Dashticz - Module - Garbage collector Topic is solved
Lokonli
Re: Dashticz - Module - Garbage collector
Post by Lokonli »
naitsirhc wrote: Sunday 17 March 2019 11:56 Hi,
Could someone give me a walk through to configure my gmail calendar (Ical) with this nice add on?
Until now i've got:
config['garbage_icalurl'] = 'https://calendar.google.com/calendar/ic ... /basic.ics';
config['garbage_maxitems'] = '12';
config['garbage_use_names'] = true;
config['garbage_use_colors'] = true;
config['garbage_icon_use_colors'] = true;
config['garbage_use_cors_prefix'] = true;
config['garbage'] = {
//gft: {kliko: 'green', code: '#375b23', name: 'GFT', icon: 'img/garbage/kliko_green.png'},
//pmd: {kliko: 'orange', code: '#db5518', name: 'PMD', icon: 'img/garbage/kliko_orange.png'},
//Restabfallbehaelter: {kliko: 'grey', code: '#5e5d5c', name: 'Restafval', icon: 'img/garbage/kliko_grey.png'},
//papier: {kliko: 'blue', code: '#153477', name: 'Papier', icon: 'img/garbage/kliko_blue.png'},
//kca: {kliko: 'red', code: '#b21807', name: 'Chemisch afval', icon: 'img/garbage/kliko_red.png'},
//brown: {kliko: 'brown', code: '#7c3607', name: 'Bruin', icon: 'img/garbage/kliko_brown.png'},
//black: {kliko: 'black', code: '#000000', name: 'Zwart', icon: 'img/garbage/kliko_black.png'},
Restabfallbehaelter: {kliko: 'yellow', code: '#f9e231', name: 'Geel', icon: 'img/garbage/kliko_yellow.png'},
//kerstboom: {kliko: 'green', code: '#375b23', name: 'Kerstboom', icon: 'img/garbage/tree.png'},
Unfortunately my Dashticz does show up, but the garbage add on shows loading and doesn't continue....
thanks in advance
In your case you have to define config['garbage_mapping'] as well. With this setting you map a certain text found in the garbage description to a garbage type. After that you can configure the representation of the garbage types with config['garbage']
Don't forget to define config['garbage_company']
Try the following:
  config['garbage_company'] = 'ical';
  config['garbage_icalurl'] = 'https://calendar.google.com/calendar/ical/afvaltwist%40gmail.com/public/basic.ics';
  config['garbage_mapping'] = {
    rest: ['Rest'],
    gelb: ['Gelber'],
    bio: ['Bio'],
    papier: ['Papier']
  rest: {kliko: 'black', code: '#000000', name: 'Restabfall', icon: 'img/garbage/kliko_black.png'},
  gelb: {kliko: 'yellow', code: '#f9e231', name: 'Gelber Sack', icon: 'img/garbage/kliko_yellow.png'},
  bio: {kliko: 'green', code: '#375b23', name: 'Bio', icon: 'img/garbage/kliko_green.png'},
naitsirhc
Post by naitsirhc »
Wow,
It's working like a charm, Thanks a lot....
Und Tschjuß
Marque1968
Post by Marque1968 »
Just a small question. The Tilburg collection does not show "rest+gft" but only "gft" (but "plastic+papier" still exists). I had my icons changed to show the two colors assosiated with the bins (green/black and orange/blue respectively) but now it shows as green only this week. Is this because the root data has changed or is there a data manipulation change?
Lokonli
Post by Lokonli »
Marque1968 wrote: Monday 18 March 2019 12:26 Just a small question. The Tilburg collection does not show "rest+gft" but only "gft" (but "plastic+papier" still exists). I had my icons changed to show the two colors assosiated with the bins (green/black and orange/blue respectively) but now it shows as green only this week. Is this because the root data has changed or is there a data manipulation change?
I don''t think there was any recent change to the Dashticz code. I guess that the Tilburg calendar changed it's description of the garbage types. With config['garbage'] and config['garbage_mapping'] I expect you can tune it to what you want.
