Page 30 of 32
Re: Domoboard - General Discussions
Posted: Friday 19 May 2017 19:04
by janvier123
squandor wrote:
Hi janvier123 which plug-in did you try to install
-v0.0.8 - Wunderground
And does this happen with every plugin you try to install?
Yes, same issue
And do you have you're server running in debug mode?
Yes and no, i used the service command, the debug mode is broke since the last update
For the first error I must ask wez3 to check so I'll get back on that one
See inline edits
After restarting domoboard, i see this:
May 19 17:21:41 raspberrypi rsyslogd-2007: action 'action 17' suspended, next retry is Fri May 19 17:22:41 2017 [try http://www.rsyslog.com/e/2007 ]
May 19 17:21:49 raspberrypi systemd[1]: Starting Domoboard dashboard...
May 19 17:21:49 raspberrypi systemd[1]: Started Domoboard dashboard.
May 19 17:21:50 raspberrypi python[22471]: Error occured during loading imports for the plugin afvalwijzer: No module named BeautifulSoup. Install it with 'easy_install BeautifulSoup' or 'pip install BeautifulSoup'
May 19 17:21:50 raspberrypi systemd[1]: domoboard.service: main process exited, code=exited, status=1/FAILURE
May 19 17:21:50 raspberrypi systemd[1]: Unit domoboard.service entered failed state.
May 19 17:21:51 raspberrypi systemd[1]: domoboard.service holdoff time over, scheduling restart.
May 19 17:21:51 raspberrypi systemd[1]: Stopping Domoboard dashboard...
May 19 17:21:51 raspberrypi systemd[1]: Starting Domoboard dashboard...
May 19 17:21:51 raspberrypi systemd[1]: Started Domoboard dashboard.
May 19 17:21:52 raspberrypi python[22479]: Error occured during loading imports for the plugin afvalwijzer: No module named BeautifulSoup. Install it with 'easy_install BeautifulSoup' or 'pip install BeautifulSoup'
May 19 17:21:52 raspberrypi systemd[1]: domoboard.service: main process exited, code=exited, status=1/FAILURE
May 19 17:21:52 raspberrypi systemd[1]: Unit domoboard.service entered failed state.
May 19 17:21:52 raspberrypi systemd[1]: domoboard.service holdoff time over, scheduling restart.
May 19 17:21:52 raspberrypi systemd[1]: Stopping Domoboard dashboard...
May 19 17:21:52 raspberrypi systemd[1]: Starting Domoboard dashboard...
May 19 17:21:52 raspberrypi systemd[1]: Started Domoboard dashboard.
May 19 17:21:53 raspberrypi python[22484]: Error occured during loading imports for the plugin afvalwijzer: No module named BeautifulSoup. Install it with 'easy_install BeautifulSoup' or 'pip install BeautifulSoup'
May 19 17:21:53 raspberrypi systemd[1]: domoboard.service: main process exited, code=exited, status=1/FAILURE
May 19 17:21:53 raspberrypi systemd[1]: Unit domoboard.service entered failed state.
May 19 17:21:53 raspberrypi systemd[1]: domoboard.service holdoff time over, scheduling restart.
May 19 17:21:53 raspberrypi systemd[1]: Stopping Domoboard dashboard...
May 19 17:21:53 raspberrypi systemd[1]: Starting Domoboard dashboard...
May 19 17:21:53 raspberrypi systemd[1]: Started Domoboard dashboard.
May 19 17:21:54 raspberrypi python[22489]: Error occured during loading imports for the plugin afvalwijzer: No module named BeautifulSoup. Install it with 'easy_install BeautifulSoup' or 'pip install BeautifulSoup'
May 19 17:21:54 raspberrypi systemd[1]: domoboard.service: main process exited, code=exited, status=1/FAILURE
May 19 17:21:54 raspberrypi systemd[1]: Unit domoboard.service entered failed state.
May 19 17:21:55 raspberrypi systemd[1]: domoboard.service holdoff time over, scheduling restart.
May 19 17:21:55 raspberrypi systemd[1]: Stopping Domoboard dashboard...
May 19 17:21:55 raspberrypi systemd[1]: Starting Domoboard dashboard...
May 19 17:21:55 raspberrypi systemd[1]: Started Domoboard dashboard.
