Siri / HomeKit support for Domoticz
mrmmc
Domoticz version: 3.7450
Re: Siri / HomeKit support for Domoticz
Post by mrmmc »
hellou!
dummy newbie try install homebridge...
i try read all topics but no same error found :
can somebody help ?
"one@jone-HP-ProBook-6360b:~/homebridge$ npm install
npm WARN engine [email protected]: wanted: {"node":">=4.3.2"} (current: {"node":"0.10.25","npm":"1.4.21"})
> [email protected] install /home/jone/homebridge/node_modules/hap-nodejs/node_modules/curve25519-n2
> node-gyp rebuild
/bin/sh: 1: node: not found
gyp: Call to 'node -e "require('nan')"' returned exit status 127. while trying to load binding.gyp
gyp ERR! configure error
gyp ERR! stack Error: `gyp` failed with exit code: 1
gyp ERR! stack at ChildProcess.onCpExit (/usr/share/node-gyp/lib/configure.js:344:16)
gyp ERR! stack at ChildProcess.EventEmitter.emit (events.js:98:17)
gyp ERR! stack at Process.ChildProcess._handle.onexit (child_process.js:797:12)
gyp ERR! System Linux 4.2.0-42-generic
gyp ERR! command "nodejs" "/usr/bin/node-gyp" "rebuild"
gyp ERR! cwd /home/jone/homebridge/node_modules/hap-nodejs/node_modules/curve25519-n2
gyp ERR! node -v v0.10.25
gyp ERR! node-gyp -v v0.12.2
gyp ERR! not ok
npm WARN This failure might be due to the use of legacy binary "node"
npm WARN For further explanations, please read
/usr/share/doc/nodejs/README.Debian
> [email protected] install /home/jone/homebridge/node_modules/hap-nodejs/node_modules/mdns
> node-gyp rebuild
node.js:811
var cwd = process.cwd();
Error: ENOENT, no such file or directory
at Function.startup.resolveArgv0 (node.js:811:23)
at startup (node.js:58:13)
at node.js:902:3
npm ERR! [email protected] install: `node-gyp rebuild`
npm ERR! Exit status 1
npm ERR!
npm ERR! Failed at the [email protected] install script.
npm ERR! This is most likely a problem with the curve25519-n2 package,
npm ERR! not with npm itself.
npm ERR! Tell the author that this fails on your system:
npm ERR! node-gyp rebuild
npm ERR! You can get their info via:
npm ERR! npm owner ls curve25519-n2
npm ERR! There is likely additional logging output above.
npm ERR! System Linux 4.2.0-42-generic
npm ERR! command "/usr/bin/nodejs" "/usr/bin/npm" "install"
npm ERR! cwd /home/jone/homebridge
npm ERR! node -v v0.10.25
npm ERR! npm -v 1.4.21
npm ERR! code ELIFECYCLE
> [email protected] install /home/jone/homebridge/node_modules/hap-nodejs/node_modules/ed25519
> node-gyp rebuild
chdir(): No such file or directory
what i do wrong?
theo69
Domoticz version: la. beta
Post by theo69 »
My homebridge was working great, after reboot my iPhone is not connecting anymore. Homebridge is running fine! Any ideas?
Love my Xiaomi Gateway in connection with homebridge and domoticz on my PI3
Xiaomi Gateway Domoticz Wiki
Jorgerui74
Post by Jorgerui74 »
I know that is a fairly simples question, but that I don't know the answer.
I have one of does cheap door (open close) sensors, If you don't bother answer this; what type you choose on domoticz? I can't manage to make it work. In domoticz the sensor works fine, and passes the information to homebridge through edomoticz. But on EVE app the status does not reflect the state.
I have it know as a door lock sensor on domoticz, but even that seem wrong on EVE app, as it shows me a switch to lock/unlock the door, nevertheless that switch never changes it state, as prior said, the state on changes in domoticz.
I think this is something related with bad configuration in domoticz.
Issue above resolved using a contact type on Domoticz
Other question that I have, if you could be so kind to answer one more doubt, is: how can I add my songs speaker to my current configuration? I have know something like this:
    "bridge": {
        "name": "Homebridge",
        "username": "CC:21:3E:E4:DE:33",
        "port": 51826,
        "pin": "031-45-154"
    "description": "Configuration file for (e)xtended Domoticz platform.",
    "platforms": [
            "platform": "eDomoticz",
            "name": "eDomoticz",
            "server": "127.0.0.1",
            "port": "8080",
            "ssl": 0,
            "roomid": 0,
            "mqtt": 0
    "accessories": []
Is almost the same thing that you have.
tillo
Post by tillo »
Hi I have the same problem as mrmmc
hellou!
can somebody help ?
> node-gyp rebuild
gyp ERR! not ok
> node-gyp rebuild
node.js:811
at node.js:902:3
npm ERR!
> node-gyp rebuild
what i do wrong?
gielie
Domoticz version: latest β
Post by gielie »
theo69 wrote: Thursday 08 June 2017 19:01 My homebridge was working great, after reboot my iPhone is not connecting anymore. Homebridge is running fine! Any ideas?
I have the same problem, Homebridge had been working great for some time now and suddenly it stopped working on my phone. When i check my pi with domoticz on it, it runs fine without any errors i just cant connect with my phone again.
Im gonna try to reinstall this weekend.
- Aeotec MultiSensor 6
- FIBARO FGS223
- FIBARO FGWPE Wall Plug
- Neo CoolCam Power plug
- Popp Smoke Detector
- Toon
- Kodi Media Server
theo69
Post by theo69 »
gielie wrote: Thursday 07 September 2017 9:52
mine working great since 2 month now
solidum90
Domoticz version: Debian
Post by solidum90 »
Hello to everyone,
I'm delighted to use this great plugin ;)
Now i'm "studing" a way to command Siri from anywhere in the home, did you find any way (for example Sonos speakers, etc..) ?
Because probably no bluetooth speaker I currently have (Aukey, TaoTronics, amazon stuff ..) it's compatible with Siri,
but even if they had been, I would never have managed to control Siri from any room.
I was thinking to byuy a smartwatch that coupled to my iphone would allow me to extend Siri, do you know someone cheap enough (50-100 €)?
According to you is a good solution?
Thanks to everyone :)
vespino
Post by vespino »
Anyone have this running on a synology diskstation? I got it running on a RPI a few months ago, but why keep those things around when "we have an app for that"?
febalci
Post by febalci »
Using homebridge on synology 916+ as a docker container successfully since 6 months without problems.
vespino
Post by vespino »
I would like to do it without using docker. Is that possible?
febalci
Post by febalci »
I was unsuccessful trying that on synology thats why i am usşng docker.
