Controlicz - Easy Domoticz to Alexa Integration Topic is solved
Alexa, Google Home and Siri
stefanwo
Re: Controlicz - Easy Domoticz to Alexa Integration
Post by stefanwo »
Hi @Madgeni
at first thanks a lot for your work and this skill!
Until a few days it work flawless, but now the "old" devices still work, but its not possible to add new devices/find changes at current devices (namechange). I de- an reactive the skill like you advice the user with a simillar problem. Also i test the connection in my controlicz.com account. Hope you can help me.Thank in advance!
PS: cant PM you at the Moment, not enough Posts. email is: domoticz(at)wmhdesign.de
stefanwo
Post by stefanwo »
Works again, dont know what it was. Have sent you a small donation for your work, its not much but hope it helps little bit.
Madgeni
Post by Madgeni »
thanks stefanwo - any donation is very welcome - just glad it's working
boris91530
Domoticz version: v3.8153
Post by boris91530 »
hi
excuse me i don't enderstand how can i made the comunication betwin google home and controlicz i m french and your prodjet is realy young to have any translation if someone can help me thanks
cogliostrio
Post by cogliostrio »
Thank you for sharing @Madgeni, very cool. Donation sent :)
boris91530
Hello madegeni have you bean accept my request tout bé had tout your project?
Madgeni
Post by Madgeni »
pm me your email - also, can you post in the right topic? This is the Alexa one :)
boris91530
thanks o have ad me does it s possible to read a temperature of domoticz capteur? i have 10 oregons and my wife hops to tell: "ok google quel temperature fait il dehors?" wel li m french :D and hops you can anderstand mi question
Madgeni
Post by Madgeni »
Should be ok? "What's the temperature in the <device>?
mblack2187
Post by mblack2187 »
This is very cool. Got it all up and running except 1 small problem. My temperatures in domoticz are set up for Fahrenheit, but trying to ask for or set the thermostat temperature Alexa converts them as if they were Celsius. Am I doing something wrong ??
Madgeni
Post by Madgeni »
hi - i pass Celsius. I'll see if the Domoticz API provides the scale and i can change it.
mblack2187
It appears that it is passing the Farenheit value, but indicating to Alexa that it is Celcius value, which she then converts to Farenheit resulting in Alexa reporting that it is 159 degrees in the house instead of the 71 degrees Farenheit that it actually is.
Many thanks for all of the work and the countless hours of help.
Madgeni
Post by Madgeni »
o_0 do you live in the Sun?
The snag is that Alexa will only take Celsius, fahrenheit or kelvin - but Domoticz doesn't provide a scale in the device detail
DieHappy
Domoticz version: V4.10717
Post by DieHappy »
Wow this works really created. I have it up and running with my synology 214play. You only have to port forward 8084!!!
DieHappy
Post by DieHappy »
I question: how do I ad controlicz in domoticz to use the friendly name ad my switches???
Madgeni
Post by Madgeni »
Hi - in the Devices tab of Domoticz, select 'edit' for a device, then in the Description field put Controlicz:<friendlyname> then when you rediscover, these should be in your Alexa app
gl4di4tor81
Domoticz version: 3.5877
Post by gl4di4tor81 »
i had to re-initiate domoticz <> controlicz <> alexa, but since then, i cannot set percentage of a scene anymore. Alexa won`t dim my scene to certain level.
In domoticz:
3x Fibaro roller shutter, configured as blinds percentage.
Scene with all these blinds
Controlicz to domoticz works, scene is imported into alexa
I can set percentage of each switch by voice, but the whole scene is not working?
Any ideas or help would be appreciated :-)
Thanks guys!
Rasp PI, Domoticz V 3.5877, OpenZWave USB Version: 1.4-2228-gbce4a88-dirty
dgilbert2
Domoticz version: 2024.7
Post by dgilbert2 »
Nick, just sent you a donation for a drink to say thank you for Controlicz. Keep up the excellent work.
Thank you ;)
Madgeni
Post by Madgeni »
Thanks dgilbert - very grateful, i've got family in Wymeswold, so lots of happy memories of your neck of the woods growing up :)
dgilbert2
Post by dgilbert2 »
It can be a small world :D
