Page 27 of 27
Re: Siri / HomeKit support for Domoticz
Posted: Monday 15 May 2017 17:58
by mrmmc
hellou!
dummy newbie try install homebridge...
i try read all topics but no same error found :
can somebody help ?
"one@jone-HP-ProBook-6360b:~/homebridge$ npm install
npm WARN engine [email protected]: wanted: {"node":">=4.3.2"} (current: {"node":"0.10.25","npm":"1.4.21"})
> [email protected] install /home/jone/homebridge/node_modules/hap-nodejs/node_modules/curve25519-n2
> node-gyp rebuild
/bin/sh: 1: node: not found
gyp: Call to 'node -e "require('nan')"' returned exit status 127. while trying to load binding.gyp
gyp ERR! configure error
gyp ERR! stack Error: `gyp` failed with exit code: 1
gyp ERR! stack at ChildProcess.onCpExit (/usr/share/node-gyp/lib/configure.js:344:16)
gyp ERR! stack at ChildProcess.EventEmitter.emit (events.js:98:17)
gyp ERR! stack at Process.ChildProcess._handle.onexit (child_process.js:797:12)
gyp ERR! System Linux 4.2.0-42-generic
gyp ERR! command "nodejs" "/usr/bin/node-gyp" "rebuild"
gyp ERR! cwd /home/jone/homebridge/node_modules/hap-nodejs/node_modules/curve25519-n2
gyp ERR! node -v v0.10.25
gyp ERR! node-gyp -v v0.12.2
gyp ERR! not ok
npm WARN This failure might be due to the use of legacy binary "node"
npm WARN For further explanations, please read
/usr/share/doc/nodejs/README.Debian
> [email protected] install /home/jone/homebridge/node_modules/hap-nodejs/node_modules/mdns
> node-gyp rebuild
node.js:811
var cwd = process.cwd();
Error: ENOENT, no such file or directory
at Function.startup.resolveArgv0 (node.js:811:23)
at startup (node.js:58:13)
at node.js:902:3
npm ERR! [email protected] install: `node-gyp rebuild`
npm ERR! Exit status 1
npm ERR!
npm ERR! Failed at the [email protected] install script.
npm ERR! This is most likely a problem with the curve25519-n2 package,
npm ERR! not with npm itself.
npm ERR! Tell the author that this fails on your system:
npm ERR! node-gyp rebuild
npm ERR! You can get their info via:
npm ERR! npm owner ls curve25519-n2
npm ERR! There is likely additional logging output above.
npm ERR! System Linux 4.2.0-42-generic
npm ERR! command "/usr/bin/nodejs" "/usr/bin/npm" "install"
npm ERR! cwd /home/jone/homebridge
npm ERR! node -v v0.10.25
npm ERR! npm -v 1.4.21
npm ERR! code ELIFECYCLE
> [email protected] install /home/jone/homebridge/node_modules/hap-nodejs/node_modules/ed25519
> node-gyp rebuild
chdir(): No such file or directory
what i do wrong?
Posted: Thursday 08 June 2017 19:01
by theo69
My homebridge was working great, after reboot my iPhone is not connecting anymore. Homebridge is running fine! Any ideas?
Posted: Sunday 18 June 2017 10:09
by Jorgerui74
I know that is a fairly simples question, but that I don't know the answer.
I have one of does cheap door (open close) sensors, If you don't bother answer this; what type you choose on domoticz? I can't manage to make it work. In domoticz the sensor works fine, and passes the information to homebridge through edomoticz. But on EVE app the status does not reflect the state.
I have it know as a door lock sensor on domoticz, but even that seem wrong on EVE app, as it shows me a switch to lock/unlock the door, nevertheless that switch never changes it state, as prior said, the state on changes in domoticz.
I think this is something related with bad configuration in domoticz.
Issue above resolved using a contact type on Domoticz
Other question that I have, if you could be so kind to answer one more doubt, is: how can I add my songs speaker to my current configuration? I have know something like this:
    "bridge": {
        "name": "Homebridge",
        "username": "CC:21:3E:E4:DE:33",
        "port": 51826,
        "pin": "031-45-154"
    "description": "Configuration file for (e)xtended Domoticz platform.",
    "platforms": [
            "platform": "eDomoticz",
            "name": "eDomoticz",
            "server": "127.0.0.1",
            "port": "8080",
            "ssl": 0,
            "roomid": 0,
            "mqtt": 0
    "accessories": []
Is almost the same thing that you have.
Posted: Tuesday 05 September 2017 8:45
by tillo
Hi I have the same problem as mrmmc
hellou!
can somebody help ?
> node-gyp rebuild
gyp ERR! not ok
> node-gyp rebuild
node.js:811
at node.js:902:3
npm ERR!
> node-gyp rebuild
what i do wrong?
Posted: Thursday 07 September 2017 9:52
by gielie
theo69 wrote: Thursday 08 June 2017 19:01 My homebridge was working great, after reboot my iPhone is not connecting anymore. Homebridge is running fine! Any ideas?
I have the same problem, Homebridge had been working great for some time now and suddenly it stopped working on my phone. When i check my pi with domoticz on it, it runs fine without any errors i just cant connect with my phone again.
Im gonna try to reinstall this weekend.
Posted: Monday 11 September 2017 22:39
by theo69
gielie wrote: Thursday 07 September 2017 9:52
mine working great since 2 month now
Posted: Tuesday 12 September 2017 11:43
by solidum90
Hello to everyone,
I'm delighted to use this great plugin ;)
Now i'm "studing" a way to command Siri from anywhere in the home, did you find any way (for example Sonos speakers, etc..) ?
Because probably no bluetooth speaker I currently have (Aukey, TaoTronics, amazon stuff ..) it's compatible with Siri,
but even if they had been, I would never have managed to control Siri from any room.
I was thinking to byuy a smartwatch that coupled to my iphone would allow me to extend Siri, do you know someone cheap enough (50-100 €)?
According to you is a good solution?
Thanks to everyone :)
Posted: Saturday 09 December 2017 20:37
by vespino
Anyone have this running on a synology diskstation? I got it running on a RPI a few months ago, but why keep those things around when "we have an app for that"?
Posted: Saturday 09 December 2017 21:47
by febalci
Using homebridge on synology 916+ as a docker container successfully since 6 months without problems.
Posted: Sunday 10 December 2017 6:55
by vespino
I would like to do it without using docker. Is that possible?
Posted: Sunday 10 December 2017 10:27
by febalci
I was unsuccessful trying that on synology thats why i am usşng docker.
