Bidibulle
Domoticz version: 2025.1
Re: machinon theme
Post by Bidibulle »
It possible to add option for change date format dd-mm-yyyy ?
thanks ;)
Bidibulle
Re: machinon theme
Post by Bidibulle »
Hi #2 :D
In Settings\Custom Icons browse button to add zip file is missing.
Domoticz Version: 4.10810 - Build Hash: 315b45b6
theme V.1.9.0
DewGew
Domoticz version: V4.10618
Re: machinon theme
Post by DewGew »
Bidibulle wrote: Thursday 23 May 2019 1:34 Hi #2 :D
theme V.1.9.0
Fixed in latest version
Bidibulle
Re: machinon theme
Post by Bidibulle »
DewGew wrote: Thursday 23 May 2019 12:32
theme V.1.9.0
It's Ok after update and clear cache.
quirk
Re: machinon theme
Post by quirk »
Bidibulle wrote: Thursday 23 May 2019 1:21 Hi
thanks ;)
Hi Bidibulle,
Update to the last beta version, it should now display last update date according to your domoticz locale.
David
quirk
Re: machinon theme
Post by quirk »
New version of machinon available v1.9.5:
  • Bug fixes (mostly related to Firefox)
  • Use Ionicons for sharp icons
https://github.com/EdddieN/machinon-dom ... tag/v1.9.5
plaaggeest
Re: machinon theme
Post by plaaggeest »
Thanks for all the great work on building the theme, I am a silent user and fan of the theme.
I would like to bring 1 'bug' to the attention. Not sure if this is the right place and the bug is due to the theme styling, but ill give it a go.
Today's wind is SW. So the wind is coming from the South West. The wind metric has the correct data but the wind arrow is opposite. Is this a bug of the theme or from domoticz?
Wrong:
Good:
gajotnt
Domoticz version: V4.9700
Re: machinon theme
Post by gajotnt »
South is down, west is left... dont get why you think domoticz is wrong.
The wind is coming from that direction.
plaaggeest
Re: machinon theme
gajotnt wrote: Wednesday 05 June 2019 13:29 South is down, west is left... dont get why you think domoticz is wrong.
Indeed, the wind is coming from that direction.
Going from 'down left' to 'up right', so in this case if you use an arrow for wind. The arrow should be in the direction were the wind is going and not were the wind is coming from.
gajotnt
Re: machinon theme
Post by gajotnt »
It is showing were the wind is coming from, its not a bug, some sites show were its coming from, others show were it's going.
quirk
Re: machinon theme
Post by quirk »
Hey,
It's an interesting question and a question of point of view : it depends if we represent where the wind comes from or if it's the wind direction.
Domoticz by default show wind origin but it would be cool to have an option to show wind direction (like a weathercock) as it's finally a more usual way to display it. I created a request feature in machinon theme github --> https://github.com/EdddieN/machinon-dom ... issues/281
David
FearNaBoinne
Domoticz version: 2021.1
Re: machinon theme
Post by FearNaBoinne »
gajotnt wrote: Wednesday 05 June 2019 14:06 It is showing were the wind is coming from, its not a bug, some sites show were its coming from, others show were it's going.
I'm not trying to start a debate, or tell you you're wrong, just curious: which sites (aside from Domoticz) show the wind origin with an arrow?
Every single site I know of shows wind origin as a text, and the wind direction (ie where it is going) as the arrow...
RasPi, Raspbian , Domoticz v2021.1, Z-Wave Stick, RFLink, RFXtrx433e, Hue, Tuya (Tasmota/Mosquitto with Discovery), ESP(easy), MySensors.org, OTGW
DewGew
Re: machinon theme
Post by DewGew »
Additional Custom Icons Machinon style
Machinon_Bed.zip
(6.1 KiB) Downloaded 130 times
Machinon_Aquarium.zip
(9.02 KiB) Downloaded 134 times
Domoticz_Cast.zip
(3.42 KiB) Downloaded 143 times
DewGew
Re: machinon theme
Post by DewGew »
More Additional Custom Icons Machinon Style
Machinon_OutdoorCamera.zip
(6.16 KiB) Downloaded 142 times
Machinon_Jacuzzi.zip
(8.06 KiB) Downloaded 121 times
Machinon_Duck.zip
(8.33 KiB) Downloaded 147 times
EdddieN
Domoticz version: 4.9700
Re: machinon theme
Post by EdddieN »
I’m also very silent lately but enjoying the updates! Thank you all guys for the great work!
11101101 - www.machinon.com
RobbieT
Re: machinon theme
Post by RobbieT »
I've downloaded the files from github and placed this in styles/machinon. However after a reboot Domoticz can't find the theme. What am i doing wrong?
Domoticz is running docker with all the config filles mapped to /config. So I placed the theme inside /config/www/styles and cleared my cache.
lzwfkv
Re: machinon theme
Post by lzwfkv »
quirk wrote: Friday 07 June 2019 10:11 Hey,
David
I personally prefer the arrows to indicate the Wind source (where it comes from) when "arrows" icons are used for Wind.
For whom has my same preferences, it is simple to implement: just replace the "Wind*" icons in Machinon's images folder with the attached ones (same as the original ones with inverted arrow heads though, you can do them yourself if you dont like my changes):
  • Download the Wind-icons.zip
  • Unzip the archive
  • on Domoticz server, move to <Domoticz path>/www/styles/machinon/images folder, make a backup of the Wind*.png files in there if you want to preserve the originial Wind icons
  • copy the downloaded Wind*.png files to overwite/replace the original Wind*.png files.
Wind-icons.zip
(51.92 KiB) Downloaded 110 times
SteGe
Re: machinon theme
Post by SteGe »
hi all, hopefully you could help me out, because I've searched for it but couldn't find anything.
I have installed this theme on my domoticz installation running on synology. If I go to the domoticz instance directly based on IP and port number the theme is running fine! But when I try to reach it outside the network via a reverse proxy this isn't working.
Is there something I could do to solve this?
Synology DS3615xs | Raspberry pi 3b |
RFXtrx433E | MySensors | Z-wave | Philips Hue | Ikea Tradfri |
Sunscreen | Power switches | Toon | Harmony | UE Smartradio |
Weatherstation | Doorbell | Letterbox reader | Lux | Temp | Humidity | Motion |
Bidibulle
Re: machinon theme
Post by Bidibulle »
Hello
To put on 2 lines the title of some devices I use the tag <br>.
It works in Dashboard, Switches, Scenes and Utility.
Is it possible to make the changes to make it work in Foorplan, Temperature and Weather??
Thank you ;)
DewGew
Re: machinon theme
Post by DewGew »
Christmas is comming and Machinon xmas edition 2019 is out
Update your machinon (keeps your settings):
cd domoticz/www/styles/Machinon
git pull
git checkout xMasEdition2019
Install:
git clone https://github.com/EdddieN/machinon-domoticz_theme Machinon
cd Machinon
Then activate xmas theme in theme settings. Snowfall is always showing in standby.
Go back to normal:
cd domoticz/styles/Machinon
git checkout master (or beta)