May 19 17:21:56 raspberrypi python[22494]: Error occured during loading imports for the plugin afvalwijzer: No module named BeautifulSoup. Install it with 'easy_install BeautifulSoup' or 'pip install BeautifulSoup'
May 19 17:21:56 raspberrypi systemd[1]: domoboard.service: main process exited, code=exited, status=1/FAILURE
May 19 17:21:56 raspberrypi systemd[1]: Unit domoboard.service entered failed state.
May 19 17:21:56 raspberrypi systemd[1]: domoboard.service holdoff time over, scheduling restart.
May 19 17:21:56 raspberrypi systemd[1]: Stopping Domoboard dashboard...
May 19 17:21:56 raspberrypi systemd[1]: Starting Domoboard dashboard...
May 19 17:21:56 raspberrypi systemd[1]: domoboard.service start request repeated too quickly, refusing to start.
May 19 17:21:56 raspberrypi systemd[1]: Failed to start Domoboard dashboard.
It seems when installing a plugin, there are dependencies that make domoboard crash, if you dont have a log ... good luck
Posted: Friday 19 May 2017 19:15
by squandor
Yes, same issue
See inline edits
Good point indeed I will add it to the issues in github and indeed you are missing BeautifulSoup
Posted: Friday 19 May 2017 19:37
by squandor
janvier123 wrote:Error Found:
------------------------------------------------------------------------------------------------- First one
XML Parsing Error: syntax error
Location: https://domoboard.nl/version.md?_=1495206829537
Line Number 1, Column 1:
1.0.16,1.0.18
XML Parsing Error: syntax error Location: moz-nullprincipal:{d9dde203-ba69-4cea-9122-1f27dcdde6b5} Line Number 1, Column 1:
1.0.16,1.0.18
------------------------------------------------------------------------------------------------- 2nd one
Instellingen => Plugins
When clicking install, it just keeps loading but nothing changes
(Using FF latest version)
Hi Janvier123, Which branch did you use for domoboard? master or develop?
Posted: Friday 19 May 2017 19:39
by janvier123
master,
if you want more info, maybe we can chat somewhere?
Posted: Saturday 20 May 2017 21:48
by janvier123
Error: unreachable code after return statement
File: static/js/domoticz.js
Line: 1901
Fix: Remove "return;"
Posted: Sunday 21 May 2017 11:59
by janvier123
Ive (
kinda) fixed the issue with 2 domoticz_temp_charts
Spending countless hours trying to fix it and ending up with a dirty way to have 2 graphs
The issue is:
when calling "
ShowTempLog" and console log the content div i got this
domoticz-chart-block-1
domoticz-chart-block-2
Great, however when calling "
AddDataToTempChart(data, $.DayChart_Temp.highcharts(), 1);" and console log "
console.log($.DayChart_Temp.highcharts());" i get this:
Object { renderTo:
<div#domoticz-chart-block-2>, userOptions: Object, respRules: Array[0], margin: Array[4], spacing: Array[4], bounds: Object, callback: undefined, isResizing: 0, options: Object, axes: Array[3], 47 more… } domoticz.js:1305:8
Object { renderTo:
<div#domoticz-chart-block-2>, userOptions: Object, respRules: Array[0], margin: Array[4], spacing: Array[4], bounds: Object, callback: undefined, isResizing: 0, options: Object, axes: Array[3], 51 more… }
It seems that something is remembering the last div and refuse to update/reset it, the way to fix it is: creating a new "
period" called it "
day2" and renaming all variables from "
DayChart_Temp" to "
Day2Chart_Temp"
now calling
ShowTempLog("domoticz-chart-block-2",14,"Serre Temp+Hum", "day2");
Havent tested with
[[domoticz_temp_charts]]
Nest Curr Temp/Hum = 28, day2, temp
seems to work
Posted: Sunday 21 May 2017 20:23
by Trigun
Hi Guys, I am new to the update process but can someone tell me what the errors re when I update?
when I do a git pull I get the following errors
Updating e10e465..f071e29
error: Your local changes to the following files would be overwritten by merge:
.gitignore
README.md
css/creative.css
index.html
js/blocks.js
js/functions.js
js/graphs.js
js/main.js
js/news.js
js/ns.js
js/sortable.js
js/switches.js
js/traffic.js
js/trash.js
lang/de_DE.js
lang/en_US.js
lang/fr_FR.js
lang/hu_HU.js
lang/it_IT.js
lang/nl_NL.js
lang/pt_PT.js
lang/sv_SE.js
vendor/ical-parser/ical_parser.js
vendor/moment.js
Please, commit your changes or stash them before you can merge.
