Introducing dzVents - Domoticz Lua file based event scripting made e-z!
dannybloe
Re: Introducing dzVents - Domoticz Lua file based event scripting made e-z!
Post by dannybloe »
dakipro wrote:Thanks about the LUX, it works as raw data. How to access temperature, also like raw?
I tried briefly and didn't find it, althought I do not need it at the moment
Here is the latest "night lights" version, might be useful for someone as a start script
	active = true,                  -- set to true to activate this script
		39,                         	-- index of the device - 39 book PIR
		['timer'] = 'every 2 minutes',  -- minutes: xx:00, xx:02, xx:04, ..., xx:58
	execute = function(domoticz, motionSensor)
		--initialize variables
		if (motionSensor==nil) then
		   -- timer was triggered, get my switch
		   motionSensor = domoticz.devices[39] --book PIR
		luxLightValue = domoticz.devices[40].rawData[1]
		tvLED = domoticz.devices[35]
		livingRoomLights = domoticz.devices[36]
		--settings
		dimToPercentages = 20
		waitingMinutes = 1
		minimumAmbientLight = 50
		-- motion triggered
		if (tonumber(luxLightValue) < minimumAmbientLight and motionSensor.state == 'On') then
			print('motion detected, tun ON the light')
			tvLED.dimTo(dimToPercentages)
			livingRoomLights.switchOn()
		-- time passed since last movement detected
		if(tvLED.state == "On" and motionSensor.lastUpdate.minutesAgo>waitingMinutes) then
			print('NO motion for long enought, tun OFF the light')
			tvLED.switchOff()
			livingRoomLights.switchOff()
Now I go to scripts folder with a smile, vs before when I was going there... without a smile :)
The code looks good to me :)
It is good practice in Lua to define your variables as locals. That way you never accidentally influence other scripts:
local myVar = 123
And I'd define your constants like this:
local DIMTO_PERCENTAGES =  = 20
local WAITING_MINUTES = 1
local MINIMUM_AMBIENT_LIGHT = 50
		if (tonumber(luxLightValue) <MINIMUM_AMBIENT_LIGHT and motionSensor.state == 'On') then
But that's just a matter of taste and code hygene ;-).
dannybloe
Post by dannybloe »
Derik wrote:Looks great
What is the simpelst way to start...
Reading the README.md perhaps? :lol:
Seriously, that explains how you can start. I added a quick start section.
dannybloe
Post by dannybloe »
I adjusted the documentation a bit to make this more clear. Many attributes are available by name on the device object like temperature, humidity etc. It is all dependent on what Domoticz passes along to the scripts (otherdevices_<attribute>). However, like Lux, not everything is passed like this (with a name) and in that case the value can be found in the rawData attribute.
I might try to figure out which attributes are available by name and add it to the docs. (or maybe someone already has that list.. hint hint).
dannybloe
Post by dannybloe »
I updated the README and now it lists all attributes that are available. I also updated the API overview. It is sorted now. Easier to find stuff.
dannybloe
Post by dannybloe »
Just published version 0.9.11:
  • Added log method to domoticz object. Using this to log message in the Domoticz log will respect the log level setting in the settings file.
  • Updated documentation. Table of contents, sensor attributes, grouping, sorting etc etc.
  • Added iterator functions (forEach and filter) to domoticz.devices, domoticz.changedDevices and domoticz.variables to iterate or filter more easily over these collections. Starting to look like javascript ;-).
  • Added a couple of example scripts.
forEach
    domoticz.devices.forEach(function(device)
        if (device.batteryLevel < 20) then
            -- do something
    end)
filter
    local deadDevices = domoticz.devices.filter(function(device)
        return (device.lastUpdate.minutesAgo > 60)
    end)
    deadDevices.forEach(function(zombie)
        -- do something
    end)
Chain them all:
    end).forEach(function(zombie)
        -- do something with the zombie
    end)
thorbj
Post by thorbj »
I'm trying to make a simple script that alters a virtual switch based on the lux level. I've copied a little from @dakipro's script
-- DEVICE INDEX
-- 34 = Lux sensor
-- 130 = Low Lux switch
      ['timer'] = 'every minute',  -- minutes: xx:00, xx:02, xx:04, ..., xx:58
   execute = function(domoticz)
      luxLightValue = domoticz.devices[34].rawData[1]
	  print ('Current lux value: ' ..luxLightValue.. '...')
	  print ('Minimum lux value: 700...')
      -- trigger switch based on lux value
      if (luxLightValue < 700 and domoticz.devices[130] == 'Off') then
         domoticz.devices[130].switchOn()
	  if (luxLightValue > 700 and domoticz.devices[130] == 'On') then
         domoticz.devices[130].switchOff()
But I can't get the switch to change. What am I doing wrong?
Heres the log output:
 2016-03-14 14:56:04.111 LUA: Handling events for: "Lux sensor", value: ""
2016-03-14 14:56:04.111 LUA: =====================================================
2016-03-14 14:56:04.111 LUA: >>> Handler: low lux
2016-03-14 14:56:04.111 LUA: >>> Device: "Lux sensor" Index: 34
2016-03-14 14:56:04.111 LUA: .....................................................
