dzVents get garbage collection dates (various)  [SOLVED]
Bikey
Domoticz version: 2020.x
Re: dzVents get garbage collection dates (various)
Post by Bikey »
That script actually works! Well sort off, it complains with this error, although the devices are updated:
 Error: dzVents: Error: (3.0.9) collectGarbage: Error parsing json to LUA table: /opt/domoticz/scripts/dzVents/../lua/JSON.lua:1234: /opt/domoticz/scripts/dzVents/../lua/JSON.lua:1016: Lua script execution exceeds maximum number of lines
So what I think needs to be done, is that as a first step in the script below, the response should be parsed to minimize it down to only contain the "afhaaldagen" part.
local function handleResponse()
            triggerObject.json = dz.utils.fromJSON(triggerObject.data)         -- dzVents does nor recognize the response as pure JSON so conversion is required
            if #triggerObject.json < 1 then
                dz.data.garbage    = triggerObject.json.data.ophaaldagen.data      -- Store this part in dz.data
                rt = triggerObject.json.data.ophaaldagen.data                      -- and in table
               errorMessage("Problem with response (no data) using data from earlier run")
               rt  = dz.data.garbage                       -- json empty. Get last valid from dz.data
               if #rt < 1 then                              -- No valid data in dz.data either
                  errorMessage("No previous data. are zipcode and housenumber ok and in afvalkalender ?")
                  return false
As said before I figured out that the regEx for this is:
.*(\"ophaaldagen\".*),.*\"ophaaldagenNext\":.*
So only need to work out in Lua how to handle that.
HansieNL
Post by HansieNL »
waaren wrote: Friday 12 June 2020 16:28
HansieNL wrote: Friday 12 June 2020 16:00 @waaren What is the latest dzvents script for MijnAfvalwijzer?
Below is the latest one I made. No idea if it still working (I don't use it myself) but should not be very hard to get it to work if mijnAfvalwijzer stil returns something that looks like a JSON.
--[[ getGarbageDates.lua for [ dzVents >= 2.4 ]
this script is only useful in those  areas of the Netherlands where the household garbage collector is connected to afvalwijzer.nl
Enter your zipcode and housenumber in the appropriate place between the lines starting with --++++
Next is to set your virtual text and or virtual alert device.
the text device will contain the most nearby collectdates for the four types of household garbage
the alert device will contain the date and type for the garbagecollecion that will arrive first
        on      =   {   timer              =  { "at 00:05","at 08:00" },    -- daily run twice
                        devices            =  { "Garbage" },               -- Only for test purposes can be ignored
                        httpResponses      =  { "getGarbage_Response" }     -- Trigger the handle Json part
        logging =   {   level              =   domoticz.LOG_DEBUG,
                        marker             =   "collectGarbage"      },
        data    =   {   garbage            =    { initial = {}      },       -- Keep a copy of last json just in case
                        lastStartline      =    { initial = 1       },
                        lastEndline        =    { initial = 1000    },
    execute = function(dz, triggerObject)
        --++++--------------------- Mandatory: Set your values and device names below this Line --------------------------------------
        local myZipcode     = "3085RA"            -- Your zipcode like "3085RA"
        local myHousenumber =  38                 -- Your housenumber like 38
        local myTextDevice  = "GarbageText"       -- Name with quotes or idx without when created as virtual text device
        local myAlertDevice = "GarbageAlert"      -- Name with quotes or idx without when created as virtual alert device
        --++++---------------------------- Set your values and device names above this Line --------------------------------------------
        local myYear = os.date("%Y")
        garbageTypes  = {"restafval","gft","papier","plastic"}
        local function collectGarbageDates(secondsFromNow)
            local getGarbage_url  = "http://json.mijnafvalwijzer.nl/?method=postcodecheck&postcode="  ..
                                    myZipcode .. "&street=&huisnummer=" ..
