43:37.187 Detail, Node013,   Received: 0x01, 0x0d, 0x00, 0x04, 0x00, 0x0d, 0x07, 0x60, 0x0d, 0x01, 0x01, 0x25, 0x03, 0x00, 0xb7
2018-07-04 23:43:37.187 Info, Node013, Response RTT 37 Average Response RTT 37
2018-07-04 23:43:37.187 Info, Node013, Received a MultiChannelEncap from node 13, endpoint 1 for Command Class COMMAND_CLASS_SWITCH_BINARY
2018-07-04 23:43:37.187 Info, Node013, Received SwitchBinary report from node 13: level=Off
2018-07-04 23:43:37.187 Detail, Node013, Refreshed Value: old value=false, new value=false, type=bool
2018-07-04 23:43:37.187 Detail, Node013, Changes to this value are not verified
2018-07-04 23:43:37.187 Detail, Node013,   Expected reply and command class was received
2018-07-04 23:43:37.187 Detail, Node013,   Message transaction complete
2018-07-04 23:43:37.188 Detail, Node013, Removing current message
2018-07-04 23:43:37.188 Detail, Node013, Notification: ValueChanged
Nothing here for me that would give a clue about the reason of crash. Node 13 is Fibaro FGS212 and never before had any issue with it.
2018-07-04 23:43:20.568  (Z wave) General/Thermostat Mode (Klimatyzacja tryb pracy)
2018-07-04 23:43:20.675  (Dzialka) General/kWh (Unknown)
2018-07-04 23:43:20.779  (Dzialka) Usage (Unknown)
2018-07-04 23:43:20.835  (Dzialka) General/kWh (Unknown)
2018-07-04 23:43:20.837  (Dzialka) Light/Switch (Unknown)
2018-07-04 23:43:24.376  (Dzialka) Usage (Unknown)
2018-07-04 23:43:24.454  (Dzialka) General/kWh (Unknown)
2018-07-04 23:43:24.455  (Dzialka) Light/Switch (Unknown)
2018-07-04 23:43:25.087  (Z wave) Temp (Kuchnia temperatura nad lodĂłwka)
2018-07-04 23:43:26.983  (Dzialka) General/kWh (Unknown)
2018-07-04 23:43:27.083  (Dzialka) Usage (Unknown)
2018-07-04 23:43:27.158  (Dzialka) General/kWh (Unknown)
2018-07-04 23:43:30.223  (Dzialka) General/kWh (Unknown)
2018-07-04 23:43:30.312  (Dzialka) Usage (Unknown)
2018-07-04 23:43:30.400  (Dzialka) General/kWh (Unknown)
2018-07-04 23:43:34.375  (Dzialka) Usage (Unknown)
2018-07-04 23:43:34.454  (Dzialka) General/kWh (Unknown)
2018-07-04 23:43:34.456  (Dzialka) Light/Switch (Unknown)
2018-07-04 23:43:36.543  (Dzialka) General/kWh (Unknown)
2018-07-04 23:43:36.634  (Dzialka) Usage (Unknown)
2018-07-04 23:43:36.714  (Dzialka) General/kWh (Unknown)
2018-07-04 23:43:37.191  Error: Domoticz received fatal signal 11 !...
