Page 30 of 184
Re: New Dashboard Design v2, custom positioning and multiple screens
Posted: Monday 10 April 2017 13:52
by robgeerts
robgeerts wrote:
Blueone wrote:The toon also have a stand-by view which is black and white and is very usefull when it is not in use and still can see the time etc without having a bright screen at the wall.
Not possible at the moment but will add this asap!
Fixed, although, I have to customize the standby CSS a bit more.
Download latest version and add to config.js:
(number = minutes)
If you dont want to use it, use:
var _STANDBY_AFTER_MINUTES = false;
Posted: Monday 10 April 2017 13:56
by pkrabben
robgeerts wrote:At the moment not possible anymore at the moment, I will fix this asap. Together with the possibility to change other icons as well.
Hi Rob.
I must say it's a very nice dashboard and it's not that hard to configure it.
Even for me with less knowledge about HTML and Scripting it worked well
Thanks again for your support
Posted: Monday 10 April 2017 13:59
by robgeerts
Yeah, but if you manually change that icon, it will get reverted back in a next update
by SwordFish
Sorry, its still a light bulb instead off a door.
Posted: Monday 10 April 2017 14:13
by robgeerts
Sorry, little bug
Fixed now
Posted: Monday 10 April 2017 14:16
by Clemen
(number = minutes)
Nice, but would be great if standby could be another screen/page. Maybe a overlay all over the page.
Also if you could exit the standby mode with a click anywhere (remove the overlay).
Posted: Monday 10 April 2017 14:25
by pvm
robgeerts wrote:Almost done with that feature
(this is regarding the more-black layout when inactive)
I was planning to do such a thing by using the camera of the tablet (done that before, when no movement, disable the screen; when movement turn it on for x seconds). Also used as screen burn-in prevention.
This feature is also nice.... but still causes burn-in (and energy usage for the screen to be on during the night, possibly only €3 a year.. not sure about that:) ). Randomizing layout every minute would also prevent burn-in... Maybe something to put on the backlog
edit: whoa in the meanwhile a lot of other posts on this topic... it's booming!
Posted: Monday 10 April 2017 14:27
by Clemen
pvm wrote:robgeerts wrote:Almost done with that feature
I been using Ipad mini mounted on walls, they are on 24/7 with the same layout. Now for 4 years with no notable burn in
Posted: Monday 10 April 2017 14:28
by robgeerts
Do you have that script somewhere? Or isnt that done with JavaScript? Could the screen stil burn-in nowadays?
Posted: Monday 10 April 2017 15:20
by Blueone
(number = minutes)
Very nice and fast! Going to try it this evening
[/quote]
Maybe it would already help to add a timer to disable screen at night or something te prevent burn-in and energy level. Maybe an idea for the future
Posted: Monday 10 April 2017 15:28
by Dynamic
Blueone wrote:Maybe it would already help to add a timer to disable screen at night or something te prevent burn-in and energy level. Maybe an idea for the future
How about a virtual switch that triggers a complete 'black' overlay? The overlay can be hidden when touched or when the virtual switch is turned on.
That would be the best solution for me, since I have an ipad.
Posted: Monday 10 April 2017 15:57
by koowee
It seems that my switches doesn't work anymore after latest update. It sends only ON command to switch, not OFF anymore
from the log
2017-04-10 16:53:56 On
2017-04-10 16:53:47 On
2017-04-10 16:53:45 On
2017-04-10 16:53:43 On
2017-04-10 16:52:06 On
2017-04-10 16:52:03 On
2017-04-10 16:52:02 On
2017-04-10 16:51:59 On
2017-04-10 16:51:56 On
Switch json
"AddjMulti" : 1.0,
"AddjMulti2" : 1.0,
"AddjValue" : 0.0,
"AddjValue2" : 0.0,
"BatteryLevel" : 255,
"CustomImage" : 2,
"Data" : "Off",
"Description" : "",
"Favorite" : 1,
"HardwareID" : 4,
"HardwareName" : "Razberry",
"HardwareTypeVal" : 21,
"HaveDimmer" : true,
"HaveGroupCmd" : true,
"HaveTimeout" : false,
"ID" : "00001401",
"Image" : "TV",
"IsSubDevice" : false,
"LastUpdate" : "2017-04-10 16:47:02",
"Level" : 0,
"LevelInt" : 0,
"MaxDimLevel" : 100,
"Name" : "TV",
"Notifications" : "false",
"PlanID" : "0",
"PlanIDs" : [ 0 ],
"Protected" : false,
"ShowNotifications" : true,
"SignalLevel" : "-",
"Status" : "Off",
"StrParam1" : "",
"StrParam2" : "",
"SubType" : "Switch",
"SwitchType" : "On/Off",
"SwitchTypeVal" : 0,
"Timers" : "false",
"Type" : "Light/Switch",
"TypeImg" : "lightbulb",
"Unit" : 1,
"Used" : 1,
"UsedByCamera" : false,
"XOffset" : "0",
"YOffset" : "0",
"idx" : "277"
I will make also donation to your tablet fund
Posted: Monday 10 April 2017 16:36
by robgeerts
Will fix the switches within 1,5 hour!
Re: RE: Re: New Dashboard Design v2, custom positioning and multiple screens
Posted: Monday 10 April 2017 16:37
by robgeerts
Thank you very much!
Posted: Monday 10 April 2017 16:54
by HansieNL
koowee wrote:It seems that my switches doesn't work anymore after latest update. It sends only ON command to switch, not OFF anymore
As a workaround you can edit main.js in js folder.
Replace <em class="fa fa-toggle-off off icon" /> with <img src="img/bulb_off.png" class="off icon" /> and <em class="fa fa-toggle-on on icon" /> with <img src="img/bulb_on.png" class="on icon" />
Posted: Monday 10 April 2017 17:49
by robgeerts
should be fixed in latest version, can anybody confirm?
Posted: Monday 10 April 2017 17:59
by HansieNL
Here switches working again
Posted: Monday 10 April 2017 18:13
by koowee
I can also confirm that switches work now
Posted: Monday 10 April 2017 19:19
by Bob123bob
robgeerts wrote:
Bob123bob wrote:
But as you can see 167_1 (now) is not working
Fixed
For me it's still not working :
device 167 displays now, today and total
device 167_1 displays now, today and total
device 167_2 displays today and total
device 167_3 displays total
Still no way to display 167_1 (now) only
No luck at this moment for this issue but that's a GOOD work for all the rest
Posted: Monday 10 April 2017 19:35
by EdwinK
SwordFish wrote:Sorry, its still a light bulb instead off a door.
Lightbulbs are the new door(s).
