Page 28 of 114
Posted: Wednesday 03 January 2018 11:21
by visuel
Hello Madgeni
Today I registered at controlicz with v*****@visuel.nl and tested the connection.
Could you please add me to beta in order to let me try things out on my google AIY voice kit?
Thanks for the awesome work!
Regards,
Victor
Posted: Wednesday 03 January 2018 13:34
by Questor1972
Hi Madgeni,
Just received your message. Could you add me to the Beta program. I've already registered with kim*********@gmail.com
Posted: Wednesday 03 January 2018 14:36
by alanlsmith
I've been using Controlicz and Google Home for a few weeks now and it's working really well for me. I'm able to control lights (on / off / dim ), curtains (open / close )
A couple of caveats:
With heating: If I say 'Set the <zone> thermostat to xx°' there is a long pause followed by the response 'Sure, setting 12 thermostats to xx° and all my zone thermostats and radiator TRVs change to that value. Not the desired effect. I can easily rectify it as by changing the main house thermostat 'manually' it sets an override that stops the heating system from updating ( based on time, outside temp, etc ), so all I have to do is switch the override off and the system sorts itself out. so not a big problem.
Conversely, if I say 'set the <zone> thermostat to xx°' the response is 'Sure, setting the <zone> thermostat to xx°.
The other thing related to heating is that if I ask what is the thermostat set to? The response is 'Unable to reach kitchen thermostat, unable to reach kitchen TRV... this then continues for all the radiator TRVs and thermostat zones, then Google says the living room is off and the temperature is 21.7°.. and continues for all the temperature sensors in other zones. I have a tablet on the wall that displays the thermostat settings so it's not really necessary to be able to ask Google but I just thought I should mention it for completeness.
One final thing, which I'm sure is to do with Google rather than Controlicz is: I have a virtual switch called 'Evening Lights' that effectively sets a scene by switching some lights off, dimming others and switching some ( artificial ) candles on. on a few occasions I have ask Google to 'turn on the evening lights' and the response has been 'Sure, turning on 33 lights.' followed by various lights going on or off or changing colour, the curtails opening, the TV changing channels a few times and the volume being turned up. I seems fairly random and some lights go on then off or change colour a number of times.
It's quite amusing really and I'm fairly sure it's got to do with Google misinterpreting what I have said somehow and nothing to do with Controlicz.
I wonder if anyone else has had something similar happen, I have not found any mention of it on the interweb.
Posted: Wednesday 03 January 2018 14:41
by Madgeni
alanlsmith wrote: Wednesday 03 January 2018 14:36
Hey Alan - what exactly is <zone>? is that a Google Room you've created, or is the name of a thermostat in Domoticz?
Re: Evening Lights - that does sound very random - are some of the actions it does nothing to do with evening lights at all? What's the IDX of 'evening lights'?
Posted: Wednesday 03 January 2018 14:52
by alanlsmith
Madgeni wrote: Wednesday 03 January 2018 14:41
Yes, <zone> is the name of a thermostat in Domoticz, I haven't set any rooms in the GH app.
The IDX of 'Evening Lights' is 330, I'm pretty sure it's purely a Google related thin, the first time it happened someone else spoke as I was telling Google to switch it on, so I assumed that it happened as a result of confusing sounds / words.
But other times it has happened when I spoken very clearly, that being said it's only occurred about 5 times, I think.
EDIT: I've just looked back on the logs and the last time it happened was 2017-11-16 23:31:46, so that was a long time ago and I don't think it's worth bothering with.
Posted: Wednesday 03 January 2018 14:57
by Madgeni
Can see a couple of requests for this, which definitely called that IDX, and only that IDX. Is this your IFTTT solution? Without wanting to point fingers at something else, don't suppose it's an issue in there??
p.s am totally pointing the finger
Posted: Wednesday 03 January 2018 15:23
by alanlsmith
Madgeni wrote: Wednesday 03 January 2018 14:57
No , this is purely Domoticz and the switch just triggers a script, not a scene but as it's Google that replies with 'Sure, turning 33 lights on', the script isn't getting actioned on those occasions.
But as I have just checked, it hasn't happened since November 16, I don't think it's worth pursuing.
Just for a laugh here is the log for that minute, the only human action was asking Google to turn on the evening lights.
