Re: HowTo: monitor Synology NAS
Posted: Sunday 16 March 2014 10:25
Is the power consumption available by SNMP?
Join 16,000+ members discussing home automation with Domoticz. Get help with Zigbee, ZWave, MQTT, scripting, and 150+ integrations
https://forum.domoticz.com/
#!/bin/bash
# Settings
# 1.3.6.1.4.1.6574.1.2.0
NASIP="192.168.5.2" # NAS IP Address
PASSWORD="public" # SNMP Password
DOMO_IP="192.168.5.3" # Domoticz IP Address
DOMO_PORT="8080" # Domoticz Port
#NAS_HD1_TEMP_IDX="37" # NAS HD1 Temp IDX
#NAS_HD2_TEMP_IDX="38" # NAS HD2 Temp IDX
#NAS_HD1_SPACE_IDX="42" # NAS HD1 Temp IDX
#NAS_HD2_SPACE_IDX="43" # NAS HD2 Temp IDX
NAS_IDX="40" # NAS Switch IDX
NAS_SYS_TEMP_IDX="44" #NAS SYSTEM Temp IDX
NAS_HD3_TEMP_IDX="16" # NAS HD3 Temp IDX
NAS_HD4_TEMP_IDX="17" # NAS HD4 Temp IDX
NAS_HD1_SPACE_IDX="45" # NAS HD1 space IDX
NAS_HD2_SPACE_IDX="46" # NAS HD2 space IDX
NAS_HD3_SPACE_IDX="19" # NAS HD3 Temp IDX
NAS_HD4_SPACE_IDX="20" # NAS HD4 Temp IDX
# Check if NAS in online
PINGTIME=`ping -c 1 -q $NASIP | awk -F"/" '{print $5}' | xargs`
echo $PINGTIME
if expr "$PINGTIME" '>' 0
then
curl -s "http://$DOMO_IP:$DOMO_PORT/json.htm?type=devices&rid=$NAS_IDX" | grep "Status" | grep "On" > /dev/null
if [ $? -eq 0 ] ; then
echo "NAS already ON"
# Temperature HD1
HDtemp1=`snmpget -v 2c -c $PASSWORD -O qv $NASIP .1.3.6.1.4.1.6574.2.1.1.6.0`
# Send data
curl -s -i -H "Accept: application/json" "http://$DOMO_IP:$DOMO_PORT/json.htm?type=command¶m=udevice&idx=$NAS_HD1_TEMP_IDX&nvalue=0&svalue=$HDtemp1"
# Temperature HD2
HDtemp2=`snmpget -v 2c -c $PASSWORD -O qv $NASIP .1.3.6.1.4.1.6574.2.1.1.6.1`
# Send data
curl -s -i -H "Accept: application/json" "http://$DOMO_IP:$DOMO_PORT/json.htm?type=command¶m=udevice&idx=$NAS_HD2_TEMP_IDX&nvalue=0&svalue=$HDtemp2"
# Temperature HD3
# HDtemp3=`snmpget -v 2c -c $PASSWORD -O qv $NASIP .1.3.6.1.4.1.6574.2.1.1.6.2`
# Send data
#curl -s -i -H "Accept: application/json" "http://$DOMO_IP:$DOMO_PORT/json.htm?type=command¶m=udevice&idx=$NAS_HD3_TEMP_IDX&nvalue=0&svalue=$HDtemp3"
# Temperature HD4
#HDtemp4=`snmpget -v 2c -c $PASSWORD -O qv $NASIP .1.3.6.1.4.1.6574.2.1.1.6.3`
# Send data
#curl -s -i -H "Accept: application/json" "http://$DOMO_IP:$DOMO_PORT/json.htm?type=command¶m=udevice&idx=$NAS_HD4_TEMP_IDX&nvalue=0&svalue=$HDtemp4"
# Temperature SYSTEM .1.3.6.1.4.1.6574.1.2.0
SYStemp=`snmpget -v 2c -c $PASSWORD -O qv $NASIP .1.3.6.1.4.1.6574.1.2.0`
# Send data
curl -s -i -H "Accept: application/json" "http://$DOMO_IP:$DOMO_PORT/json.htm?type=command¶m=udevice&idx=$NAS_SYS_TEMP_IDX&nvalue=0&svalue=$SYStemp"
# Free space Volym1
HDUnit=`snmpget -v 2c -c $PASSWORD -O qv $NASIP .1.3.6.1.2.1.25.2.3.1.4.36`
HDTotal=`snmpget -v 2c -c $PASSWORD -O qv $NASIP .1.3.6.1.2.1.25.2.3.1.5.36`