                                    myHousenumber .. "&toevoeging"
            dz.openURL  ({  url = getGarbage_url ,
                            method = "GET",
                            callback = "getGarbage_Response" }).afterSec(secondsFromNow)
        -- Add entry to log and notify to all subsystems
        local function errorMessage(message)
            dz.log(message,dz.LOG_ERROR)
            dz.notify(message)
        local function string2Epoch(dateString) -- seconds from epoch based on stringdate (used by string2Date)
            -- Assuming a date pattern like: yyyy-mm-dd
            local pattern = "(%d+)-(%d+)-(%d+)"
            local runyear, runmonth, runday= dateString:match(pattern)
            local convertedTimestamp = os.time({year = runyear, month = runmonth, day = runday})
            return convertedTimestamp
        local function string2Date(str,fmt)             -- convert string from json into datevalue
            if fmt then return os.date(fmt,string2Epoch(str)) end
            return os.date(" %A %d %B, %Y",string2Epoch(str))
        local function alertLevel(delta)
            if delta < 2 then return dz.ALERTLEVEL_RED end
            if delta < 3 then return dz.ALERTLEVEL_YELLOW end
            if delta < 4 then return dz.ALERTLEVEL_ORANGE end
            return dz.ALERTLEVEL_GREEN
        local function setGarbageAlertDevice(alertDevice,alertText,alertDate)
            local delta = tonumber(string2Date(alertDate,"%d")) - tonumber(os.date("%d"))  -- delta in days between today and first garbage collection date
            dz.devices(alertDevice).updateAlertSensor(alertLevel(delta),alertText)
            dz.log("\nalertLevel: " .. alertLevel(delta) .. ", alertText: " .. alertText,dz.LOG_DEBUG)
            return (delta == 0)
        local function longGarbageName(str)                                        -- Use descriptive strings
            str = tostring(str)
            str = str:gsub("plastic","  Plastic verpakkingen, blik en drinkpakken ")
            str = str:gsub("gft","  Groente-, fruit- en tuin afval            ")
            str = str:gsub("papier","  Papier en kartonnen verpakkingen          ")
            str = str:gsub("restafval" ,"  Restafval                                ")
            return str
                  return false
            local lastEndline = 1000
            if dz.data.lastStartline ~= 1 then
                lastEndline = dz.data.lastStartline + 10
            local garbageLines = ""
            local typeEarliestDate
            local overallEarliestDate   = "2999-12-31"       -- Hopefully we will have a different garbage collection system by then
            local garbageToday = false
            local today = os.date("%Y-%m-%d")
            for i = 1,#garbageTypes do --walk the the type Table
                typeEarliestDate      = "2999-12-31"
                for j = dz.data.lastStartline,math.min(#rt,lastEndline) do                                 -- walk the response table
                    dz.log(rt[j].date .. ": " .. rt[j].type,dz.LOG_DEBUG)
                    if  rt[j].date >= today and rt[j].date < typeEarliestDate and
                        rt[j].type == garbageTypes[i] then              -- Keep date closest to today per type
                        typeEarliestDate =  rt[j].date
                        if  typeEarliestDate < overallEarliestDate then     -- date closest to today overall ?
                            overallEarliestDate = typeEarliestDate          -- keep date
                            overallEarliestType =  garbageTypes[i]          -- keep type
                            dz.data.lastStartline = j
                        garbageLines = garbageLines .. string2Date(typeEarliestDate,"%a %e %b" ) .. longGarbageName(rt[j].type) .. " " .. "\n"
                        typeEarliestDate = rt[j].date  -- Keep date closest to today
            if myAlertDevice then   -- Update AlertDevice with nearby date / type
                garbageToday = setGarbageAlertDevice(  myAlertDevice,
                                                        longGarbageName(overallEarliestType) .. "\n" ..
                                                        string2Date(overallEarliestDate),
            if myTextDevice then       -- Update defined virtual text device with dates / types
                dz.devices(myTextDevice).updateText(garbageLines)
                dz.log("\n" .. garbageLines,dz.LOG_DEBUG)
            if dz.time.matchesRule("at 08:00-17:00") and garbageToday then
                dz.notify(longGarbageName(overallEarliestType) .. "will be collected today")
        -- Main
        if triggerObject.isHTTPResponse then
            if triggerObject.ok then
                handleResponse()
                errorMessage("Problem with response from hvcgroep (not ok)")
                --collectGarbageDates(600)                            -- response not OK, try again after 10 minutes
            collectGarbageDates(1)
Thanx. AfvalWijzer does still works o.k. with your script. Only because I had no virtual alert device I got some errors, but all is working fine now.
