Gearoticz | Galaxy Watch, Gear S3 and S2 Tizen implementation
ehallq
Re: Gearoticz | Gear S3 and S2 Tizen implementation
Post by ehallq »
xavier1306 wrote: Tuesday 16 January 2018 17:11 Thanks for the answer. But that is what i did :(
I'll keep trying
Envoyé de mon MI 5s en utilisant Tapatalk
Hmm, in your browser, try to go to
https://username:password@IP:Port/json.htm?type=devices&filter=light&used=true&order=Name
This is the request that the watch does basically. If you dont get an answer similar to below from this, then something is wrong with your settings:
"result" : [
"IsDimmer" : false,
"Name" : "Bedroom lights",
"SubType" : "Energenie",
"Type" : "Lighting 1",
"idx" : "43"
"IsDimmer" : false,
"Name" : "Hall",
"Type" : "Lighting
It shouldnt be a problem, but I havent tested it butif you have a custom HTTPS port, try changing it to the standardport 443 on your domoticz setup.
ehallq
Post by ehallq »
vidjer wrote: Wednesday 27 December 2017 9:09
vidjer wrote:I just bought the app on Galaxy App. It's very frustrating to have nothing functional. Thank you for doing the best.
Envoyé de mon SM-G935F en utilisant Tapatalk
Hello
I do reset. Reinstall all soft.
Now I can see devices.
Temperature looks like switch. Swith too.... But no effect! I test in http and https. I test on stable and beta server. I have 2 domoticz server.
Help please
Thank's ImageImage
Hi again, the solution I wrote in the first answer to you is still valid. However, I noticed that you for some reason doesnt run the updated app. The menus should be blue, like my pictures above your post. Version should be 1.2.0 if you check the store.
xavier1306
Post by xavier1306 »
I'll keep trying
"result" : [
"IsDimmer" : false,
"idx" : "43"
"IsDimmer" : false,
"Name" : "Hall",
"Type" : "Lighting
For some reason it works now ImageImageImage
Is there a possibility to decrease the font size in gearoticz ?
I have configured my Gear S3 to the smallest font, but gearoticz is still far to Big to properly display the labels of my switches
skybehind
Post by skybehind »
ehallq wrote:
skybehind wrote: Wednesday 27 December 2017 1:23 Got one for Christmas, first app I looked for was Domoticz, lol. Was happy to see it existed. So I added server and got it working, so far so good.
Question, can we add by domain name or is address only? Domain would be beneficial when not at home and in the case of dynamic is.
Sent from my Nexus 6 using Tapatalk
xavier1306 wrote: Tuesday 16 January 2018 17:04 Hi Ehallq
I dis not see the answer regarding the fact of using domain name instead of IP in the server parameters.
For those who dont have a fixed IP, this is a must when outside the house wifi...
I can easily access to domoticz with any brother using https://mydomainname:myport but it does not work with gearoticz.
Any idea?
I use a domain instead of IP for Gearoticz, and it works. You shouldnt enter https://mydomainname:myport in the IP field
Since you use SSL (HTTPS)
You should have the following settings:
IP: mydomainname
Port: myport
User: username
Password: password
HTTPS?: yes
In my case I navigate to https://www.mydomain.com
Then
IP: www.mydomain.com
Port: 443
HTTPS?: yes
I did what was instructed for the domain, port, etc. I am behind a reverse proxy, which may be the reason why this doesn't work. Are there any settings that need to be accounted for in an nginx configuration (i.e. forwarding headers, etc.)?
domoticzba
Post by domoticzba »
I can not find the application from the Samsung Gear application portal ... is there any problem ?. I'm looking for "Gearoticz" ....
denman091
Domoticz version: 3.8153
Post by denman091 »
domoticzba wrote:I can not find the application from the Samsung Gear application portal ... is there any problem ?. I'm looking for "Gearoticz" ....
Have the same problem
domoticzba
denman091 wrote: Tuesday 17 July 2018 23:36
Nobody Knows ?
denman091
Post by denman091 »
Nobody Knows ?
I found it a few days ago. I've searched for gearoticz and first there were no search result. But you have two types of stores, one for dials and one for apps. By default you only search in the dials section. Select apps and you wil find the app
sonar
Post by sonar »
Hi Ehallq,
I have added blinds and a sunscreen to my domoticz.
If I add these as switches I can only switch them on or off.
It would be nice if there was an option like in the web interface -> up - stop - down.
Including the current state.
Can you add support to your gear app?
