Nefit Easy™
- BartdaMan
Re: Nefit Easy™
I cannot remember exactly. It was not so difficult. I remember I had to log out as pi user and log in as root. And then log in as pi user again and change to the /home/pi folder for installation of the easy server.
jannl
- Domoticz version: 2025.5.x
Re: Nefit Easy™
Whenever I have problems connecting to the Nefit with the easy app on android, I reboot domoticz and everything works again. May be I need to create a easy server restart on the pi.
- BartdaMan
Re: Nefit Easy™
That's funny, because when I have Domoticz/Raspberry connection problems (maybe 1x per week) I disconnect the thermostat from the wall connector and refit it. It then reboots which also solves the Domoticz connection problem.jannl wrote:Whenever I have problems connecting to the Nefit with the easy app on android, I reboot domoticz and everything works again. May be I need to create a easy server restart on the pi.
jannl
Re: Nefit Easy™
I know, but rebooting domoticz is way easier. I created a switch for that long time ago
- mvveelen
Re: Nefit Easy™
I'm lost.... can someone point me to the solution?
I've been using the easy-server for a long while on my Synology and everything was fine. I just rebooted the Synology and there is no data transferred to Domoticz.
The server is running and starts when the Synology starts:
The hardware in Domoticz has exactly the same settings (IP and port)
Killing the process and restarting the easy-server doesn't help:
What can I do to get the data transferred to the devices again? Last update is a few hours ago. I even tried to replace the current DB wit a DB from yesterday: no result.
The log shows:
Edit:
I feel stupid.....
The Nefit was OFF, so no data was transferred. When I discovered this and turned the Nefit ON, all data came back..... Stupid, stupid, stupid. But hey, it works again
root@DiskStation:~# ps wax | grep easy
16699 pts/13 Rl 0:03 node /usr/local/bin/easy-server --serial=xxx --password=xxx --access-key=xxx --host=127.0.0.1 --port=3000
16713 pts/13 S+ 0:00 grep --color=auto easy
nohup easy-server --serial=xxx --password=xxx --access-key=xxx --host=127.0.0.1 --port=3000 &>/dev/null &
The log shows:
2016-10-31 22:06:24.601 Error: NefitEasy: Invalid data received (main)!
Edit:
I feel stupid.....
- mvveelen
Re: Nefit Easy™
OK,
I've been in contact with Robert Klep and he has updated his nefit-easy-cli. Now I can switch the hot water ON or OFF, regardless of the mode it is in (program or manual). This can be done via CLI:
I asked Gizmocuz to have a look at it. I would love to have this available as a regular switch (whereas the current hot water switch doesn't work for me).
Or else I have to make a script which I can use to toggle the hot water.
easy --serial=xxxx --password=xxxx --access-key=xxxx hot-water-supply on
easy --serial=xxxx --password=xxxx --access-key=xxxx hot-water-supply off
jannl
Re: Nefit Easy™
Can't you put this in the on/off action of a switch?
- mvveelen
Re: Nefit Easy™
Not sure if that's possible, I prefer to have it built in as a switch. But if that isn't going to happen, then I can try to make a workaround
Edit:
For now (I still hope Gizmocuz can build this into Domoticz) I made a (dummy) switch where I use:
the 'On Action':
and 'Off Action':
The python scripts:
hotwater_on.py:
hotwater_off.py
Don't forget to:
chmod +x hotwater_on.py
chmod +x hotwater_off.py
Works like a charm !
Edit:
the 'On Action':
script:///volume1/@appstore/domoticz/var/scripts/python/hotwater_on.py
script:///volume1/@appstore/domoticz/var/scripts/python/hotwater_off.py
hotwater_on.py:
#!/bin/sh
easy --serial=yourserial --password=yourpassw --access-key=youracckey hot-water-supply on
#!/bin/sh
easy --serial=yourserial --password=yourpassw --access-key=youracckey hot-water-supply off
- BartdaMan
Re: Nefit Easy™
What exactly can you switch now?mvveelen wrote:OK,
I asked Gizmocuz to have a look at it. I would love to have this available as a regular switch (whereas the current hot water switch doesn't work for me).Code: Select all
easy --serial=xxxx --password=xxxx --access-key=xxxx hot-water-supply on easy --serial=xxxx --password=xxxx --access-key=xxxx hot-water-supply off
Boiler on/off?
Or can you really switch off hot water supply? That would be nice if someone is taking a shower for too long time...
- mvveelen
Re: Nefit Easy™
I can switch on/off the hot water supply.....
- BartdaMan
Re: Nefit Easy™
Should the hotwater_off.py not read:
So off instead of on?
#!/bin/sh
easy --serial=yourserial --password=yourpassw --access-key=youracckey hot-water-supply off- mvveelen
Re: Nefit Easy™
Yes. Wrong copy-paste.... I'll correct it
- BartdaMan
Re: Nefit Easy™
Alright, it didn't work for me at first, until I read your earlier post carefully. So I had to update Robert Klep's Nefit-easy CLI.
And now indeed, works like a charm.
But I still don't understand why this could be useful. What are you using it for?
- mvveelen
Re: Nefit Easy™
The Hot Water (in my situation) "follows" the program. But there is no need to have hot water available whenever I'm at home. So I want to make a dependancy: if the waterflow > 1 and light in bathroom = ON, etc. Perhaps it might save some energy
juppetup
- Domoticz version: 3.4834
Re: Nefit Easy™
How do i upgrade my nefit-easy-server? I'm running version 2.1.0 at the moment.
Can it be done in the command-line on my Pi?
I used npm i nefit-easy-http-server -g to install the nefit-easy-server but when i do that again version 2.1.0 is installed.
regards,
Joop
regards,
Joop
- BartdaMan
Re: Nefit Easy™
Maybe 2-3 times per month the Nefit easy server hangs on my Raspi3. I then have to reboot Domoticz and everything works again.
Does anyone have similar problem?
Is there a fix?
Or a workaround script e.g. if connection time-out then reboot Domoticz?
Is there a fix?
SweetPants
Re: Nefit Easy™
This is a known issue, see earlier messages in this topic. I don't think it's an Domoticz issue, just refitting the thermostat also solves the problem. For me I just switch off/on the Nefit adapter between the Easy and the boiler if I see timeout messages in the Domoticz log.BartdaMan wrote:Maybe 2-3 times per month the Nefit easy server hangs on my Raspi3. I then have to reboot Domoticz and everything works again.
Is there a fix?
Flappie
Re: Nefit Easy™
Can someone help me with some basic Nefit Easy stuff?
I have a scene "Go to bed" to switch of all light in de living room and turn on the lights in tbe bedroom.
Now i try to override the Nefit Easy program and set a manual temperature to save gas usage. My Nefit Easy programs sets temperature to 17.5 degrees celcius on 22:30 i want to set it to 17.5 degrees when i activate the scene.
I tried to send the command:
curl -XPOST http://127.0.0.1:3000/bridge/heatingCir ... RoomManual -d '{"value":18 degrees}' -H 'Content-Type: application/json'
It says "OK" but temperature is not set to
- felix63
- Domoticz version: 2020.1
Re: Nefit Easy™
Have you added the Nefit Easy as Hardware? That should give you devices you can use to set the desired behavior.
Flappie
Re: Nefit Easy™
Yes, i have the Nefit Easy as hardware in Domoticz but there is no option to control temperature when using a scene.felix63 wrote:Have you added the Nefit Easy as Hardware? That should give you devices you can use to set the desired behavior.
