Pass2PHP
ropske
Domoticz version: V3_8394
Re: Pass2PHP
Post by ropske »
Probably a stupid question, but how can i return the floating number?
this is what is in the JSON: [Data] => 36722.658 kWh
What i receive is: 36722658
<?php
$data=json_decode(file_get_contents('http://127.0.0.1:8080/json.htm?type=devices&rid=304'),true);
$elek = filter_var($data['result']['0']['Data'], FILTER_SANITIZE_NUMBER_FLOAT);
echo $elek ;
Egregius
Domoticz version: v2024.7
Re: Pass2PHP
Post by Egregius »
Is it always 3 digits after the comma?
Then do a FILTER_SANITIZE_NUMBER_INT and divide it by 1000.
$elek = filter_var($data['result']['0']['Data'], FILTER_SANITIZE_NUMBER_INT) / 1000;
Or you could just replace the kWh:
$elek = str_replace(' kWh','',$data['result']['0']['Data']);
ropske
Re: Pass2PHP
Post by ropske »
What i did now is:
<?php
$stijn=$data['result']['0']['Data'];
$stijn=str_replace("kWh","",$stijn);
echo $stijn;
now i got the floating point data and i removed the 'kWh'
I don't know if it is the correct way, but it works :p
ropske
Re: Pass2PHP
Post by ropske »
Egregius wrote: Sunday 11 February 2018 20:52 Is it always 3 digits after the comma?
Hi, i just see your answer,
its not allways 3 digits after comma.
but its max 3 digits
sincze
Domoticz version: 2024.4
Re: Pass2PHP
Post by sincze »
Inspired on the 'Afvalkalender Post'. http://www.domoticz.com/forum/viewtopic.php?t=17963 I thought maybe this could be a nice pass2php addition :lol:
$dom = new DOMDocument();
libxml_use_internal_errors(true);
$dom->loadHTMLFile('http://www.mijnafvalwijzer.nl/nl/'.$zipcode.'/'.$housenumber.'/');
$data = $dom->getElementById("banner");
$result=$data->nodeValue;
This gives me:
Eerstvolgende ophaalmoment: dinsdag 13 februari Plasticverpakkingen en drankenkartons
Now I need to figure out how to sanitize this in PHP. Just had some 'rough' bash weeks with reading the data from my router so I am a bit PHP rusty.
Any ideas :lol:
Pass2php
USB: RFXCom, ZWave, Sonoff 3
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Solar: Omnik, PVOutput
Sensors: You name it I got 1.
Egregius
Re: Pass2PHP
Post by Egregius »
Depends on what you want to do with it...
sincze
Re: Pass2PHP
Post by sincze »
Easiest thing would be to store date and trash type in text sensor. If date is updated I send the house a telegram notice so they can take out the appropriate thrash :)
Of course I could just strip 'Eerstvolgende ophaalmoment:' and store the result in text sensor. :)
However I was thinking.. What can I do with the date :) or separate date from trash type :)
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Egregius
Re: Pass2PHP
Post by Egregius »
This should get you going:
$result="Eerstvolgende ophaalmoment: dinsdag 13 februari Plasticverpakkingen en drankenkartons";
$result=str_replace('Eerstvolgende ophaalmoment: ','',$result);
$result=explode(' ',$result);
$langedatum=$result[1].' '.$result[2].' '.strftime('%Y',time()).' 8:00:00';
$datum=strtotime($langedatum);
if($datum>apcu_fetch('previousgarbagedate')){
	$garbages=array_slice($result,3);
	$garbage='';
	foreach($garbages as $i)$garbage.=$i.' ';
	telegram('Tijd om '.$garbage.'buiten te zetten');
	apcu_store('previousgarbagedate',$datum);
sincze
Re: Pass2PHP
Post by sincze »
'For Some reason the ' ' dit not deal with the space in the $result correctly.
