Page 4 of 17
Re: Introducing dzVents - Domoticz Lua file based event scripting made e-z!
Posted: Sunday 13 March 2016 16:37
by dannybloe
dakipro wrote:Thanks about the LUX, it works as raw data. How to access temperature, also like raw?
I tried briefly and didn't find it, althought I do not need it at the moment
Here is the latest "night lights" version, might be useful for someone as a start script
active = true, -- set to true to activate this script
39, -- index of the device - 39 book PIR
['timer'] = 'every 2 minutes', -- minutes: xx:00, xx:02, xx:04, ..., xx:58
execute = function(domoticz, motionSensor)
--initialize variables
if (motionSensor==nil) then
-- timer was triggered, get my switch
motionSensor = domoticz.devices[39] --book PIR
luxLightValue = domoticz.devices[40].rawData[1]
tvLED = domoticz.devices[35]
livingRoomLights = domoticz.devices[36]
--settings
dimToPercentages = 20
waitingMinutes = 1
minimumAmbientLight = 50
-- motion triggered
if (tonumber(luxLightValue) < minimumAmbientLight and motionSensor.state == 'On') then
print('motion detected, tun ON the light')
tvLED.dimTo(dimToPercentages)
livingRoomLights.switchOn()
-- time passed since last movement detected
if(tvLED.state == "On" and motionSensor.lastUpdate.minutesAgo>waitingMinutes) then
print('NO motion for long enought, tun OFF the light')
tvLED.switchOff()
livingRoomLights.switchOff()
Now I go to scripts folder with a smile, vs before when I was going there... without a smile
The code looks good to me
It is good practice in Lua to define your variables as locals. That way you never accidentally influence other scripts:
And I'd define your constants like this:
local DIMTO_PERCENTAGES = = 20
local WAITING_MINUTES = 1
local MINIMUM_AMBIENT_LIGHT = 50
if (tonumber(luxLightValue) <MINIMUM_AMBIENT_LIGHT and motionSensor.state == 'On') then
But that's just a matter of taste and code hygene
Posted: Sunday 13 March 2016 16:39
by dannybloe
Derik wrote:Looks great
What is the simpelst way to start...
Reading the README.md perhaps?
Seriously, that explains how you can start. I added a
quick start section.
Posted: Sunday 13 March 2016 17:05
by dannybloe
I adjusted the documentation a bit to make this more clear. Many attributes are available by name on the device object like temperature, humidity etc. It is all dependent on what Domoticz passes along to the scripts (otherdevices_<attribute>). However, like Lux, not everything is passed like this (with a name) and in that case the value can be found in the rawData attribute.
I might try to figure out which attributes are available by name and add it to the docs. (or maybe someone already has that list.. hint hint).
Posted: Sunday 13 March 2016 18:15
by dannybloe
dannybloe wrote:dakipro wrote:Thanks about the LUX, it works as raw data. How to access temperature, also like raw?
I updated the README and now it lists
all attributes that are available. I also updated the API overview. It is sorted now. Easier to find stuff.
Posted: Monday 14 March 2016 0:03
by dannybloe
Just published version
0.9.11:
- Added log method to domoticz object. Using this to log message in the Domoticz log will respect the log level setting in the settings file.
- Updated documentation. Table of contents, sensor attributes, grouping, sorting etc etc.
- Added iterator functions (forEach and filter) to domoticz.devices, domoticz.changedDevices and domoticz.variables to iterate or filter more easily over these collections. Starting to look like javascript
- Added a couple of example scripts.
forEach
domoticz.devices.forEach(function(device)
if (device.batteryLevel < 20) then
-- do something
end)
filter
local deadDevices = domoticz.devices.filter(function(device)
return (device.lastUpdate.minutesAgo > 60)
end)
deadDevices.forEach(function(zombie)
-- do something
end)
Chain them all:
end).forEach(function(zombie)
-- do something with the zombie
end)
Posted: Monday 14 March 2016 15:07
by thorbj
I'm trying to make a simple script that alters a virtual switch based on the lux level. I've copied a little from @dakipro's
script
-- DEVICE INDEX
-- 34 = Lux sensor
-- 130 = Low Lux switch
['timer'] = 'every minute', -- minutes: xx:00, xx:02, xx:04, ..., xx:58
execute = function(domoticz)
luxLightValue = domoticz.devices[34].rawData[1]
print ('Current lux value: ' ..luxLightValue.. '...')
print ('Minimum lux value: 700...')
-- trigger switch based on lux value
if (luxLightValue < 700 and domoticz.devices[130] == 'Off') then
domoticz.devices[130].switchOn()
if (luxLightValue > 700 and domoticz.devices[130] == 'On') then
domoticz.devices[130].switchOff()
But I can't get the switch to change. What am I doing wrong?