2016-03-14 14:56:04.111 LUA: Current lux value: 1000...
2016-03-14 14:56:04.111 LUA: Minimum lux value: 700...
2016-03-14 14:56:04.111 LUA: <<< Done
2016-03-14 14:56:04.111 LUA: -----------------------------------------------------
2016-03-14 14:56:04.112 LUA: Handling events for: "Lux sensor_Utility", value: "1000"
2016-03-14 14:56:04.112 LUA: =====================================================
2016-03-14 14:56:04.112 LUA: >>> Handler: low lux
2016-03-14 14:56:04.112 LUA: >>> Device: "Lux sensor" Index: 34
2016-03-14 14:56:04.112 LUA: .....................................................
2016-03-14 14:56:04.112 LUA: Current lux value: 1000...
2016-03-14 14:56:04.112 LUA: Minimum lux value: 700...
2016-03-14 14:56:04.112 LUA: <<< Done
2016-03-14 14:56:04.112 LUA: -----------------------------------------------------
and
 2016-03-14 15:04:00.449 LUA: Handle timer events
2016-03-14 15:04:00.531 LUA: =====================================================
2016-03-14 15:04:00.531 LUA: >>> Handler: low lux
2016-03-14 15:04:00.531 LUA: .....................................................
2016-03-14 15:04:00.531 LUA: Current lux value: 1000...
2016-03-14 15:04:00.531 LUA: Minimum lux value: 700...
2016-03-14 15:04:00.531 LUA: <<< Done
2016-03-14 15:04:00.531 LUA: -----------------------------------------------------
- Thanks!
2xRaspberry Pi Model 2 w/RaZberry z-wave chip (master/slave)|Fibaro Wall Plug|Fibaro Universal Dimmer 500W|Aeon Labs Multisensor|RFXtrx433E|Nexa WMR-1000|Nexa Pe-3|Nexa Remote|Nexa LGDR3500|Lightify Gateway|Lightify RGBW bulb
dannybloe
Post by dannybloe »
Heh.. took me a while to see what's wrong :)
You have to check for the state or bState (boolean) of the device:
      if (luxLightValue < 700 and domoticz.devices[130].state == 'Off') then
	  if (luxLightValue > 700 and domoticz.devices[130].state == 'On') then
There is no default attribute for devices so you have to pick whatever you want to inspect. Lemme know if that indeed was the problem.
The value of domoticz.devices[130] is that actual table object.
Oh, just a tip for better code readability. I'd do it like this:
local LUX_SENSOR = 34
lcoal LL_SWITCH = 130
	on...
	active...
		local lux = domoticz.devices[34].rawData[1]
		local llSwitch = domoticz.devices[LL_SWITCH)
		if (lux < 700 and llSwitch.state == 'Off') then
			llSwitch.switchOff()
		if (lux > 700 and llSwitch.state == 'On') then
     			llSwitch.switchOn()
I use to define named constants in my code at the top so I can easily adjust them and then use the names in the code so it reads more like sentences with words instead of numbers. I advise to always declare variables as local instead of putting them in the global namespace. You might get side effects you don't expect and it's good code hygiene ;-).
Cheers,
Danny
thorbj
Post by thorbj »
Thanks Danny! But I'm still unable to get it to work. I've tried with both .state, and .bState.
-- DEVICE INDEX
-- 34 = Lux sensor
local LL_SWITCH = 130
	  print ('Current lux value: ' ..lux.. '...')
         llSwitch.switchOn()
dannybloe
Post by dannybloe »
bState is a boolean that evaulates to true or false:
	if (device.bState) then
		-- bState == true
	-- or
	if (device.bState == true) then
		-- true
	--or
	if (not device.bState) then
		-- false
	-- or
	if (device.state == 'On') then -- explicitly compare state to the string 'On'
		-- it's on
Does that help?
thorbj
Post by thorbj »
Unfortunately not, the script still has no effect on the switch.
-- DEVICE INDEX
-- 34 = Lux sensor
      LUX_SENSOR,
      local lux = domoticz.devices[LUX_SENSOR].rawData[1]
	  local llSwitch = domoticz.devices[LL_SWITCH]
      if (lux < 700 and (not llSwitch.bState)) then
         llSwitch.switchOn()
     if (lux > 700 and llSwitch.bState) then
dannybloe
Post by dannybloe »
thorbj wrote:Unfortunately not, now nothing about this script pops up in the log either.
Ah crap, my bad. Somehow the error got swallowed (gotta check that one out):
It should be (note the brace at the end):
and
local lux = tonumber(domoticz.devices[LUX_SENSOR].rawData[1])
Domoticz passes all the raw stuff as strings :(
I just built in support for a couple of those attributes like lux and now (when I pushed it) you can do this:
local lux = domoticz.devices[LUX_SENSOR].lux
thorbj
Post by thorbj »
You are a genius! Now it works perfectly!
