Page 4 of 5
Re: Dashticz - Module - Public Transport
Posted: Wednesday 02 May 2018 9:16
by robgeerts
Added NMBS (Belgium) in latest beta! (Thanks to ericvb)
Try:
publictransport.mol={station:'Mol',title:'Station Mol',show_lastupdate:true,provider:'irailbe',icon:'train',interval:15,width:7,results:5};
Posted: Tuesday 31 July 2018 7:54
by Dlanor
Anyone a idea how get rid of the
Lijn null?
- Knipsel.PNG (16.93 KiB) Viewed 4454 times
var publictransport = {}
publictransport.ovinfotrain = { show_via: true, station: 'station-den-haag-ypenburg', title:'NS-Ypenburg', provider: '9292-train', show_lastupdate:true, icon: 'train', width: 5, results: 6 };
Posted: Wednesday 05 September 2018 22:08
by amauryverschooren
robgeerts wrote: Monday 15 May 2017 23:00
First of all, thanks to @ultrara1n who started to build this module just the way the calendar- and trashmodule is coded too
In latest beta it is possible to show the timetable of the public transport company VVS (Germany) AND NS (Netherlands) with live data.
VVS:
To call the function properly, you will need the correct station id from:
https://efa-api.asw.io/api/v1/station/
So for Stuttgart Central Station the station id is 5006118
Then add this to config.js:
publictransport.hbf= { show_via: true, station: '5006118', title:'Trains', show_lastupdate:true, provider: 'VVS', icon: 'train', interval: 15, results: 5 };
9292.nl:
First get the station id from
http://api.9292.nl/0.1/locations?lang=nl-NL&q=eindhoven
(Change eindhoven to your own search parameter).
Then copy the id!
//example station id: station-eindhoven
publictransport.ovinfo= { show_via: true, station: 'station-eindhoven', title:'OV Info', show_lastupdate:true, provider: '9292', icon: 'train', results: 5 };
publictransport.ovinfotrain= { show_via: true, station: 'station-eindhoven', title:'Bus', show_lastupdate:true, provider: '9292-bus', icon: 'bus', results: 5 };
publictransport.ovinfobus= { show_via: true, station: 'station-eindhoven', title:'Trein', show_lastupdate:true, provider: '9292-train', icon: 'train', results: 5 };
Mobiliteit.lu:
To call the function properly, you will need the correct station name, for example:
Luxembourg/Centre, Royal
publictransport.ovinfobus = { key:'ovinfobus', show_via: false, station: 'Luxembourg/Centre, Royal', provider: 'mobiliteit',title:'Royal Stop',show_lastupdate:true, icon: 'bus', width:6, results: 4}
icon is simply font-awesome without fa, interval = time in seconds for refreshing the data, and results = number of shown results. Also possible is to customize the width, but i would not change the value of 12 because of the size of the output.
If anyone can provide JSON-output from other transport companies, please send me a message and I will add these!
hello Rob, is there also a version for in Belgium?
Posted: Monday 24 September 2018 9:15
by Recky
I have a request. Could you add the option to show the balance of the (anonymous) OV card? I'll crosspost this to the official request threat also. Thanks!
https://www.ov-chipkaart.nl/saldo-terug ... hecker.htm#/
Posted: Friday 21 February 2020 17:56
by rolandbreedveld
Is it possible for publictransport.ovinfobus to filter on destination, half of the info is not relevant for me, while the bus is driving the wrong direction.
Posted: Friday 21 February 2020 21:12
by Jimster
rolandbreedveld wrote: Friday 21 February 2020 17:56
Yes, you can use destination: 'Name of destination' to filter the destinations.
See
https://dashticz.readthedocs.io/en/mast ... sport.html
Posted: Saturday 22 February 2020 13:31
by rolandbreedveld
@Jimster, thanxzzz,
I works partly, I can't get "Rotterdam Zuidplein" as destination, what do I wrong:
publictransport.ovinfobus = { show_via: false, station: 'hendrik-ido-ambacht/bushalte-de-heerlijkheid', destination: 'Ridderkerk,Rotterdam Zuidplein', provider: '9292-bus', width: 6, results: 5 };
"Ridderkerk" works! but "Rotterdam Zuidplein" not, if I do without destination, I get :
"12:41 +3 - Lijn 392 - Rotterdam Zuidplein"
Should expect it working, I tried "Rotterdam", "Zuidplein", "Rotterdam Bushalte Zuidplein", "rotterdam/bushalte-zuidplein", and more combinations, but no result
This comes from the api:
"id": "rotterdam/bushalte-zuidplein",
"type": "stop",
"stopType": "Bushalte",
"name": "Zuidplein",
"place": {
"name": "Rotterdam",
"regionCode": "ZH",
"regionName": "Zuid-Holland",
"showRegion": false,
"countryCode": "NL",
"countryName": "Nederland",
"showCountry": false
"latLong": {
"lat": 51.886946,
"long": 4.488258
"urls": {
"nl-NL": "/rotterdam/bushalte-zuidplein",
"en-GB": "/en/rotterdam/bushalte-zuidplein"
Posted: Saturday 22 February 2020 16:42
by Jimster
Problably is 'Rotterdam Zuidplein' not the full name of that destination. Set show_via to true to see the full name. Then you can use the full name.