Had to modify it a bit.
function afvalkalender()
    $dom->loadHTMLFile('http://www.mijnafvalwijzer.nl/nl/'.zipcode.'/'.housenumber.'/');
    $result=preg_split('/\s+/', $result);
    $datum =mktime(0,0,0,nlDate($result[5]),$result[4],strftime('%Y',time()));
    if($datum>cget('previousgarbagedate'))
        $garbages=array_slice($result,6);
        $garbage='';
        telegramnotification('Tijd om '.$garbage.' buiten te zetten, zal op '.date("j F Y",$datum).' worden opgehaald',false,'Bernini');
        $text=date("j F Y",$datum).' '.$garbage;
        cset('previousgarbagedate',$datum);
function nlDate($datum)
  $datum = str_replace("januari",   1,  $datum);
  $datum = str_replace("februari",  2,  $datum);
  $datum = str_replace("maart",   3,  $datum);
  $datum = str_replace("april",   4,  $datum);
  $datum = str_replace("mei",     5,  $datum);
  $datum = str_replace("juni",    6,  $datum);
  $datum = str_replace("juli",    7,  $datum);
  $datum = str_replace("augustus",  8,  $datum);
  $datum = str_replace("september", 9,  $datum);
  $datum = str_replace("oktober",   10, $datum);
  $datum = str_replace("november",  11, $datum);
  $datum = str_replace("december",  12, $datum);
  return $datum;
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
sincze
Re: Pass2PHP
Post by sincze »
I was thinking of turning my smarttv to a specific sound level if it recognizes a specic series.
Retrieve svalue
Retrieve svalue
However the value 'Video' is stored in '$status' so that enables me to DIM the lights properly. :D
if($status=='Video') { lg('Kodi Keuken playing Video'); sl('Lamp (Keukentafel) (RF)',25); rgb('Lamp LED Keukenkast','white',10,001,'Colour White'); }
else { lg('Kodi Keuken not playing Video'); sl('Lamp (Keukentafel) (RF)',35); rgb('Lamp LED Keukenkast','white',25,001,'Colour White'); }
However the name of the series is stored in 'svalue'. Any chance we can retrieve that in an easy way? :lol:
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Egregius
Re: Pass2PHP
Post by Egregius »
Unfortunately svalue isn't available in the lua table.
A workaround could be to add it in one of the cron files with the /json.htm?type=devices&rid=IDX json call.
ropske
Re: Pass2PHP
Post by ropske »
Nice work :p
Egregius, you also have a garbage tool in your php for Belgium?
I found this data for my street:
http://www.ophaalkalender.be/api/rides? ... pcode=8800
only the start and title should be extracted from the result, but will try to check this is the weekend :)
then you can fill up an array with the upcoming garbage dates
Egregius
Re: Pass2PHP
Post by Egregius »
Didn't know that one, but since it's a nice json reply it's pretty easy to handle.
I made this of it, in cron28800:
$data=json_decode(file_get_contents('http://www.ophaalkalender.be/api/rides?id=77009&housenumber=0&zipcode=8800'),true);
$first=true;
foreach($data as $i){
	if(strtotime($i['start'])<time+86400){
		if($first){
			$afval=$i['title'];
			$first=false;
		}else $afval.=' + '.$i['title'];
if(isset($afval))apcu_store('afval',$afval);
else apcu_store('afval','');
And then on my floorplan:
$afval=apcu_fetch('afval');
	if(!empty($afval))echo '<div class="fix z0" style="top:370px;left:160px">'.$afval.' buiten zetten</div>';
So, when the collection date is tomorrow it'll be printed on my floorplan what I need to put outside.
Didn't look for that in the past because I always import the ICS into my calendar of http://mirom.be/ophaalkalender
sincze
Re: Pass2PHP
Post by sincze »
Just wondering.
Any idea how many people are using Pass2PHP ?
- Egregius
- Robske
- Me
just curious. :D
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Egregius
Re: Pass2PHP
Post by Egregius »
Don't know, there are some users from Tweakers.net also, but how many, no clue at all.
ropske
Re: Pass2PHP
Post by ropske »
ah, you download it directly to your calendar from Mirom?
That calendar, is it the google calendar ?
Is it also on your github?
Thanks mate
Egregius
Re: Pass2PHP
Post by Egregius »
Yes, you can download a ics calendar file from the mirom site and import that in your calendar program or Google Calendar
ropske
Re: Pass2PHP
Post by ropske »
You also have an example of this how you do this? :oops: ;)
Egregius
Re: Pass2PHP
Post by Egregius »
ropske
Re: Pass2PHP
Post by ropske »
I found somewhere your php to handle the google calendar
but i don't find it anymore :oops:
