Page 27 of 184
Re: New Dashboard Design v2, custom positioning and multiple screens
Posted: Sunday 09 April 2017 10:51
by Bob123bob
Bob123bob wrote:I have an issue when I want to only display energy now in Watt. I use the idx_1 (e.g. '147_1') but I have a empty box follow by today and total. idx_2 for today and idx_3 for total are working fine. When I use 147 without sub value, I can see the 3 boxes working fine.
Can you help me to display only energy now ?
In the first line in the picture I just added device idx 167 in config and it display 3 devices (now, today, total)
The 3rd line I added 167_1, 167_2, 167_3 in the config
But as you can see 167_1 (now) is not working :(
Here is one of the device (Aeotec DSB28 Home Energy Meter)
         "AddjMulti" : 1.0,
         "AddjMulti2" : 1.0,
         "AddjValue" : 0.0,
         "AddjValue2" : 0.0,
         "BatteryLevel" : 255,
         "CounterToday" : "4.250 kWh",
         "CustomImage" : 0,
         "Data" : "10945.601 kWh",
         "Description" : "",
         "Favorite" : 0,
         "HardwareID" : 6,
         "HardwareName" : "Aeon Stick S2",
         "HardwareTypeVal" : 21,
         "HaveTimeout" : false,
         "ID" : "00001D01",
         "LastUpdate" : "2017-04-09 08:39:45",
         "Name" : "EDF 2P",
         "Notifications" : "false",
         "Options" : "0",
         "PlanID" : "0",
         "PlanIDs" : [ 0 ],
         "Protected" : false,
         "ShowNotifications" : true,
         "SignalLevel" : "-",
         "SubType" : "kWh",
         "SwitchTypeVal" : 0,
         "Timers" : "false",
         "Type" : "General",
         "TypeImg" : "current",
         "Unit" : 1,
         "Usage" : "140.0 Watt",
         "Used" : 1,
         "XOffset" : "0",
         "YOffset" : "0",
         "idx" : "167"
Posted: Sunday 09 April 2017 11:06
by maluko
hi
testing open with external ddns adress on other internet conection and seens to be open for anyone.
thabks
Posted: Sunday 09 April 2017 11:28
by SuperMouse
I tried this very nice Dashboard yesterday with almost 100% success.
I just can not get the 'weather' and 'currentweather' working, and this was really the part I wanted to have :(
Offcourse I have a vaild Wunderground API key
var _APIKEY_WUNDERGROUND   		= 'fbe1******2567';
var _WEATHER_CITY          		= 'Maassluis';
var _WEATHER_COUNTRY       		= 'NL';
Anyone an idea?
Posted: Sunday 09 April 2017 11:51
by maluko
I have x10 blinds but seems to be inverted on dashboard botton, the image its ok but the command arent, so when i click down the blind will open and appear the blind on botton open, must be click up and will open and appear the blind image open
EDIT: Sorry, blinds fixed on last update.
AddjMulti: 1,
AddjMulti2: 1,
AddjValue: 0,
AddjValue2: 0,
BatteryLevel: 255,
CustomImage: 0,
Data: "Open",
Description: "",
Favorite: 0,
HardwareID: 3,
HardwareName: "Slave X10- HDD",
HardwareType: "Domoticz - Remote Server",
HardwareTypeVal: 3,
HaveDimmer: false,
HaveGroupCmd: true,
HaveTimeout: false,
Image: "Light",
IsSubDevice: false,
LastUpdate: "2017-04-09 09:49:14",
Level: 0,
LevelInt: 0,
MaxDimLevel: 0,
Name: "Persiana Cozinha",
Notifications: "true",
PlanID: "0",
PlanIDs: [
0
Protected: false,
ShowNotifications: true,
SignalLevel: "-",
Status: "Open",
StrParam1: "",
StrParam2: "",
SubType: "X10",
SwitchType: "Blinds Inverted",
SwitchTypeVal: 6,
Timers: "false",
Type: "Lighting 1",
TypeImg: "blinds",
Unit: 5,
Used: 1,
UsedByCamera: false,
XOffset: "0",
YOffset: "0",
idx: "xx"
and the select botton dont work ether, can select the order but cant reach to domoticz.