Oops... I got 3 dates, but missing 2 next dates:
Wed 24 Jun Restafval
Wed 1 Jul Groente-, fruit- en tuin afval
Thu 16 Jul Papier en kartonnen verpakkingen
If I use this old script:
    --  on      =  { timer           =  {"every 1 minutes"},         -- During test / debug (only one "on =" line can be active )
    --  on      =  { timer           =  {"never"},                   -- To deactivate
--  logging =   {   level     =   domoticz.LOG_DEBUG,              -- Remove the "-- at the beginning of this and next line for debugging the script
--                  marker    =   "collectGarbage"      },
    data    =   {   garbage     = {initial = {} },             -- Keep a copy of last json just in case
        local myZipcode     = "nnnntt"            -- Your zipcode like "3085RA"
        local myHousenumber =  nn                 -- Your housenumber like 38
                            method = "GET",
            dz.notify(message)
            return (delta == 0)
            str = tostring(str)
            return str
                  return false
                for j = 1,#rt do                                 -- walk the response table
        -- Main
                handleResponse()
                errorMessage("Problem with response (not ok)")
I got all dates (inclusing 2 next dates), but dates sorting is wrong :
Wed 17 Jun Groente-, fruit- en tuin afval
Thu 18 Jun Papier en kartonnen verpakkingen
Blah blah blah
HansieNL wrote: Friday 12 June 2020 18:20 Thanx. AfvalWijzer does still works o.k. with your script. Only because I had no virtual alert device I got some errors, but all is working fine now.
If you send me (via PM) a working zipcode / housenumber, if will have a look.
Bikey
Post by Bikey »
Don’t you get this error?
Error: dzVents: Error: (3.0.9) ...1016: Lua script execution exceeds maximum number of lines
Bikey wrote: Friday 12 June 2020 20:57 Don’t you get this error?
ronaldbro
Post by ronaldbro »
I just played a little with it and it looks like line 91 can be deleted.
I guess it's not needed anymore because triggerObject.json is filled already. While testing the error is gone and it works after removing this line.
@waaren, can you confirm that this is not needed anymore?
ronaldbro wrote: Friday 12 June 2020 22:16 I just played a little with it and it looks like line 91 can be deleted.
If the return is already recognized by dzVents as a valid JSON then this line is not needed.
If I remember well, I added this forced conversion for cases where the return was not a 100% correct JSON. Then this line will try to force a conversion from the returned data into a Lua table.
This forced conversion should not cause a fatal error but a correcter code would be something like
if not(triggerOject.isJSON) then dz.utils.fromJSON(triggerObject.data) end
ronaldbro
Post by ronaldbro »
Thanks waaren,
For your information these are the full errors this line gives
 2020-06-12 22:09:03.935 Error: dzVents: Error: (3.0.9) collectGarbage: Error parsing json to LUA table: /home/pi/domoticz/scripts/dzVents/../lua/JSON.lua:1234: /home/pi/domoticz/scripts/dzVents/../lua/JSON.lua:1016: Lua script execution exceeds maximum number of lines
2020-06-12 22:09:03.935 Error: dzVents: Error: (3.0.9) collectGarbage: An error occurred when calling event handler Afvalwijzer
2020-06-12 22:09:03.936 Error: dzVents: Error: (3.0.9) collectGarbage: ...moticz/scripts/dzVents/generated_scripts/Afvalwijzer.lua:93: attempt to get length of a nil value (field 'json')
Where line 93 actually is line 91 in your script. I added a few debug lines...
Anyway, I guess a correct json is returned so if I understand well the line is not needed in this script.
ronaldbro wrote: Friday 12 June 2020 22:41 For your information these are the full errors this line gives
Thx for sharing!
I guess you get this error because of the very large JSON that is now converted to a table twice resulting in too many lines to be interpreted by the Lua engine of domoticz.
Using the isJSON check that I posted before this one should prevent calling the second (redundant) conversion.
