Page 4 of 6
Re: Step by step guide: Visonic Powermax Pro integration
Posted: Monday 13 March 2017 8:48
by BornToKill
You need to download the last commit from ayasystems.
It patches this segfault issue when opening zone.
PM me your email if you want latest zip.
Posted: Monday 13 March 2017 12:31
by stichx360
Hi, hoping someone can help me. Thanks for putting this together guys, great work.
I am a newbie with PI and coding so a lot of trial and error for me.
I’ve followed the guide but I’m getting stuck on step 3d when I try to run
root@raspberrypi:~/pmaxd$ ./pmaxd -fvvvvvvvv
(null):0 - file I/O error
I’ve read through the post and not sure how borntokill (who also had the issue) actually resolved this issue. He seemed to imply that it was a location issues and pmaxd.conf should be located in /etc/pmaxd/pmaxd.conf however that’s not how the guide reads and it’s not possible to create the pmaxed folder in /etc.? I have run strace and get the same issue as him….
munmap(0x76f32000, 73990) = 0
brk(0) = 0xa11000
brk(0xa32000) = 0xa32000
open("/etc/pmaxd/pmaxd.conf", O_RDONLY) = -1 ENOENT (No such file or directory)
write(2, "(null):0 - file I/O error\n", 26(null):0 - file I/O error
) = 26
exit_group(1) = ?
+++ exited with 1 +++
It may however be the cabling I have chosen. Instead of the guide process I had a powermax dual cable rs232, so this may we be the issue, this is connected to the Pi via a rs232/usb adapter using ch340. I did however run through step 2 and test the connection with the visonic interface driver and it seemed to work (I could not however arm/disarm the panel).
I have since ordered the usb ttl auto converter and will try the pc/ipn method as described in the guide.
Just wanted to see if I was doing something wrong other than the possible cabling issue, since I am NEWBIE.
http://www.cts-direct.net/visonic-power ... Ar3q8P8HAQ
Posted: Monday 13 March 2017 13:33
by BornToKill
Mkdir -p /etc/pmaxd/
Then mv pmaxd.conf file in this folder.
Regards.
Posted: Monday 13 March 2017 20:37
by stichx360
Thanks borntokill, that did the trick. stuck on very next stage with starting main loop....................lol... :oops:
xpl_hub is running
NOTICE: [Mon Mar 13 19:30:53 2017 initLog:0058]Logging initialized
 NOTICE: [Mon Mar 13 19:30:53 2017 initLog:0059]Verbose level: 7
 NOTICE: [Mon Mar 13 19:30:53 2017 main:0417]Program started by User 1000
 INFO: [Mon Mar 13 19:30:53 2017 main:0419]setting SID
 NOTICE: [Mon Mar 13 19:30:53 2017 main:0451]Starting......
 INFO: [Mon Mar 13 19:30:53 2017 initSerialPort:0071]there are 2 device in your config file
 INFO: [Mon Mar 13 19:30:53 2017 initSerialPort:0085]opening /dev/ttyUSB0
I have 8 zone:
 NOTICE: [Mon Mar 13 19:30:53 2017 PmaxInit:0165]zone: 0, name: R.D.C.
 NOTICE: [Mon Mar 13 19:30:53 2017 PmaxInit:0165]zone: 1, name: Etage
 NOTICE: [Mon Mar 13 19:30:53 2017 PmaxInit:0165]zone: 2, name: Salon
 NOTICE: [Mon Mar 13 19:30:53 2017 PmaxInit:0165]zone: 3, name: Salle a manger
 NOTICE: [Mon Mar 13 19:30:53 2017 PmaxInit:0165]zone: 4, name: cuisine
 NOTICE: [Mon Mar 13 19:30:53 2017 PmaxInit:0165]zone: 5, name: porte garage
 NOTICE: [Mon Mar 13 19:30:53 2017 PmaxInit:0165]zone: 6, name: volet garage
 NOTICE: [Mon Mar 13 19:30:53 2017 PmaxInit:0165]zone: 7, name: detecteur incendie
 DEBUG: [Mon Mar 13 19:30:53 2017 sendBuffer:0174]Sending the following buffer to serial TTY
 DEBUG: [Mon Mar 13 19:30:53 2017 logBuffer:0157]BufferSize: 12
 DEBUG: [Mon Mar 13 19:30:53 2017 logBuffer:0158]Buffer: A2 00 00 00 00 00 00 00 00 00 00 43
 DEBUG: [Mon Mar 13 19:30:53 2017 calculChecksum:0167]checksum: 001A
 DEBUG: [Mon Mar 13 19:30:53 2017 sendBuffer:0183]result of serial write:: 15
 DEBUG: [Mon Mar 13 19:30:53 2017 logBuffer:0158]Buffer: AB 06 00 00 00 00 00 00 00 00 00 43
 DEBUG: [Mon Mar 13 19:30:53 2017 calculChecksum:0167]checksum: 000B
 DEBUG: [Mon Mar 13 19:30:53 2017 main:0456]Sarting main loop....