HDUsed=`snmpget -v 2c -c $PASSWORD -O qv $NASIP .1.3.6.1.2.1.25.2.3.1.6.36`
HDFree=$((($HDTotal - $HDUsed) * $HDUnit / 1024 / 1024 / 1024))
# Send data
curl -s -i -H "Accept: application/json" "http://$DOMO_IP:$DOMO_PORT/json.htm?type=command¶m=udevice&idx=$NAS_HD1_SPACE_IDX&nvalue=0&svalue=$HDFree"
# Free space Volym 2
HDUnit=`snmpget -v 2c -c $PASSWORD -O qv $NASIP .1.3.6.1.2.1.25.2.3.1.4.37`
HDTotal=`snmpget -v 2c -c $PASSWORD -O qv $NASIP .1.3.6.1.2.1.25.2.3.1.5.37`
HDUsed=`snmpget -v 2c -c $PASSWORD -O qv $NASIP .1.3.6.1.2.1.25.2.3.1.6.37`
# Send data
curl -s -i -H "Accept: application/json" "http://$DOMO_IP:$DOMO_PORT/json.htm?type=command¶m=udevice&idx=$NAS_HD2_SPACE_IDX&nvalue=0&svalue=$HDFree"
# Free space Volym 3
#HDUnit=`snmpget -v 2c -c $PASSWORD -O qv $NASIP .1.3.6.1.2.1.25.2.3.1.4.38`
#HDTotal=`snmpget -v 2c -c $PASSWORD -O qv $NASIP .1.3.6.1.2.1.25.2.3.1.5.38`
#HDUsed=`snmpget -v 2c -c $PASSWORD -O qv $NASIP .1.3.6.1.2.1.25.2.3.1.6.38`
#HDFree=$((($HDTotal - $HDUsed) * $HDUnit / 1024 / 1024 / 1024))
# Send data
#curl -s -i -H "Accept: application/json" "http://$DOMO_IP:$DOMO_PORT/json.htm?type=command¶m=udevice&idx=$NAS_HD3_SPACE_IDX&nvalue=0&svalue=$HDFree"
# Free space volymusb1
#HDUnit=`snmpget -v 2c -c $PASSWORD -O qv $NASIP .1.3.6.1.2.1.25.2.3.1.4.39`
#HDTotal=`snmpget -v 2c -c $PASSWORD -O qv $NASIP .1.3.6.1.2.1.25.2.3.1.5.39`
#HDUsed=`snmpget -v 2c -c $PASSWORD -O qv $NASIP .1.3.6.1.2.1.25.2.3.1.6.39`
# Send data
curl -s -i -H "Accept: application/json" "http://$DOMO_IP:$DOMO_PORT/json.htm?type=command¶m=udevice&idx=$NAS_HD4_SPACE_IDX&nvalue=0&svalue=$HDFree"
echo "NAS ON"
# Send data
curl -s -i -H "Accept: application/json" "http://$DOMO_IP:$DOMO_PORT/json.htm?type=command¶m=switchlight&idx=$NAS_IDX&switchcmd=On"
# Temperature HD1
# Send data
# Temperature HD2
# Send data
# Temperature HD3
#HDtemp3=`snmpget -v 2c -c $PASSWORD -O qv $NASIP .1.3.6.1.4.1.6574.2.1.1.6.2`
# Send data
# Temperature HD4
# Send data
# Send data
# Free space Volym 1
# Send data
# Send data
# Send data
# Send data
fi
curl -s "http://$DOMO_IP:$DOMO_PORT/json.htm?type=devices&rid=$NAS_IDX" | grep "Status" | grep "Off" > /dev/null
echo "NAS already OFF"
exit
echo "NAS OFF"
# Send data
curl -s -i -H "Accept: application/json" "http://$DOMO_IP:$DOMO_PORT/json.htm?type=command¶m=switchlight&idx=$NAS_IDX&switchcmd=Off"
fi
fi
root@archimedes:~# snmpget -c public -v2c -O qv 192.168.0.15 .1.3.6.1.4.1.6574.1.2.0
No Such Object available on this agent at this OID
root@archimedes:~#
root@archimedes:~# snmpget -c public -v 2c -O qv 192.168.0.15 .1.3.6.1.4.1.6574.1.2.0
root@archimedes:~#
pi@raspberrypi ~ $ snmpget -c public -v 2c -O qv 192.168.5.2 .1.3.6.1.4.1.6574.1.2.0
57
I think it needs to beCreate 1 virtual switch and 3 virtual temperature sensors.
