Page 27 of 36
Re: machinon theme
Posted: Thursday 23 May 2019 1:21
by Bidibulle
It possible to add option for change date format dd-mm-yyyy ?
thanks ;)
Re: machinon theme
Posted: Thursday 23 May 2019 1:34
by Bidibulle
Hi #2 :D
In Settings\Custom Icons browse button to add zip file is missing.
Domoticz Version: 4.10810 - Build Hash: 315b45b6
theme V.1.9.0
Re: machinon theme
Posted: Thursday 23 May 2019 12:32
by DewGew
Bidibulle wrote: Thursday 23 May 2019 1:34 Hi #2 :D
theme V.1.9.0
Fixed in latest version
Re: machinon theme
Posted: Thursday 23 May 2019 13:08
by Bidibulle
DewGew wrote: Thursday 23 May 2019 12:32
theme V.1.9.0
It's Ok after update and clear cache.
Re: machinon theme
Posted: Thursday 23 May 2019 14:14
by quirk
Bidibulle wrote: Thursday 23 May 2019 1:21 Hi
thanks ;)
Hi Bidibulle,
Update to the last beta version, it should now display last update date according to your domoticz locale.
David
Re: machinon theme
Posted: Tuesday 04 June 2019 12:54
by quirk
New version of machinon available v1.9.5:
  • Bug fixes (mostly related to Firefox)
  • Use Ionicons for sharp icons
https://github.com/EdddieN/machinon-dom ... tag/v1.9.5
Re: machinon theme
Posted: Wednesday 05 June 2019 13:22
by plaaggeest
Thanks for all the great work on building the theme, I am a silent user and fan of the theme.
I would like to bring 1 'bug' to the attention. Not sure if this is the right place and the bug is due to the theme styling, but ill give it a go.
Today's wind is SW. So the wind is coming from the South West. The wind metric has the correct data but the wind arrow is opposite. Is this a bug of the theme or from domoticz?
Wrong:
Good:
Re: machinon theme
Posted: Wednesday 05 June 2019 13:29
by gajotnt
South is down, west is left... dont get why you think domoticz is wrong.
The wind is coming from that direction.
Re: machinon theme
Posted: Wednesday 05 June 2019 13:59
by plaaggeest
gajotnt wrote: Wednesday 05 June 2019 13:29 South is down, west is left... dont get why you think domoticz is wrong.
Indeed, the wind is coming from that direction.
Going from 'down left' to 'up right', so in this case if you use an arrow for wind. The arrow should be in the direction were the wind is going and not were the wind is coming from.
Re: machinon theme
Posted: Wednesday 05 June 2019 14:06
by gajotnt
It is showing were the wind is coming from, its not a bug, some sites show were its coming from, others show were it's going.
Re: machinon theme
Posted: Friday 07 June 2019 10:11
by quirk
Hey,
It's an interesting question and a question of point of view : it depends if we represent where the wind comes from or if it's the wind direction.
Domoticz by default show wind origin but it would be cool to have an option to show wind direction (like a weathercock) as it's finally a more usual way to display it. I created a request feature in machinon theme github --> https://github.com/EdddieN/machinon-dom ... issues/281
David
Re: machinon theme
Posted: Sunday 18 August 2019 9:58
by FearNaBoinne
gajotnt wrote: Wednesday 05 June 2019 14:06 It is showing were the wind is coming from, its not a bug, some sites show were its coming from, others show were it's going.
I'm not trying to start a debate, or tell you you're wrong, just curious: which sites (aside from Domoticz) show the wind origin with an arrow?
Every single site I know of shows wind origin as a text, and the wind direction (ie where it is going) as the arrow...
Re: machinon theme
Posted: Tuesday 20 August 2019 14:38
by DewGew
Additional Custom Icons Machinon style
Re: machinon theme
Posted: Tuesday 20 August 2019 14:40
by DewGew
More Additional Custom Icons Machinon Style
Re: machinon theme
Posted: Wednesday 21 August 2019 14:35
by EdddieN
I’m also very silent lately but enjoying the updates! Thank you all guys for the great work!
Re: machinon theme
Posted: Thursday 22 August 2019 16:37
by RobbieT
I've downloaded the files from github and placed this in styles/machinon. However after a reboot Domoticz can't find the theme. What am i doing wrong?
Domoticz is running docker with all the config filles mapped to /config. So I placed the theme inside /config/www/styles and cleared my cache.
Re: machinon theme
Posted: Sunday 08 September 2019 10:10
by lzwfkv
quirk wrote: Friday 07 June 2019 10:11 Hey,
David
I personally prefer the arrows to indicate the Wind source (where it comes from) when "arrows" icons are used for Wind.
For whom has my same preferences, it is simple to implement: just replace the "Wind*" icons in Machinon's images folder with the attached ones (same as the original ones with inverted arrow heads though, you can do them yourself if you dont like my changes):
  • Download the Wind-icons.zip
  • Unzip the archive
  • on Domoticz server, move to <Domoticz path>/www/styles/machinon/images folder, make a backup of the Wind*.png files in there if you want to preserve the originial Wind icons
  • copy the downloaded Wind*.png files to overwite/replace the original Wind*.png files.
Wind-icons.zip
(51.92 KiB) Downloaded 79 times
Re: machinon theme
Posted: Friday 13 September 2019 20:51
by SteGe
hi all, hopefully you could help me out, because I've searched for it but couldn't find anything.
I have installed this theme on my domoticz installation running on synology. If I go to the domoticz instance directly based on IP and port number the theme is running fine! But when I try to reach it outside the network via a reverse proxy this isn't working.
Is there something I could do to solve this?
Re: machinon theme
Posted: Friday 11 October 2019 23:15
by Bidibulle
Hello
To put on 2 lines the title of some devices I use the tag <br>.
It works in Dashboard, Switches, Scenes and Utility.
Is it possible to make the changes to make it work in Foorplan, Temperature and Weather??
Thank you ;)
Re: machinon theme
Posted: Monday 18 November 2019 15:38
by DewGew
Christmas is comming and Machinon xmas edition 2019 is out
Update your machinon (keeps your settings):
cd domoticz/www/styles/Machinon
git pull
git checkout xMasEdition2019
Install:
git clone https://github.com/EdddieN/machinon-domoticz_theme Machinon
cd Machinon
Then activate xmas theme in theme settings. Snowfall is always showing in standby.
Go back to normal:
cd domoticz/styles/Machinon
git checkout master (or beta)