Hang on... I have just noticed a possible clue. I had created a virtual switch called 'Unspecified lights' which does nothing and is triggered when Google hears just 'turn the lights on' ( by a google shortcut ) I was hoping that this might stop lots of lights being switched if Google didn't hear properly. and although 'evening lights' is switched as well, 'unspecified lights is triggered first as well as all the others., So, to me that would indicate that Google misheard and that's the problem.
I hope that makes sense, it did when it left my head and hopefully it continues to do so as it lands on the screen.
2017-11-16 23:31:43.813 User: Admin initiated a switch command (5/Landing_Light/On)
2017-11-16 23:31:43.837 (RFX Transceiver) Lighting 5 (Landing_Light)
2017-11-16 23:31:43.838 User: Admin initiated a scene/group command
2017-11-16 23:31:43.838 Activating Scene/Group: [White_LEDs]
2017-11-16 23:31:43.838 Activating Scene/Group Device: Living_Room_LEDs (On)
2017-11-16 23:31:44.364 (LED Milight) Lighting Limitless/Applamp (Living_Room_LEDs)
2017-11-16 23:31:44.415 User: Admin initiated a switch command (433/Unspecified Lights/On)
2017-11-16 23:31:44.439 (General Virtual Switches) Lighting 1 (Unspecified Lights)
2017-11-16 23:31:44.439 User: Admin initiated a switch command (299/Living_Room_LEDs/On)
2017-11-16 23:31:44.564 (LED Milight) Lighting Limitless/Applamp (Living_Room_LEDs)
2017-11-16 23:31:44.564 User: Admin initiated a switch command (415/Candles/On)
2017-11-16 23:31:44.618 (General Virtual Switches) Lighting 1 (Candles)
2017-11-16 23:31:44.619 User: Admin initiated a switch command (347/Big Fan/On)
2017-11-16 23:31:44.643 (RFX Transceiver) Lighting 1 (Big Fan)
2017-11-16 23:31:44.643 User: Admin initiated a switch command (418/Television/On)
2017-11-16 23:31:44.673 EventSystem: Script event triggered: /home/alan/domoticz/scripts/lua/script_device_television.lua
2017-11-16 23:31:44.681 (General Virtual Switches) Lighting 1 (Television)
2017-11-16 23:31:44.681 User: Admin initiated a scene/group command
2017-11-16 23:31:44.682 Activating Scene/Group: [Red_LEDs]
2017-11-16 23:31:44.682 Activating Scene/Group Device: Living_Room_LEDs (On)
2017-11-16 23:31:44.720 (Television) onCommand called for Unit 1: Parameter 'On', Level: 0
2017-11-16 23:31:45.150 (RFX Transceiver) Lighting 5 (Landing_Light)
2017-11-16 23:31:45.208 (LED Milight) Lighting Limitless/Applamp (Living_Room_LEDs)
2017-11-16 23:31:45.258 Activating Scene/Group Device: Living_Room_Lights (On)
2017-11-16 23:31:45.283 (RFX Transceiver) Lighting 5 (Living_Room_Lights)
2017-11-16 23:31:45.333 User: Admin initiated a switch command (54/Kitchen_Under_Cupboard_Lights/On)
2017-11-16 23:31:45.358 (RFX Transceiver) Lighting 5 (Kitchen_Under_Cupboard_Lights)
2017-11-16 23:31:45.358 User: Admin initiated a switch command (364/Coloured Lights/On)
2017-11-16 23:31:45.412 (General Virtual Switches) Lighting 1 (Coloured Lights)
2017-11-16 23:31:45.413 User: Admin initiated a switch command (300/Standard_Lamp_LEDs/On)
2017-11-16 23:31:45.537 (LED Milight) Lighting Limitless/Applamp (Standard_Lamp_LEDs)
2017-11-16 23:31:45.537 User: Admin initiated a switch command (172/Heating_Override/On)
2017-11-16 23:31:45.563 (General Virtual Switches) Lighting 1 (Heating_Override)
2017-11-16 23:31:45.563 User: Admin initiated a switch command (80/Porch_Light/On)
2017-11-16 23:31:45.587 (RFX Transceiver) Lighting 5 (Porch_Light)
2017-11-16 23:31:45.588 User: Admin initiated a scene/group command
2017-11-16 23:31:45.588 Activating Scene/Group: [Blue_LEDs]
2017-11-16 23:31:45.588 Activating Scene/Group Device: Living_Room_LEDs (On)
2017-11-16 23:31:46.114 (LED Milight) Lighting Limitless/Applamp (Living_Room_LEDs)
2017-11-16 23:31:46.165 Activating Scene/Group Device: Living_Room_Lights (On)
2017-11-16 23:31:46.189 (RFX Transceiver) Lighting 5 (Living_Room_Lights)
2017-11-16 23:31:46.240 User: Admin initiated a switch command (183/Heating_Boost/On)
2017-11-16 23:31:46.243 LUA: Heating boost on - temperature 22.2 deg.
