Page 4 of 14
Re: Zigbee2MQTT
Posted: Friday 31 August 2018 18:35
by ben53252642
Git updated, seems it's now supported?
https://github.com/Koenkk/zigbee2mqtt/issues/295
Re: Zigbee2MQTT
Posted: Friday 31 August 2018 20:05
by EddyG
No changes in github yet.
Re: Zigbee2MQTT
Posted: Sunday 02 September 2018 18:57
by ben53252642
Node-Red flow to unpair a device in Zigbee2MQTT
[{"id":"881e4b14.568708","type":"mqtt out","z":"f962b96d.7044c8","name":"zigbee2mqtt/in","topic":"zigbee2mqtt/bridge/config/remove","qos":"","retain":"","broker":"cd51966f.aa7e38","x":480,"y":420,"wires":[]},{"id":"c60eb810.782768","type":"inject","z":"f962b96d.7044c8","name":"Device to Unpair","topic":"","payload":"0x001388020121e5ei","payloadType":"str","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":300,"y":420,"wires":[["881e4b14.568708"]]},{"id":"4eb439f3.01d7f8","type":"comment","z":"f962b96d.7044c8","name":"Unpair a Device","info":"","x":100,"y":420,"wires":[]},{"id":"cd51966f.aa7e38","type":"mqtt-broker","z":"","name":"Domoticz","broker":"192.168.0.5","port":"1883","clientid":"","usetls":false,"compatmode":true,"keepalive":"60","cleansession":true,"birthTopic":"","birthQos":"0","birthPayload":"","closeTopic":"","closeQos":"0","closePayload":"","willTopic":"","willQos":"0","willPayload":""}]
Instructions:
1) Click "Device to Unpair"
2) "Payload" should be the name of the device to unpair (can be found in configuration.yaml)
3) Click the little button to the left of "Device to Unpair"
4) Check configuration.yaml in /opt/zigbee2mqtt/data the device should be removed
https://github.com/Koenkk/zigbee2mqtt/w ... nfigremove
Also a note:
To pair a Philips Hue Lightstrip with the Hue Bridge after it's previously been paired with Zigbee2MQTT, the solution is to type the 6 digit SN code on the back of the lightstrip controller when adding via the Hue app.
Re: Zigbee2MQTT
Posted: Wednesday 05 September 2018 4:51
by ben53252642
Created an admin panel in Node-Red
https://github.com/ben423423n32j14e/zig ... adminpanel
Re: Zigbee2MQTT
Posted: Wednesday 05 September 2018 20:22
by EddyG
Nice work. :D
Hopefully this Zigbee solution can hardware wise be directly integrated in Domoticz.
Saves a lot of nodered programming.
Re: Zigbee2MQTT
Posted: Wednesday 05 September 2018 20:49
by ben53252642
Indeed, unfortunately I don't currently have that level of skillset. :(
For me personally I don't see any reason why not to continue building on Node-Red, I like that I can integrate support for just about any Zigbee device that can join Zigbee2MQTT.
I'm creating a separate Git with flows for each type of device.
Re: Zigbee2MQTT
Posted: Saturday 08 September 2018 17:01
by EddyG
I am very curious for the flow of the Cube ( MFKZQ01LM - Xiaomi Mi smart home cube )
A whole lot of combinations. ;)
Re: Zigbee2MQTT
Posted: Sunday 09 September 2018 7:59
by Dlanor
I am trying to figure how to add devices. Does anyone have a step by step tutorial?
Re: Zigbee2MQTT
Posted: Monday 10 September 2018 2:28
by ben53252642
EddyG, have thought about the Xiaomi Cube (it's the only Xiaomi Zigbee sensor I don't currently have).
Would be cool in a 1 bedroom apartment type setup, I've got ZRC-90 remotes for each room with labelled buttons.
viewtopic.php?t=13782#p186794
My thinking RE the cube is I would forget what movement triggered x action, I'm very happy with the ZRC-90's.
Also have a few Aeotec Wallmote's setup as a panel in the kitchen which are fantastic.
viewtopic.php?f=24&t=16372&start=20#p172869
Hopefully my Xiaomi vibration / tilt/ fall sensors arrive today. :)
Re: Zigbee2MQTT
Posted: Monday 17 September 2018 19:14
by ben53252642
EddyG, are you finding that your Xiaomi Motion Sensors are not reporting battery status?
Also my Vibration / Tilt / Fall sensors finally arrived (today), will start playing with them soon.
Re: Zigbee2MQTT
Posted: Monday 17 September 2018 19:59
by EddyG
Dlanor wrote: Sunday 09 September 2018 7:59 I am trying to figure how to add devices. Does anyone have a step by step tutorial?
