Rebuilding the Nest plugin
simon_rb
Re: Rebuilding the Nest plugin
Post by simon_rb »
Is this with the latest beta? I'm on latest stable and cannot get to work.
Cheers peps
Upper78
Domoticz version: V4.10228
Post by Upper78 »
Yes, this is with the latest beta.
poudenes
Domoticz version: 3.8993
Post by poudenes »
With latest beta and the NEST OAuth methode i only had 1 error in couple of days.
simon_rb
Post by simon_rb »
Thanks peps, guess I will be doing a back up and upgrading to the latest beta from stable. :D
poudenes
Post by poudenes »
:( And had some errors again!
2018-11-29 05:42:11.873 Error: NestOAuthAPI: Error while performing login: Got empty response body while getting structures. Response code: 28
2018-11-29 05:42:11.873 Error: NestOAuthAPI: Login failed: token did not validate.
2018-11-29 05:42:46.393 Error: Pushover:
2018-11-29 05:43:22.400 Error: NestOAuthAPI: Error while performing login: Got empty response body while getting structures. Response code: 28
2018-11-29 05:43:22.400 Error: NestOAuthAPI: Login failed: token did not validate.
2018-11-29 05:44:32.929 Error: NestOAuthAPI: Error while performing login: Got empty response body while getting structures. Response code: 28
2018-11-29 05:44:32.929 Error: NestOAuthAPI: Login failed: token did not validate.
2018-11-29 05:45:43.457 Error: NestOAuthAPI: Error while performing login: Got empty response body while getting structures. Response code: 28
2018-11-29 05:45:43.457 Error: NestOAuthAPI: Login failed: token did not validate.
2018-11-29 05:45:56.121 Error: Pushover:
2018-11-29 05:46:53.770 Error: Pushover:
2018-11-29 05:46:53.994 Error: NestOAuthAPI: Error while performing login: Got empty response body while getting structures. Response code: 28
2018-11-29 05:46:53.995 Error: NestOAuthAPI: Login failed: token did not validate.
2018-11-29 05:48:04.529 Error: NestOAuthAPI: Error while performing login: Got empty response body while getting structures. Response code: 28
2018-11-29 05:48:04.529 Error: NestOAuthAPI: Login failed: token did not validate.
2018-11-29 05:48:11.033 Error: Error opening url: https://api.buienradar.nl/data/public/1.1/jsonfeed
2018-11-29 05:49:05.294 Error: Pushover:
2018-11-29 05:49:15.062 Error: NestOAuthAPI: Error while performing login: Got empty response body while getting structures. Response code: 28
2018-11-29 05:49:15.063 Error: NestOAuthAPI: Login failed: token did not validate.
2018-11-29 05:50:04.153 Error: Pushover:
2018-11-29 05:50:25.591 Error: NestOAuthAPI: Error while performing login: Got empty response body while getting structures. Response code: 28
2018-11-29 05:50:25.591 Error: NestOAuthAPI: Login failed: token did not validate.
2018-11-29 05:51:36.119 Error: NestOAuthAPI: Error while performing login: Got empty response body while getting structures. Response code: 28
2018-11-29 05:51:36.119 Error: NestOAuthAPI: Login failed: token did not validate.
2018-11-29 05:52:46.650 Error: NestOAuthAPI: Error while performing login: Got empty response body while getting structures. Response code: 28
2018-11-29 05:52:46.650 Error: NestOAuthAPI: Login failed: token did not validate.
2018-11-29 05:53:57.189 Error: NestOAuthAPI: Error while performing login: Got empty response body while getting structures. Response code: 28
2018-11-29 05:53:57.189 Error: NestOAuthAPI: Login failed: token did not validate.
2018-11-29 05:55:07.716 Error: NestOAuthAPI: Error while performing login: Got empty response body while getting structures. Response code: 28
2018-11-29 05:55:07.716 Error: NestOAuthAPI: Login failed: token did not validate.
