Python Plugin: WLED
vwtune
Re: Python Plugin: WLED
Where is the support here?
frustreerMeneer
I have little time at the moment. I haven't tried the new WLED myself yet. As soon as i have more time for the project i will look into it.
Have you tried going back to an older version of WLED, if that solves the problem?
antonlamers
- Domoticz version: 2021.1
Hi reinstalled domoticz and restore the database, now I have an error by WLED. I add the pIugin but i don't see WLED by the hardware page. I did remove the directory WLED and reinstal WLED, but I don’t see WLED by the hardware. How must I remove WLED in domoticz and reinstalled it?
Anton
Anton
Greating,
Anton
Version: 2023.2
Build Hash: 19efd039c
Compile Date: 2023-07-21 17:23:44
dzVents Version: 3.1.8
Python Version: 3.9.2 (default, Feb 28 2021, 17:03:44) [GCC 10.2.1 20210110]
Anton
Version: 2023.2
- wizardnl
First of all thank you for the effort works great in the new wled version you have the segment option any change this could be included? Need it for a nice project
Again thanks for the effort
frustreerMeneer
Did you get it working?antonlamers wrote: Tuesday 02 June 2020 20:50 Hi reinstalled domoticz and restore the database, now I have an error by WLED. I add the pIugin but i don't see WLED by the hardware page. I did remove the directory WLED and reinstal WLED, but I don’t see WLED by the hardware. How must I remove WLED in domoticz and reinstalled it?
Anton
Ironburn
Same problem here. Any solution?salopette wrote: Saturday 29 February 2020 9:13 Hi. I have been told that the switch remains on even though the lamp has been switched off.
Can you fix that?
2020-02-29 09:12:43.088 Status: User: Admin initiated a switch command (6473/LED - Color & Brightness/Off)
frustreerMeneer
Check out the new version, i have fixed the On/Off statuses.Ironburn wrote: Saturday 10 October 2020 14:49Same problem here. Any solution?salopette wrote: Saturday 29 February 2020 9:13 Hi. I have been told that the switch remains on even though the lamp has been switched off.
Can you fix that?
salopette
- Domoticz version: BETA
Thank you! It works!
antonlamers
No.frustreerMeneer wrote: Friday 25 September 2020 13:26Did you get it working?antonlamers wrote: Tuesday 02 June 2020 20:50 Hi reinstalled domoticz and restore the database, now I have an error by WLED. I add the pIugin but i don't see WLED by the hardware page. I did remove the directory WLED and reinstal WLED, but I don’t see WLED by the hardware. How must I remove WLED in domoticz and reinstalled it?
Anton
my SD had an error, i fixed it now, but when i reinstal wled, i don't see it.
I can i first remove it en install it again?
I did remove the directory, but that doesn't work
Greating,
Anton
Version: 2023.2
Anton
Version: 2023.2
frustreerMeneer
Remove it from Domoticz hardware, then restart.antonlamers wrote: Friday 16 October 2020 16:36 I can i first remove it en install it again?
If the directory is still there, remove it and restart.
Then try reinstalling.
Make sure you have the WLED directory in domoticz/plugins.
frustreerMeneer
I'm working on segments now. I will release it soonwizardnl wrote: Sunday 26 July 2020 10:54 First of all thank you for the effort works great in the new wled version you have the segment option any change this could be included? Need it for a nice project![]()
salopette
That's cool! What exactly is being done?
frustreerMeneer
I'm still working things out. But as soon as you have more than 1 segment you will get a master color and brigtness slider (the one that you already have) and 1 color and brightness slider per extra segment. I think it is the same way Home Assistant does it.
I still have to look into effects, presets and palletes.
Let me know your ideas.
- Clipboard01.jpg (52.73 KiB) Viewed 3175 times
salopette
I was only curious! This is very good the way they do it!
I don't have a single pigment myself, I don't know how to use it.
vwtune
Since i updated to version 2020.2 of Domoticz
Domoticz is crashing almost once a day. Before it crashes, i can see in the log:
After this, domoticz crashed
It has something to do with wled plugin i think....
I already did a git pull and restart to get the latest wled plugin, but still get the crashes on WLED.
Can you please take a look at this?
2020-10-30 17:41:15.764 Error: (WLED Hal Nodemcu ) Exception detail: 'Unterminated string starting at: line 5 column 49 (char 1236)'
2020-10-30 17:41:15.764 Error: (WLED Hal Nodemcu ) 'onMessage' failed 'ValueError'.
2020-10-30 17:41:15.764 Error: Domoticz(pid:771, tid:775('PluginMgr')) received fatal signal 11 (Segmentation fault)
2020-10-30 17:41:15.764 Error: siginfo address=0x303, address=(nil)
Dave21w
- Domoticz version: Stable
Does anyone know why this doesn't work
The lamp switches on and off ok and all set percentages get written ok but it completely ignores the Set WLED - Effects value so I can't have a preset pattern at power on, I've tried altering the Set order and delaying it but it makes no difference, also tried the value in a txt box with the pattern no. and name but no response, changing the pattern in Domoticz directly on the switch page works fine.
Any ideas guys.
TIA
Dave
Any ideas guys.
TIA
Dave
frustreerMeneer
WLED - Effects is also a level setting. In this case 50%.Dave21w wrote: Monday 07 December 2020 22:06 Does anyone know why this doesn't work
Any ideas guys.
TIA
Dave
It seems a bit strange but that is how Domoticz selects work.
Dave21w
Ah OK, but then this means I can't go above pattern 100 (%)
Thanks for your really quick response
frustreerMeneer
I think you actually can go higher as it's not really a percentage.Dave21w wrote: Monday 07 December 2020 22:32 Ah OK, but then this means I can't go above pattern 100 (%)
