Re: Get online airquality data
Posted: Thursday 07 October 2021 15:25
data from http://waqi.info/
An API key is required and can be aquired here ==> http://aqicn.org/data-platform/token/
Based on the original idea and script from @elmortero
http://api.waqi.info/feed/geo:51.852062;4.507676/?token=Your_apikey = Zwartewaalstraat, Rotterdam Zuid
http://api.waqi.info/feed/geo:51.986119;4.934413/?token=Your_apikey = Lopik (co)
http://api.waqi.info/feed/geo:51.867238,4.354981/?token=Your_apikey = Leemkuil (so2)
timer = { "every 30 minutes" },
httpResponses = { "waqi*" } -- matches callback wildcard
data = {
safedMessage = { history = true, maxItems = 100 , maxHours = 168 }
logging = { level = domoticz.LOG_DEBUG,
marker = "Waqi" },
execute = function(dz, triggerItem)
local apiKey = "my api"
local defaultLocation = "my location"
local sensorType
local colorDevice = dz.devices('desk light')
if dz.data.safedMessage.get(1) == nil then
dz.data.safedMessage.add("Init")
local geo = { nearby = defaultLocation, -- to get station closest to your home
so2 = "", -- if value for this item cannot be obtained from "nearby"
co = "", -- else keep this as an empty string
pm25 = "",
pm10 = "",
o3 = "",
no2 = "",
aqi = "",
p = "", --barometer
w = "",
-- wg = "",
local sensors = { so2 = { sensor = 62, alert = 63 }, -- enter device index Numbers or 0 for sensor and alert "
co = { sensor = 64, alert = 65 },
pm25 = { sensor = 66, alert = 67 },
pm10 = { sensor = 68, alert = 69 },
o3 = { sensor = 70, alert = 71 },
no2 = { sensor = 72, alert = 73 },
aqi = { sensor = 76, alert = 75 , aqiSensor = 74}, -- additional Air Quality sensor
p = { sensor = 647, alert = 0 }, --barometer
w = { sensor = 656, alert = 0 },
-- wg = { sensor = 657, alert = 0 },
local sensorTypes = { alert = "Alert", aqi = "Air Quality", custom = "Custom Sensor" }
local function responseType(str) -- strip waqi_ from string
return str:gsub("waqi_","")
local function setColor(value, device)
local colors = {
green = {min = 0, max = 50, red = 0, green = 255, blue = 0},
yellow = {min = 51, max = 100, red = 255, green = 255, blue = 0},
orange = {min = 101, max = 150, red = 255, green = 165, blue = 0},
red = {min = 151, max = 200, red = 255, green = 0, blue = 0},
purple = {min = 201, max = 300, red = 128, green = 0, blue = 128},
maroon = {min = 301, max = 999999, red = 128, green = 0, blue = 0},
for color, control in pairs(colors) do
if value > control.min and value <= control.max then
device.setColor(control.red, control.green, control.blue, device.level)
device.dimTo(device.level).afterSec(1)
--device.dump()
local function errorMessage(message,notify) -- Add entry to log and notify to all subsystems
dz.log(message,dz.LOG_ERROR)
if notify then
dz.notify(message)
local function callPollutionURL(location,callback,delay)
local delay = delay or 1
local url = "http://api.waqi.info/feed/geo:".. location .. "/?token=" .. apiKey
dz.openURL({ url = url,
method = "GET",
callback = callback
}).afterSec(delay)
local function getAirQualityData()
local delay = 1
for callType, location in pairs(geo) do
if location ~= "" then
callPollutionURL(location,"waqi_" .. callType,delay)
delay = delay + 30
local function alertLevelAQI(value)
if value < 50 then return dz.ALERTLEVEL_GREEN,"Excellent" end
if value < 100 then return dz.ALERTLEVEL_YELLOW,"Poor" end
if value < 150 then return dz.ALERTLEVEL_ORANGE,"Polluted" end
return dz.ALERTLEVEL_RED,"Dangerous"
function deviceType(device)
if device ~= nil then
if dz.devices(device).deviceType:upper() == "GENERAL" then
return dz.devices(device).deviceSubType
return dz.devices(device).deviceType
return nil
local function setSensor(sensor,value)
if sensor ~= 0 and value ~= nil then
if deviceType(sensor) == sensorTypes.custom then
dz.devices(sensor).updateCustomSensor(value)
elseif deviceType(sensor) == sensorTypes.aqi then
dz.devices(sensor).updateAirQuality(value)
local alertLevel, alertText = alertLevelAQI(value)
local alertString = alertText .. "(" .. tostring(value) .. ")"
if dz.devices(sensor).text ~= alertString then
dz.devices(sensor).updateAlertSensor(alertLevel, alertString)
local function handleResponse(type)
local rt = triggerItem.json -- rt is just a reference to the data no actual copy is done
dz.log(triggerItem.data,dz.LOG_DEBUG)
if triggerItem.json ~= nil and rt.data ~= nil and tonumber(rt.data.aqi) then
if type == "nearby" then
rt.data.iaqi["aqi"] = {}; rt.data.iaqi["aqi"].v = rt.data.aqi -- handle exception in iaqi as aqi is stored elsewhere
for nearbyType, location in pairs(geo) do
if nearbyType ~= "nearby" and location == "" then -- No other location for this type
handleResponse(nearbyType)
for setDevice, idx in pairs(sensors[type]) do
dz.log("setDevice" .. setDevice, dz.log_DEBUG)
dz.log("idx" .. idx, dz.log_DEBUG)
dz.log("sensors[Type]" .. tostring(sensors[Type]), dz.log_DEBUG)
dz.log("rt" .. tostring(rt), dz.log_DEBUG)
dz.log("rt.data" .. tostring(rt.data), dz.log_DEBUG)
dz.log("rt.data.iaqi" .. tostring(rt.data.iaqi), dz.log_DEBUG)
dz.log("rt.data.iaqi[type]" .. tostring(rt.data.iaqi[type]), dz.log_DEBUG)
setSensor(idx,rt.data.iaqi[type:lower()].v)
dz.log("type" .. tostring(type), dz.log_DEBUG)
if type:lower() == 'pm10' then
dz.log("pm10 value" .. tostring(rt.data.iaqi.pm10.v), dz.log_DEBUG)
setColor(rt.data.iaqi.pm10.v, colorDevice)
errorMessage("This should not happen") -- aqi should always be there and set
if dz.data.safedMessage.get(1).time.secondsAgo > 30 then
errorMessage("I will call url again") -- aqi should always be there and set
callPollutionURL(geo[responseType(triggerItem.trigger)],triggerItem.trigger,1)
dz.data.safedMessage.add("Extra call to openURL for " .. triggerItem.trigger)
if triggerItem.isHTTPResponse then
if triggerItem.ok and triggerItem.isJSON then
handleResponse(responseType(triggerItem.trigger))
errorMessage("Problem with response from waqi",true)
getAirQualityData()
waltervl wrote: Saturday 23 July 2022 22:58 You can add a check for device.active in the if statement.
See also wiki https://www.domoticz.com/wiki/DzVents:_ ... ll_devices