2017-11-16 23:31:46.272 EventSystem: Fetching url...
2017-11-16 23:31:46.272 EventSystem: Script event triggered: /home/alan/domoticz/scripts/lua/script_device_heating_boost.lua
2017-11-16 23:31:46.295 (General Virtual Switches) Lighting 1 (Heating_Boost)
2017-11-16 23:31:46.295 User: Admin initiated a switch command (75/Living_Room_Lights/On)
2017-11-16 23:31:46.372 (General Virtual Switches) Lighting 1 (Heating_Override)
2017-11-16 23:31:46.395 (RFX Transceiver) Lighting 5 (Living_Room_Lights)
2017-11-16 23:31:46.396 User: Admin initiated a switch command (399/Television_Source/Set Level)
2017-11-16 23:31:46.400 User: Admin initiated a switch command (330/Evening_Lights/On)
2017-11-16 23:31:46.405 EventSystem: Script event triggered: /home/alan/domoticz/scripts/lua/script_device_evening_lights.lua
2017-11-16 23:31:46.424 (Television) onCommand called for Unit 3: Parameter 'Set Level', Level: 20
2017-11-16 23:31:46.427 (General Virtual Switches) Lighting 1 (Evening_Lights)
2017-11-16 23:31:46.432 User: Admin initiated a switch command (53/Kitchen_Lights/On)
2017-11-16 23:31:46.456 (RFX Transceiver) Lighting 5 (Kitchen_Lights)
2017-11-16 23:31:46.456 User: Admin initiated a switch command (73/Bedroom_Light/On)
2017-11-16 23:31:46.532 (RFX Transceiver) Lighting 5 (Bedroom_Light)
2017-11-16 23:31:46.532 User: Admin initiated a switch command (273/Living_Room_Curtains_Remote/On)
2017-11-16 23:31:46.555 EventSystem: Script event triggered: /home/alan/domoticz/scripts/lua/script_device_living_room_curtains_remote.lua
2017-11-16 23:31:46.557 (General Virtual Switches) Lighting 1 (Living_Room_Curtains_Remote)
2017-11-16 23:31:46.562 User: Admin initiated a scene/group command
2017-11-16 23:31:46.563 Activating Scene/Group: [White_LEDs]
2017-11-16 23:31:46.563 Activating Scene/Group Device: Living_Room_LEDs (On)
2017-11-16 23:31:46.637 (LED Milight) Lighting Limitless/Applamp (Living_Room_LEDs)
2017-11-16 23:31:46.661 (RFX Transceiver) Lighting 5 (Living_Room_Lights)
2017-11-16 23:31:46.736 (RFX Transceiver) Lighting 5 (Kitchen_Lights)
2017-11-16 23:31:46.790 (General Virtual Switches) Lighting 1 (Candles)
2017-11-16 23:31:47.088 (LED Milight) Lighting Limitless/Applamp (Living_Room_LEDs)
2017-11-16 23:31:47.139 User: Admin initiated a switch command (399/Television_Source/Set Level)
2017-11-16 23:31:47.163 Sending SetPoint to device....
