Traffic with Google Maps in Domoticz
- Westcott
Re: Traffic with Google Maps in Domoticz
Hi Assenzuid,
Let me be the first to ask -
can you please post your script script_time_googletravel.lua
Thanks.
Thanks.
- jvdz
- Domoticz version: 4.107
Could it be that the variable mins isn't initialized when the this for fails causing the setting of message fail with this error?
Jos
-- mins is only the number part of duration (for evaulation purpose or to return a number in a number device)
for minutes in string.gmatch(duration, "%d+") do mins = tonumber(minutes) end
-- send a Telegram message with status update (replace xxxxxxx with chatid and yyyyyyyyy with bot key)
-- In case you don't want to receive Telegram message, just remove or comment next two lines
message = mins..' mins to go to office at '..time.hour..':'..time.min..' !!!'
assenzuid
@Westcott.
My script:
My script:
--Script to calculate duration and distance between two points using Google Maps
--Author : woody4165 based on Neutrino Traffic with Waze, updated by G3rard
--Date : 9 April 2016
time = os.date("*t")
day = tonumber(os.date("%w"))
--idx of devices for capturing the travel minutes in both direction
idxhomework='135'
idxworkhome='136'
--usual traveltime (mins)
usualtimehomework = 30
usualtimeworkhome = 30
--coordinates home
fromx="52.992753"
fromy="6.564228"
--coordinates work
tox="53.219383"
toy="6.566502"
--Google Api Key
key='XXXXXXXXXXXXX-MY-Google-API-KEY'
--determine workday (Mo-Fri)
if (day > 0 and day < 6) then
werkweek=true; weekend=false
werkweek=false; weekend=true
--determine time (7:00-9:00, 16:00-19:00)
if ((time.hour > 6 and time.hour < 9) or (time.hour == 9 and time.min < 1)) then
ochtend=true; middag=false
elseif ((time.hour > 15 and time.hour < 19) or (time.hour == 19 and time.min < 1)) then
ochtend=false; middag=true
ochtend=false; middag=false
--calculate traveltime
function traveltime(fromx,fromy,tox,toy)
--import JSON.lua library
json = (loadfile "/home/pi/domoticz/scripts/lua/JSON.lua")()
-- get data from Google Maps and decode it in gmaps
local jsondata = assert(io.popen('curl "https://maps.googleapis.com/maps/api/directions/json?origin='..fromx..','..fromy..'&destination='..tox..','..toy..'&departure_time=now&key='..key..'"'))
local jsondevices = jsondata:read('*all')
jsondata:close()
local gmaps = json:decode(jsondevices)
-- Read from the data table, and extract duration and distance in text
distance = gmaps.routes[1].legs[1].distance.text
duration = gmaps.routes[1].legs[1].duration_in_traffic.text
return mins
--weekday (Mo-Fri) and time between 7:00-9:00
if (werkweek and ochtend) then
--every 15 minutes
if((time.min % 30)==0) then
homework=traveltime(fromx,fromy,tox,toy)
message=tostring(homework)..' minuten naar kantoor | '..("%02d:%02d"):format(time.hour, time.min)
print(message)
--send message if traveltime is longer than usual
if(homework > usualtimehomework) then
commandArray['SendNotification']=message
--return a text to the device (eg. 12 mins)
commandArray[1]={['UpdateDevice'] =idxhomework..'|0|' .. tostring(homework)}
--weekday (Mo-Thu) and time between 16:00-19:00
if (werkweek and middag) then
--every 15 minutes
workhome=traveltime(tox,toy,fromx,fromy)
message=tostring(workhome)..' minuten naar huis | '..("%02d:%02d"):format(time.hour, time.min)
print(message)
if(workhome > usualtimeworkhome) then
commandArray[2]={['UpdateDevice'] =idxworkhome..'|0|' .. tostring(workhome)}
- Westcott
So line 54 is -
This suggests that incomplete route info was returned.
Perhaps the script needs to check that the returned "status" is "OK" before proceeding.
Can you try printing the url (line 48) and running it in a browser?
assenzuid
The error message is:
"error_message" : "Browser API keys cannot have referer restrictions when used with this API.",
"routes" : [],
"status" : "REQUEST_DENIED"
Looks like something wrong with my Google API
"routes" : [],
assenzuid
Solved.assenzuid wrote:I get below error.
2016-04-15 19:00:00.749 Error: EventSystem: in /home/pi/domoticz/scripts/lua/script_time_googletravel.lua: /home/pi/domoticz/scripts/lua/script_time_googletravel.lua:54: attempt to index field '?' (a nil value)
2016-04-15 19:00:01.531 Error: EventSystem: in script_time_googletravel: [string "--------------------------------- ..."]:54: attempt to index field '?' (a nil value)
Wrong API, now enabled Google Maps Directions API and the url at line 48 is working.