Ewaldharmsen
Post by Ewaldharmsen »
I am in the Netherlands, just got a Galaxy Watch yesterday. The first thing I wanted to do is install gearoticz. But I can't find it in the App Store. Is it still available?
ehallq
Post by ehallq »
sonar wrote: Friday 07 September 2018 21:46 Hi Ehallq,
Ewaldharmsen wrote: Friday 02 November 2018 9:02 Hi all,
Hi!
Sorry for late response, I am not visiting this forum that much these days, but I will try to get better. Also I will try to make an update for the app with some small fixes. Like making the app updating the status of the switches without closing and opening the app, and add support for locks in a nicer way other than ordinary switches.
About blinds, I might be able to add that later on in that update. I don't have any blinds myself, but I could always try it with a dummy switch :)
About the app, yes it should be available, however it costs 1$, which might make it hidden for some countries. But Netherlands should definitely find it. Be sure that you are under the watch category in the galaxy app store. Also I don't have the Galaxy Watch, so not sure if that watch is supported, and if that could make it hard for you to find it on the app store. But my guess is that the app should be supported by all round samsung watches. I have no plan to buy the Galaxy Watch currently, mostly due to that I find it to expensive, when I currently have the Gear S3 :roll:
EDIT: A friend have the Galaxy Watch and we were able to download it. However, the app doesnt appear in the app store on the watch. You need to use the phone to find the app.
dise
Re: Gearoticz | Galaxy Watch, Gear S3 and S2 Tizen implementation
Post by dise »
Dear Collegues, is there any possibility to use this ap on Xiaomi Amazfit Stratos 2 ?
Chenel
Post by Chenel »
Hello, could you confirm if this app can run on Samsung Smartwatch (SM-R810), it runs Tizen 4.0.
spider2
Post by spider2 »
I bought this app, but it isn't working. After I set it up I see the switches and can add it and use it, but after a while it stopped working so cant switch the light anymore. (do nothing) I tryed in http and https mode too. When setting up again can use but after about 10? minutes no more working. What is the problem, what you think?
jarahlaser
Post by jarahlaser »
Guys honestly i went to store and i was playing 2 hoirs both with te new iwatch and samys one and both are ry good i dont like the shape of the iwatch thats why i went and i both the galaxy one. I verry happy with it the rotating bazel is n...
کلینیک مهنا
Jopie2104
Post by Jopie2104 »
HI, I bought the app and setup according to the manual. I see the switches but the switches don't work. Tried everything from resetting, HTTP, HTTPS, username, password, etc.etc. it just doesn't work My domoticz version is 4.9700 and runs on Raspberry Pi. Please help!
ehallq
Post by ehallq »
Chenel wrote: Wednesday 21 November 2018 12:13 Hello, could you confirm if this app can run on Samsung Smartwatch (SM-R810), it runs Tizen 4.0.
Galaxy Watch users have downloaded it at least. Cannot confirm if it has worked or not, but I haven't gotten any complaints
spider2 wrote: Tuesday 27 November 2018 9:00 Hi,
I have no idea actually. If it works for a while, and then stops, it has to do with something on your watch.
Jopie2104 wrote: Thursday 29 November 2018 20:40 HI, I bought the app and setup according to the manual. I see the switches but the switches don't work. Tried everything from resetting, HTTP, HTTPS, username, password, etc.etc. it just doesn't work My domoticz version is 4.9700 and runs on Raspberry Pi. Please help!
Are you sure that you aren't in the menu where you just add the switches to the startscreen of the app? I really sure that you are in the settings menu, toggling adding/removing the switch to the startscreen of the app.
spider2
Post by spider2 »
Now I can use but after about 10 minutes if I want use again run the program on my watch and must wait about 10-15 seconds to use it again. So some delay on it. :(
tchris
Post by tchris »
I've just bought this application (for a Gear S2) which seemed very promising, but after it worked very good (including for my zwave lock) for a while, it stopped working.
It seems the whole server configuration is blanked randomly ? (don't know what could trigger that).
After putting in the configuration again : it works again (for a little time).
Could you please check what could do this ?
C4rtm4N
Post by C4rtm4N »
ehallq wrote: Wednesday 19 April 2017 9:52 I have just made my first public app.
http://apps.samsung.com/gear/appDetail. ... n6USK8R2Y4
tchris wrote: Tuesday 11 December 2018 13:26 It seems the whole server configuration is blanked randomly
Sadly I'm having the exact same problem - the config doesn't even last beyond the watch screen timing out once. @ehallq please try to have a look at this as the app has real promise!