2018-11-29 05:56:18.246 Error: NestOAuthAPI: Error while performing login: Got empty response body while getting structures. Response code: 28
2018-11-29 05:56:18.246 Error: NestOAuthAPI: Login failed: token did not validate.
2018-11-29 05:57:28.772 Error: NestOAuthAPI: Error while performing login: Got empty response body while getting structures. Response code: 28
2018-11-29 05:57:28.772 Error: NestOAuthAPI: Login failed: token did not validate.
2018-11-29 05:58:39.300 Error: NestOAuthAPI: Error while performing login: Got empty response body while getting structures. Response code: 28
2018-11-29 05:58:39.300 Error: NestOAuthAPI: Login failed: token did not validate.
2018-11-29 05:59:49.834 Error: NestOAuthAPI: Error while performing login: Got empty response body while getting structures. Response code: 28
2018-11-29 05:59:49.834 Error: NestOAuthAPI: Login failed: token did not validate.
2018-11-29 06:00:19.003 Error: Pushover:
2018-11-29 06:01:00.366 Error: NestOAuthAPI: Error while performing login: Got empty response body while getting structures. Response code: 28
2018-11-29 06:01:00.366 Error: NestOAuthAPI: Login failed: token did not validate.
2018-11-29 06:01:57.406 Error: Pushover:
2018-11-29 06:02:10.895 Error: NestOAuthAPI: Error while performing login: Got empty response body while getting structures. Response code: 28
2018-11-29 06:02:10.896 Error: NestOAuthAPI: Login failed: token did not validate.
2018-11-29 06:02:55.517 Error: Pushover:
2018-11-29 06:03:21.430 Error: NestOAuthAPI: Error while performing login: Got empty response body while getting structures. Response code: 28
2018-11-29 06:03:21.430 Error: NestOAuthAPI: Login failed: token did not validate.
2018-11-29 06:03:56.674 Error: Pushover:
2018-11-29 06:04:31.959 Error: NestOAuthAPI: Error while performing login: Got empty response body while getting structures. Response code: 28
2018-11-29 06:04:31.959 Error: NestOAuthAPI: Login failed: token did not validate.
2018-11-29 06:05:42.489 Error: NestOAuthAPI: Error while performing login: Got empty response body while getting structures. Response code: 28
2018-11-29 06:05:42.489 Error: NestOAuthAPI: Login failed: token did not validate.
2018-11-29 06:06:53.023 Error: NestOAuthAPI: Error while performing login: Got empty response body while getting structures. Response code: 28
2018-11-29 06:06:53.023 Error: NestOAuthAPI: Login failed: token did not validate.
2018-11-29 06:08:03.564 Error: NestOAuthAPI: Error while performing login: Got empty response body while getting structures. Response code: 28
2018-11-29 06:08:03.564 Error: NestOAuthAPI: Login failed: token did not validate.
2018-11-29 06:09:14.092 Error: NestOAuthAPI: Error while performing login: Got empty response body while getting structures. Response code: 28
2018-11-29 06:09:14.092 Error: NestOAuthAPI: Login failed: token did not validate.
2018-11-29 06:10:24.620 Error: NestOAuthAPI: Error while performing login: Got empty response body while getting structures. Response code: 28
2018-11-29 06:10:24.620 Error: NestOAuthAPI: Login failed: token did not validate.
2018-11-29 06:11:35.147 Error: NestOAuthAPI: Error while performing login: Got empty response body while getting structures. Response code: 28
2018-11-29 06:11:35.147 Error: NestOAuthAPI: Login failed: token did not validate.
2018-11-29 06:12:10.895 Error: Error opening url: https://api.buienradar.nl/data/public/1.1/jsonfeed
2018-11-29 06:12:45.674 Error: NestOAuthAPI: Error while performing login: Got empty response body while getting structures. Response code: 28
2018-11-29 06:12:45.674 Error: NestOAuthAPI: Login failed: token did not validate.