Heres the log output:
2016-03-14 14:56:04.111 LUA: Handling events for: "Lux sensor", value: ""
2016-03-14 14:56:04.111 LUA: =====================================================
2016-03-14 14:56:04.111 LUA: >>> Handler: low lux
2016-03-14 14:56:04.111 LUA: >>> Device: "Lux sensor" Index: 34
2016-03-14 14:56:04.111 LUA: .....................................................
2016-03-14 14:56:04.111 LUA: Current lux value: 1000...
2016-03-14 14:56:04.111 LUA: Minimum lux value: 700...
2016-03-14 14:56:04.111 LUA: <<< Done
2016-03-14 14:56:04.111 LUA: -----------------------------------------------------
2016-03-14 14:56:04.112 LUA: Handling events for: "Lux sensor_Utility", value: "1000"
2016-03-14 14:56:04.112 LUA: =====================================================
2016-03-14 14:56:04.112 LUA: >>> Handler: low lux
2016-03-14 14:56:04.112 LUA: >>> Device: "Lux sensor" Index: 34
2016-03-14 14:56:04.112 LUA: .....................................................
2016-03-14 14:56:04.112 LUA: Current lux value: 1000...
2016-03-14 14:56:04.112 LUA: Minimum lux value: 700...
2016-03-14 14:56:04.112 LUA: <<< Done
2016-03-14 14:56:04.112 LUA: -----------------------------------------------------
and
2016-03-14 15:04:00.449 LUA: Handle timer events
2016-03-14 15:04:00.531 LUA: =====================================================
2016-03-14 15:04:00.531 LUA: >>> Handler: low lux
2016-03-14 15:04:00.531 LUA: .....................................................
2016-03-14 15:04:00.531 LUA: Current lux value: 1000...
2016-03-14 15:04:00.531 LUA: Minimum lux value: 700...
2016-03-14 15:04:00.531 LUA: <<< Done
2016-03-14 15:04:00.531 LUA: -----------------------------------------------------
- Thanks!
Posted: Monday 14 March 2016 19:59
by dannybloe
Heh.. took me a while to see what's wrong
You have to check for the state or bState (boolean) of the device:
if (luxLightValue < 700 and domoticz.devices[130].state == 'Off') then
if (luxLightValue > 700 and domoticz.devices[130].state == 'On') then
There is no default attribute for devices so you have to pick whatever you want to inspect. Lemme know if that indeed was the problem.
The value of domoticz.devices[130] is that actual table object.
Oh, just a tip for better code readability. I'd do it like this:
local LUX_SENSOR = 34
lcoal LL_SWITCH = 130
on...
active...
local lux = domoticz.devices[34].rawData[1]
local llSwitch = domoticz.devices[LL_SWITCH)
if (lux < 700 and llSwitch.state == 'Off') then
llSwitch.switchOff()
if (lux > 700 and llSwitch.state == 'On') then
llSwitch.switchOn()
I use to define named constants in my code at the top so I can easily adjust them and then use the names in the code so it reads more like sentences with words instead of numbers. I advise to always declare variables as local instead of putting them in the global namespace. You might get side effects you don't expect and it's good code hygiene
Cheers,
Danny
Posted: Monday 14 March 2016 20:37
by thorbj
Thanks Danny! But I'm still unable to get it to work. I've tried with both .state, and .bState.
-- DEVICE INDEX
-- 34 = Lux sensor
local LL_SWITCH = 130
print ('Current lux value: ' ..lux.. '...')
llSwitch.switchOn()
Posted: Monday 14 March 2016 20:48
by dannybloe
bState is a boolean that evaulates to true or false:
if (device.bState) then
-- bState == true
-- or
if (device.bState == true) then
-- true
--or
if (not device.bState) then
-- false
-- or
if (device.state == 'On') then -- explicitly compare state to the string 'On'
-- it's on
Does that help?
Posted: Monday 14 March 2016 20:57
by thorbj
Unfortunately not, the script still has no effect on the switch.
-- DEVICE INDEX
-- 34 = Lux sensor
LUX_SENSOR,
local lux = domoticz.devices[LUX_SENSOR].rawData[1]
local llSwitch = domoticz.devices[LL_SWITCH]
if (lux < 700 and (not llSwitch.bState)) then
llSwitch.switchOn()
if (lux > 700 and llSwitch.bState) then
Posted: Monday 14 March 2016 21:32
by dannybloe
thorbj wrote:Unfortunately not, now nothing about this script pops up in the log either.
Ah crap, my bad. Somehow the error got swallowed (gotta check that one out):
It should be (note the brace at the end):
and
local lux = tonumber(domoticz.devices[LUX_SENSOR].rawData[1])
Domoticz passes all the raw stuff as strings
I just built in support for a couple of those attributes like lux and now (when I pushed it) you can do this:
local lux = domoticz.devices[LUX_SENSOR].lux
Posted: Monday 14 March 2016 21:45
by thorbj
You are a genius! Now it works perfectly!
