Re: Working: Gasmetersensor based on Kaku doorsensor (15 euros)
Posted: Saturday 02 April 2016 12:29
Set local switchName = "Contacteur Gaz" to local switchName = "gaz"?
Open source Home Automation System
https://forum.domoticz.com/
Prerequisites
Domoticz v3.8837 or later (dzVents version 2.4 or later)
User Variable named UV_GasMeter type float, that holds value of the gas meter
Dummy switches that match the variables beneath
CHANGE LOG: See https://github.com/Geo-Ron/dzVents/commits/master/dzUtilityMeters.lua
local scriptVersion = '1.2.29'
local inspiredByUrl = 'https://www.domoticz.com/forum/viewtopic.php?f=14&t=1641'
local inspiredByAuthor = 'pwhooftman'
---- Variables to match dummy switches withing Domoticz
local GasMeterUserVariableName = 'UV_GasMeter' -- User Variable type Float that holds the current meter reading
local GasPulseSensorName = 'Gasmeter_Sensor' -- Actual Gas Pulse Sensor
local GasMeterName = 'Gasmeter' -- Dummy Counter or Gas device
local UpdateType = 'Gas' -- Possible values: Gas or Counter type device
local devicecorrectionfactor = 1000
----- End Variables
logging = {
--level = domoticz.LOG_DEBUG, -- Uncomment to override the dzVents global logging setting
marker = 'dzUtilityMeters v'..scriptVersion
-- timer = {
-- 'every minute'
devices = {
GasPulseSensorName
local CurrentGasMeterValue = domoticz.variables(GasMeterUserVariableName).value
if (item.isDevice) then
-- Run Only if a device has changed on the Domoticz side...
-- Note that the OpenURL call is made AFTER the script has finished
domoticz.log('Device '.. item.name ..' changed.', domoticz.LOG_DEBUG)
--Run when device Changed
--domoticz.openURL(string.format('http://%s/happ_thermstat?action=setSetpoint&Setpoint=%s', ToonIP, device.SetPoint*100))
--item.dump()
if item.name == GasPulseSensorName and item.state == 'Open' then
--local NewToonSetPoint = domoticz.utils.round(item.setPoint, 2)
local NewGasMeterValue = CurrentGasMeterValue + 0.01
domoticz.log('Updating Gasmeter to '.. NewGasMeterValue, domoticz.LOG_DEBUG)
--Update Variable in m3
if UpdateType == 'Gas' then
--Update Device in dm3
domoticz.devices(GasMeterName).updateGas(NewGasMeterValue*devicecorrectionfactor)
--Update Total to m3
domoticz.devices(GasMeterName).updateCounter(NewGasMeterValue)
--Update UV
domoticz.variables(GasMeterUserVariableName).set(NewGasMeterValue)
domoticz.log('Not updating GasMeter. Pulse device state is '..item.state, domoticz.LOG_DEBUG)
Thanks, this is a very helpfull script. More precise than all the devices offered with ESP32. I am using it with a NeoCool Zwave doorsensor.georon wrote: Saturday 26 January 2019 20:52 Great!
I was wondering more than a year now how to get readings of my (belgian) Gas meter that stands outside the house.
I currently rushed off today to get this working.
Broke the glass of the reed contact when trying to get it to read the gas meter. Bummer.
I will also attach a 2xAA battery unit in the future so it will last somewhat longer than a few weeks (I guess that should do the trick...)
So I need to order a new reed contact.
And asked a friend to 3D print one of these for me:
https://www.thingiverse.com/thing:1949041
https://www.thingiverse.com/thing:2749173
My dzVents script approach for this:Code: Select all
--[[ Prerequisites ================================== Domoticz v3.8837 or later (dzVents version 2.4 or later) User Variable named UV_GasMeter type float, that holds value of the gas meter Dummy switches that match the variables beneath CHANGE LOG: See https://github.com/Geo-Ron/dzVents/commits/master/dzUtilityMeters.lua ]]-- local scriptVersion = '1.2.29' local inspiredByUrl = 'https://www.domoticz.com/forum/viewtopic.php?f=14&t=1641' local inspiredByAuthor = 'pwhooftman' ---- Variables to match dummy switches withing Domoticz local GasMeterUserVariableName = 'UV_GasMeter' -- User Variable type Float that holds the current meter reading local GasPulseSensorName = 'Gasmeter_Sensor' -- Actual Gas Pulse Sensor local GasMeterName = 'Gasmeter' -- Dummy Counter or Gas device local UpdateType = 'Gas' -- Possible values: Gas or Counter type device local devicecorrectionfactor = 1000 ----- End Variables return { logging = { --level = domoticz.LOG_DEBUG, -- Uncomment to override the dzVents global logging setting marker = 'dzUtilityMeters v'..scriptVersion }, on = { -- timer = { -- 'every minute' -- }, devices = { GasPulseSensorName } }, execute = function(domoticz, item) local CurrentGasMeterValue = domoticz.variables(GasMeterUserVariableName).value if (item.isDevice) then -- Run Only if a device has changed on the Domoticz side... -- Note that the OpenURL call is made AFTER the script has finished domoticz.log('Device '.. item.name ..' changed.', domoticz.LOG_DEBUG) --Run when device Changed --domoticz.openURL(string.format('http://%s/happ_thermstat?action=setSetpoint&Setpoint=%s', ToonIP, device.SetPoint*100)) --item.dump() if item.name == GasPulseSensorName and item.state == 'Open' then --local NewToonSetPoint = domoticz.utils.round(item.setPoint, 2) local NewGasMeterValue = CurrentGasMeterValue + 0.01 domoticz.log('Updating Gasmeter to '.. NewGasMeterValue, domoticz.LOG_DEBUG) --Update Variable in m3 if UpdateType == 'Gas' then --Update Device in dm3 domoticz.devices(GasMeterName).updateGas(NewGasMeterValue*devicecorrectionfactor) else --Update Total to m3 domoticz.devices(GasMeterName).updateCounter(NewGasMeterValue) end --Update UV domoticz.variables(GasMeterUserVariableName).set(NewGasMeterValue) else domoticz.log('Not updating GasMeter. Pulse device state is '..item.state, domoticz.LOG_DEBUG) end end end }
