Locked
rbisschops
Domoticz version: 2.2563
Re: New Dashboard Design v2, custom positioning and multiple screens
Post by rbisschops »
SuperMouse wrote:@rbisschops
Sure Ralph
Actually it is just a different background:
http://imgur.com/a/Dx7zT
Change it in the config.js
var _BACKGROUND_IMAGE      		= 'background.jpg';
And I change line 495 from white into black in the CSS:
div.screen {
  -webkit-background-size: cover;
  -moz-background-size: cover;
  -o-background-size: cover;
  background-position: center;
  color: black;
@SuperMouse Thanks! Works like a charm!
However, its maybe better to add the changed CSS to the custom.css file. I think Rob introduced that one for customisations (leaving the orginal in place when you need to upgrade.
Thx!
Ralph
RPi 3B (master): RFXtrx433, Harmony Hub, Z-Wave devices, CoCo units, Hue, Xiaomi Aquara
RPi 2B (slave): P1 connection, MySensors with custom built watermeter sensors on Aquadis+
RPi’s with: Mosquitto MQTT, Home Bridge, Home Assistant (for evaluation only)
mAiden88
Domoticz version: 3.7286
Post by mAiden88 »
EdKo66 wrote:
mAiden88 wrote:
EdKo66 wrote:
Already send a copy of CONFIG.js to Rob, but here is the columns[1] block
columns[1] = {}
columns[1]['blocks'] = [1,2,6,7,84,91,'s1',51,99,53,55,56,57,58,59,60,62,63,95,97,98,96] //idx 101 = Setpoint
columns[1]['width'] = 5;
There are no empty block titles?
blocks['blocktitle_1'] = {}
blocks['blocktitle_1']['title'] = 'Schakelaars';
But what I want is not a title there, but no block at all, so to save space on a smaller tablet (7")
I know what you want. You want to remove that empty Space..
Let me think..
Maybe a weird thing. Do you remove 'Schaakelaars' all ready?
You know me, i only want to think with you.
Anyone can build a fast processor. The trick is to build a fast system.
EdwinK
Post by EdwinK »
Sure Ralph
Added this image (I like it), but somehow it looks different.
rbisschops
robgeerts wrote:Hold on, I'll check my wife's ipad 2..
Edit: Yes, same issue, will try to fix this asap!
Meanwhile...
GRAPHS ARE LIVE (BETA!!!)
Download latest version from gitlab.
Enter the follow key in the definitions: 'graph_IDX', if your graph in Domoticz is idx 150, use:
columns[2]['blocks'] = ['graph_150']
ATTENTION: Only tested it with my energy and gas from Toon Thermostat!
Hi Rob,
Tested with P1 meterdata. When a data point is hovered it shows the time. Shouldn't this be the usage during that hour?
Thx
Ralph
rbisschops
Hi Rob,
I have a (puls) water meter in Domoticz. When I add the water meter it shows two fields when I add this:
columns[3]['blocks'] = ['clock','sunrise',buttons.buienradar,'blocktitle_3','8','9','122']
When I add:
columns[3]['blocks'] = ['clock','sunrise',buttons.buienradar,'blocktitle_3','8','9','122_1']
It shows an emtpy box
When I add:
columns[3]['blocks'] = ['clock','sunrise',buttons.buienradar,'blocktitle_3','8','9','122_2']
It shows the total meter value
Any thoughts?
Thx
Ralph
EdwinK
Post by EdwinK »
Let me think..
I moved the idx 's1' to be the first in the row, and now it looks a bit better.
robgeerts
Domoticz version: 3.7067
Post by robgeerts »
Will look into all your bugs etc. later... Meanwhile, edko66, it doesnt recognize your background image? What if you clear your browser cache?
mAiden88
Post by mAiden88 »
Let me think..
Nice. I need to fight with it..
Tablet on the wall with this nice dashboard, even my wife likes it :shock:
EdwinK
Post by EdwinK »
robgeerts wrote:Will look into all your bugs etc. later... Meanwhile, edko66, it doesnt recognize your background image? What if you clear your browser cache?
Done so, but... will give it another try.
EdwinK
Post by EdwinK »
For shame... :oops:
Somehow, the background.jpg wasn't copied to the img folder.
robgeerts
Post by robgeerts »
Clemen wrote: So for my watt graph it says undefined
Fixed
pvm wrote:Thanks for fixing the clock not being centered, Goodnight!
I've tested the graph for PI temperature and CPU usage, it reports "PITemperature: undefined" and does not show a graph
Could you send me the output, when entering:
http://DOMOTICZ_URL/json.htm?type=graph&sensor=counter&idx=YOUR_IDX&range=day
(replace 'YOUR_IDX' with the idx of the device
Bob123bob wrote:Is there a way to add Alert device type ?
