Page 29 of 114
Posted: Thursday 04 January 2018 9:50
by Madgeni
hmm, i could hardcode that hex, so if it matches, it sets that switch iswhite to true (usually it's false, as it's setting another colour)
Posted: Thursday 04 January 2018 12:13
by Tyturion
Madgeni wrote: Thursday 04 January 2018 9:50
Yeah, you are right. This command also changes the color to white even though the statement "iswhite" is still false:
https://192.168.2.9/json.htm?type=comma ... hite=false
Let me know if you need some testing done.
Cheers,
Thomas
Posted: Thursday 04 January 2018 12:29
by Madgeni
Tyturion wrote: Thursday 04 January 2018 12:13
Cheers,
Thomas
ok, so if that's the case, then there's not much I can do. i'm guessing that when you ask Google to set the lamp to white, it's triggering the 'colortemperature' trait, rather than 'colorSpectrum' trait - which means I have no control over it, otherwise it would be working. So in Domoticz terms, it's using that setKelvinLevel, rather than setcolbrightnessvalue
Posted: Thursday 04 January 2018 12:32
by Madgeni
On SelectorSwitches - as i've said before - it's stupid. Google have to manually configure every level type you use individually, in order for you to use them. I've asked them for a 'mode' which is more configurable, so simply passes on the level word, and I deal with it, but we'll see.
In the interim, i've got it working, if you use off/small/medium/large for your selector switch levels in Domoticz. Now i don't use them, so i don't know how silly that is for you, but it's all i can do at the moment, as this is the only mode selectors they've configured.
So set your levels to all/some of those, then when you've re-sync'd you can say 'set <device> load to <small/medium/large> and it should work.
It's silly, but a minor step forward.
Posted: Thursday 04 January 2018 13:57
by DewGew
I have zwave dimmers and 433mhz dimmers but dimming is not working. GA is responding correct with " Sure, dimming the lamp by 50 percent."
Any ideas?
Posted: Thursday 04 January 2018 13:58
by wimfabries
Hi Madgeni,
I have asked several times to include me in the beta programm, but no reply. Am I doing something wrong ?
Greetz Wim
Posted: Thursday 04 January 2018 14:26
by Madgeni
Hi -
you were added a while back, maybe you didn't receive the email notification. I get a lot of posts on here, and I also have a job, so i do miss things
by Madgeni
DewGew wrote: Thursday 04 January 2018 13:57
Any ideas?
hey - can you PM your email address, and i'll take a look
Posted: Thursday 04 January 2018 14:32
by wimfabries
Hi Madgeni,
Excuses, mail came into spam folder. Sorry !
Greetz
Wim
Posted: Thursday 04 January 2018 14:43
by Madgeni
Any ideas?
ok - so here's the thing. Currently (as far as i can tell) google doesn't allow you to decrement/increment percentages, but it does say it does. So technically, the only brightness control is absolute (set light to x%) - but you can ask to decrement/increment, but it sets it to 0 in the actual request.
Will investigate - but if you say 'set my device to x%' - that should work.
Posted: Thursday 04 January 2018 14:58
by DewGew
Madgeni wrote: Thursday 04 January 2018 14:43
Any ideas?
Thanks I got it working with "set lamp to 50%"
Posted: Thursday 04 January 2018 15:02
by alanlsmith
Madgeni wrote: Thursday 04 January 2018 12:29
Ok, So I know it's a bodge and shouldn't really be needed but if you add the following script: 'script_device_lampname.lua
( change lampname & idx to your lamp name and lamp idx )
local lampname = 'Sofa_Lights'
local lampidx = 299
if( devicechanged[lampname] ) then
if ( otherdevices[lampname] == 'Set Kelvin Level' ) then
print(lampname.. 'wants to be white')
commandArray[#commandArray+1] = {['OpenURL']='http://127.0.0.1:8080/json.htm?type=command¶m=setcolbrightnessvalue&idx=' ..lampidx.. '&hex=ffffff'}
It intercepts the Set Kelvin command issued by Google and changes lamp to white.
Posted: Thursday 04 January 2018 16:07
by MaxArma
Hello Madgeni,
I Would like to participate to test your solution for GH.
I am registred on Controlicz with the mail
[email protected] and i have acces to domoticz in HTTPS.
Can you add me to your test group ?
Thank you for your job.
Ps: sorry for my english, i'm french !
Posted: Thursday 04 January 2018 16:20
by Madgeni
hey MaxArma -
pas de soucis, ma française est plus mauvais - vous avez accès maintenant
Posted: Thursday 04 January 2018 17:06
by Madgeni
ok...
can someone try the 'white' thing again please? both white and warm white - thanks
Posted: Thursday 04 January 2018 17:10
by gijsje
if i ask for white they they change to warm white has always worked for me
Posted: Thursday 04 January 2018 17:51
by Tyturion
Madgeni wrote: Thursday 04 January 2018 17:06
ok...
No, doesn't work, but thanks for trying.
Cheers,
Thomas
Posted: Thursday 04 January 2018 17:58
by gijsje
I have tested again.
In the past if you say white it did change to warm white almost yellow to the max warm white of the mi light bulbs.
If i ask now for white they change to cold white.
If i ask for warm white the change to something in between warm and cold white
Posted: Thursday 04 January 2018 18:08
by Madgeni
Tyturion wrote: Thursday 04 January 2018 17:51
Cheers,
Thomas
so if you curl https://yourhost:port/json.htm?type=command¶m=setkelvinlevel&idx=63&kelvin=50
does that not do anything?
Posted: Thursday 04 January 2018 18:13
by Madgeni
gijsje wrote: Thursday 04 January 2018 17:58
Is that good or bad? It sounds bad.
