Page 4 of 4
Re: new zwave plus thermostat valves
Posted: Friday 19 October 2018 12:59
by Argarath
I'm wondering, I somehow cannot get my Spirit thermostats to work. They used to work flawlessly, until the last Domoticz update (I think?). I then started to apply the changes in this thread, and my Spirits get recognized, but I do not see the setpoints in Domoticz (at least no usable setpoints that react on the Spirit). This has partly to do with the fact that I'm not sure which is the right .xml to use, because there are different versions in the Github. Can somebody maybe help me?
Posted: Monday 29 October 2018 21:37
by swilting
I added two Spirit thermostats, one showing the actual temrature and one not, both not reacting on the set dry air seting. What can I do to fix?
(I addedn<Product type="0003" id="0001" name="EUR_SPIRITZ Wall Radiator Thermostat Valve Control" config="eurotronic/eur_spiritz.xml"/> and the eur_spirit.xml, but not know if this is the correct one
Posted: Friday 16 November 2018 16:23
by brommetje
Hi all, I am using now the latest beta v4.10203 and try to make the Spirit Z work no results yet.
As of 27 October the Spirit Z is added to the OpenZwave MASTER 1.4 and a few days later is in the Config op Domoticz.
The problem is now and is really confusing that we have a lot of eur_spiritz.xml files now but what is the right one?
I have compiled v4.10203 with the patch of @w1||14am and delivers a lot more devices but it crash after a will.
In the OpenZwave MASTER 1.4 only the config files are there but not the patch for setpoint and that is maybe the problem.
The patch from @w1||14am is doing something with the setpoint but is not stable or I missed something to run in this beta.
So I am now using the eur_spiritz.xml which comes with Domoticz so that is the one from the MASTER 1.4
- Spirit Z.gif (26.79 KiB) Viewed 602 times
Whatever I change it is not working or a message in the log "
Error: ZW_SEND_DATA could not be delivered to Z-Wave stack".
Has anyone a idea how to get this work beta?
Do we have to wait when the setpoint thing is implemented into the OpenZwave MASTER 1.4 or wait for 1.6?
I the picture I also see the device named "Furnance" what does this mean?
Posted: Friday 23 November 2018 13:32
by knielen
@brommetje
Any update on this project? You got it running now?
Furnace means 'open haard' by the way, I guess you can use this option when the room temperate is reached due to the furnace, but you still need heat from your radiator (when placed in another room for example).
Posted: Friday 23 November 2018 16:35
by brommetje
@knielen not yet,I tried several xml files but it’s not stable. setpoint not availble in Domoticz or Level not reliable.
Still not know which xml to use I should say what comes with latest Domoticz beta’s same as openzwave 1.4 master.
But we still have to change something but what we also some code for the setpoint I think.