AddjMulti: 1,
AddjMulti2: 1,
AddjValue: 5,
AddjValue2: 0,
BatteryLevel: 255,
CustomImage: 11,
Data: "Off",
Description: "",
Favorite: 1,
HardwareID: 4,
HardwareName: "Virtual",
HardwareType: "Dummy (Does nothing, use for virtual switches only)",
HardwareTypeVal: 15,
HaveDimmer: true,
HaveGroupCmd: true,
HaveTimeout: false,
Image: "Water",
IsSubDevice: false,
LastUpdate: "2017-04-09 10:00:44",
Level: 0,
LevelActions: "||||||",
LevelInt: 0,
LevelNames: "Off|OFF|5 Min|10 Min|15 Min|20 Min|Limpeza",
LevelOffHidden: true,
MaxDimLevel: 100,
Name: "Programa de rega",
Notifications: "false",
PlanID: "10",
PlanIDs: [
10
Protected: false,
SelectorStyle: 0,
SignalLevel: "-",
Status: "Off",
StrParam1: "",
StrParam2: "",
SubType: "Selector Switch",
SwitchType: "Selector",
SwitchTypeVal: 18,
Timers: "true",
Type: "Light/Switch",
TypeImg: "Light",
Unit: 1,
Used: 1,
XOffset: "0",
YOffset: "0",
idx: "xx"
thanks
Posted: Sunday 09 April 2017 12:17
by pvdhelm
[codevar _LANGUAGE = 'nl_NL'; //or en_US
var _HOST_DOMOTICZ = 'http://[ip domoticz server]:[port]';
//var _HOST_ZIGGO_HORIZON = ''; //e.g. http://192.168.1.3/domoticz/switch_horizon.php';
var _APIKEY_WUNDERGROUND = '7b2356fed42de50e';
var _WEATHER_CITY = 'Schijndel';
var _USE_AUTO_POSITIONING = false; //don't want to configure positions, use auto positioning
var _USE_FAVORITES = false; //only used when using auto positioning
var _HIDE_SECONDS_IN_CLOCK = false; //do not show the seconds in the clock
var _NEWS_RSSFEED = 'http://www.nu.nl/rss/algemeen';
var buttons = {}
buttons.buienradar = {width:12, isimage:true, image: 'http://api.buienradar.nl/image/1.0/Rada ... =285&h=256', url: 'http://www.weer.nl/verwachting/nederlan ... l/1810170/'}
buttons.nunl = {width:12, icon: 'fa-newspaper-o', title: 'Nieuws', url: 'http://www.nu.nl'}
CUSTOM POSITIONING:
//defining wich blocks to show, de numbers represents the IDX of the device in Domoticz
//only define if you want to use a custom width instead of the default
var blocks = {}
//defining number of columns, their contents en widths
//width can be a number 1 to 12, but total widths of all columns should always be 12
var columns = {}
columns[1] = {}
columns[1]['blocks'] = [83,84]
columns[1]['width'] = 5;
columns[2] = {}
columns[2]['blocks'] = ['currentweather_big','weather']
columns[2]['width'] = 5;
columns[3] = {}
columns[3]['blocks'] = ['clock','sunrise',buttons.buienradar,buttons.radio,buttons.nunl]
columns[3]['width'] = 2;
//if you want to use multiple screens, use the code below:
var screens = {}
screens[1] = {}
screens[1]['background'] = 'bg1.jpg';
//screens[2] = {}
//screens[2]['background'] = 'bg3.jpg';
//screens[2]['columns'] = [4,5,6]
*/][/code]
in colum 1 i don't see my switches. get the idx of the domoticz device list. both are dimmers.
what goes wrong here?
tnx patrick
Posted: Sunday 09 April 2017 12:26
by maluko
pvdhelm wrote:[codevar _LANGUAGE = 'nl_NL'; //or en_US
var buttons = {}
CUSTOM POSITIONING:
var blocks = {}
var columns = {}
columns[1] = {}
columns[2] = {}
columns[3] = {}
var screens = {}
screens[1] = {}
//screens[2] = {}
*/][/code]
tnx patrick
you have to add the blocks indvidual each idx you want to add, like
var blocks = {}
blocks[83] = {}  //
blocks[83]['width'] = 3; //1 to 12, remove this line if you want to use the default (4)
blocks[84] = {} //t
blocks[84]['width'] = 3;
83 and 84 are the idx
Posted: Sunday 09 April 2017 12:31
by madrian
OMG. This project is growing very quickly. :P
Can you guys recommend me a mounting solution for my iPad on the wall?