Bikey
Post by Bikey »
I tried to reduce the result set by adding these lines which should reduce the result to only the "ophaaldagen" object, but that seem not to do anything, still getting the error that there are too many lines.
triggerObject.data = triggerObject.data:match('.*(\"ophaaldagen\".*),.*\"ophaaldagenNext\":.*')
triggerObject.data = "{"..triggerObject.data.."}"
Is that because it already get's into problems by ingesting the response, even before the first line in script above?
jvdz
Domoticz version: 4.107
Post by jvdz »
Not sure how to code this in dzVents, but this is the regex I use to strip the majority of the returned data and fix the JSON syntax:
webdata:match('(.-),\"mededelingen\":').."}}"
so maybe:
triggerObject.data = triggerObject.data:match('(.-),\"mededelingen\":').."}}"
Jos
Bikey
Post by Bikey »
Hi Jos,
Thanks for the tip, I actually got the idea from your script ;-)
My version is a try to improve that even a bit further by not only filtering everything out of the reply after the "ophaaldagen" object, but also everything before. If I test this regex in an online regex editor with the resultset from afvalwijzer it gets a nice result. I guess your code should work in DzVents as well, as this is basically also Lua.
Bikey wrote: Saturday 13 June 2020 13:07 Is that because it already get's into problems by ingesting the response, even before the first line in script above?
Yes and unfortunately this is not something that can be avoided easily. The dzVents mechanism to automatically convert the data to a json is triggered but as your return is too large and completely following the JSON RFC, it fails.
Bikey wrote: Saturday 13 June 2020 13:07 I tried to reduce the result set by adding these lines which should reduce the result to only the "ophaaldagen" object, but that seem not to do anything, still getting the error that there are too many lines.
can you try again after changing line
to
            if not triggerObject.json then
                triggerObject.json = dz.utils.fromJSON(triggerObject.data:gsub('"ophaaldagen:','"ophaaldagen":'))         -- dzVents does nor recognize the response as pure JSON so conversion is required
You will still see the error but script will continue and process the data.
ronaldbro
Post by ronaldbro »
Hi waaren,
I don't understand why it's better to keep this line. If you remove it the error is gone and everything works.
I understand the idea or best practice to do this when getting a bad json and try to force it. But in this case it seems the site return a proper json and it gets parsed right away. So I assume the site will always return a proper json (ok, maybe this is wishful thinking...).
ronaldbro wrote:Hi waaren,
If it works for you it's ok but I received private mails from other members (with ofcourse other zipcode / housenumbers) where the json needed fixing before it could be converted to a Lua table.
ronaldbro
Post by ronaldbro »
That makes sense, didn't expect the same website to return a proper json for some addresses and not for other addresses.
Updated the script to work for full compliant addresses and for addresses that return a somewhat crippled JSON.
Also fixed the skipping of some dates and ordering of the dates.
                            method = "GET",
            dz.notify(message)
            return (delta == 0)
            str = tostring(str)
            return str
            if type(triggerObject.json) == 'table' then
                  return false
            dz.utils.dumpTable(rt)
            local garbage = {}
                for j = 1, math.min(#rt, #dz.data.garbage) do                                 -- walk the response table
                   if  rt[j].date >= today and rt[j].date < typeEarliestDate and  rt[j].type == garbageTypes[i] then -- Keep date closest to today per type
                        garbage[string2Epoch(typeEarliestDate,"%a %e %b" )] = string2Date(typeEarliestDate,"%a %e %b" ) .. longGarbageName(rt[j].type)
            -- Order the lines based on dates
            local keyTable = {}
            local garbageLines = ''
            for key in pairs(garbage) do
                table.insert(keyTable, key)
            table.sort(keyTable)
            for _, key in ipairs(keyTable) do
                garbageLines = garbageLines .. garbage[key] ..  '\n'
            -- Update the devices
                dz.notify(longGarbageName(overallEarliestType) .. " will be collected today")
        -- Main
                handleResponse()
hjzwiers
Post by hjzwiers »
I had not checked this issue for a while, updated the script and its working. Thmx
ronaldbro
Post by ronaldbro »
Yep, working like a charm.
Now I need three small bulbs above my containers, lol.
