Domoboard - General Discussions
Domoboard is a dashboard for Domoticz based on Python Flask.
Moderators: leecollings, wez3
Forum rules
Before posting here, make sure you are using the latest Beta or Stable version.
In order to fix issues or add features these have to be reported on the Domoboard Github pages.
This makes it possible to keep track of issues/features on a centralized place.
Refer to the issue of the github tracker when possible.
This subforum is meant to discuss issues and/or feature requests, or anything else related to Domoboard.
EdwinK
Re: Domoboard - General Discussions
Post by EdwinK »
Dont' have systemd/ in my Synology
squandor
Domoticz version: 3.5837
Post by squandor »
EdKo66 wrote:Dont' have systemd/ in my Synology
perhaps than with screen ?
jjnj
Post by jjnj »
squandor wrote:
Hi jjnj,
It's looking great :) unfortunately the scrolling is an temporary bug so the menu can be scrolled on mobile devices. We will try to fix the menu scrolling bug so that the unnecessary scrolling of the page can be disabled again
Thank you very much for the information. I really like the interface and the possibilities!
EdwinK
Post by EdwinK »
Not there either. I'm on Synology, so maybe they have different commands.
GuyTreepbush
Post by GuyTreepbush »
I do not have such complicated setup for Synology to keep the service running (yet). I found that if I kick of the service in debug mode it keeps running when I close the ssh session.
Drawback is that when the Synology Goes down the service needs to be restarted.
Debug mode is described somewhere in this forum thread.
EdwinK
Post by EdwinK »
Going to try that. Thanx
Same problem :(
jjnj
Post by jjnj »
two Domoticz temp graph results into an error where domoboard tries to merge values:
[history]
  [[display_components]]
    components = domoticz_temp_charts[Woonkamer], domoticz_temp_charts[Buiten]
	[[domoticz_temp_charts]]
	[[[Woonkamer]]]
		Woonkamer = 1025, month, temp
	[[[Buiten]]]
		Buiten = 1036, month, temp
Also is it possible to disable the percentage pop-up for the sliders? I'm touching on the percentage of the slider below the slider i want to change
miljume
Domoticz version: v3.8742
Post by miljume »
I have a problem with the sync between Domoticz and Domoboard
If I change a switch in Domoticz GUI it doesn't change in Domoboard dashboard
The opposite works perferctly fine
Any clues?
Trigun
Domoticz version: 4.10717
Post by Trigun »
jjnj wrote:two Domoticz temp graph results into an error where domoboard tries to merge values:
[history]
	[[[Woonkamer]]]
	[[[Buiten]]]
Hi jjnj,
i got the same error with two of the same graphs on the same page. unfortunately there is, as squandor mentioned, no solution for this at the moment. a new version might be on its way which might have the solution to combine graphs, which might do the trick. I am also really looking forward having this possibility. anyway way big thanks for the team for considering this as a possible new feature.
Cheers
squandor
Post by squandor »
miljume wrote:Hello,
Any clues?
Hi Miljume,
It could take a moment for the buttons to change. We used an timer to update the buttons because we didn't want to blow up the domoticz server by unlimited pulls ;)
miljume
Post by miljume »
Any clues?
Hi Miljume,
Thanks but something strange is going on,the swith is always going back to "On" when i refresh the page in Domoboard even if the connected switch in Domoticz is "Off"
If I change the swithc to "Off" again in Domoboard and refresh the page it reverts back to "On" immediately
The sync between Domoticz to Domoboard must be broken, no matter how long I wait the swith stays in "On" position in DOmoboard
squandor
Post by squandor »
Any clues?
Hi Miljume,
And did you get an error in the console.log?
miljume
Post by miljume »
squandor wrote:
miljume wrote:
squandor wrote: Hi Miljume,
Sorry but where do I find console.log?
squandor
Post by squandor »
In chrome you can use right mouse click on the page and then choose inspect
miljume
Post by miljume »
squandor wrote:
miljume wrote:
squandor wrote: And did you get an error in the console.log?
OK, seems to have an error there
Uncaught TypeError: Cannot read property '0' of undefined
    at domoboard.js:93
    at Object.success (domoboard.js:9)
    at i (jquery-3.1.0.min.js:2)
    at Object.fireWith [as resolveWith] (jquery-3.1.0.min.js:2)
    at A (jquery-3.1.0.min.js:4)
    at XMLHttpRequest.<anonymous> (jquery-3.1.0.min.js:4)
Keeps popping up with a regular frequency
squandor
Post by squandor »
    at domoboard.js:93
well that's you're problem but the question is where is it coming from. It seems that you're connection between domoboard en domoticz isn't flaweless. Do you have authentication enabled in domoticz?
miljume
Post by miljume »
Yes, I have authentication enabled but not for local IP adresses and the Domoboard is on the same RPI so that shouldnt be the problem
I did a git pull from the development branch so I am on the latest development version
squandor
Post by squandor »
miljume wrote:Yes, I have authentication enabled but not for local IP adresses and the Domoboard is on the same RPI so that shouldnt be the problem
Could you send the [general_settings] part of the config so we can see if the problem is in there.
miljume
Post by miljume »
Sure, see below
I guess the username/password part for Domoticz isn't needed when I have excluded login for local IP's?
[general_settings]
  [[server]]
    url = 192.168.0.51:8081			# IP-address of Domoticz backend
    flask_url = 192.168.0.51:8090		# Please note: this is the internal IP-address including port of the Domoboard server
    user = username			# Username for Domoticz (if required)
    password = password			# Password for Domoticz (if required)
    secret_key = <secret key> # A random secret key used for Python authentication. Change to anything random.
  [[users]]
    user1 = password1			# Add users for Domoboard here. In this case login with username "username" and password "password"
    user2 = password2
  [[domoboard]]
    time = True			# True/False: show time in top bar
    date = True			# True/False: show date in top bar
    language = "sv"			# Change this to display date/time in local language and format
    #google_maps_api_key = <api key>		# Google Maps Embed API key
    autologon = True       # True/False: enable autologon
  [[wunderground]]
  	api = <api key>
  	language = en
squandor
Post by squandor »
Sure, see below
[general_settings]
  [[server]]
  [[users]]
    user2 = password2
  [[domoboard]]
  [[wunderground]]
  	api = <api key>
  	language = en
you could try that to make sure that it's not needed and also set something in the secret key to make sure that all the possibility's are filled in. beside that you could try to set the url to url = 127.0.0.1:8081