Fixed
Bob123bob wrote: But as you can see 167_1 (now) is not working :(
Fixed
SuperMouse wrote:Hi all,
I just can not get the 'weather' and 'currentweather' working, and this was really the part I wanted to have :(
'Maassluis' is working here, are you sure your key is right?
Maybe you can PM your key so I can test this once.. (wont abuse this of course), or do you get any error in console (f12) ?
maluko wrote: and the select botton dont work ether, can select the order but cant reach to domoticz.
AddjMulti: 1,
AddjMulti2: 1,
Level: 0,
LevelActions: "||||||",
LevelInt: 0,
LevelNames: "Off|OFF|5 Min|10 Min|15 Min|20 Min|Limpeza",
LevelOffHidden: true,
idx: "xx"
Shouldn't 'LevelActions' be filled?
SuperMouse wrote: Is there a way to change the height of the graph itself?
In custom.css, add something like:
#graphoutput150 {
	height:100px;
Change '150' to the idx of your device
rbisschops wrote: I noticed a minor bug is the css.
At line 110: border-color: #FFFF; should be #FFF.
Fixed
SuperMouse wrote: And I change line 495 from white into black in the CSS:
Better to overwrite in custom.css, otherwise your change will be gone in a next update!
rbisschops wrote: Tested with P1 meterdata. When a data point is hovered it shows the time. Shouldn't this be the usage during that hour?
rbisschops wrote:Hi Rob,
When I add:
When I add:
Could you send me your output so I can test with it?
Visit: DOMOTICZ_URL/json.htm?type=devices&filter=all&used=true&order=Name
(Only the output for the device we're talking about..)
irishv
Post by irishv »
I can't believe how far this has come in a week. I think I have everything working now, but have two requests:
  • Can you make an option to switch between Celsius and Fahrenheit?
  • Can you make the media buttons larger for the Logitech Media Server and add Volume Up and Down buttons?
I've been able to make both of those changes manually, but have to do them every time I update. Thanks again, I've been looking for something like this since I first installed Domoticz.
robgeerts
Post by robgeerts »
irishv wrote:I can't believe how far this has come in a week. I think I have everything working now, but have two requests:
What css do you apply every time?
Will fix the celcius/fahrenheit switch.. changing ºC to ºF is enough?
Or do I have to recalculate the output?
EDIT: set in config.js:
var _USE_FAHRENHEIT = true;
rbisschops
@robgeerts Will sent you the input tomorrow evening after work. Thx for the fast response.
Ralph
Martijn85
Domoticz version: Stable
Post by Martijn85 »
Realy nice dashboard!
I have this running on another webserver, i have the correct http://user:pass@ip:port but i keep a emty screen?
See the attached file. How can i fix this, what am i missing?
edit: never mind, this not read the README. Just change the config.default en save to default and your good to go!
HansieNL
Post by HansieNL »
Hello Rob,
If I change css from -100% to -200% 3rd page is shown. Can you check if the code in creative.css should be corrected?
.slide-radio3:checked ~ .fullslider {
-webkit-transform: translateX(-200%);
Blah blah blah
irishv
Post by irishv »
robgeerts wrote: What css do you apply every time?
Awesome, I'll give that a try tonight. I had been changing the weather.js file manually (temp_c to temp_f and .celsius to .fahrenheit). For the music buttons I switched to different icons and set font-size:25px. Haven't really gotten it a way I like, but really just need larger buttons.
pvm
Domoticz version: 4.10538
Post by pvm »
robgeerts wrote:
pvm wrote: I've tested the graph for PI temperature and CPU usage, it reports "PITemperature: undefined" and does not show a graph
I've tried this for memory usage of PI:
   "ValueQuantity" : "",
   "ValueUnits" : "",
   "status" : "OK",
   "title" : "Graph counter day"
you requested to use
DOMOTICZ_URL/json.htm?type=graph&sensor=counter&idx=MYIDX&range=day
Domoticz uses:
DOMOTICZ_URL/json.htm?type=graph&sensor=Percentage&idx=MYIDX&range=day
The same issue applies to a virtual sensor I have to measure soil humidity
But don't put too much effort in for now, this is purely a nice to have (for me)
I'm much more interested in getting Domoticz data on the iPad :)
maluko
Post by maluko »
AddjMulti: 1,
AddjMulti2: 1,
Level: 0,
LevelInt: 0,
idx: "xx"
no. i dont have level action, i have a blockly that listen the select switch and execute scenes each type.
my question is when we select "5min" level on dashboard arent to switch on real domoticz too?
HansieNL
Post by HansieNL »
maluko wrote:
robgeerts wrote:
maluko wrote: my question is when we select "5min" level on dashboard arent to switch on real domoticz too?
Has to be fixed. I have the same problem with a Toon Thermostat selector switch. I'm sure Rob will fix it asap... please be patient in the meantime.
Blah blah blah
Locked