2017-11-16 23:31:47.184 (Television) onCommand called for Unit 3: Parameter 'Set Level', Level: 40
2017-11-16 23:31:47.186 (General Virtual Switches) Thermostat (Main Thermostat)
2017-11-16 23:31:47.187 User: Admin initiated a switch command (399/Television_Source/Set0Level)
2017-11-16 23:31:47.188 User: Admin initiated a switch command (457/Twinkly Lights/On)
2017-11-16 23:31:47.221 EventSystem: Script event triggered: /home/alan/domoticz/scripts/lua/script_device_living_room_curtains_open.lua
2017-11-16 23:31:47.257 (Television) Update Television_Status: 1 - 'HDMI 3'
2017-11-16 23:31:47.263 (General Virtual Switches) Lighting 1 (Living_Room_Curtains_Open)
2017-11-16 23:31:47.327 (Television) Update Television_Source: 1 - '40'
2017-11-16 23:31:47.327 (Television) onCommand called for Unit 3: Parameter 'Set0Level', Level: 20
2017-11-16 23:31:47.334 (General Virtual Switches) Lighting 1 (Twinkly Lights)
2017-11-16 23:31:47.334 User: Admin initiated a scene/group command
2017-11-16 23:31:47.335 Activating Scene/Group: [Green_LEDs]
2017-11-16 23:31:47.335 Activating Scene/Group Device: Living_Room_LEDs (On)
2017-11-16 23:31:47.860 (LED Milight) Lighting Limitless/Applamp (Living_Room_LEDs)
2017-11-16 23:31:47.911 Activating Scene/Group Device: Living_Room_Lights (On)
2017-11-16 23:31:47.935 (RFX Transceiver) Lighting 5 (Living_Room_Lights)
2017-11-16 23:31:50.271 (Television) Update Television_Status: 1 - 'HDMI 3/ARC'
2017-11-16 23:31:51.584 (General Virtual Switches) Lighting 1 (Living_Room_Curtains_Remote)
2017-11-16 23:31:52.252 (General Virtual Switches) Lighting 1 (Living_Room_Curtains_Open)
2017-11-16 23:31:56.452 (General Virtual Switches) Lighting 1 (Evening_Lights)
2017-11-16 23:31:57.280 (RFX Transceiver) Lighting 4 (Living_Room_Curtains)
2017-11-16 23:31:58.864 (Z-Stick) General/kWh (Greenwave2_Energy)
2017-11-16 23:31:59.229 (Z-Stick) Usage (Greenwave2_Watts)
2017-11-16 23:31:59.254 (Z-Stick) General/kWh (Greenwave2_Energy)
2017-11-16 23:31:59.717 (Television) onCommand called for Unit 3: Parameter 'Set Level', Level: 20
2017-11-16 23:31:59.756 (Television) Update Television_Status: 1 - 'HDMI 1'
2017-11-16 23:31:59.780 (Television) Update Television_Source: 1 - '20'
2017-11-16 23:31:59.799 (Z-Stick) Usage (Greenwave2_Watts)
2017-11-16 23:31:59.824 (Z-Stick) General/kWh (Greenwave2_Energy)
2017-11-16 23:32:00.207 LUA: Door has been closed
Posted: Wednesday 03 January 2018 16:24
by Tyturion
Hi Madgeni,
thanks for adding me to the beta. After assigning all devices to rooms in Domoticz I have successfully added some switches, lights, temperature sensors and Milights to the Google Home control so far.
They all work fine and I even get different icons for wallplugs, lights, temp. sensors and scenes. Great stuff. Syncing works nicely, too.
The biggest issue I encountered so far is changing the color of the Milights to white. Any other color works fine but I can't get back to white (or soft white, warm white or day light
When I change to red: Domoticz nicely transmits this:
2018-01-03 16:10:20.256 RFLink Sending: 10;MiLightv1;e452;01;2000;ON
2018-01-03 16:10:20.487 RFLink Sending: 10;MiLightv1;e452;01;2000;COLOR
2018-01-03 16:10:20.714 (RFLINK 433MHZ) Lighting Limitless/Applamp (Gästezimmer Lichtleiste)
2018-01-03 16:10:20.815 RFLink Sending: 10;MiLightv1;e452;01;00ff;ON
2018-01-03 16:10:21.036 RFLink Sending: 10;MiLightv1;e452;01;00ff;BRIGHT
When it receives the "change to white command" it says:
2018-01-03 16:11:15.581 Error: RFLink: trying to send unknown led switch command: 33
Have you come across this yet by any chance? At least I couldn't find it in the forum.
Btw. I use Domoticz on a Pi 3 and RFLink v.48.4 to control the Milights.
