Page 26 of 37
Re: Nefit Easy™
Posted: Tuesday 27 September 2016 18:05
by geezerrr
felix63 wrote:Hi,
Trying to find an answer to a simple question. Went through the wiki/forum but couldn't find a clear answer.
If I connect a Nefit Easy to Domoticz what functionality do I get?
Can anyone give me some insights?
Cheers,
Lex
Here is printscreen from my Nefit functions in Domoticz
No devices
Posted: Thursday 29 September 2016 0:59
by felix63
Installed easy httpserver which is working.
If I call it in a browser:
http://192.168.178.50:3001/bridge/syste ... emPressure
I get a JSON response:
{"id":"/system/appliance/systemPressure","type":"floatValue","recordable":0,"writeable":0,"value":25.5,"unitOfMeasure":"bar","minValue":0,"maxValue":25}
If I check PM2 I get:
pi@domus:~$ pm2 info 0
Describing process with id 0 - name nefiteasyhttpserver
│ status │ online │
│ name │ nefiteasyhttpserver │
│ restarts │ 0 │
│ uptime │ 5m │
│ script path │ /home/pi/nefiteasyhttpserver.sh │
│ script args │ N/A │
│ error log path │ /home/pi/.pm2/logs/nefiteasyhttpserver-error-0.log │
│ out log path │ /home/pi/.pm2/logs/nefiteasyhttpserver-out-0.log │
│ pid path │ /home/pi/.pm2/pids/nefiteasyhttpserver-0.pid │
│ interpreter │ bash │
│ interpreter args │ N/A │
│ script id │ 0 │
│ exec cwd │ /home/pi │
│ exec mode │ fork_mode │
│ node.js version │ N/A │
│ watch & reload │ ✘ │
│ unstable restarts │ 0 │
│ created at │ 2016-09-28T21:06:38.300Z │
Add your own code metrics: http://bit.ly/code-metrics
Use `pm2 logs nefiteasyhttpserver [--lines 1000]` to display logs
Use `pm2 monit` to monitor CPU and Memory usage nefiteasyhttpserver
In domotica I have added Hardware of type Nefit:
15 Nefit Easy Ja Nefit Easy HTTP server over LAN interface 192.168.178.50 3001 Niet actief
But if I look at devices I see no new devices added.
What is going wrong? Can anyone help me out?
Running Domoticz V3.4834 on a Raspberry Pi 3
Thanks for your help!
Re: Nefit Easy™
Posted: Thursday 29 September 2016 8:58
by SweetPants
Are you sure your Nefit HTTP server is running? Process id = 0 sounds strange to me, this should be higher then 1. Can you check with ps command?
Re: Nefit Easy™
Posted: Thursday 29 September 2016 10:06
by felix63
I see all kinds..
<knip>
avahi 413 0.0 0.2 4008 2428 ? Ss 02:00 0:08 avahi-daemon: running [domus.local]
message+ 414 0.0 0.3 5616 3136 ? Ss 02:00 0:00 /usr/bin/dbus-daemon --system --address=systemd: --nofork --nopidfile --systemd-activation
mosquit+ 417 0.0 0.4 5432 3836 ? S 02:00 0:09 /usr/sbin/mosquitto -c /etc/mosquitto/mosquitto.conf
nobody 430 0.0 0.1 2292 1440 ? Ss 02:00 0:00 /usr/sbin/thd --daemon --triggers /etc/triggerhappy/triggers.d/ --socket /var/run/thd.socket --pidfile /var/run/t
avahi 440 0.0 0.0 3876 240 ? S 02:01 0:00 avahi-daemon: chroot helper
root 446 0.0 0.2 14892 2468 ? Sl 02:01 0:03 /usr/bin/monit -c /etc/monit/monitrc
pi 466 0.0 6.1 138336 58092 ? SNl 02:01 0:07 node-red
root 484 0.0 0.0 0 0 ? S< 02:01 0:00 [kworker/2:1H]
root 485 0.0 0.3 7156 3336 ? Ss 02:01 0:00 /sbin/wpa_supplicant -s -B -P /run/wpa_supplicant.wlan0.pid -i wlan0 -D nl80211,wext -c /etc/wpa_supplicant/wpa_s
