[154] - CurrentCost Envir support
Nautilus
Re: [154] - CurrentCost Envir support
Post by Nautilus »
djib78 wrote:Hello,
I try to link current cost bridge with Domoticz without success.
My current cost bridge working fine in my.currentcost.com.
To add current cost bridge material in Domoticz you need to set IP address en port number :
- IP address is local network IP ?
- port number is 80 ?
Thanks for your help
From earlier in this thread:
JohnAdders wrote:
Nautilus wrote: just to confirm - do I understand correctly that the LAN interface option is not meant to be working with CurrenCost Bridge (available for EnviR at least)? But the USB option should work just by hooking the unit (EnviR in my case) to the Pi running Domoticz?
Correct
John
So at least my interpretation was that it is not meant to work with the bridge, unfortunately...
djib78
Post by djib78 »
Thanks for your feedback.
Is it possible to use LAN and USB in the same time on current cost enviR ?
Using specific cable maybe ?
Nautilus
Post by Nautilus »
djib78 wrote:Thanks for your feedback.
Check out the bolded bit at the end...:)
Nautilus wrote:
JC38 wrote:Hello Panser,
You're right for the cable.
But you can't use both solution at the same time.
However, there is a Current Cost device with Lan Interface in Domoticz, maybe this is for your netsmart.
Im afraid it's not:
Correct
John
I have currently hooked my EnviR to both Netsmart bridge and USB with a help of RJ45 splitter (you can get one from Ebay for a dollar or two).
djib78
Post by djib78 »
Thanks.
I will buy one RJ45 splitter to test.
Winjas
Domoticz version: 3.5877
Post by Winjas »
Sorry to drag up an old thread, but I picked up a brand new sealed Envir kit at a Yard Sale for just a few pennies (UK), Bargain of the year!
Two questions:
Anyone know if the cable is propriety, i.e. can I make one ? Electronics workshop here and all sorts parts etc just trying to work out Ethernet to USB schematic the Envir uses?
Secondly, once cabled, can it connect directly to my PI in one of the spare USB ports, and kind of set and forgot (my Domoticz Pi is in a hard accessible cupboard)
