Domoboard - General Discussions
Domoboard is a dashboard for Domoticz based on Python Flask.
Moderators: leecollings, wez3
Forum rules
Before posting here, make sure you are using the latest Beta or Stable version.
In order to fix issues or add features these have to be reported on the Domoboard Github pages.
This makes it possible to keep track of issues/features on a centralized place.
Refer to the issue of the github tracker when possible.
This subforum is meant to discuss issues and/or feature requests, or anything else related to Domoboard.
miljume
Domoticz version: v3.8742
Re: Domoboard - General Discussions
Post by miljume »
miljume wrote:
squandor wrote:
miljume wrote:Yes, I have authentication enabled but not for local IP adresses and the Domoboard is on the same RPI so that shouldnt be the problem
I did a git pull from the development branch so I am on the latest development version
Could you send the [general_settings] part of the config so we can see if the problem is in there.
Sure, see below
I guess the username/password part for Domoticz isn't needed when I have excluded login for local IP's?
[general_settings]
  [[server]]
    url = 192.168.0.51:8081			# IP-address of Domoticz backend
    flask_url = 192.168.0.51:8090		# Please note: this is the internal IP-address including port of the Domoboard server
    user = username			# Username for Domoticz (if required)
    password = password			# Password for Domoticz (if required)
    secret_key = <secret key> # A random secret key used for Python authentication. Change to anything random.
  [[users]]
    user1 = password1			# Add users for Domoboard here. In this case login with username "username" and password "password"
    user2 = password2
  [[domoboard]]
    time = True			# True/False: show time in top bar
    date = True			# True/False: show date in top bar
    language = "sv"			# Change this to display date/time in local language and format
    #google_maps_api_key = <api key>		# Google Maps Embed API key
    autologon = True       # True/False: enable autologon
  [[wunderground]]
  	api = <api key>
  	language = en
I have found the error!
The switch in Domoticz was called "Ljusträd" and it seems like it's the same error I reported on before (for temperature sensor) that the script can't handle Swedish letters when receiving info from Domoticz. When renaming the switch to "Light Tree" it started working again :)
SwordFish
Domoticz version: V4.11375
Post by SwordFish »
Nice work with this frontend.
I setup Domoboard and it is working but i noticed that with klikaanklikuit dimmers the sliders only work within the 1 to 16%. The dimmers don't support dimming in % only in steps (16 in this case). Is there a fix for?
Keep up the good work.
squandor
Domoticz version: 3.5837
Post by squandor »
sander815 wrote:Just got my HDMI display and second rpi. One question, do i install this on a fresh rpi with raspbian? Or on the rpi that runs domoticz
It is both possible. If you run domoboard on an fresh rpi you can change the config settings like this:
[general_settings]
[[server]]
url = url of you're domoticz server like 192.168.1.2:8080
flask_url = the ip adres of you're fresh rpi
then it should work fine :)
jake
Post by jake »
I tried to install the Domoboard on an Xbain RPI setup. So far I haven't succeeded:
 sudo apt-get install python-setuptools
sudo easy_install flask flask-auth configobj gitpython simplejson bleach requests
sudo apt-get install git
git clone https://github.com/wez3/domoboard
sudo apt-get install python-pip
pip install setuptools --upgrade
pip install html5lib
xbian@xbian ~/domoboard $ python server.py -c jacco.conf
  File "server.py", line 8, in <module>
    import modules.api as api
  File "/home/xbian/domoboard/modules/api.py", line 7, in <module>
    import security, charts, plugins, webconfig, domoticz
  File "/home/xbian/domoboard/modules/security.py", line 5, in <module>
    import json, simplejson, hashlib, os, bleach
  File "/usr/local/lib/python2.7/dist-packages/bleach-2.0.0-py2.7.egg/bleach/__init__.py", line 5, in <module>
    from bleach.linkifier import (
  File "/usr/local/lib/python2.7/dist-packages/bleach-2.0.0-py2.7.egg/bleach/linkifier.py", line 5, in <module>
    from html5lib.filters.base import Filter
ImportError: No module named base
It looks like it gets stuck on every step of the process, but now I am at the 'ImportError: No module named base' and have no clue how to continue.