root 491 0.0 0.0 0 0 ? S< 02:01 0:00 [kworker/0:1H]
root 494 0.0 0.2 32144 2832 ? Ssl 02:01 0:00 /usr/sbin/rsyslogd -n
root 501 0.0 0.5 35900 5204 ? Ssl 02:01 0:00 /usr/sbin/lightdm
root 615 0.0 2.7 111440 26336 tty7 Ssl+ 02:01 0:00 /usr/bin/X :0 -seat seat0 -auth /var/run/lightdm/root/:0 -nolisten tcp vt7 -novtswitch
root 624 0.0 0.0 0 0 ? S< 02:01 0:00 [kworker/u9:0]
root 625 0.0 0.0 0 0 ? S< 02:01 0:00 [hci0]
root 626 0.0 0.0 0 0 ? S< 02:01 0:00 [hci0]
root 627 0.0 0.0 2068 132 ? S 02:01 0:00 /usr/bin/hciattach /dev/serial1 bcm43xx 921600 noflow -
root 629 0.0 0.0 0 0 ? S< 02:01 0:00 [kworker/u9:2]
root 632 0.0 0.3 5008 3352 ? Ss 02:01 0:00 /usr/lib/bluetooth/bluetoothd
root 655 0.0 0.5 27912 5516 ? Sl 02:01 0:00 lightdm --session-child 17 20
lightdm 659 0.0 0.3 4976 3272 ? Ss 02:01 0:00 /lib/systemd/systemd --user
lightdm 663 0.0 0.1 7020 1412 ? S 02:01 0:00 (sd-pam)
lightdm 666 0.0 3.5 65248 33220 ? Ssl 02:01 0:07 /usr/sbin/lightdm-gtk-greeter
lightdm 691 0.0 0.1 3692 1488 ? S 02:01 0:00 /usr/bin/dbus-launch --autolaunch 3882d14b5e8d408bb132425829ac6413 --binary-syntax --close-stderr
lightdm 753 0.0 0.2 5492 2120 ? Ss 02:01 0:00 /usr/bin/dbus-daemon --fork --print-pid 5 --print-address 7 --session
root 754 0.0 0.1 2564 1724 ? Ss 02:01 0:01 /sbin/dhcpcd -q -w
lightdm 756 0.0 0.5 44428 4788 ? Sl 02:01 0:00 /usr/lib/at-spi2-core/at-spi-bus-launcher
root 757 0.0 0.4 7864 4392 ? Ss 02:01 0:00 /usr/sbin/sshd -D
lightdm 761 0.0 0.3 5492 2908 ? S 02:01 0:00 /usr/bin/dbus-daemon --config-file=/etc/at-spi2/accessibility.conf --nofork --print-address 3
lightdm 764 0.0 0.4 17616 4256 ? Sl 02:01 0:00 /usr/lib/at-spi2-core/at-spi2-registryd --use-gnome-session
root 812 0.0 0.3 7912 3228 ? S 02:01 0:00 sudo -u pi DEBUG=* /usr/local/bin/homebridge
root 835 0.0 0.1 4052 1752 tty1 Ss+ 02:01 0:00 /sbin/agetty --noclear tty1 linux
ntp 837 0.0 0.3 5776 3680 ? Ss 02:01 0:02 /usr/sbin/ntpd -p /var/run/ntpd.pid -g -c /var/lib/ntp/ntp.conf.dhcp -u 106:111
pi 847 0.0 0.3 4976 3268 ? Ss 02:01 0:00 /lib/systemd/systemd --user
pi 851 0.0 0.1 7020 1416 ? S 02:01 0:00 (sd-pam)
pi 860 0.0 3.6 140968 34800 ? Sl 02:01 0:05 homebridge
snmp 905 0.1 0.5 12992 5244 ? S 02:01 0:39 /usr/sbin/snmpd -Lsd -Lf /dev/null -u snmp -g snmp -I -smux mteTrigger mteTriggerConf -p /run/snmpd.pid
root 906 5.4 2.1 253092 20056 ? Ssl 02:01 26:28 /home/pi/domoticz/domoticz -daemon -www 8080 -daemon sslwww 443
root 1011 0.0 2.0 93176 19696 ? Ss 02:01 0:01 /usr/sbin/apache2 -k start
root 1027 0.0 0.4 9356 4100 ? S 02:01 0:00 lightdm --session-child 13 20
pi 1042 0.0 3.3 128860 31748 ? Ssl 02:01 0:04 PM2 v2.0.15: God Daemon (/home/pi/.pm2)
pi 1200 0.0 0.2 4620 2320 ? Ss 02:01 0:00 bash /home/pi/nefiteasyhttpserver.sh
pi 1201 0.0 3.6 130152 34428 ? Sl 02:01 0:26 node /usr/local/bin/easy-server --serial=XXX --access-key=XXX --password=XXX --port=3001
<knip>
Re: Nefit Easy™
Posted: Thursday 29 September 2016 10:18
by SweetPants
Hmm, the PID of the easy-server is 1201 not 0 as pm2 is telling you. So the HTTP server is running.