AlsoCreate 1 virtual switch and 2 virtual temperature sensors and 1 virtual counter.
NAS_HD_SPACE_IDX="4" # NAS HD1 Temp IDXCode: Select all
NAS_HD_SPACE_IDX="4" # NAS HD Space IDXI have a DS213+ and can confirm the given script works also on a DS213+.bierlaagh wrote:strange...
this is my output on my PI when i contact my nas
could it be that the 213+ does not support system temperature?Code: Select all
pi@raspberrypi ~ $ snmpget -c public -v 2c -O qv 192.168.5.2 .1.3.6.1.4.1.6574.1.2.0 57
and is this oid the only one that does not work?
Any suggestions to get this working with DS412+?stappel wrote:For DSM 5.1beta the disk has moved in snmp iod
It's now .39 instead of ,36
Ok, just updated to 5.1. as well.BigDog wrote:have updated to DSM 5.1and yep the code has changed..
have anybody changed the script in the wiki?![]()
or the changes that must be made?
becose HD1 isnt showing temp and space![]()
36 change to 39 dont work wil look Further @ home..
Greetz BigDog
decrxgarage wrote:My DS213+ is running DSM 5.1. The temperature is still given in Domoticz but the diskspace isn't logged anymore.
snmpget -c public-domoticz -v2c -O qv 192.168.2.12 .1.3.6.1.2.1.25.2.3.1.4.36
snmpget -c public-domoticz -v2c -O qv 192.168.2.12 .1.3.6.1.2.1.25.2.3.1.5.36
snmpget -c public-domoticz -v2c -O qv 192.168.2.12 1.3.6.1.2.1.25.2.3.1.6.36
#Variables
NAS_MEM_IDX="55" # NAS MEM IDX
NAS_CPU_IDX="56" # NAS CPU IDX
# Free Memory Available in %
MemAvailable=`snmpget -v 2c -c $PASSWORD -O qv $NASIP 1.3.6.1.4.1.2021.4.6.0`
MemAvailableinMo=$(($MemAvailable / 1024))
MemUsepercent=$((($MemAvailableinMo * 100) / 1024))
# Send data
curl -s -i -H "Accept: application/json" "http://$DOMO_IP:$DOMO_PORT/json.htm?type=command¶m=udevice&idx=$NAS_MEM_IDX&nvalue=0&svalue=$MemUsepercent"
# CPU utilisation
CpuUser=`snmpget -v 2c -c $PASSWORD -O qv $NASIP 1.3.6.1.4.1.2021.11.9.0`
CpuSystem=`snmpget -v 2c -c $PASSWORD -O qv $NASIP 1.3.6.1.4.1.2021.11.10.0`
CpuUse=$(($CpuUser + $CpuSystem))
# Send data
curl -s -i -H "Accept: application/json" "http://$DOMO_IP:$DOMO_PORT/json.htm?type=command¶m=udevice&idx=$NAS_CPU_IDX&nvalue=0&svalue=$CpuUse"
Works great. Updated my nas.sh.MAidEN wrote:Hi all,
I had add a monitor of CPU and Memory of my Synology with DSM 5.1.
Maybe you can add it to the NAS wiki.MAidEN wrote:Hi all,
I had this code on my nas.sh :
Change Variable with your IDX virtual device (type General and Pourcentage)Code: Select all
#Variables NAS_MEM_IDX="55" # NAS MEM IDX NAS_CPU_IDX="56" # NAS CPU IDX # Free Memory Available in % MemAvailable=`snmpget -v 2c -c $PASSWORD -O qv $NASIP 1.3.6.1.4.1.2021.4.6.0` MemAvailableinMo=$(($MemAvailable / 1024)) MemUsepercent=$((($MemAvailableinMo * 100) / 1024)) # Send data curl -s -i -H "Accept: application/json" "http://$DOMO_IP:$DOMO_PORT/json.htm?type=command¶m=udevice&idx=$NAS_MEM_IDX&nvalue=0&svalue=$MemUsepercent" # CPU utilisation CpuUser=`snmpget -v 2c -c $PASSWORD -O qv $NASIP 1.3.6.1.4.1.2021.11.9.0` CpuSystem=`snmpget -v 2c -c $PASSWORD -O qv $NASIP 1.3.6.1.4.1.2021.11.10.0` CpuUse=$(($CpuUser + $CpuSystem)) # Send data curl -s -i -H "Accept: application/json" "http://$DOMO_IP:$DOMO_PORT/json.htm?type=command¶m=udevice&idx=$NAS_CPU_IDX&nvalue=0&svalue=$CpuUse"
And is ok
