Dashticz - Module - Garbage collector Topic is solved
marktn
Re: Dashticz - Module - Garbage collector
Post by marktn »
HansieNL wrote: Tuesday 19 November 2019 23:28 Are you sure??? If you put it between /* and */ it's a comment and nothing will be styled.
Aiii... that was easy... It was my first custom.css :oops:
Thanks for helping!
Domoticz latest stable, Intel NUC, Proxmox, Zigate, RFLink, Kaku switches, Ikea lights, Xiaomi sensors, Honeywell smoke detectors, Yeelight, Shelly, Slave Domoticz PI 3B+, Node-Red, Espeasy.
madradrakie
Post by madradrakie »
can you maybe take a look if something changed in the data feed coming from the garbage company in Almere. Monday it was still working but today suddenly not anymore. Thanks in advance.
Lokonli
Post by Lokonli »
madradrakie wrote: Wednesday 11 December 2019 22:07 can you maybe take a look if something changed in the data feed coming from the garbage company in Almere. Monday it was still working but today suddenly not anymore. Thanks in advance.
Which exact Dashticz version are you using?
Can you test with master or an earlier beta version?
I had to update the jQuery version, what might have some unwanted side effects.
madradrakie
Lokonli wrote: Wednesday 11 December 2019 22:25
i am using the latest beta version (did a gitt pull yesterday). Is there an easy way to switch to the master version?
Lokonli
Post by Lokonli »
madradrakie wrote: Thursday 12 December 2019 21:20
git checkout master
Don't forget to refresh your cache.
madradrakie
i switched to the master version but the garbage module is still not working. It only shows a black garbage container.
This is the code in the config.js:
config['garbage_company'] = 'almere';
config['garbage_icalurl'] = 0;
config['garbage_zipcode'] = '';
config['garbage_street'] = '';
config['garbage_housenumber'] = '';
config['garbage_maxitems'] = '3';
config['garbage_mapping'] = {
    rest: ['grof', 'grey', 'rest', 'grijs','grijze'],
    gft: ['GFT & Rest','gft', 'tuin', 'refuse bin', 'green', 'groen', 'Biodégradables', 'snoei'],
    pmd: ['Verpakkingen','plastic', 'pmd', 'verpakking', 'kunststof', 'valorlux'],
    papier: ['Papier','blauw', 'blue', 'recycling bin collection'],
    kca: ['chemisch', 'kca','kga'],
    brown: ['brown', 'verre'],
    black: ['black', 'zwart'],
    milieu: ['milieu'],
    kerstboom: ['kerst'],
config['garbage'] = {
    gft: {kliko: 'green', code: '#375b23', name: 'GFT', icon: 'img/garbage/kliko_green.png'},
    pmd: {kliko: 'orange', code: '#db5518', name: 'PMD', icon: 'img/garbage/kliko_orange.png'},
    rest: {kliko: 'grey', code: '#5e5d5c', name: 'Restafval', icon: 'img/garbage/kliko_grey.png'},
    papier: {kliko: 'blue', code: '#153477', name: 'Papier', icon: 'img/garbage/kliko_blue.png'},
    kca: {kliko: 'red', code: '#b21807', name: 'Chemisch afval', icon: 'img/garbage/kliko_red.png'},
    brown: {kliko: 'brown', code: '#7c3607', name: 'Bruin', icon: 'img/garbage/kliko_brown.png'},
    black: {kliko: 'black', code: '#000000', name: 'Zwart', icon: 'img/garbage/kliko_black.png'},
    milieu: {kliko: 'yellow', code: '#f9e231', name: 'Geel', icon: 'img/garbage/kliko_yellow.png'},
    kerstboom: {kliko: 'green', code: '#375b23', name: 'Kerstboom', icon: 'img/garbage/tree.png'},
Lokonli
Post by Lokonli »
I guess you filled in your zipcode and housenumber in your CONFIG.js.
On my system (beta) Almere garbage is working.
Do you access Dashticz via https?
Lokonli
Post by Lokonli »
If still not working, then it's time to debug :)
In Chrome press F12 to open the Developer Window.
Refresh Dashticz
Do you see any error on the console tab?
Open the network tab.
Filter on 'waste'
You should see two network requests:
FetchAdress
GetCalendar
Select FetchAdress
What is the response code? It should start with
 {"userMessage":{"type":null,"messageCode":0,"description":null},"ExtraOption":
Select GetCalendar
madradrakie
yes i filled in my zipcode and housenumber in the config.js and you are more then welcome at my home so i can show you my system, but to invite everybody ;-).
in the console tab i see the following error:
VM1415:417 Uncaught TypeError: Cannot read property 'charAt' of undefined
at getTrashRow (<anonymous>:417:68)
at <anonymous>:446:49
at Array.forEach (<anonymous>)
at addToContainer (<anonymous>:445:17)
at Object.success (<anonymous>:159:13)
at fire (bundle.js:48)
at Object.fireWith [as resolveWith] (bundle.js:48)
at done (bundle.js:48)
at XMLHttpRequest.<anonymous> (bundle.js:48)
see row number 2 and 5.....could that be the error?