Suggestions welcome
squandor
Post by squandor »
jake wrote:I tried to install the Domoboard on an Xbain RPI setup. So far I haven't succeeded:
Suggestions welcome
could you try the following command:
pip install bleach --upgrade
i thought that base is an module that should be installed with bleach but maybe it needs an update.
jake
Re: RE: Re: Domoboard - General Discussions
Post by jake »
I tried your suggestion. I needed to do it as sudo because of permission error. However, it didn't help, the error is still the same.
Verstuurd vanaf mijn GT-I9195 met Tapatalk
squandor
Post by squandor »
hmm could you try the follow command:
pip install html5lib==0.999999999
wez3
Post by wez3 »
If you have some issues installing domoboard on raspbian lite or full (probably other OS's aswell) you could try to use a virtualenv. I've tested this on lite and full, both seem to work flawless (change the path /home/pi if domoboard is located somewhere else):
sudo apt-get install python-virtualenv
virtualenv /home/pi/domoboard/
cd /home/pi/domoboard/bin
source activate
cd ..
pip install -r requirements.txt
python server.py -c config.conf
Please let me know if this works for you guys, so i can modify the installation instructions on the github page :).
bbos
Post by bbos »
@wez3,
I had the same problem today on raspbian full, so I tried the virtualenv as you suggested... and it works like a charm.
Thx
janvier123
Post by janvier123 »
is this project still active?
Any updates lately?
wez3
Post by wez3 »
janvier123 wrote:is this project still active?
Any updates lately?
Yes it is. Soon we will start writing code to configure domoboard through the webinterface.
wez3
Post by wez3 »
I've created a script to easier install Domoboard. Domoboard can be installed in the current folder with the following command:
curl -L https://www.domoboard.nl/install | bash
bbos
Post by bbos »
How can I make the domoboard run at startup?
Previously I used pm2 (on another RPi)
On my new RPi I have to run domoboard via the virtualenv, and setting it up on pm2 has not worked so far.
I have also tried putting the following commands in my rc.local:
cd domoboard/bin
source activate
cd ..
python server.py -c domo.conf
but this also didn't work
wez3
Post by wez3 »
bbos wrote:How can I make the domoboard run at startup?
cd domoboard/bin
source activate
cd ..
Checkout the "Install as a service" instructions on the github page:
This explains how to get it running under systemd.
janvier123
[statistics]
  [[display_components]]
    components = domoticz_temp_charts[1], domoticz_temp_charts[2]
   [[domoticz_temp_charts]]
      [[[1]]]
		Temperatuur = 13, day, temp
      [[[2]]]
		Temperatuur2 = 14, day, temp
This does not seem to work, i see 2 blocks, but only the bottom one (2) is working, the first one is blank
wez3
Post by wez3 »
janvier123 wrote:
[statistics]
      [[[1]]]
      [[[2]]]
This is a known issue. Please see:
https://github.com/wez3/domoboard/issues/28
janvier123
Got a 2nd RPI and i wanted to install domoboard, however it didnt work
i used: 2017-04-10-raspbian-jessie-lite (Minimal Install)
So after installing over and over again, ive made a list that allowes you to install it without any issues.
So please update the install script to the following?
PLEASE NOTE: that i did not use the NOOBS install, so it can be that some lines are not needed ;)
Here is what ive done:
sudo apt-get update
sudo apt-get install python-dev -y
sudo apt-get install python-pip -y
sudo apt-get install git -y
its up to you what to do with it, this is the most working install for me :)
wez3
Post by wez3 »
janvier123 wrote:Got a 2nd RPI and i wanted to install domoboard, however it didnt work
sudo apt-get update
Thanks. Just added this to the install script :)
janvier123
Error Found:
------------------------------------------------------------------------------------------------- First one
XML Parsing Error: syntax error
Location: https://domoboard.nl/version.md?_=1495206829537
Line Number 1, Column 1:
1.0.16,1.0.18
XML Parsing Error: syntax error Location: moz-nullprincipal:{d9dde203-ba69-4cea-9122-1f27dcdde6b5} Line Number 1, Column 1:
1.0.16,1.0.18
------------------------------------------------------------------------------------------------- 2nd one
Instellingen => Plugins
When clicking install, it just keeps loading but nothing changes
(Using FF latest version)
squandor
Post by squandor »
janvier123 wrote:Error Found:
1.0.16,1.0.18
1.0.16,1.0.18
Hi janvier123 which plug-in did you try to install And does this happen with every plugin you try to install? And do you have you're server running in debug mode? For the first error I must ask wez3 to check so I'll get back on that one