Posted: Sunday 09 April 2017 12:33
by maluko
hpapagaj wrote:OMG. This project is growing very quickly. :P
search on lasts posts, i think sameone have bought what you want for 17€.
edit: viewtopic.php?f=8&t=16526&hilit=ipad+17&start=240
Posted: Sunday 09 April 2017 12:36
by koowee
pvdhelm wrote: in colum 1 i don't see my switches. get the idx of the domoticz device list. both are dimmers.
tnx patrick
You have commented the custom positioning part > remove /* and */ (also remove text CUSTOM POSITIONING or add // before it)
CUSTOM POSITIONING:
by pvm
Pvdhelm, can you remove the /* before 'custom positioning' ?
Posted: Sunday 09 April 2017 12:50
by pvdhelm
Ok i try now tnx for the quick answers
Posted: Sunday 09 April 2017 13:07
by pvdhelm
Tnx now it works
Posted: Sunday 09 April 2017 13:33
by SuperMouse
robgeerts wrote:Hold on, I'll check my wife's ipad 2..
Edit: Yes, same issue, will try to fix this asap!
Meanwhile...
GRAPHS ARE LIVE (BETA!!!)
Download latest version from gitlab.
Enter the follow key in the definitions: 'graph_IDX', if your graph in Domoticz is idx 150, use:
columns[2]['blocks'] = ['graph_150']
ATTENTION: Only tested it with my energy and gas from Toon Thermostat!
VERY VERY NICE !
Is there a way to change the height of the graph itself?
Then I can even add more graphs on my tablet.
Many thanks in advance.
Posted: Sunday 09 April 2017 19:20
by SuperMouse
SuperMouse wrote:Hi all,
Anyone an idea?
Never Mind,
I got it working from my tablet at home :mrgreen:
Posted: Sunday 09 April 2017 19:30
by rbisschops
Hi Rob,
Nice dashboard. Just started testing it.
I noticed a minor bug is the css.
At line 110: border-color: #FFFF; should be #FFF.
Keep up the good work!
Ralph
Posted: Sunday 09 April 2017 19:33
by rbisschops
Anyone an idea?
Never Mind,
Hi @supermouse Can you share the css you used, like your design.
Thx
Ralph
Posted: Sunday 09 April 2017 19:59
by EdwinK
Clemen wrote:
Paste your
columns[1]['blocks'] = [.......
Already send a copy of CONFIG.js to Rob, but here is the columns[1] block
columns[1] = {}
columns[1]['blocks'] = [1,2,6,7,84,91,'s1',51,99,53,55,56,57,58,59,60,62,63,95,97,98,96] //idx 101 = Setpoint
Posted: Sunday 09 April 2017 20:20
by mAiden88
EdKo66 wrote:
Clemen wrote:
Paste your
columns[1] = {}
There are no empty block titles?
Posted: Sunday 09 April 2017 20:25
by SuperMouse
@rbisschops
Sure Ralph
Actually it is just a different background:
http://imgur.com/a/Dx7zT
Change it in the config.js
var _BACKGROUND_IMAGE      		= 'background.jpg';
And I change line 495 from white into black in the CSS:
div.screen {
  -webkit-background-size: cover;
  -moz-background-size: cover;
  -o-background-size: cover;
  background-position: center;
  color: black;
Posted: Sunday 09 April 2017 20:56
by EdwinK
mAiden88 wrote:
EdKo66 wrote:
Clemen wrote:
Paste your
columns[1] = {}
blocks['blocktitle_1'] = {}
blocks['blocktitle_1']['title'] = 'Schakelaars';
But what I want is not a title there, but no block at all, so to save space on a smaller tablet (7")
