Page 4 of 4
Re: Dromoticz for Android TV (Leanback)
Posted: Thursday 01 September 2016 16:18
by galadril
have you tried the latest beta??
Posted: Thursday 01 September 2016 18:01
by sharif
galadril wrote:have you tried the latest beta??
Just got home and tried it out.
So, much better! I see my devices :-)
few issues:
1. Menu shows duplicates, I have multiple switches, temperaure, utilities sensors, settings etc, basically multiple "copies" of all available menus.
All of them are showing same information (same devices). See attached image
2. Also, there is one Scene defined...which i deleted couple of days ago, so in domoticz its not present. I tested re-installing application didn't help. Tested clearing app cache and app data, didn't help either. So I guess there are som residual "cache" files on the internal storage that aren't cleared/removed/updated
3. Overlays...not sure if these are supposed to work or if I am testing it wrong (was outside application and tried with regular switch on/off, but nothing happened). Just to be clear, overlays seem to work when i in the app switch on/off a device. But when I triggered my other sensors (like the door sensor) nothing popped up on the screen, but maybe thats not what its suposed to do
Posted: Thursday 01 September 2016 18:57
by sharif
Ok, I thought it was self solved the point 1 and 2
Uninstalled the application and then via ES file explorer deleted Domoticz folder which was left on Internal Storage.
Now menu looks as they should, but ONLY during first start of the application.
Tried to enable 1 switch (ON), application self-exited.
Started application again and now there were duplicates of menus again :s
Posted: Thursday 01 September 2016 21:07
by cogliostrio
Tried the new version now. This works a lot better.
A few observations from a quick test.
When I start it, I get a desktop with settings and refresh button. When going into the settings
menu, I enter my server details (no information here whether I go back or apply settings in some fashion).
When I go back out of the menu, my server is not appearing (refresh did not work). I had to
restart the app for my server to show up.
When activating a switch, the selection jumps back to the first switch on the row,
instead of staying on the switch just operated (also no dim for light). Not sure if this is the intended
behavior, but I think I would prefer if the selection stayed on the same switch after activating it.
Camera menu in the works?
I have not experienced any of the issues @sharif has encountered.
Nice work :)
Posted: Thursday 01 September 2016 21:22
by sharif
cogliostrio wrote:Tried the new version now. This works a lot better.
Nice work :)
Whats your android tv platform if I may ask?
Galadril was kind enough to debug the application directly towards my domoticz server and it was mostly successful, as obviously last beta I can at least now start the application :)
Posted: Thursday 01 September 2016 22:33
by cogliostrio
Im using an nvidia shield tv. Nice of you to lend out your system for debuging :)
Posted: Friday 02 September 2016 8:45
by galadril
Good suggestion!
Posted: Friday 02 September 2016 8:46
by galadril
Overlays are not working correct yet.. :(
Posted: Friday 02 September 2016 8:49
by galadril
Weird.. I never experience that issue..
Ill disable the cached files in the next beta.. just to see if it's related to that!
Posted: Friday 02 September 2016 16:56
by galadril
Also add log records:
Posted: Friday 02 September 2016 18:13
by sharif
Excellent! As of todays beta, duplicates in the menu sections are now gone. Restarted application several times just to see if I could provoke the bad behavior again, but I couldn't. So thumbs up!!! :)
Posted: Monday 05 September 2016 7:47
by galadril
sharif wrote:Excellent! As of todays beta, duplicates in the menu sections are now gone. Restarted application several times just to see if I could provoke the bad behavior again, but I couldn't. So thumbs up!!! :)
Thanks!!
Posted: Friday 09 September 2016 17:57
by sharif
Ready for some more fun? :)
I have one "device" that is in Utilities category. It's basically virtual/dummy device which I am feeding with values from a script via Json.
(script reads status of my UPS device and send it to device as an integer / percentage value).
Device works fine in domoticz and also displays fine in your application. However if I click on this device on the TV, application exits to the dashboard.
No error or anything, just exits. All other device offer some kind of feature, on/off or at least to make them Favority.
My virtual device is not of on/off type, but I guess it should be possible to choose it as Favorite at least.
This is not a problem nor annoyance for me personally, as all I need to see from this device is displayed in the main screen overview. Just wanted to let you know
Device definition:
Posted: Monday 12 September 2016 9:35
by galadril
sharif wrote:Ready for some more fun? :)
Ill see if I can reproduce the issue
Posted: Friday 23 September 2016 16:04
by sharif
Updated to the new version yesterday and discovered that on first start of the app it seems to just "exit" even on other devices.
This time just a regular on/off switch. However after another start of the app it was all fine. So as mentioned before, imo, priority on this "issue" can be set to "vewy vewy low" as Elmder Fud would say :)
Posted: Wednesday 14 June 2017 14:22
by mariareese
Such a nice features it has .. thanku for this.. but should make it more light as possible .. :D
Re: Domoticz for Android TV (Leanback)
Posted: Monday 02 October 2017 8:08
by RobinsBright2
Amplify your Full HD viewing experience with this Epson home cinema projector. It lets you project 1080p content up to a size of 300 inches, and it provides brilliant picture quality thanks to its 3100-lumen brightness and 3LCD technology.
Posted: Saturday 10 March 2018 12:38
by rabiyajamal45
Very good features it has. thank you for share this
Posted: Thursday 14 February 2019 21:08
by Minglarn
The the development dead?
Still looking for a good way to push notifications to my android tv.
Skickat från min SM-N950F via Tapatalk