JacKok
Domoticz version: V4.10717
Post by JacKok »
Hello Rob,
Could someone give me a walk through to configure garbage settings.
I live in hellendoorn, and we can see garbage calendar https://afvalportaal.2go-mobile.com/mod ... jverdal---
I download the ical file and inport it to my public calendar in Gmail.
My Config
config['garbage_icalurl'] = 'https://calendar.google.com/calendar?ci ... Z2xlLmNvbQ';
rest: {kliko: 'grey', code: '#5e5d5c', name: 'Restafval', icon: 'img/garbage/kliko_grey.png'},
unfortunately it not working, and showing only Loading. Please help!
Working with latest version of Dashticz v2
thanks
JacKok
Post by JacKok »
JacKok wrote: Wednesday 24 April 2019 23:37 Hello Rob,
My Config
thanks
UPDATE! ITS WORKING!!!
I was using the wrong URL for my calendar
BAD:
Good:
Find in Google calender the ''Public adres in Ical'' and use that link for config['garbage_icalurl'] =
Open Google Calendar > Settings > Click right calendar > public address in ical format
Gianni
Post by Gianni »
need some help cant figure out myself
if i leave the garbage standard i get(ophaalkalender be)
restafval dinsdag
p-k dindag
pmd 13-08-2013
so this is correct like the calendar.
but if i put this code
then i only get
restafval dinsdag
pmd 13-08-2013
SO no P-K
if i read goo then is the first mapping the word searching in the online calendar.
Papier en karton is written like P-K on the online calendar
so if i write this
p-k: {kliko: 'blue', code: '#153477', name: 'Papier', icon: 'img/garbage/kliko_blue.png'},
then i only got
restafval dinsdag
restafval 13*08*2019
restzfvzl 20*08*2019
if i made a mapping he only show pmd
{papier: ['P-K', 'blauw', 'blue', 'recycling bin collection'],
If i give this mapping it's say no data found
    rest: ['Restafval'],
    pmd: ['PMD'],
    papier: ['Papier','P-K','p-k']
if i take the json cal en copied into te browser then this is correct
allDay	true
color	"grey"
start	"2019-08-06T00:00:00+02:00"
title	"Restafval"
1
allDay	true
color	"brown"
title	"P-K"
2
allDay	true
color	"blue"
start	"2019-08-13T00:00:00+02:00"
title	"PMD"
3
allDay	true
color	"grey"
title	"Restafval"
4
allDay	true
color	"grey"
start	"2019-08-20T00:00:00+02:00"
title	"Restafval"
how can i fix this?
Gianni
Post by Gianni »
solved .
found the V2 manual.
Match the mapping with the json call and now it's work correct.
grts
jaaap
Post by jaaap »
I've tried to get it running, but no luck so far :-( I've got the script running in Domoticz itself, but I don't like the display of the variable in dashticz (I know I could fix this via custom.css, but I think it's nicer to have the garbage module run on dashticz). I only see the garbage can icon in dashticz, and 'Geen gegevens gevonden'.
My setup:
domoticz 4.10717 running on synology nas
dashticz V3.0.0 master running on synology nas,
python version: none,
php version 7.0.33
I've mapped the types of trash according to our local garbage company (I got the right names from the script in domoticz. That works so I know the mapping now refers to the right names).
config['garbage_company'] = 'dar';
config['garbage_icalurl'] = '';
config['google_api_key'] = '';
config['garbage_calendar_id'] = '';
config['garbage_zipcode'] = '6663AJ';
config['garbage_street'] = 'Radmakerstraat';
config['garbage_housenumber'] = '13';
config['garbage_housenumberadd'] = '';
config['garbage_maxitems'] = '5';
config['garbage_width'] = '4';
config['garbage_hideicon'] = false;
    gft: ['Gft-afval'],
    pmd: ['Plastic+'],
    papier: ['Papier (overdag)'],
    kerstboom: ['kerst'],
    gft: {kliko: 'green', code: '#375b23', name: 'Gft-afval', icon: 'img/garbage/kliko_green.png'},
    pmd: {kliko: 'orange', code: '#db5518', name: 'Plastic+', icon: 'img/garbage/kliko_orange.png'},
Any ideas?
jaaap
Post by jaaap »
jaaap wrote: Monday 05 August 2019 16:13 Hi all,
My setup:
php version 7.0.33
    gft: ['Gft-afval'],
    pmd: ['Plastic+'],
Any ideas?