2018-07-04 23:43:37.213  Error:   /home/pi/domoticz/domoticz() [0x262fa0]
2018-07-04 23:43:37.213  Error:   /home/pi/domoticz/domoticz(_Z14signal_handleri+0x4c) [0x263058]
2018-07-04 23:43:37.213  Error:   /lib/arm-linux-gnueabihf/libc.so.6(__default_sa_restorer+0) [0x76c5d6b0]
2018-07-04 23:43:37.213  Error:   /home/pi/domoticz/domoticz(_ZN9OpenZWave9ValueList8WriteXMLEP12TiXmlElement+0xbc) [0x7dff78]
2018-07-04 23:43:37.213  Error:   /home/pi/domoticz/domoticz(_ZN9OpenZWave12CommandClass8WriteXMLEP12TiXmlElement+0x3c4) [0x81b354]
2018-07-04 23:43:37.213  Error:   /home/pi/domoticz/domoticz(_ZN9OpenZWave12CentralScene8WriteXMLEP12TiXmlElement+0x14) [0x80cc50]
2018-07-04 23:43:37.213  Error:   /home/pi/domoticz/domoticz(_ZN9OpenZWave4Node8WriteXMLEP12TiXmlElement+0xe7c) [0x801ac0]
2018-07-04 23:43:37.213  Error:   /home/pi/domoticz/domoticz(_ZN9OpenZWave6Driver11WriteConfigEv+0x218) [0x7eaa00]
2018-07-04 23:43:37.213  Error:   /home/pi/domoticz/domoticz(_ZN9OpenZWave7Manager11WriteConfigEj+0x1c) [0x7c8624]
2018-07-04 23:43:37.213  Error:   /home/pi/domoticz/domoticz(_ZN10COpenZWave21WriteControllerConfigEv+0x1c) [0x4fed6c]
2018-07-04 23:43:37.213  Error:   /home/pi/domoticz/domoticz(_ZN10COpenZWave19OnZWaveNotificationEPKN9OpenZWave12NotificationE+0x1264) [0x51304c]
2018-07-04 23:43:37.213  Error:   /home/pi/domoticz/domoticz(_ZN9OpenZWave7Manager14NotifyWatchersEPNS_12NotificationE+0x74) [0x7d3808]
2018-07-04 23:43:37.213  Error:   /home/pi/domoticz/domoticz(_ZN9OpenZWave6Driver14NotifyWatchersEv+0xcc) [0x7f1b28]
2018-07-04 23:43:37.213  Error:   /home/pi/domoticz/domoticz(_ZN9OpenZWave6Driver16DriverThreadProcEPNS_5EventE+0x2a0) [0x7fa550]
2018-07-04 23:43:37.213  Error:   /home/pi/domoticz/domoticz(_ZN9OpenZWave10ThreadImpl3RunEv+0x20) [0x844a98]
2018-07-04 23:43:37.213  Error:   /home/pi/domoticz/domoticz(_ZN9OpenZWave10ThreadImpl10ThreadProcEPv+0x8) [0x844ab4]
greenwitch
Re: ZXT-120
I have found the solution. Crashes were not result of patch (which works great!!!)
It was due to different version of ozw which was less stable. I recommend to use 1.4.2888 from development branch.
To do it:
cd /home/pi
git clone https://github.com/OpenZWave/open-zwave open-zwave-read-only
cd open-zwave-read-only
# put remotec-zxt120.diff in /home/pi/open-zwave-read-only folder
git checkout 54682370a134cbb77e66802ac112f80f5f0d5c9c # change version to 1.4.2888 dirty
git apply  /home/pi/open-zwave-read-only/remotec-zxt120.diff
make
and follow instruction from
https://www.domoticz.com/wiki/Raspberry ... rom_source
greenwitch
Re: ZXT-120
I have update diff script to work with openzwave 1.6.
Enjoy.
Adam
remotec-zxt120-OZW-16.zip
(1.62 KiB) Downloaded 34 times
greenwitch
Re: ZXT-120
There was change in ozw 1.6 and there is only ozwcache_0xcfe3020d.xml which seems to be temporary file.
I cannot store sleepaftersend value in it.
Any hint how to solve this problem?
Adam
greenwitch
Re: ZXT-120
OK,
I have evolved the patch and make it simpler.
As only ZXT-120 seems to have that problem I have hard coded in driver.cpp check that if node is zxt device than it adds 20000us before removing message. Works like a charm.
Please find attached diff file.
Adam
ozw16zxtfix.zip
(568 Bytes) Downloaded 33 times