if you run:
curl
http://127.0.0.1:3001/bridge/ecus/rrc/uiStatus
on the shell, what do you see?
Does your port (3001) match the Domoticz setting (default = 3000)
Enabled 'Accept new hardware"?
Re: Nefit Easy™
Posted: Thursday 29 September 2016 20:52
by felix63
running in the shell:
curl http://127.0.0.1:3001/bridge/ecus/rrc/uiStatus
curl: (7) Failed to connect to 127.0.0.1 port 3001: Connection refused
curl http://192.168.178.50:3001/bridge/ecus/rrc/uiStatus
{"id":"/ecus/rrc/uiStatus","type":"uiUpdate","recordable":0,"writeable":0,"value":{"CTD":"2016-09-29T20:49:54+01:00 Th","CTR":"weather","UMD":"manual","MMT":"14.0","CPM":"auto","CSP":"24","TOR":"off","TOD":"0","TOT":"14.0","TSP":"19.0","IHT":"21.40","IHS":"ok","DAS":"off","TAS":"off","HMD":"off","ARS":"init","FPA":"off","ESI":"off","BAI":"No","BLE":"false","BBE":"false","BMR":"false","PMR":"false","RS":"off","DHW":"on","HED_EN":"true","HED_DEV":"true","FAH":"false","DOT":"false","HED_DB":""}}pi@domus:~$
Hardware setting in Domoticz is ip: 192.168.178.50 and port: 3001
Re: Nefit Easy™
Posted: Thursday 29 September 2016 21:04
by felix63
Enabled 'Accept new hardware"? was the trick... sorry
Re: Nefit Easy™
Posted: Tuesday 04 October 2016 11:38
by jimmyb
This is an observation of the Worcester Wave more than an issue with this software.
I have a server running Domoticz monitoring my Worcester Wave heating controller via the nefit web server. I have found since monitoring that the wave becomes unresponsive after a couple of days and needs to be reset before coming back to life.
The controller becomes inaccessible from both the nefit web server and the mobile applications which makes me think the issue is with the controller.
Anybody else has this kind of problem?
James
Re: Nefit Easy™
Posted: Tuesday 04 October 2016 16:45
by SweetPants
jimmyb wrote:The controller becomes inaccessible from both the nefit web server and the mobile applications which makes me think the issue is with the controller. Anybody else has this kind of problem?
Yes, and this has been discussed in this thread before. Last few days it seems to happen more often, possibly because of maintenance on the Bosch backend server(s). It has been stable for me for several months, but now I have issues in the last two days. I also noticed that using the app and HTTP Server at the same time increases the change on 'timeouts' (see domoticz logs). I also inserted a switch (I also use the Nefit Easy Adapter) to power off/on the adapter and therefor the thermostat as well, to restart the connection to the backend by the thermostat in case of 5 minutes no response. Most of the time this helps getting the thing running again, but last few days something else is going on, and an off/on of the adapter not always works.