Here is the pairing of devices: https://github.com/Koenkk/zigbee2mqtt/w ... ng-devices
@ben53252642 All of my battery devices are reporting the battery %, but some of them are still on 100%, but they are new.
On the cube on top there is Aquara logo, so you could start from there.
Flip 90 on 4 sides, flip 180, wakeup, shake. Every side has a number so json look like:
object
battery: "100.00"
voltage: 3035
linkquality: 5
action: "flip90"
from_side: 0
to_side: 5
Re: Zigbee2MQTT
Posted: Monday 17 September 2018 20:09
by ben53252642
Thanks EddyG, I will wait to see if the motion sensor eventually checks in with a battery status (it's not sending one each time motion is triggered).
Battery works fine for my Xiaomi Temp / Humidity sensor, it's been fluctuating from around 85 - 88%, seems to be effected by temperature I'm guessing since it's stuck on a metal surface.
Re: Zigbee2MQTT
Posted: Wednesday 19 September 2018 20:10
by MarFan
First of all, really great dashboard! Thanks.
Do you think you can integrate a function like this https://github.com/Koenkk/zigbee2mqtt/issues/252?
I also hopes that an integration for Zigbee2MQTT will be in domoticz.
Somebody already start building it ? (maybe I can join)
Re: Zigbee2MQTT
Posted: Wednesday 19 September 2018 20:25
by ben53252642
MarFan, current thinking is a bit different.
I'm working on adding a "Device Health" widget, that lists devices with low signal, low battery or have not been seen for more than 6 hours (potentially failed).
Re: Zigbee2MQTT
Posted: Thursday 20 September 2018 3:02
by ben53252642
Added support for Philips Hue Lightstrip Plus V2
https://github.com/ben423423n32j14e/zig ... er/devices
Note, lightstrip firmware cannot have been upgraded using a Hue Bridge. If it has you will need to wait until Z-Stack 3.0 is available for Zigbee2MQTT.
Re: Zigbee2MQTT
Posted: Friday 21 September 2018 0:34
by ben53252642
EddyG, check this out,
Worked out how to use a variable for the MQTT topic.
A single flow that can control any Hue Lightstrip in the house (includes a HTTP API) so I can control using Lua scripts.
Eg:
http://192.168.0.5:1880/hueapi?devicename=lightstripkittylitter&state=on&brightness=126&r=0&g=0&b=0&colortemp=366&transition=1
[{"id":"fb7148f.58630b8","type":"comment","z":"ecbf4921.26b488","name":"Philips Hue Plus Lightstrips","info":"","x":150,"y":120,"wires":[]},{"id":"48eebee9.f9ecc","type":"mqtt in","z":"ecbf4921.26b488","name":"","topic":"domoticz/out","qos":"2","broker":"cd51966f.aa7e38","x":350,"y":60,"wires":[["a9756327.ccade"]]},{"id":"80a1c890.346428","type":"function","z":"ecbf4921.26b488","name":"Domoticz Control","func":"var idx = msg.payload.idx;\n\n// Domoticz IDX to Zigbee2MQTT Device Name Map\nif (idx == '1258'){\n    devicename = 'lightstrip2ndbathroommirror';\n} else if (idx == '1260'){\ndevicename = 'lightstripkittylitter';\n} else if (idx == '1261'){\ndevicename = 'lightstripmainbathmirror';\n} else if (idx == '1262'){\ndevicename = 'lightstripmbrwardrobe';\n} else {\n    devicename = null;\n}\n\nif (typeof devicename !== 'undefined' && devicename !== null){\n\nvar nvalue = msg.payload.nvalue;\nvar brightness = msg.payload.svalue1;\nvar r = msg.payload.Color.r;\nvar g = msg.payload.Color.g;\nvar b = msg.payload.Color.b;\nvar colortemp = msg.payload.Color.ww;\nmsg.payload = {}\n\nif(nvalue == '0') {\n    msg.payload.state = 'OFF'\n}\nif(nvalue == '1' || nvalue == '10') {\n    msg.payload.state = 'ON';\n    msg.payload.brightness = Math.round(brightness * 255 / 100);\n    if (r === 0 && b === 0 && g === 0) {\n    msg.payload.color_temp = Math.round(500 / 255 * colortemp);\n    msg.payload.transition = 1;\n    }else{\n    msg.payload.color = {\"r\":r,\"g\":g,\"b\":b};\n    msg.payload.transition = 1;\n}\n}\n\nmsg.topic = 'zigbee2mqtt/'+devicename+'/set';\n\nreturn