error: The following untracked working tree files would be overwritten by merge:
custom_2/CONFIG_DEFAULT.js
img/kliko_black.png
img/kliko_blue.png
img/kliko_brown.png
img/kliko_green.png
img/kliko_grey.png
img/kliko_orange.png
img/kliko_red.png
img/kliko_white.png
img/kliko_yellow.png
index2.html
js/calendar.js
js/publictransport.js
js/thermostat.js
sounds/airplane.aac
sounds/airplane.mp3
sounds/airplane.ogg
sounds/beer_can_opening.aac
sounds/beer_can_opening.mp3
sounds/beer_can_opening.ogg
sounds/bell_ring.aac
sounds/bell_ring.mp3
sounds/bell_ring.ogg
sounds/branch_break.aac
sounds/branch_break.mp3
sounds/branch_break.ogg
sounds/button_click.aac
sounds/button_click.mp3
sounds/button_click.ogg
sounds/button_click_on.aac
sounds/button_click_on.mp3
sounds/button_click_on.ogg
sounds/button_push.aac
sounds/button_push.mp3
sounds/button_push.ogg
sounds/camera_flashing.aac
sounds/camera_flashing.mp3
sounds/camera_flashing.ogg
sounds/computer_error.aac
sounds/computer_error.mp3
sounds/computer_error.ogg
sounds/door_bell.aac
sounds/door_bell.mp3
sounds/door_bell.ogg
sounds/door_bump.aac
sounds/door_bump.mp3
sounds/door_bump.ogg
sounds/doorbell.aac
sounds/doorbell.mp3
sounds/doorbell.ogg
sounds/glass.aac
sounds/glass.mp3
sounds/glass.ogg
sounds/light_bulb_breaking.aac
sounds/light_bulb_breaking.mp3
sounds/light_bulb_breaking.ogg
sounds/ping.aac
sounds/ping.mp3
sounds/ping.ogg
sounds/pop_cork.aac
sounds/pop_cork.mp3
sounds/pop_cork.ogg
sounds/snap.aac
sounds/snap.mp3
sounds/snap.ogg
sounds/sonar.aac
sounds/sonar.mp3
sounds/sonar.ogg
sounds/tap.aac
sounds/tap.mp3
sounds/tap.ogg
sounds/water_droplet.aac
sounds/water_droplet.mp3
sounds/water_droplet.ogg
vendor/ion.sound/ion.sound.js
vendor/ion.sound/ion.sound.min.js
vendor/mobiledetect/mobiledetect.js
Please move or remove them before you can merge.
Aborting
Thnx in advance!
Posted: Sunday 21 May 2017 21:26
by squandor
Trigun wrote:Hi Guys, I am new to the update process but can someone tell me what the errors re when I update?
.gitignore
README.md
css/creative.css
index.html
js/blocks.js
js/functions.js
js/graphs.js
js/main.js
js/news.js
js/ns.js
js/sortable.js
js/switches.js
js/traffic.js
js/trash.js
lang/de_DE.js
lang/en_US.js
lang/fr_FR.js
lang/hu_HU.js
lang/it_IT.js
lang/nl_NL.js
lang/pt_PT.js
lang/sv_SE.js
vendor/moment.js
img/kliko_black.png
img/kliko_blue.png
img/kliko_brown.png
img/kliko_green.png
img/kliko_grey.png
img/kliko_red.png
img/kliko_white.png
index2.html
js/calendar.js
js/thermostat.js
sounds/airplane.aac
sounds/airplane.mp3
sounds/airplane.ogg
sounds/doorbell.aac
sounds/doorbell.mp3
sounds/doorbell.ogg
sounds/glass.aac
sounds/glass.mp3
sounds/glass.ogg
sounds/ping.aac
sounds/ping.mp3
sounds/ping.ogg
sounds/pop_cork.aac
sounds/pop_cork.mp3
sounds/pop_cork.ogg
sounds/snap.aac
sounds/snap.mp3
sounds/snap.ogg
sounds/sonar.aac
sounds/sonar.mp3
sounds/sonar.ogg
sounds/tap.aac
sounds/tap.mp3
sounds/tap.ogg
Aborting
Thnx in advance!