Re: Nefit Easy™
Posted: Tuesday 04 October 2016 18:34
by mvveelen
Is it possible to turn on/off the hot water boiler using Domoticz in combination with the Easy-httpd-server ?
Re: Nefit Easy™
Posted: Sunday 09 October 2016 20:26
by edwin1234
Can someone please explain how to install this under windows?
Step by step pls
Sorry i a noob at this but want to learn
Re: Nefit Easy™
Posted: Tuesday 11 October 2016 18:34
by Kochmeister
Kochmeister wrote:Hi,
I could not find this using the search, but is it possible to switch on and off warm water as well?
That would be great!
I was in contact with Robert Klep and he was very helpfull.
I asked him how to switch the hot water supply on/off
In the Pi's commandline you can do:
easy put /dhwCircuits/dhwA/dhwOperationManualMode '{"value":"off"}' --serial=xxxx --access-key=xxxx --password=xxxx
I aksed if he could integrate this in het CommandLineInterface and after an update of the CLI there is an easier way to switch on/off
Update:
npm i -g nefit-easy-cli
Now the hot water supply will show up in 'easy -h' as
easy [options] hot-water-supply [ on | off ]
from domoticz lua I can now switch on/off:
os.execute ("easy hot-water-supply on --serial=xxxx --access-key=xxxx --password=xxxx")
So all there is left is that someone integrates this with a nice button in domoticz
I hope this is something 'Holland' can do?!
This is the info I have till now.
Have fun!
Re: Nefit Easy™
Posted: Tuesday 11 October 2016 19:17
by mvveelen
This should be something the nefit-easy-http-server would be able to do, right?
I managed to break my installation of node.js on my Synology, but got it running again
The final step would be to be able to switch the boiler ON and OFF with the nefit-easy-http-server..... So if he could update that package, that would be great. Especially now when the cold period has arrived
Re: Nefit Easy™
Posted: Tuesday 11 October 2016 20:35
by Kochmeister
mvveelen wrote:This should be something the nefit-easy-http-server would be able to do, right?
Not sure, I am quite a new to this. Only thing I know is that the commandline via LUA is working now.
If I know what is needed I could contact Robert again if he can do an update on the nefit-easy-http-server if that is what it takes to get a on/off button in domoticz.
Maybe he already didan update, but I am not sure.
Anyone who can check?
Re: Nefit Easy™
Posted: Wednesday 12 October 2016 0:36
by pepijn
No, the http server is not updated but there is no need to do that. You can send this uri directly. What you are looking for is an updated Nefit class in Domoticz to support this feature.
Re: Nefit Easy™
Posted: Wednesday 12 October 2016 8:15
by Kochmeister
pepijn wrote:No, the http server is not updated but there is no need to do that. You can send this uri directly. What you are looking for is an updated Nefit class in Domoticz to support this feature.
OK, sounds good, as said, I am quite new to this.
What or who do I need to get this feature in? It would be great to have this feature!
Re: Nefit Easy™
Posted: Wednesday 12 October 2016 18:44
by mvveelen
So, when Gizmocuz implements this in Domoticz, it could already work ?
@Kochmeister : (if yes) then you probably have to ask Gizmocuz if he can add it to Domoticz.
Re: Nefit Easy™
Posted: Thursday 13 October 2016 19:17
by mvveelen
I see Gizmocuz already built this in. Unfortunately, when I add it as a switch and turn it off, in the Nefit app it isn't turned off and after a little while the switch in Domoticz turns on. So, is something overruling the switch in Domoticz or something?
Re: Nefit Easy™
Posted: Thursday 13 October 2016 19:35
by Kochmeister
Still work in progress i guess.
He built a beta and the switch operates the hot water on/off fine in my case.
However when I switch the hot water on the thermostat it does not update the switch in domoticz yet.
Little more patience needed
Re: Nefit Easy™
Posted: Thursday 13 October 2016 19:37
by mvveelen
So when you switch off the hot water switch in Domoticz, it switches off in the Nefit Easy app on your smartphone? Or do you check it on the wall panel itself?
Edit: can't try it myself right now, because my wife is taking a shower atm