Thank you!
v0.9.12
Posted: Monday 14 March 2016 21:56
by dannybloe
Just released
0.9.12:
* Fixed a bug with log level printing. Now errors are printed.
* Added setPoint, heatingMode, lux, WhTotal, WhToday, WActual attributes to devices that support it. No need to access rawData for these anymore.
Due to this log error you didn't see when there were syntax errors in your modules. Now you should see them.
Posted: Monday 14 March 2016 22:35
by dakipro
Oh come on... you are now just showing off, making me jealous.. I wish I started this project and became a rockstar
Just kidding, you are on fire, excellent real life examples! The "check battery levels" is something I was thinking about making in last 5 months, but I didn't want to start with the "old" plan lua scripting, this is now just to add a new device to the array, the way it should be - plain and simple.
Since the script is now growing and getting a lot more functionality, if I may suggest to start with the some sort of automated testing, just so that script doesn't become a victim of its own success, and overgrows itself and maybe becomes slow or memory demanding.
With some sort of automated tests you can also keep the compatibility with future changes. I think it is important to prevent situation when a new functionality could potentially brake something that was previously working, thus avoiding the situation where people would go back to "plan lua" due to instability.
I think script has so much potential and have a huge "community" sharing their scripts, something we can all benefit from.
Posted: Monday 14 March 2016 23:10
by dannybloe
dakipro wrote:Oh come on... you are now just showing off, making me jealous.. I wish I started this project and became a rockstar
Yup I was playing with this idea for almost a year and finally decided to start building it. Glad you like it. (I like it too
Yes, that's my plan as well. I already have tests for the timer stuff. I will start adding tests for the rest. I just takes time. I wanted to have the features in there that i wanted and i think that it's about at that level. I'll fix some bugs if they arise in the coming days and then make a 1.0 I guess. Then I will start added tests.
Posted: Tuesday 15 March 2016 9:13
by thorbj
Now I bumped into another obstacle while trying to convert my scripts.
I have this script that check whether I'm home or not and alters a dummy switch based on this.
I have converted most of the script, but I'm stuck on how to work with user vartiables. Like do I still use
commandArray['Variable:' .. USERVAR] = tostring(no_motion_time)
And can I get values with this string
no_motion_time = tonumber(uservariables[USERVAR])
Here's the full script: (updated)
local MOTION = 54
local CELL_ONE = 45
local CELL_TWO = 46
local HOME_SW = 81
local PANASONIC = 119
local USERVAR = 'TimeHjemmeAv'
MOTION,
CELL_ONE,
CELL_TWO,
execute = function(domoticz, presenceDevice)
if (presenceDevice==nil) then
presenceDevice = domoticz.devices[MOTION,CELL_ONE,CELL_TWO]
local homeSwitch = domoticz.devices[HOME_SW]
local no_motion_time = domoticz.variables['USERVAR'].nValue
local mediaSwitch = domoticz.devices[PANASONIC]
local text_home = '<font color="green">Det er registrert folk hjemme</font>'
local text_away = '<font color="orange">Det er IKKE registrert folk hjemme</font>'
if (presenceDevice.state == 'On') and (homeSwitch.state == 'Off') then
homeSwitch.switchOn()
print(text_home)
if (presenceDevice.state == 'Off') and (mediaSwitch.state == 'Off') then
no_motion_time = no_motion_time + 1
else no_motion_time = 0
domoticz.variables['USERVAR'].set(no_motion_time) -- Don't know if this is right??
if (homeSwitch.status == 'On') and (no_motion_time > 5) then
print(text_away)
homeSwitch.switchOff()
-Thanks
Posted: Tuesday 15 March 2016 9:20
by dannybloe
thorbj wrote:
commandArray['Variable:' .. nomotion_uservar] = tostring(no_motion_minutes)
It is (of course
) easier than you think:
domoticz.variables['nomotion_uservar'].set(no_motion_minutes) -- no need to cast to string
RTFM
And to get a variable:
local myVar = domoticz.variables['someVar'].value -- or nValue for converted to number version of the value
Posted: Tuesday 15 March 2016 9:30
by thorbj
dannybloe wrote:
RTFM
LOL, yeah I tried, but I probably didn't read thoroughly
So, just to be sure that I've understood this right, I can use this to get the uservar?
local no_motion_time = domoticz.variables['USERVAR'].nValue -- nValue instead of tonumber(domoticz.variables['USERVAR']) ??
and this to store the new uservar
Sorry, I'm a slow learner on this sort of things
Posted: Tuesday 15 March 2016 9:31
by dannybloe
Yes, that should work
Posted: Tuesday 15 March 2016 10:21
by thorbj
Does the "domoticz.variables['USERVAR'].set(no_motion_time)" string have to be inside an if statement, or can it be after
end - before a new
if?
I can't see that the uservar is changing.
I put a
in my script. Maybe that broke it?