Cheers,
Thomas
Posted: Wednesday 03 January 2018 17:02
by alanlsmith
Tyturion wrote: Wednesday 03 January 2018 16:24
I've just remembered that I've had the same issue with MiLight lamps, colours generally work but white / cool white / warm white doesn't. No errors from Domoticz, it just shows an entry for the lamp in the log. However the Switch in Domoticz changes from 'On' to 'Set Kelvin Level' see screen shot below but the actual colour of the lamp doesn't change.
Also when switching the MiLight lamps on with a script they sometimes come on blue or purple even when they were previously set to white and also when they are white the colour chart in Domoticz shows the 'dot' as being in the blue sector.
This has been happening for a couple of years ever since I first started using MiLight lamps so I've just got used to it.
I got round setting the lamps to white by using a Domoticz scene. So this is what I used to do the same thing when I started using Controlicz.
Posted: Wednesday 03 January 2018 17:45
by Madgeni
Hey all - let me take a look at setkelvinlevel - in lieu of any documentation on this api call, i pass it the actual kelvin level, I wonder if Domoticz expects something else..
Posted: Wednesday 03 January 2018 19:57
by HallezJB
Bonjour je suis sans réponse à ma question Samedi 30 Décembre 2017 20:39.
Je suis Français...
Je souhaite intégrer Google Home à Domoticz, je suis inscris sur Controlicz avec succès en HTTPS.
Mon Email
[email protected]
Je n'ai rien reçu... Que dois-je faire ????
Merci Beaucoup JB Hallez.
Posted: Wednesday 03 January 2018 20:01
by alanlsmith
Madgeni wrote: Wednesday 03 January 2018 17:45
Hope I'm not doubling up on work but I looked into this a bit and I think Domoticz accepts kelvin levels as percentages of 25%-50%-75%-100%, ( not actual kelvin values ), but only for newer MiLight lamps which have colour temperature control. I tried json calls of:
http://127.0.0.1:8080/json.htm?type=command¶m=setkelvinlevel&idx=299&kelvin=25
and that had no effect on my lamps.
However
http://127.0.0.1:8080/json.htm?type=command¶m=setcolbrightnessvalue&idx=299&hex=fafafa
did change the lamps to white.
My lamps are a couple of years old and are RGB-WW so the only white is warm white.
Posted: Wednesday 03 January 2018 20:06
by Madgeni
alanlsmith wrote: Wednesday 03 January 2018 20:01
However
so, if you ask google to set a light to white, does it work? Not 'warm/cold' white - which would probably go via Kelvin, but simple colour switch.
I'd had a look at that kelvin level thing, but it seems - suboptimal..
Posted: Wednesday 03 January 2018 20:07
by Madgeni
HallezJB wrote: Wednesday 03 January 2018 19:57
Je suis Français...
Mon Email
[email protected]
désolé - vous avez accès maintenant
Posted: Wednesday 03 January 2018 20:12
by alanlsmith
Madgeni wrote: Wednesday 03 January 2018 20:06
Nope. 'Set to white' has no effect. Oh.. Other than showing 'Set Kelvin Level' on the switch in the Domoticz dashboard.
Posted: Wednesday 03 January 2018 20:13
by Madgeni
bugger
Posted: Wednesday 03 January 2018 20:14
by alanlsmith
Madgeni wrote: Wednesday 03 January 2018 20:13bugger
Somehow thought that you might think that.
Posted: Wednesday 03 January 2018 21:26
by Madgeni
quick poll - selector switches - do you stick to the 10/20/30/etc levels, and do you always keep the default 0 = Off?
Posted: Wednesday 03 January 2018 21:39
by alanlsmith
Madgeni wrote: Wednesday 03 January 2018 21:26
Yes, that's what I use, although at the moment I only use a selector switch for the television source and I use virtual switches with scripts to change the selector switch. ( Makes for easier wording when adding Google ).
Yes, I know I'm a pain in the @®$€ as I never seem to do anything in a straight forward manner.
Posted: Thursday 04 January 2018 9:36
by Tyturion
in the meantime I did some testing and found out that this json command switches the Milighs to white:
https://192.168.2.9/json.htm?type=comma ... white=true
The question is now how to get Google to trigger and send this command?
Cheers,
Thomas
