Page 29 of 31
Re: Cheap chinese z-wave products
Posted: Thursday 19 July 2018 10:17
by terrorsource
Mmmhm, looks like the script isn't fully working in production.
MASTER = connected to the black wire (single switch)
SLAVE = no black wire connected ( double switch)
When i press MASTER the lights will go ON but the SLAVE button does not switch ON
When i press SLAVE the lights will go ON and the MASTER button does switch ON
When MASTER turned lights ON, i need to press the button on SLAVE once to turn it ON and again to turn OFF, then MASTER will turn off and lights goes OFF.
EDIT: Problem is not the script. It's in the 1CH Wall Switches.
They don't always send their status to Domoticz when the physical button is pressed.
Posted: Sunday 04 November 2018 8:54
by sincze
heggink wrote: Thursday 21 June 2018 21:03
sincze wrote: Thursday 21 June 2018 10:44
My aiming price is around 15-17 euro's. Even if I don't need them I buy them at these prices.
next time you see them at that price, let me know!!!
@heggink. On your request.
http://www.tomtop.com/p-s1473eu.html
Around 17 euro now.
Posted: Sunday 04 November 2018 11:07
by remb0
a new player in town:
Alfawise PE1004T Smart Plug Mini WiFi Socket EU Standard.
In flash sale for 7,95 euro. works with own IOS and Android app, Alexa and google home on Wifi, Domoticz compatible is not confirmed yet.
Posted: Sunday 04 November 2018 12:40
by jvdz
Not really ZWave I guess but rather Wifi.
Jos
Posted: Monday 19 November 2018 21:37
by snellejellep
i have it and have taken it apart, it seems that the wifi chip is tasmota compatible so i will try to get it flashed
Posted: Friday 23 November 2018 17:53
by snuiter
hi snellejellep,
any luck on integrating the alfawise into domoticz? I also have received a few just now.
Posted: Friday 23 November 2018 17:55
by snellejellep
snuiter wrote:hi snellejellep,
I did not have time yet, will try soon
Posted: Monday 26 November 2018 18:55
by LouiS22
snellejellep wrote: Monday 19 November 2018 21:37
Where on earth the screws are? I haven't found them. Or do I have to use a scalp to dismount it?
Posted: Thursday 29 November 2018 10:47
by gerthjan
LouiS22 wrote: Saturday 01 July 2017 8:10
Just a quick feedback.
Arrived yesterday:
https://www.aliexpress.com/item/Z-wave- ... 0.0.QIDx6w
As I initially suspected, this is Heiman's smoke sensor - and it really is, detected as Smart Sensor HS1SA. The package is a pain white box with only chinese manual included, but you can find a detailed english version at z-wave alliance database. There's not much to configure, only wake-up time
The inclusion a bit tricky: there's a small hole on the side of the device, you have to put a thin nail or something similar to it, an push it three times. Did a test, it's a noisy beep-beep-beep
@LouiS22, it's been a while that you've posted about the HS1SA smoke sensor. I was woundering. Did you get it to work with Domoticz? I've got exactly the same, but I can't get it to show up in my hardware list (see image 0x09). Do you have any tips on what i can try to make it work?
I'm using domoticz on my Synology NAS and have Aeotec ZW090 Z-Stick Gen5 EU (see image)
- 2018-11-29 10_44_50-Domoticz.png (16.12 KiB) Viewed 4597 times
Posted: Saturday 01 December 2018 16:38
by gerthjan
Does anyone have experience with this
https://nl.aliexpress.com/item/Z-wave-S ... 0.0.QIDx6w Z-wave smoke detector using Domoticz on a Synology NAS?
I've been trying to get it to work, but haven't been succesful.
I hope there are people who can give me some pointers.
Posted: Saturday 01 December 2018 17:13
by LouiS22
gerthjan wrote: Thursday 29 November 2018 10:47
Arrived yesterday:
I'm using domoticz on my Synology NAS and have Aeotec ZW090 Z-Stick Gen5 EU (see image)2018-11-29 10_44_50-Domoticz.png
Yes, it's working, I think your network didn't recognize it properly (unknown). Try to exclude that unknown node (If I recall it, there's a small hole on the side of the sensor and you have to push it 5 times (not sure, please check the manual) to trigger the exclusion.
Posted: Friday 21 December 2018 16:24
by Spymate
Posted: Saturday 22 December 2018 12:33
by nmaster
Posted: Sunday 23 December 2018 16:45
by sincze
sincze wrote: Sunday 04 November 2018 8:54
Around 18 euro now.
https://nl.aliexpress.com/item/NEO-COOL ... 57235.html
Posted: Sunday 23 December 2018 17:14
by heggink
@sincze thx!
Verstuurd vanaf mijn SM-G955F met Tapatalk
Posted: Friday 04 January 2019 23:48
by sincze
heggink wrote: Sunday 23 December 2018 17:14
@sincze thx!
Here we go again 18.69
https://s.click.aliexpress.com/e/bvxyxXfi
Posted: Wednesday 16 January 2019 11:45
by rrozema
Wintersale at aliexpress:
€ 19,32 38%OFF | NEO COOLCAM NAS-WR01ZE Z-wave Plus Smart Power Plug EU Socket Smart Home Automation Systeem thuis
https://s.click.aliexpress.com/e/EFKVY5j
Posted: Friday 18 January 2019 16:58
by akamming
Does anyone have experience with the Heiman Humidity Sensor HS1HT-Z ?
I received this device yesterday from AliExpress. Temp sensor works ok, but humidity only works after factory reset for an certain amount of time and then gets stuck on a certain value. I am sure humidity changed after this, cause i tested by closing windows, turning off ventilation and turning on 2 hot showers in the bathroom. The entire room got wet. Temperature went up according to the sensor (OK!), and i did get a lot of updates also on the humidity, however they were all the same value
A few hours later it started working again by reporting other values and then a few hours later it was stuck again at the same percentage.
Does anyone have the same experienace with this sensor (implying that the sensor is too cheap and therefor unusable for humidity) ? Or is this just a faulty one...
Posted: Friday 18 January 2019 17:56
by Alcloud
akamming wrote: Friday 18 January 2019 16:58
I have the same one, but my works ok..
Posted: Saturday 19 January 2019 7:19
by akamming
Alcloud wrote: Friday 18 January 2019 17:56
Good to know. I sent a message to the seller to send a new one...