msg;\n}","outputs":1,"noerr":0,"x":650,"y":60,"wires":[["f7ed5194.3f7f9"]]},{"id":"a9756327.ccade","type":"json","z":"ecbf4921.26b488","name":"","property":"payload","action":"","pretty":false,"x":490,"y":60,"wires":[["80a1c890.346428"]]},{"id":"772e44e0.eeb13c","type":"template","z":"ecbf4921.26b488","name":"page","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"<html>\n<head></head>\n<body>\n<h1>API:</h1>\n<h3>Usage: /hueapi?devicename=huetest&state=on&brightness=100&r=50&g=170&b=2&colortemp=0&transition=1</h3>\n<h3>or</h3>\n<h3>Usage: /hueapi?devicename=huetest&state=on&brightness=100&r=0&g=0&b=0&colortemp=270&transition=1</h3>\n<h4>Note: this page is always displayed regardless if command is successful or not.</h4>\n</body>\n</html>","x":490,"y":180,"wires":[["bf0118ca.6ffa08"]]},{"id":"d13ff611.844ac8","type":"http in","z":"ecbf4921.26b488","name":"","url":"/hueapi","method":"get","upload":false,"swaggerDoc":"","x":350,"y":120,"wires":[["84c8aed7.2462a","772e44e0.eeb13c"]]},{"id":"bf0118ca.6ffa08","type":"http response","z":"ecbf4921.26b488","name":"","x":610,"y":180,"wires":[]},{"id":"84c8aed7.2462a","type":"function","z":"ecbf4921.26b488","name":"HTTP Control","func":"var state = msg.req.query.state;\nvar brightness = msg.req.query.brightness;\nvar r = msg.req.query.r;\nvar g = msg.req.query.g;\nvar b = msg.req.query.b;\nvar colortemp = msg.req.query.colortemp;\nvar devicename = msg.req.query.devicename;\nvar transition = msg.req.query.transition;\nmsg.payload = {}\n\n\nmsg.payload.state = state;\nmsg.payload.brightness = brightness;\nmsg.payload.transition = transition;\nif (r === '0' && g === '0' && b === '0') {\nmsg.payload.color_temp = colortemp;\n}else{\nmsg.payload.color = {\"r\":r,\"g\":g,\"b\":b};\n}\nmsg.topic = 'zigbee2mqtt/'+devicename+'/set';\n\nreturn msg;\n","outputs":1,"noerr":0,"x":520,"y":120,"wires":[["f7ed5194.3f7f9"]]},{"id":"f7ed5194.3f7f9","type":"mqtt out","z":"ecbf4921.26b488","name":"zigbee2mqtt/in","topic":"","qos":"","retain":"","broker":"cd51966f.aa7e38","x":700,"y":120,"wires":[]},{"id":"cd51966f.aa7e38","type":"mqtt-broker","z":"","name":"MQTT","broker":"127.0.0.1","port":"1883","clientid":"","usetls":false,"compatmode":true,"keepalive":"60","cleansession":true,"birthTopic":"","birthQos":"0","birthPayload":"","closeTopic":"","closeQos":"0","closePayload":"","willTopic":"","willQos":"0","willPayload":""}]
Go to: http://noderedip:1880/hueapi
Domoticz Control function maps IDX numbers to Zigbee2MQTT device names.
So far I've disconnected the Xiaomi Hub, now I can get rid of my Hue bridge. :mrgreen:
Re: Zigbee2MQTT
Posted: Friday 21 September 2018 18:06
by StasDemydiuk
I started implementing python plugin for domoticz to add native zigbee2mqtt support
viewtopic.php?f=65&t=24975
Re: Zigbee2MQTT
Posted: Friday 21 September 2018 18:22
by quack3d
Sweet. Think I need to order some new hardware now. Please don't forget Windows support.
Re: Zigbee2MQTT
Posted: Saturday 22 September 2018 20:29
by EddyG
ben53252642 wrote: Friday 21 September 2018 0:34 EddyG, check this out,
Will do in october after my holiday.
Re: Zigbee2MQTT
Posted: Saturday 22 September 2018 23:00
by Willem16
Hey guys,
I've just started with home domotica. I would like to use domoticz on a ubuntu machine. I've installed domoticz. I've flashed a cc2531 usb sniffer and would like to use this with domoticz, but from here it gets a bit blurry.
- As I understood I need to install and run CC2531 https://github.com/Koenkk/zigbee2mqtt/w ... the-bridge
- I've installed mqtt as well (https://www.vultr.com/docs/how-to-insta ... untu-16-04)
- And I've installed domoticz-zigbee2mqtt-plugin (https://github.com/stas-demydiuk/domoti ... qtt-plugin)
I think it goes wrong with the domoticz-zigbee2mqtt-plugin.
Is there a step by step guide how to set this up for a noob like me? Or is there someone how could help me with this? I really would appreciate it.
I'm planning to use this setup to combine the Ikea Tradfri with the Xiaomi censors. I've allready have a couple of Ikea tradfri bulbs and the Xiaomi Magic cube.
Willem