Posted: Monday 13 March 2017 20:41
by BornToKill
Come in PM. You seem to be french ;) me too. Easiest to Help.
Posted: Monday 20 March 2017 10:32
by andersonherry
Informative! Your step by step guiding for Visonic Powermax Pro integration will be helpful. Thanks for sharing.
Posted: Tuesday 18 April 2017 15:03
by jelleeelco
BornToKill wrote:Hi,
Thank you for your reply! I actually got to the same conclusion and completely forgot to check this topic...apologies. All is working now perfectly and have everything nicely integrated into Domoticz. I am now also able to use the sensors to trigger events, something I never dreamed off :roll:
Posted: Saturday 22 July 2017 13:52
by al300kr
Hi, can you control viconic chime on/off in domoticz?
thanks
Posted: Tuesday 01 August 2017 11:54
by jelleeelco
Does anyone else is having issues with pmaxd? It just stopped working at some point. I rebuild a new image to test, but also that one doesn't work. Everything is running as it should, but there doesn't seem to be a connection between the PI and the visonic. When I run it manually it just stops at ' Sarting Main loop...'
I tested even with a different PI, no difference. Tested with the serial connector linked to a windows pc, and from there everything worked.
Can it be that xPLL_Hub has changed?
Posted: Tuesday 22 August 2017 22:45
by BornToKill
Same here since rpi-update has been done....
Investigating..
Posted: Wednesday 23 August 2017 16:35
by jelleeelco
Pfew, so glad you're replying... I think I have done the same thing (rpi-update) and of course with a new build it's the same...
Really can't figure out what's wrong... this is above my knowledge. It looks like the xPL is not communicating, but it's a wild guess.
Posted: Wednesday 23 August 2017 19:58
by BornToKill
OK,
So kernel 4.9.X broke something.
To downgrade 4.4.50 : rpi-update 52241088c1da59a359110d39c1875cda56496764
Reboot !
Enjoy :)
PS : I'm on Jessie (Raspbian)
Posted: Wednesday 23 August 2017 21:28
by jelleeelco
Ok mate... after helping me like that you're my mate, so....forgive me my familiarity😁
So how do I downgrade? I go to ssh, sudo rpi-update and then I enter that whole string of code?
Apologies if this is a stupid question....!!
Posted: Wednesday 23 August 2017 22:16
by BornToKill
PM your email.
Will be easier.
Posted: Wednesday 23 August 2017 22:30
by jelleeelco
Send!
Posted: Thursday 24 August 2017 10:03
by jelleeelco
Ok. Thanks to BornToKill it's sorted. As he said, the kernel update must have broken something. I don't know how I performed the kernel update, as the instruction rpi-update was not available.
So, this is what I did (well, what BortToKill asked me to do....and it worked). SSH into the pi and then:
cat /etc/issue
(outcome should be Raspbian GNU/Linux 8 \n \l which means running Jessie)
uname -a
This gives the kernel currently running, mine was: Linux raspberrypi 4.9.35-v7+ #1014 SMP Fri Jun 30 14:47:4
I didn't have rpi-update installed, so first I installed that:
apt-get update
apt-get install rpi-update
and then downgrade the kernel by being root user:
sudo su
Then reboot and it worked!
All credits to BornToKill, I just followed his instructions via the email.
Posted: Thursday 24 August 2017 12:22
by BornToKill
;) happy to help the community!
Thanks for your reply.
Posted: Thursday 24 August 2017 18:39
by jelleeelco
You are right though that the lua script is breaking pmaxd... I get the same thing now.
What script are you running and how does domoticz then get the status?
Posted: Monday 13 November 2017 2:18
by Holland
Thanks guys
After an uptime of 6 months, I thought, maybe a good idea to update the pi to the latest version. Not....
Kernel 4.9 kills the pmaxd!!
So did; rpi-update 52241088c1da59a359110d39c1875cda56496764
And it's up and running again. Cool
Posted: Monday 13 November 2017 8:49
by BornToKill
Glad to help you !
