- corbin
I haven't added temp sensors yet, but will get them in.
Power plugs/sockets is also working, allowing you to control the plug from Domoticz.
- corbin
The hub/gateway has a radio function, which plays Internet radio streams, not FM or WiFi. But it looks to be only Chinese stations available.deennoo wrote:What do you mean by radio ? FM band ? Wifi band ?
MP3 can be uploaded to use as the doorbell sound.
deennoo
Ok ! Fm ! Lol!
Start thinking about switch and cube : a selector switch ! This allow 10 differentes value.
3 positions for switch :
Clik
Double click
Long click
For cube as many as the cube got (ordered one).
Clik
Double click
Long click
http://domo-attitude.fr
Coldman
There are two versions of power plugs, WiFi and ZigBee. How to add them?corbin wrote:I haven't added temp sensors yet, but will get them in.
Thanks for your great work.
Отправлено с моего MI PAD 2 через Tapatalk
pavelbor
- Domoticz version: LastBeta
I can see status of my ZigBee sockets, but can not control (switch on/off) them.corbin wrote:Power plugs/sockets is also working, allowing you to control the plug from Domoticz.
How can i do it?
pavelbor
I added only ZigBee version of smart socket. WiFi is not visible (developer mode must be enabled somehow).Coldman wrote: There are two versions of power plugs, WiFi and ZigBee. How to add them?
"Setup --> Devices --> Not used"
You have to manually switch on/off socket, then it will be visible in devices.
But at first step, you must add Xiaomi Gateway in "Setup --> Hardware"
Coldman
Re: RE: Re: RE: Re: Xiaomi Smart Home Suite (very cheap) compatibilty?
My power plugs are WiFi version, the Domoticz can't find them, I've ordered one ZigBee to test. Xiaomi Gateway added, others devices are working very well.pavelbor wrote:I added only ZigBee version of smart socket. WiFi is not visible (developer mode must be enabled somehow).Coldman wrote: There are two versions of power plugs, WiFi and ZigBee. How to add them?
Thanks for your advice.
arkoko
Good news, but how to use it?corbin wrote:Power plugs/sockets is also working, allowing you to control the plug from Domoticz.
I have added group scene, but on and off buttons didn't do nothing.
- corbin
I haven't published the code that allows control of the smart plugs yet - have a couple of other bits to finish.
You do need the Zigbee version of the plug, the WiFi plug will not work with Domoticz.
pavelbor
Because most of Xiaomi sensors (body, door/window, switch, temp/hum) are wireless, it very important to know, does battery is good yet.
Is it possible to get battery status info from sensors connected to Xiaomi Gateway as well ?
ERRORR2
I added my Gateway to Domoticz hardware, but can not see my ZigBee Socket in devices. Can you help me with it?corbin wrote:You do need the Zigbee version of the plug, the WiFi plug will not work with Domoticz.
I tried to power off/on socket and gateway, but it doesn't help.
Developer mode and LAN access are enabled on Gateway.
- corbin
There is supposed to be battery level reported from the sensors, but I have not seen it as yet from my sensors during testing.pavelbor wrote:Because most of Xiaomi sensors (body, door/window, switch, temp/hum) are wireless, it very important to know, does battery is good yet.
- corbin
Do you have other Xiaomi devices that it is finding? My next update sends a discovery message so that may help.ERRORR2 wrote:
pavelbor
Does it will be included in latest beta? So, i just need to update Domoticz beta?corbin wrote:My next update sends a discovery message so that may help.
- corbin
It isn't in the beta just yet, code is working but I need to test it a bit more.
pavelbor
Good luck thencorbin wrote:It isn't in the beta just yet, code is working but I need to test it a bit more.
ERRORR2
No, I have only gateway, zigbee socket and temperature sensor and nothing is finding in devices. Waiting for update) Thanks for your great work!corbin wrote: Do you have other Xiaomi devices that it is finding? My next update sends a discovery message so that may help.
pavelbor
I have ZigBee sockets too, but they are in list of devices. Probably you have to press on/off button to "activate" them.ERRORR2 wrote: No, I have only gateway, zigbee socket and temperature sensor and nothing is finding in devices.
Then they will be listed in "Not used" devices tab.
ERRORR2
Yes, I've tried that several times, but still no successpavelbor wrote: Probably you have to press on/off button to "activate" them.
- corbin
Can you compile the code at https://github.com/corbinmunce/domoticz and see if it finds your devices?