I finally figured it out. It was all due to some extention settings on the PHP on my synology. It appears that I should not only tick the curl box, but also the openssl box.
madradrakie
Post by madradrakie »
Can somebody help me. Suddenly my garbage collector is not working anymore. I'am running dashticz and domoticz on a raspherry pi. This is the script i use at te moment:
config['dashticz_php_path']='./vendor/dashticz/'
config['garbage_company'] = 'almere';
config['garbage_icalurl'] = '0';
config['garbage_zipcode'] = '1234AAV';
config['garbage_street'] = 'xxx xx xxx';
config['garbage_housenumber'] = '1234';
config['garbage_maxitems'] = '3';
config['garbage_icon_use_colors'] = 1;
config['garbage_use_colors'] = 0;
config['garbage_use_names'] = 1;
config['garbage_use_cors_prefix'] = 1;
    rest: ['grof', 'grey', 'rest', 'grijs','grijze'],
    gft: ['gft', 'tuin', 'refuse bin', 'green', 'groen', 'Biodégradables', 'snoei'],
    pmd: ['plastic', 'pmd', 'verpakking', 'kunststof', 'valorlux'],
    papier: ['papier', 'blauw', 'blue', 'recycling bin collection'],
    kca: ['chemisch', 'kca','kga'],
    brown: ['brown', 'verre'],
    black: ['black', 'zwart'],
    milieu: ['milieu'],
    milieu: {kliko: 'yellow', code: '#f9e231', name: 'Geel', icon: 'img/garbage/kliko_yellow.png'},
It shows on the screen:
Zwart: Vandaag
Zwart: Vrijdag
What is going wrong?
HansieNL
Post by HansieNL »
Have you changed something in your garbage settings?
My advice is to backup your CONFIG.js and try with basic garbage settings to see if that works.
Blah blah blah
madradrakie
HansieNL wrote: Wednesday 02 October 2019 18:13 Have you changed something in your garbage settings?
No i changed nothing. Also when i use basic settings in a clean dashticz installation it shows the same.
Lokonli
Post by Lokonli »
madradrakie wrote: Sunday 06 October 2019 11:04
There is a change in the data Dashticz receives from the Almere garbage provider.
I've made the fix in the latest beta.
madradrakie
Lokonli wrote: Sunday 06 October 2019 14:30
Thanks again Lokonli, it is working again! :D
Lokonli
Post by Lokonli »
Good! Thanks for confirming.
marktn
Post by marktn »
Is this working under dashticz v3?
I like to have a larger font.
.trash .state div.trashrow {
    font-size: 100px;
.trash .state div.trashtoday {
    font-size: 100px;
.trash .state div.trashtomorrow {
    font-size: 100px;
Domoticz latest stable, Intel NUC, Proxmox, Zigate, RFLink, Kaku switches, Ikea lights, Xiaomi sensors, Honeywell smoke detectors, Yeelight, Shelly, Slave Domoticz PI 3B+, Node-Red, Espeasy.
HansieNL
Post by HansieNL »
marktn wrote: Saturday 16 November 2019 20:49 Hello,
    font-size: 100px;
    font-size: 100px;
    font-size: 100px;
Just tried with latest beta. Looks like it is working.
Blah blah blah
marktn
Post by marktn »
HansieNL wrote: Sunday 17 November 2019 2:54
    font-size: 100px;
    font-size: 100px;
    font-size: 100px;
Oke....strange.
This is my custom.css
Can you send me your css file?
font-size: 100px;
font-size: 100px;
font-size: 100px;
HansieNL
Post by HansieNL »
Are you sure??? If you put it between /* and */ it's a comment and nothing will be styled.
Blah blah blah