Thank you!
dannybloe
v0.9.12
Post by dannybloe »
Just released 0.9.12:
* Fixed a bug with log level printing. Now errors are printed.
* Added setPoint, heatingMode, lux, WhTotal, WhToday, WActual attributes to devices that support it. No need to access rawData for these anymore.
Due to this log error you didn't see when there were syntax errors in your modules. Now you should see them.
dakipro
Domoticz version: 3.5877
Post by dakipro »
Oh come on... you are now just showing off, making me jealous.. I wish I started this project and became a rockstar :)
Just kidding, you are on fire, excellent real life examples! The "check battery levels" is something I was thinking about making in last 5 months, but I didn't want to start with the "old" plan lua scripting, this is now just to add a new device to the array, the way it should be - plain and simple.
Since the script is now growing and getting a lot more functionality, if I may suggest to start with the some sort of automated testing, just so that script doesn't become a victim of its own success, and overgrows itself and maybe becomes slow or memory demanding.
With some sort of automated tests you can also keep the compatibility with future changes. I think it is important to prevent situation when a new functionality could potentially brake something that was previously working, thus avoiding the situation where people would go back to "plan lua" due to instability.
I think script has so much potential and have a huge "community" sharing their scripts, something we can all benefit from.
Raspberry Pi 2 B - MySensors (dimmers, switches, motion, temperature, lux, humidity sensors)
zWave (220v switches)
various 433 via RFLink
dannybloe
Post by dannybloe »
dakipro wrote:Oh come on... you are now just showing off, making me jealous.. I wish I started this project and became a rockstar :)
Yup I was playing with this idea for almost a year and finally decided to start building it. Glad you like it. (I like it too ;-))
Yes, that's my plan as well. I already have tests for the timer stuff. I will start adding tests for the rest. I just takes time. I wanted to have the features in there that i wanted and i think that it's about at that level. I'll fix some bugs if they arise in the coming days and then make a 1.0 I guess. Then I will start added tests.
thorbj
Post by thorbj »
Now I bumped into another obstacle while trying to convert my scripts.
I have this script that check whether I'm home or not and alters a dummy switch based on this.
I have converted most of the script, but I'm stuck on how to work with user vartiables. Like do I still use
commandArray['Variable:' .. USERVAR] = tostring(no_motion_time)
And can I get values with this string
no_motion_time = tonumber(uservariables[USERVAR])
Here's the full script: (updated)
local MOTION = 54
local CELL_ONE = 45
local CELL_TWO = 46
local HOME_SW = 81
local PANASONIC = 119
local USERVAR = 'TimeHjemmeAv'
		MOTION,
		CELL_ONE,
		CELL_TWO,
	execute = function(domoticz, presenceDevice)
		if (presenceDevice==nil) then
			presenceDevice = domoticz.devices[MOTION,CELL_ONE,CELL_TWO]
		local homeSwitch = domoticz.devices[HOME_SW]
		local no_motion_time = domoticz.variables['USERVAR'].nValue
		local mediaSwitch = domoticz.devices[PANASONIC]
		local text_home = '<font color="green">Det er registrert folk hjemme</font>'
		local text_away = '<font color="orange">Det er IKKE registrert folk hjemme</font>'
		if (presenceDevice.state == 'On') and (homeSwitch.state == 'Off') then
			homeSwitch.switchOn()
			print(text_home)
		if (presenceDevice.state == 'Off') and (mediaSwitch.state == 'Off') then
			no_motion_time = no_motion_time + 1
			else no_motion_time = 0
		domoticz.variables['USERVAR'].set(no_motion_time) -- Don't know if this is right??
		if (homeSwitch.status == 'On') and (no_motion_time > 5) then
			print(text_away)
			homeSwitch.switchOff()
-Thanks
dannybloe
Post by dannybloe »
thorbj wrote:
	commandArray['Variable:' .. nomotion_uservar] = tostring(no_motion_minutes)
It is (of course ;-) ) easier than you think:
	domoticz.variables['nomotion_uservar'].set(no_motion_minutes) -- no need to cast to string
RTFM ;-)
And to get a variable:
	local myVar = domoticz.variables['someVar'].value -- or nValue for converted to number version of the value
thorbj
Post by thorbj »
dannybloe wrote:
RTFM ;-)
LOL, yeah I tried, but I probably didn't read thoroughly :oops:
So, just to be sure that I've understood this right, I can use this to get the uservar?
local no_motion_time = domoticz.variables['USERVAR'].nValue -- nValue instead of tonumber(domoticz.variables['USERVAR']) ??
and this to store the new uservar
Sorry, I'm a slow learner on this sort of things :oops:
dannybloe
Post by dannybloe »
Yes, that should work :)
thorbj
Post by thorbj »
Does the "domoticz.variables['USERVAR'].set(no_motion_time)" string have to be inside an if statement, or can it be after end - before a new if?
I can't see that the uservar is changing.
I put a
in my script. Maybe that broke it?
Locked