2018-11-29 06:13:56.208 Error: NestOAuthAPI: Error while performing login: Got empty response body while getting structures. Response code: 28
2018-11-29 06:13:56.208 Error: NestOAuthAPI: Login failed: token did not validate.
2018-11-29 06:15:06.747 Error: NestOAuthAPI: Error while performing login: Got empty response body while getting structures. Response code: 28
2018-11-29 06:15:06.747 Error: NestOAuthAPI: Login failed: token did not validate.
2018-11-29 06:16:17.275 Error: NestOAuthAPI: Error while performing login: Got empty response body while getting structures. Response code: 28
2018-11-29 06:16:17.275 Error: NestOAuthAPI: Login failed: token did not validate.
2018-11-29 06:17:27.813 Error: NestOAuthAPI: Error while performing login: Got empty response body while getting structures. Response code: 28
2018-11-29 06:17:27.813 Error: NestOAuthAPI: Login failed: token did not validate.
2018-11-29 06:18:38.351 Error: NestOAuthAPI: Error while performing login: Got empty response body while getting structures. Response code: 28
2018-11-29 06:18:38.351 Error: NestOAuthAPI: Login failed: token did not validate.
2018-11-29 06:19:01.384 Error: Pushover:
2018-11-29 06:19:48.886 Error: NestOAuthAPI: Error while performing login: Got empty response body while getting structures. Response code: 28
2018-11-29 06:19:48.886 Error: NestOAuthAPI: Login failed: token did not validate.
2018-11-29 06:19:56.377 Error: Pushover:
2018-11-29 06:20:59.416 Error: NestOAuthAPI: Error while performing login: Got empty response body while getting structures. Response code: 28
2018-11-29 06:20:59.416 Error: NestOAuthAPI: Login failed: token did not validate.
2018-11-29 06:22:09.954 Error: NestOAuthAPI: Error while performing login: Got empty response body while getting structures. Response code: 28
2018-11-29 06:22:09.954 Error: NestOAuthAPI: Login failed: token did not validate.
2018-11-29 06:23:09.302 Error: Pushover:
2018-11-29 06:23:20.491 Error: NestOAuthAPI: Error while performing login: Got empty response body while getting structures. Response code: 28
2018-11-29 06:23:20.491 Error: NestOAuthAPI: Login failed: token did not validate.
2018-11-29 06:24:08.744 Error: Pushover:
2018-11-29 06:24:31.029 Error: NestOAuthAPI: Error while performing login: Got empty response body while getting structures. Response code: 28
2018-11-29 06:24:31.029 Error: NestOAuthAPI: Login failed: token did not validate.
2018-11-29 06:25:41.559 Error: NestOAuthAPI: Error while performing login: Got empty response body while getting structures. Response code: 28
2018-11-29 06:25:41.559 Error: NestOAuthAPI: Login failed: token did not validate.
2018-11-29 07:00:04.499 Error: Error opening url: https://gadgets.buienradar.nl/data/raintext?lat=52.37&lon=4.90
2018-11-29 07:03:18.570 Error: NestOAuthAPI: Error getting structures!
simon_rb
Post by simon_rb »
No updated to latest beta yet. Gonna do today if time permits. Any more luck with this in the latest beta? I see above you had some errors :-(
jbackes
Post by jbackes »
i updated to the lastest beta (4.10311) but having issues with the thermostat. domoticz does not seem to find it.
2019-01-02 15:42:35.600 NestOAuthAPI: Trying to access API on https://developer-api.nest.com/structures.json?auth=xxx
2019-01-02 15:42:37.512 NestOAuthAPI: Access token appears to be valid.
2019-01-02 15:42:37.512 NestOAuthAPI: Login success. Token successfully validated.
2019-01-02 15:42:41.453 Error: NestOAuthAPI: request not successful 1 (no thermostat or protect was received), restarting..!
any ideas?
plantjes
Domoticz version: 3.5877
Post by plantjes »
Same problem here...
But i wonder how the worker should now the login passwd of the nest thermostat...
Benno