It seems that you changed or added files in the git directory and you can't update the repo when this files aren't stashed or temporary moved.
Posted: Sunday 21 May 2017 22:22
by Trigun
True i thought the easiest way to get the New version up and running is to download the latest from github and put then(overwrite) them all in repository. I guess I shouldn't have done it?
Posted: Monday 22 May 2017 8:49
by squandor
Trigun wrote:True i thought the easiest way to get the New version up and running is to download the latest from github and put then(overwrite) them all in repository. I guess I shouldn't have done it?
Well actually from what i see it are all files that you created yourself so if you get an new clone and add you files to it again it will work again. but i am not good enough with git to have an good answer to fix this with the git cli
Posted: Friday 26 May 2017 12:20
by janvier123
Little update:
Ive decided to dump the Domoboard, yes iam sorry
Its very limited and very little updates
But iam making a PHP version of domoboard based on:
- Original Javascript
- Updated version of Gentelella (new CSS / HTML / JS / ..)
Anyway still coding the project, and MAYBE release it with permission
Posted: Friday 26 May 2017 22:49
by Martijn85
janvier123 wrote:Little update:
Great to hear you are makeing a new version. Still love Domoboard, hope you are you going to share the new version (on github?)
Posted: Friday 26 May 2017 22:51
by squandor
Sorry to hear that. Momentarily we are working on an simpler configuration which you can edit using the web interface but it's taking more time than we thought. Buying and building houses and such stuff but it's in the making!!
Posted: Friday 26 May 2017 22:56
by janvier123
Martijn85 wrote:Great to hear you are makeing a new version. Still love Domoboard, hope you are you going to share the new version (on github?)
Yes, once its in "beta"
squandor wrote:Sorry to hear that. Momentarily we are working on an simpler configuration which you can edit using the web interface but it's taking more time than we thought. Buying and building houses and such stuff but it's in the making!!
Dont be sorry, its my personal experience
Posted: Friday 26 May 2017 23:10
by Snowtiger
Please place a sneak peak in your own thread or whatsoever - this is still the Domoboard Thread - put your own stuff anywhere else please - it is not decent to capture someone else's Thread for your own promotion.
I feel squandor can delete this if you do not do it yourself ......
Posted: Saturday 27 May 2017 12:51
by wez3
Hi Janvier,
Why dont you start developing on the current project on github. We've developed a framework that makes it easy to add functionalities to Domoboard. The development is going slow sometimes because we are busy people
. But we decided to share the source code so people could use it, but also so developers could join to make the software even better.
wez3
Posted: Saturday 27 May 2017 14:24
by janvier123
the thing is, i dont know anything about Python or Flask, but i do know PHP
Thats why ive decided to make a PHP version
Posted: Tuesday 13 June 2017 7:57
by janvier123
sander815 wrote:why am i getting these errors?
pi@raspberrypi:~/domoboard $ /home/pi/domoboard/bin/python /home/pi/domoboard/server.py -d -c /home/pi/domoboard/example2.conf -d
Error when starting the Flask server: [Errno 13] Permission denied
and if i run it like this
pi@raspberrypi:~/domoboard $ python /home/pi/domoboard/server.py -d -c /home/pi/domoboard/test.conf
File "/home/pi/domoboard/server.py", line 4, in <module>
from flaskext.auth import Auth, AuthUser, login_required, logout
ImportError: No module named auth
Its happened to me also when they updated it
- Open 2 terminals (connecting to the same IP / Raspberry ...)
- in the first window type:
sudo tail -f /var/log/syslog => this will output any debug info
- in the second window type:
sudo systemctl start domoboard.service
Posted: Wednesday 14 June 2017 9:14
by squandor
could you try the following command:
sudo /home/pi/domoboard/bin/pip install flask-auth --upgrade
Posted: Wednesday 14 June 2017 17:33
by janvier123
Still doesnt work:
pi@raspberrypi:~/domoboard $ python server.py -c config.conf -d
File "server.py", line 3, in <module>
from flask import Flask, g, redirect, url_for, render_template, abort, request, session
ImportError: No module named flask
And then this:
pi@raspberrypi:~/domoboard $ sudo /home/pi/domoboard/bin/pip install flask --upgrade
Requirement already up-to-date: flask in ./lib/python2.7/site-packages
Cleaning up...
Same error as above