Now to figure out how to check if it's working correctly.
woody4165
I'm thinking to use a dummy switch with timers to activate the script, because I see it's called every minute.
Probably I'm still new to Domoticz, but how can I let the switch call the script and run repeatedly while the switch is On?
- G3rard
- Target OS: -
- Domoticz version: No
All time scripts are called every minute. That is no problem. Moreover the calculation of the traveltime will only take place every 30 minutes in the time frame that is put in the script. So the "heavy" part of the script will not run every minute.
Not using Domoticz anymore
- G3rard
- Target OS: -
I have made an icon for the custom sensor. The zip file is attached in this post.
woody4165
Well done and very nice. How can I change it?
- G3rard
- Target OS: -
Go to Setup, More Options, Custom Icons and add the zip file. Then you can edit the switch and change the icon.
woody4165
Don't know why, but I can't edit the Custom Switch. All the others I can.
I tried to create also a new one, but it's the same.
I'm on beta 3.5065
I'm on beta 3.5065
- G3rard
- Target OS: -
Make sure you have choosen a Custom Sensor at Create Custom Sensors and not a Text sensor.
woody4165
Absolutely.
PS: Tried with another browser than Chrome and it worked.
In Chrome I tried also to clean cache. Strange it works with all the other Devices.
- G3rard
- Target OS: -
I am on 3.5070 so that could be the difference.
Edit: was a cache issue.
bran2000
ok Thanks i'll try this settings when you'll post a new script with all of this.woody4165 wrote:One more thing I've found regarding the google map api.
The travel time is being calculated on a certain route and it may vary depending on the traffic.
So if you want to know on which route is being calculated the travel time, just get this value:
And you will know on which route has been calculated.Code: Select all
summary = gmaps.routes[1].summary
Now I'm using the Custom Device to get travel time, and to get also logs, and I resumed the Dummy Text device to show the message that I have already built to send it via Telegram, adding just the summary variable.
and modified/addedCode: Select all
message=tostring(homework)..'min to go to office at '..("%02d:%02d"):format(time.hour, time.min)..' route '..tostring(summary)
Nice!Code: Select all
-- modified, added [1] after commandArray commandArray[1]={['UpdateDevice'] =idxhomework..'|0|' .. tostring(homework)} -- addedd commandArray[2]={['UpdateDevice'] =idxroute..'|0|' .. tostring(message)}
Thanks anyway !
woody4165
Here is my latest script:
commandArray={}
idxtraffic='xx'
idxroute='xx'
usualtimehomework = 25
usualtimeworkhome = 25
-- Coordinates starting point
fromx="xx.xxxxx"
fromy="xx.xxxx"
-- Coordinates destination point
tox="xx.xxxx"
toy="xx.xxxx"
--Google Api Key
key='xxxxxxxxxxx'
mattina=true; sera=false
mattina=false; sera=true
mattina=false; sera=false
jsondata:close()
mins=0
return mins
if (week and mattina) then
--every 15 minutes
if((time.min % 15)==0) then
traffic=traveltime(fromx,fromy,tox,toy)
message=tostring(traffic)..'min per andare in ufficio alle '..("%02d:%02d"):format(time.hour, time.min)..' percorso '..tostring(summary)
print(message)
if(traffic > usualtimehomework) then
os.execute('curl --data chat_id=xxxxxxxx --data-urlencode "text='..message..'" "https://api.telegram.org/botxxxxxxxxxxxxx/sendMessage" ')
-- commandArray['SendNotification']=message
commandArray[1]={['UpdateDevice'] =idxtraffic..'|0|' .. tostring(traffic)}
elseif (week and sera) then
--every 15 minutes
traffic=traveltime(tox,toy,fromx,fromy)
message=tostring(traffic)..'min per andare a casa alle '..("%02d:%02d"):format(time.hour, time.min)..' percorso '..tostring(summary)
print(message)
-- if(traffic > usualtimeworkhome) then
-- os.execute('curl --data chat_id=xxxxxx --data-urlencode "text='..message..'" "https://api.telegram.org/botxxxxxxxxx/sendMessage" ')
-- end
-- set device to 0 to prevent device get the last value after working hour
zero=0
commandArray[1]={['UpdateDevice'] =idxtraffic..'|0|' .. tostring(zero)}
commandArray[2]={['UpdateDevice'] =idxroute..'|0|' .. tostring(zero)}
bran2000
Thanks, i'll tell you tomorrow but i'm still with the stable version.
bran2000
Hi, i tried your new script !
it's working but the instructions about the traffic is in italian ?
anyway it can be in French for example ?
EBOOZ
- Domoticz version: V3.8153
There's a bug when the time exceeds one hour.
Google API output:
Sensors in Domoticz:
Log in Domoticz:
I couldn't find a solution yet. If anyone else has an idea? Much appreciated!
Google API output:
Log in Domoticz:
