Aurora theme
EdwinK
Re: Aurora theme
Post by EdwinK »
Yes.. Got it working :)
Just a remark, maybe just me, but I find that even in 'compact' mode the blocks are too big.
Screen Shot 2017-12-21 at 12.44.47.png (120.05 KiB) Viewed 6004 times
And 2) We can't change the setting in 'general options'? They look clickable, but don't change
fkok
Re: Aurora theme
Post by fkok »
Maybe a stupid question, but can somebody please tell me how i get my camera on the dashboard? I have camera installed, but is isn't showing up on the dashboard.
gajotnt
Domoticz version: V4.9700
Re: Aurora theme
Post by gajotnt »
fkok wrote: Thursday 21 December 2017 13:44 Maybe a stupid question, but can somebody please tell me how i get my camera on the dashboard? I have camera installed, but is isn't showing up on the dashboard.
You need to associate a camera to a switch.
Go to the camera panel, select camera, then add a device to that camera.
fkok
Re: Aurora theme
Post by fkok »
gajotnt wrote: Thursday 21 December 2017 13:56
So i have to create a new Virtual on/off switch and add it to the camera?
fkok
Re: Aurora theme
Post by fkok »
fkok wrote: Thursday 21 December 2017 13:59
Thanks, it works!!!
jeanclic
Re: Aurora theme
Post by jeanclic »
it seems like there is an issue with the custom icons page :
2017-12-21 19_58_49-Domoticz.png (102.1 KiB) Viewed 5924 times
what can I change to correct that ?
RPI3B (Domoticz 4.9700 + ~60 scripts) + RFXtrx433E (fw1020) + Z-Stick Gen5 + MySensors / RPI2B+ (RasPlex)
x1 Eth. wired tablet
x8 T/H Oregon / x1 T/H Bresser
x7 heaters / x2 QUBINO "Flush 1 relay"
x10 plugs / x15 contacts
x4 fibaro / x1 PIR
jeanclic
Re: Aurora theme
Post by jeanclic »
Hello again,
things seems working better since yesterday night update, but still issue with icons as I said in the previous post, and I found an other issue with wind on dashboard :
2017-12-22 18_34_52-Domoticz.png (44.82 KiB) Viewed 5830 times
not correct I think.
Edit: datavisualization still not displaying temperatures below 4°C.
x4 fibaro / x1 PIR
Eoreh
Re: Aurora theme
Post by Eoreh »
Very cool theme. Should be in "box" domoticz's theme (or even default).
Get fresh ideas to domoticz's theme. My favorite features is : preview camera on dashboard, "grouped items", "shows idx numbers on items"
A great idea is to parameterize the theme in the settings tab
I change this on my default.
Thank You very much!!
dutchdevil83
Domoticz version: latest
Re: Aurora theme
Post by dutchdevil83 »
How to change the transparancy of the normal switches/buttons? When setting a custom background it is not readable anymore. For floorplan its fine but not for the rest of the tabs.
Hardware
1x Raspberry Pi
1x Razberry Z-Wave
1x RFXtrx433E
1x Toon
1x GoodWe Solarpanels
2x FGSD-002 Smoke Detector
1x FGBS-001 Binaire Sensor (RFID lezer)
7x FGMS-001 Motion Sensor
3x ZW089 Verzonken Deursensor
7x NC Wallplug
&lots of KaKu stuff
Eoreh
Re: Aurora theme
Post by Eoreh »
I think you have to check in css file in folder "Aurora".
My dashboard without picture in background looks very ok.
blauwebuis
Domoticz version: current
Re: Aurora theme
Post by blauwebuis »
@dutchdevil83 Try renaming the file 'dashboard_highlights_see-through.css' and then reloading the page. Originally most of the transparency was placed inside that file.
I've created a new version.
FIXES
- icon upload page now works. Thanks @jeanclic
- Wind sensors now work fine. Thanks @jeanclic
FEATURES
- Colors and background image is now also stored in Domoticz. For @remb0.
- Choosing the compact option now really makes it compact. Really really. For @EdwinK.
- A "time ago" option that changes the timestamp into a more human readable "3 minutes ago" type of output. Click on the timestamp to switch between the two.
- Battery status indicators. A small icon in the footer of each element will help you see the status at a glance. Hover over the battery icon to see the percentage remaining.
