Page 4 of 6
Re: NUT Mini BATTERY SERVICE
Posted: Wednesday 23 January 2019 8:44
by emme
ned to check the scanble status....
in nodered console you should get a greed or red dot under the scan node...
if you gets UNAUTHORIZED you need to issue a command in ssh
(I'm looking for it....)
Posted: Wednesday 23 January 2019 9:36
by Artursd
Posted: Wednesday 23 January 2019 10:26
by emme
looks like noble scan is not installed.....
try to reinstall everything
Posted: Wednesday 23 January 2019 11:08
by Artursd
Posted: Wednesday 23 January 2019 12:35
by Artursd
Posted: Wednesday 23 January 2019 12:38
by Artursd
Posted: Wednesday 23 January 2019 12:44
by emme
...what kind of distro you have?!
you're supposed to get jessie or stretch... aren't you?
try with
sudo npm install bluetooth-hci-socket
basically... if it tells you you miss something, try to
sudo npm install <what-is-missing>
and then retry to install noble.
Posted: Wednesday 23 January 2019 13:52
by Artursd
https://yadi.sk/i/tUuN7oX-lKVtZg
put v8 and it worked, but another error came out. Maybe you need to put a friend version? or incorrectly set?
https://yadi.sk/i/8B8AX5sTexD-dg
Posted: Wednesday 23 January 2019 15:47
by Artursd
Posted: Wednesday 23 January 2019 15:51
by Artursd
Posted: Wednesday 23 January 2019 16:06
by Artursd
I don't know much about NodeRed yet. I know how to import a stream, but how to save the stream in NR ???
Posted: Wednesday 23 January 2019 16:26
by emme
as soon as you deploy a flow that is saved and active.
Actually your problem with BLE looks like an issue with the wireless card hardware
try with the adafruit guide....
https://learn.adafruit.com/install-blue ... stallation
Posted: Thursday 24 January 2019 13:41
by Artursd
Posted: Thursday 24 January 2019 15:43
by Artursd
Posted: Thursday 24 January 2019 15:47
by Artursd
Posted: Thursday 24 January 2019 15:59
by Artursd
Posted: Friday 25 January 2019 8:39
by emme
try with
sudo setcap cap_net_raw+eip $(eval readlink -f `which node`)
Posted: Friday 25 January 2019 20:07
by Artursd
Posted: Friday 25 January 2019 20:21
by Artursd
Unable to start BLE scan. Ada pter state: unknown
Posted: Friday 25 January 2019 20:27
by Artursd