Posted: Saturday 22 February 2020 17:06
by rolandbreedveld
Jimster wrote: Saturday 22 February 2020 16:42
Yes, thanxz that did the trick it was "Rotterdam Zuidplein via Lombardijen"
Posted: Thursday 05 March 2020 11:59
by Omemanti
For a couple of weeks, my public transport as well as the garbage module stopped getting data.
it worked for months without a hassle. (I didn't update anything on domotics, only Linux updates)
anyone else got this issue?
Posted: Saturday 07 March 2020 8:23
by Lokonli
Both modules make use of PHP functionality. Maybe one of the required PHP libraries is not installed correctly.
Posted: Thursday 06 January 2022 18:58
by HansieNL
Publictransport block will not load at the moment. Only the message “Loading” is shown.
Are there more people with this error at this moment?
Posted: Thursday 06 January 2022 20:27
by JeroenG
Hansie,
same here for bus and train since few days.
Posted: Friday 07 January 2022 16:21
by Jimster
HansieNL wrote: Thursday 06 January 2022 18:58
Yes, me too, seems like since the beginning of the year.
I think 9292 took their API down. The URL gives an 404
I hope there is an alternative
Seems like everyone needs to request for access to their API:
https://9292.nl/zakelijk/9292-reisadvies-api
Maybe OvAPI is an alternative:
https://github.com/skywave/KV78Turbo-OVAPI/wiki
Or NDOV
https://ndovloket.nl/
Posted: Monday 21 February 2022 10:42
by Doudy
To Robgeerts,
robgeerts wrote: Wednesday 02 May 2018 9:16
Try:
Is it possible to also provide information in French?
E.g.: spoor = voie
Bergen = Mons
Charleroi-Zuid = Charleroi-Sud
etc...
Thank you
Posted: Monday 21 February 2022 12:57
by Lokonli
Doudy wrote: Monday 21 February 2022 10:42
To Robgeerts,
Try:
E.g.: spoor = voie
Bergen = Mons
etc...
Thank you
The irail.be API supports other languages as well (ne, en, de, fr)
It's not too difficult to add a language block parameter (which could get a default value derived from the Dashticz language setting).
Posted: Sunday 27 February 2022 19:39
by Lokonli
To Robgeerts,
Try:
E.g.: spoor = voie
Bergen = Mons
etc...
Thank you
Implemented in latest beta (3.9.2)
Posted: Monday 28 February 2022 7:59
by Doudy
Thank you. 'Spoor' is not translated!
Posted: Monday 28 February 2022 19:51
by Lokonli
Doudy wrote: Monday 28 February 2022 7:59
Should work now...
(it will follow the Dashticz language setting, not the block parameter)
Posted: Sunday 12 February 2023 13:26
by Beschuitje
If not posted in the right topic, a request to the moderator to show me in the right direction?
Rediscovering Dashticz and setting up a new dashboard for the last couple of days. Using 3.10.1 beta.
Having problems however with the public tranport block. I am wrestling with it for a few days now but cannot get it solved.
Is there a problem perhaps with 'ovapi'?
I am getting "loading' result;
- Lijn 53.png (34.8 KiB) Viewed 3173 times
blocks['ovapi'] = {
tpc: '09542',
title: 'Lijn 53 Diemen Zuid - Centraal Station',
show_lastupdate: true,
provider: 'ovapi',
show_via: true,
icon: 'fas fa-subway',
interval: '120',
newindow: '1',
results: 5,
width: 6
tpc code is for GVB lines 50 and 53 at station 'Diemen Zuid'
- 09542.png (68.77 KiB) Viewed 3173 times
When i load 'treinen' for station Diemen Zuid it works perfectly.
Is this because ovapi is not working correct or am i doing something wrong?