- icon upload page now looks really good if you have the 'submenu sidebar' option enabled.
Last edited by blauwebuis on Saturday 23 December 2017 22:03, edited 1 time in total.
blauwebuis
Re: Aurora theme
@edwinK: where was that bug with the data table?
EdwinK
Re: Aurora theme
Post by EdwinK »
It is in the temperature block, at http://*.*.*.*/#/Temperature
EdwinK
Re: Aurora theme
Post by EdwinK »
blauwebuis wrote: Saturday 23 December 2017 20:47 - Choosing the compact option now really makes it compact. Really really. For @EdwinK.
Thanks. Guess I need to download again
Eoreh
Re: Aurora theme
Post by Eoreh »
First i have to say - I love this theme.
From my punkt view to version from today -> 20171223:
- bug:(1) layout by rows ("unchecked -> Vertical columns on the dashboard"): Now in one row i have 5 items and only first 3 items in row have big "size" (icon etc). (see picture)
- bug:(2) layout by rows: 3-th or 2-end row in section have different "column" span. (see picture)
- future:(3) - can You add option to hide "name section". I dont need it and it take only space. For example in function newPage() i added code like this
$('#dashSwitches > h2').hide();
$('#dashTemperature > h2').hide();
$('#dashUtility > h2').hide();
(see picture - results).
- future / bug:(4) time ago in "merged" item - show for oldest one. In merged item i preferred show "update time" in line each name or at all. Is it possible ?. (see picture)
- future / bug:(5) - I love "big" value with temperature / humidity - etc. In this version value is moved to in "row" with name so it's not the same look as previously.
In central item now show - minor information which is for me less important than value item.
- future / bug:(6) - Datavisualisations is in the same color, witch information in item. When line cross letters its not readable. Maybe change color of line will be better ?.
TiXav
Re: Aurora theme
Post by TiXav »
I test this theme, I would like to say impressive !
But; if a proxy is used and a folder is used like this http://host:port/folder then the uservariable API request says error 404 in the dev tools of chrome or firefox so I made a little modification in my custom.js
If the index of the array is not # then there is a folder so needed to add it to the baseURL, perhaps a new way to do this is better...
started from line 55
var folder ="";
if (pathArray[3]!="#") { folder="/"+pathArray[3] }
var baseURL = protocol + '//' + host + folder ;[code]
[/code]
jeanclic
Re: Aurora theme
Post by jeanclic »
Hello there,
thanks again for this theme ! it looks very better than the default one.
Following last update, I still have a lot to tell about bugs/features. I made 4 pictures to explain :
2017-12-24 11_39_03-Domoticz_remarks-1.png (155.81 KiB) Viewed 5547 times
2017-12-24 11_39_03-Domoticz_remarks-2.png (133.36 KiB) Viewed 5547 times
x4 fibaro / x1 PIR
jeanclic
Re: Aurora theme
Post by jeanclic »
My pictures are too big, so I go on here :
2017-12-24 11_39_03-Domoticz_remarks-3.png (372.86 KiB) Viewed 5546 times
2017-12-24 11_39_03-Domoticz_remarks-4.png (154.97 KiB) Viewed 5546 times
x4 fibaro / x1 PIR
Docdigit
Re: Aurora theme
Post by Docdigit »
gijsje wrote: Sunday 17 December 2017 22:17 I have the issue that it does not show corect but i have it with all the themes.
I did delete the cache and did try ctrl F5
Any ideas?
Same issue overhere - I think it may be an issue with access rights on files after ftp'ing into the proper folder.
Will let you know once I found out...
Happy Xmas,
DD
With both feet on the ground you can't make any step forward...
gijsje
Domoticz version: Stable
Re: Aurora theme
Post by gijsje »
are you on the stable version?
I think it only works with beta so i did give up to get to work
I am not going to beta as the timers are not working
Synology DS218+ - RFXtrx433 - Aeotec Z-Stick Gen5 - Toon Thermostat - Neo CoolCam plug - Neo CoolCam PIR - FIBARO PIR - Heiman Smart Smoke Senso - Neo CoolCam Leakage Detector - BeNext Tag Reader - P1 and S0 USB - many Mi-Light lights - KAKU switches
