moroen wrote: ↑Friday 29 September 2017 12:14
sejonr wrote: ↑Friday 29 September 2017 9:01
Hi All i have one problem i cant find IKEA lamps and i got this fault in Domoticz logg. What can it be?
2017-09-29 08:55:14.106 (IKEA Lampor) {'action': 'setConfig', 'error': 'Connection timed out', 'status': 'Failed'}
It appears that the coap-client can't connect to the ikea-gateway. Have you tried testing the coap-client from the command-line?
$ coap-client -k your_key_goes_here coaps://ip/.well-known/core
Regards,
M
Hi M
When i putting in my ip and Key i got this. I am new in Linux so i need help
I run another Coap-script that i find on the web an could find IKEA lamps. (I removed my IKEA Key)
I using Domoticz V3.8153, Python 3.4, Ikea gateway version 1.1.0015.
coap-client -k "MY Key" coaps://192.168.1.45/.well-known/core
v:1 t:CON c:GET i:190c {} [ ]
<//15001/65541>;ct=0;obs,<//15001/65536>;ct=0;obs,<//15001/65542>;ct=0;obs,<//15001/65544>;ct=0;obs,<//15001/65543>;ct=0;obs,<//15001/65550>;ct=0;obs,<//15001/65546>;ct=0;obs,<//15001/65547>;ct=0;obs,<//15001/65548>;ct=0;obs,<//15001/65545>;ct=0;obs,<//150v:1 t:CON c:GET i:190d {} [ ]
01/65537>;ct=0;obs,<//15001/65540>;ct=0;obs,<//15001/65538>;ct=0;obs,<//15001/65549>;ct=0;obs,<//15001/65539>;ct=0;obs,<//15004/179393>;ct=0;obs,<//15004/142833>;ct=0;obs,<//15004/144989>;ct=0;obs,<//15004/170133>;ct=0;obs,<//15004/170529>;ct=0;obs,<//1500v:1 t:CON c:GET i:190e {} [ ]
5/179393/210242>;ct=0;obs,<//15005/179393/221571>;ct=0;obs,<//15005/179393/213378>;ct=0;obs,<//15005/170529/197393>;ct=0;obs,<//15005/179393/227922>;ct=0;obs,<//15005/142833/216337>;ct=0;obs,<//15005/179393>;ct=0;obs,<//15005/142833>;ct=0;obs,<//15005/1449v:1 t:CON c:GET i:190f {} [ ]
89/204536>;ct=0;obs,<//15005/144989/214163>;ct=0;obs,<//15005/144989/200829>;ct=0;obs,<//15005/142833/207015>;ct=0;obs,<//15005/142833/200247>;ct=0;obs,<//15005/142833/219269>;ct=0;obs,<//15005/142833/198771>;ct=0;obs,<//15005/142833/198755>;ct=0;obs,<//15v:1 t:CON c:GET i:1910 {} [ ]
005/170133/204103>;ct=0;obs,<//15005/170133/207258>;ct=0;obs,<//15005/170133/208775>;ct=0;obs,<//15005/170529/210006>;ct=0;obs,<//15005/170529/227710>;ct=0;obs,<//15005/144989>;ct=0;obs,<//15005/170133>;ct=0;obs,<//15005/170529>;ct=0;obs,<//15005/170529/19v:1 t:CON c:GET i:1911 {} [ ]
9134>;ct=0;obs,<//15005/170529/201532>;ct=0;obs,<//15005/170529/219012>;ct=0;obs,<//15005/170133/198681>;ct=0;obs,<//15005/170133/202935>;ct=0;obs,<//15005/170133/213727>;ct=0;obs,<//15001>;ct=0;obs,<//15001/reset>;ct=0,<//status>;ct=0;obs,<//15005>;ct=0;ov:1 t:CON c:GET i:1912 {} [ ]
bs,<//15004>;ct=0;obs,<//15004/add>;ct=0,<//15004/remove>;ct=0,<//15006>;ct=0;obs,<//15011/15012>;ct=0;obs,<//15011/9034>;ct=0,<//15011/9030>;ct=0,<//15011/9031>;ct=0,<//15011/9063>;ct=0,<//15011/9033>;ct=0,<//15010>;ct=0;obs
