Page 30 of 32
Re: MyDomoticz - Testers wanted!
Posted: Wednesday 21 November 2018 12:10
by JanK
ppaciek wrote: Wednesday 21 November 2018 10:51
I have a problem with my.domoticz.com - when I try to log in I get the message "invalid error", even though the password is correct. Only after a few attempts I manage to log in. What's is wrong? This will be corrected?
Hi, I have the same problem from Firefox and Chrome.
By Android Firefox, time to time help longer press "Sign in" button.
Is any solution?
Posted: Wednesday 21 November 2018 12:11
by chimit
You may want to refresh the page (F5) before logging in.
This is a known issue and on our to-fix list.
== Rene
Posted: Wednesday 21 November 2018 12:15
by ppaciek
chimit wrote: Wednesday 21 November 2018 12:11
== Rene
Thanks for your answer. Is good news, so I am waiting impatiently to fix the issue
Regards,
Posted: Sunday 02 December 2018 23:24
by Sway06
hjzwiers wrote: Wednesday 21 November 2018 9:29
I have a strange issue with mydomoticz. After enabling in the setup page all works well, also with my vanity name. So all settings and port forwarding in the router are fine.
The strange thing is that every time I want to connect externally I need to switch off enabling in the settings and enable again. The moment I apply the settings en login turns green and I can login. (I change the settings through a direct connection to my domoticz system to test this)
Once I do this it works till I need to login again ???
Why do I need to re-enable every time I use it. Anyone have a clue?
Hi! I have exactly the same problem you have. Did you manage to resolve it?
Posted: Monday 03 December 2018 8:14
by hjzwiers
No I have not resolved it, have no clue why this is happening.
Posted: Monday 03 December 2018 21:10
by Sway06
hjzwiers wrote: Monday 03 December 2018 8:14
What kind of Internet connection do you have linked to your domoticz installation? I have mobile broadband giving access to the Raspberry Pi where Domoticz is running, internet is given to the Pi via a 4G router. Since my internet provider only allows dynamic IP, I wonder if this has anything to do with MyDomoticz losing the access upon next login? I think I only tried to re-access MyDomoticz the day after when it was not working so maybe the fact that the IP changes makes the connection between MyDomoticz and Domoticz broken. Just a guess but it could be that I have no clue what I am talking about
Posted: Monday 03 December 2018 22:40
by hjzwiers
I log in from a PC at work. I think it has something to do within Domoticz, because if I toggle the enabling (also remotely, but then through a direct link to Domotics through the router) the icon turns green immediately in mydomoticz. So it does not allow connection to the server without toggling. I use the mydomoticz to see a combined graph on a full screen instead of a phone. The app also connects without problems, its only the mydomoticz server that has this connection issue.
Posted: Monday 03 December 2018 22:44
by hjzwiers
After the toggle I do see: Status: Proxymanager started in the logging. Does this give anyone a clue?
Posted: Thursday 06 December 2018 21:28
by Deruut
Hey there,
im just starting with my domoticz and registered with my.domoticz.com to test domoticz with ifttt.com.
is there a way to put the authentication of my.domoticz.com in the url or is the a way to genrate a authentication token to put in the url ?
greeting for a newbie user with great/ wild ideas on what domoticz can do!!!
Mark
Posted: Monday 10 December 2018 18:50
by sorampage
Hello
It's possible to use Android Domoticz App, and connect via MyDomoticz ???
I use a 4G router, i can't forward port ..
Posted: Wednesday 12 December 2018 9:23
by hjzwiers
hjzwiers wrote: Monday 03 December 2018 22:44
No-one has a clue? Why do I always need to toggle enabled before the I can connect remotely (icon turns green the second I turn enabled back on)
MyDomoticz Settings:
MyDomoticz Instance ID: 2CDADF07F3A2E9D
MyDomoticz API Key:
8F82A55FDDD7E0C
MyDomoticz Password:
Enabled
Posted: Wednesday 12 December 2018 13:48
by Tonny
hjzwiers wrote:hjzwiers wrote: Monday 03 December 2018 22:44
MyDomoticz API Key:
8F82A55FDDD7E0C
Enabled
I'm suffering from the same issue, only re-enabling allows me to connect next time. That situation causes that remote access doesn't work at all in fact as in order to re-enable I have to be in my local network from which I have access all the time.
Sent from my SM-G900F using Tapatalk
Posted: Thursday 03 January 2019 22:43
by hofkicks
Is there an option to use a Geofence application like Locative in combination with MyDomoticz?
Posted: Wednesday 13 February 2019 14:49
by Calzor Suzay
Trying to get this working today but having no luck can anyone help?
So went to
https://my.domoticz.com/
Setup account, got email, verified, logged on have API key etc.
Went to my installation (4.9700)
Setup > Settings > MyDomoticz Settings and entered API along with password.
Saved then bounced box for good measures.
Went back to
https://my.domoticz.com/ and "Your current ip address" is wrong it's a 165. address but assume my box needs to talk out to update this.
I notice in log this though...
Error: No servers are configured. Hence mydomoticz will not be started either.
Where/how/what do I need to change to correct this?
Posted: Wednesday 13 February 2019 15:42
by chimit
Thanks for this information.
I see in the server logs that reconnecting doesn't work because MyDomoticz thinks that your domoticz is still connected. Somehow, it takes 15 minutes to figure this out.
I will put this as a bug on the roadmap.
hjzwiers wrote: Wednesday 12 December 2018 9:23
MyDomoticz API Key:
8F82A55FDDD7E0C
Enabled
Posted: Wednesday 13 February 2019 15:43
by chimit
hofkicks wrote: Thursday 03 January 2019 22:43
How would you want this option to work?
Posted: Wednesday 13 February 2019 15:45
by chimit
1.
"Your current IP address" is the one that you are browsing from.
2.
Are you able to access your domoticz locally via http? Possibly the servers don't get started because of a port permission or other problem.
== Rene
Calzor Suzay wrote: Wednesday 13 February 2019 14:49
So went to
Went back to
by chimit
sorampage wrote: Monday 10 December 2018 18:50
Hello
Not yet. It's on the roadmap with unspecified date.
Posted: Wednesday 13 February 2019 15:47
by chimit
Ifttt is a domoticz add-on. It doesn't work with my.domoticz.com yet.
Support for that is on the roadmap with unspecified date.
Deruut wrote: Thursday 06 December 2018 21:28
Hey there,
Mark
Posted: Wednesday 13 February 2019 18:41
by Calzor Suzay
chimit wrote: Wednesday 13 February 2019 15:45
1.
2.
== Rene
1. Ok current IP makes sense.
2. I can access my Domoticz web page when on local LAN yes but only as https as I've set it as this, it may be on a non standard port as well I can't remember off the top of my head. is this the issue?