My responde code is:
At calander the responde code is:
{"userMessage":{"type":null,"messageCode":0,"description":null},"ExtraOption":{"$type":"System.Dynamic.ExpandoObject, System.Core"},"dataList":[{"pickupDates":["2019-12-20T00:00:00","2020-01-03T00:00:00"],"pickupType":18,"_pickupType":18,"_pickupTypeText":"GREENGREY","description":"Route Duo 3 Rest"},{"pickupDates":["2019-12-13T00:00:00","2019-12-27T00:00:00","2020-01-10T00:00:00"],"pickupType":10,"_pickupType":10,"_pickupTypeText":"PACKAGES","description":"Route Duo 3 Kunststof"},{"pickupDates":["2019-12-24T00:00:00","2020-01-07T00:00:00"],"pickupType":2,"_pickupType":2,"_pickupTypeText":"PAPER","description":"Papier 06 Wijk 10,12,54 & 55"}],"intDataList":null,"data":null,"status":true,"messageCode":107,"pdfResponse":null,"token":null,"ID":null,"invalidParameters":null,"total":0,"messageToString":null}
Lokonli
Post by Lokonli »
madradrakie wrote: Thursday 12 December 2019 22:06 yes i filled in my zipcode and housenumber in the config.js and you are more then welcome at my home so i can show you my system, but to invite everybody ;-).
The calendar responses look ok.
The error is not ok.
I can reproduce the error. Temporary workaround: Add the following to your config.js:
config['garbage_use_names'] = 1;
Later this week I'll try to make a real fix.
madradrakie
thanks in advance for your help and work.
I have add the workaround and now it shows:
Zwart: Vandaag
Zwart: vrijdag
Zwart: 24-12-2019
Let me know if i can test anything for you.
Lokonli
Post by Lokonli »
Almere changed it's garbage interface again...
It's fixed in the latest beta.
edit:
I've used the following settings:
    milieu: ['milieu'],
madradrakie
thanks once again! It works!
jurg1505
Post by jurg1505 »
I have problems with the Garbage.
When i set the complete address to Almere, it works.
When i set it to twentemilieu i get nothing.
/*Vuilnis Module	*/
	config['dashticz_php_path']='./vendor/dashticz/';
	config['garbage_company'] = 'twentemilieu';
	config['garbage_icalurl'] = '0';
	config['garbage_zipcode'] = '7483BH';
	config['garbage_street'] = 'Vingerhoedskruid';
	config['garbage_housenumber'] = '1';
	config['garbage_maxitems'] = '12';
	config['garbage_use_names'] = true;
	config['garbage_use_colors'] = true;
	config['garbage_icon_use_colors'] = true;
	config['garbage_use_cors_prefix'] = true;
		gft: {kliko: 'green', code: '#FF8C00', name: 'GFT', icon: 'img/garbage/kliko_brown.png'},
		rest: {kliko: 'grey', code: '#7CFC00', name: 'Restafval', icon: 'img/garbage/kliko_green.png'},
		papier: {kliko: 'blue', code: '#00BFFF', name: 'Papier', icon: 'img/garbage/kliko_blue.png'},
		kerstboom: {kliko: 'green', code: '#375b23', name: 'Kerstboom', icon: 'img/garbage/tree.png'},}
EdwinK
Post by EdwinK »
O. great, my town changed to another system to display the garbage data. From 'afvalwijzer' to an app of their own. Can't find if it uses json or something else.
Site is https://bar-afvalbeheer.nl/
It's somewhat of a challenge I read on domotica forum
nike
Domoticz version: 4.10717
Post by nike »
EdwinK wrote: Thursday 02 January 2020 19:41 O. great, my town changed to another system to display the garbage data. From 'afvalwijzer' to an app of their own. Can't find if it uses json or something else.
i live in Barendrecht with the same problem...
Lokonli
Post by Lokonli »
EdwinK wrote:O. great, my town changed to another system to display the garbage data. From 'afvalwijzer' to an app of their own. Can't find if it uses json or something else.
Do you have a link for that forum?
EdwinK
Post by EdwinK »
Of course.
https://www.domoticaforum.eu/viewforum.php?f=99
(for rooted Toon thermostats)
unclekoen
Post by unclekoen »
jurg1505 wrote: Thursday 02 January 2020 12:50 I have problems with the Garbage.
Did you get it to work?
It's my first time using the garbage collector. It works fine, but not jet good enough. I also used twentemilieu for the garbage_company.
Lines are showing, but no blue paper line, wich should be picked up 22-01-2020.
config['garbage_company'] = 'twentemilieu';			//https://dashticz.readthedocs.io/en/beta/blocks/specials/garbage.html
config['garbage_icalurl'] = '';
config['garbage_calendar_id'] = '';
config['garbage_zipcode'] = 'the-correct-zipcode';
config['garbage_street'] = 'the-correct-address';
config['garbage_housenumber'] = 'the-correct-number';
config['garbage_housenumberadd'] = '';
config['garbage_icon_use_colors'] = 1;
config['garbage_use_names'] = 0;
config['garbage_use_cors_prefix'] = 1;
        gft: {kliko: 'green', code: '#00bf00', name: 'GFT', icon: 'img/garbage/kliko_green.png'},
        pmd: {kliko: 'orange', code: '#ffa500', name: 'PMD', icon: 'img/garbage/kliko_orange.png'},
        rest: {kliko: 'grey', code: '#bfbfbf', name: 'Restafval', icon: 'img/garbage/kliko_grey.png'},
        papier: {kliko: 'blue', code: '#0742e5', name: 'Papier', icon: 'img/garbage/kliko_blue.png'},
2020-01-11 10_29_29-Dashticz.png (56.62 KiB) Viewed 2586 times
Lokonli
Post by Lokonli »
Twente Milieu has been fixed in latest beta.
(I did not change the release number yet: just pull the latest version from Github)
