I fully disagree on this with you: a Domoticz crash doesn't always mean you lose all the contents of your sd/ssd. Db corruptions can occur for example by an update gone wrong and all sorts of other things can go wrong making you have to re-install domoticz and/or it's db. Keeping collected data in separate storage based on what its intended purpose is, is always a good idea: The domoticz.db is for use by domoticz only and a separate database should be used for your collected data. Influxdb is an easy choice for this because it's well integrated as a data-push. You can store that influxdb in the same machine with your Domoticz because that's available already. But you might just as well store it in some other machine -f.e. if you're really afraid of losing the data when your sd/ssd crashes-. You can also store data from other sources in that same influx database, for example from a second domoticz instance or from completely other sources. But still the most important point for me to have a separate storage for my collected data is that the use for the both data sets is different: A very important principle to me is to never re-use the same thing for different purposes. Re-using the same data for a secondary purpose, almost without exception leads to conflicts and limitations in the future.waltervl wrote: Monday 04 October 2021 21:51 Agreed on the 5 min interval data (max 7 days in domoticz). For air quality data the Domoticz daily summary would be good enough I suppose.
Not agreed on losing data on a Domoticz crash as automatic database backup is part of Domoticz setup.
If your sd/ssd crashes you would also loose the influxdb data if you did not backup externally (influxdb and Domoticz).
Luftdaten [SOLVED]
rrozema
Re: Luftdaten
- Domoticz version: 2026.3
Re: Luftdaten
My principle is to use what I have. Exporting data to influxdb is an extra layer that should not be used for backup purposes.
So agreed that influxdb is better in storing loads of derailed information but it has no extra function as an extra data backup possibility.
But we agree to disagree
ariepapa
- Domoticz version: 2022.2
Re: Luftdaten
Used your script but needed to adept it a little because i used different sensor BMP280 instead of BME280
Setup of the sensor:
Add hardware (dummy device)
Add devices:
> Name: "Luftdaten PM10", Type: custom sensor, X-axis: µg/m3
> Name: "Luftdaten PM2.5", Type: custom sensor, X-axis: µg/m3
> Name: "Luftdaten DHT22", Type: Temp + Humidity
> Name: "Luftdaten BMP280", Type: Temp + Baro, (optional sensor)
updateTempBaro according to the wiki finally made it work for me.
Thanks for the great script, and all the credits for svde!
Add devices:
local FQDN = 'luftdaten.[xxx].com' -- without the []
active = true,
timer = { 'every 5 minutes' },
httpResponses = { 'luftdatenRetrieved' } -- matches callback string below
if (item.isTimer) then
domoticz.openURL({
url = 'http://.... local ip of the sensor.... /data.json',
method = 'GET',
callback = 'luftdatenRetrieved'
elseif (item.isHTTPResponse) then
if (item.ok and item.isJSON) then -- statusCode == 2xx
if tonumber(item.json.age) < 60 then
for i, t2 in pairs(item.json.sensordatavalues) do
if (t2.value_type == 'SDS_P1') then
domoticz.devices('Luftdaten PM10').updateCustomSensor(t2.value)
elseif (t2.value_type == 'SDS_P2') then
domoticz.devices('Luftdaten PM2.5').updateCustomSensor(t2.value)
elseif (t2.value_type == 'temperature') then
temperature = t2.value
elseif (t2.value_type == 'humidity') then
humidity = t2.value
elseif (t2.value_type == 'BMP280_temperature') then
BMP280_temperature = t2.value
elseif (t2.value_type == 'BMP280_pressure') then
BMP280_pressure = t2.value/100
if (temperature ~= nil and humidity ~= nil) then
domoticz.devices('Luftdaten DHT22').updateTempHum(temperature,humidity,0)
if (BMP280_temperature ~= nil and BMP280_pressure ~= nil) then
domoticz.devices('Luftdaten BMP280').updateTempBaro(BMP280_temperature,BMP280_pressure,0)
-- oops
domoticz.log('Error fetching Luftdaten data', domoticz.LOG_ERROR)
domoticz.log(item.data, domoticz.LOG_ERROR)
