Page 26 of 32
Re: MyDomoticz - Testers wanted!
Posted: Monday 26 March 2018 21:09
by jaha
chimit wrote: Monday 26 March 2018 15:24 Do you have any idea what request it was? Or did you just click on the green icon?
jaha wrote: Monday 26 March 2018 15:12
chimit wrote: Wednesday 21 March 2018 7:23 Apologies... There has been an incident with the CPU of the host machine that hosts the MyDomoticz VPS.
Therefore, MyDomoticz has been down last night from 02:40 until just now. Apologies for the inconvenience.
== Rene
2018-03-26 13:10:44.437 PROXY: Incoming connection from:XXXXXX
2018-03-26 13:10:44.438 Error: Domoticz received fatal signal 11 !...
2018-03-26 13:10:44.463 Error: /home/pi/domoticz/domoticz() [0x24eb0c]
2018-03-26 13:10:44.463 Error: /home/pi/domoticz/domoticz(_Z14signal_handleri+0x4c) [0x24ebc4]
2018-03-26 13:10:44.463 Error: /lib/arm-linux-gnueabihf/libc.so.6(__default_sa_restorer+0) [0x76be26b0]
2018-03-26 13:10:44.463 Error: /home/pi/domoticz/domoticz(_ZN4http6server20cWebemRequestHandler14handle_requestERKNS0_7requestERNS0_5replyE+0x11c) [0x5f2130]
2018-03-26 13:10:44.464 Error: /home/pi/domoticz/domoticz(_ZN4http6server12CProxyClient10GetRequestERKNSt7__cxx1112basic_stringIcSt11char_traitsIcESaIcEEEN5boost4asio17mutab$
2018-03-26 13:10:44.464 Error: /home/pi/domoticz/domoticz(_ZN4http6server12CProxyClient17HandlePDU_REQUESTEPKcR16CValueLengthPart+0x3d0) [0x6028fc]
2018-03-26 13:10:44.464 Error: /home/pi/domoticz/domoticz(_ZN4http6server12CProxyClient10PduHandlerER8ProxyPdu+0x100) [0x5fd1a0]
2018-03-26 13:10:44.464 Error: /home/pi/domoticz/domoticz(_ZN4http6server12CProxyClient11handle_readERKN5boost6system10error_codeEj+0x144) [0x601dc8]
2018-03-26 13:10:44.464 Error: /home/pi/domoticz/domoticz(_ZN5boost4asio3ssl6detail5io_opINS0_19basic_stream_socketINS0_2ip3tcpEEENS2_7read_opINS0_17mutable_buffers_1EEENS_3$
2018-03-26 13:10:44.464 Error: /home/pi/domoticz/domoticz(_ZN5boost4asio6detail23reactive_socket_recv_opINS0_17mutable_buffers_1ENS0_3ssl6detail5io_opINS0_19basic_stream_soc$
2018-03-26 13:10:44.464 Error: /home/pi/domoticz/domoticz(_ZN5boost4asio6detail13epoll_reactor16descriptor_state11do_completeEPvPNS1_19scheduler_operationERKNS_6system10erro$
2018-03-26 13:10:44.464 Error: /home/pi/domoticz/domoticz(_ZN5boost4asio6detail9scheduler3runERNS_6system10error_codeE+0x378) [0x3e75a4]
2018-03-26 13:10:44.464 Error: /home/pi/domoticz/domoticz(_ZN4http6server13CProxyManager11StartThreadEv+0x190) [0x600ff4]
2018-03-26 13:10:44.465 Error: /home/pi/domoticz/domoticz() [0x7ba650]
Just clicked on the green icon then this happens.
Posted: Friday 30 March 2018 7:51
by mitko67
chimit wrote: Monday 19 March 2018 14:33 As you can see, there is a new option in MyDomoticz: A vanity host name. This option is available to the people who are so nice to donate an arbitrary amount of euros (minimal 1).
This is to celebrate a 2500 concurrent Domoticz instances mile stone.
You can find the option in the settings screen of your instance(s).
For the people who already donated: Thanks for that!
== Rene
Hello everybody! Sorry for my English (I do not even know him)
I donated money twice, but I can not even see the sensor temperature graph. Connection through (mydomoticz.com).
The system offers to donate again.
"Enter your api data to your own Domoticz in order to use this service
Please consider a Donation and get to use an ssl vanity hostname for your Domoticz!
Hostnames of your choice are served on a first-come-first-get basis "
What am I doing wrong.
Thank you!
Posted: Friday 30 March 2018 10:25
by chimit
Hi, thanks for the feed back.
You only need to Donate once. The Donate link underneath the dashboard is something that's just always there.
The api data is something that you need to enter in your own Domoticz settings screen, locally. You need to do that first in order to use MyDomoticz.
== Rene
mitko67 wrote: Friday 30 March 2018 7:51
== Rene
Thank you!
Posted: Thursday 05 April 2018 10:47
by jaha
== Rene
Found the problem, you have to run domoticz on port 8080 for my.domoticz.com to work. Can´t you change the code so its works with port 443 also?
Posted: Thursday 05 April 2018 10:51
by chimit
jaha wrote: Thursday 05 April 2018 10:47 Found the problem, you have to run domoticz on port 8080 for my.domoticz.com to work. Can´t you change the code so its works with port 443 also?
That's interesting... I will look into that. If you say running on 443, are you ONLY using the secure server? With the plain server disabled?
Posted: Thursday 05 April 2018 12:41
by jaha
chimit wrote: Thursday 05 April 2018 10:51
Yes have been using the server with only https :)
Posted: Thursday 05 April 2018 12:51
by chimit
jaha wrote: Thursday 05 April 2018 12:41
Ah, that might be the problem. As I said I will look into the issue. Thanks for reporting.
Posted: Thursday 05 April 2018 13:14
by chimit
I made a pull request for the Domoticz development branch. If you are able to, when you get the chance, could you please test?
Posted: Thursday 05 April 2018 14:15
by jaha
chimit wrote: Thursday 05 April 2018 12:51
Thanks, is there a plan to make this proxy work with the mobile apps for iPhone and Android?
Posted: Friday 06 April 2018 10:34
by jaha
Oh one more "bug"
Just changed the name of my domoticz on my.domoticz.com proxy and after that just blank dashboard.
my domo.png (139.43 KiB) Viewed 3632 times
Posted: Friday 06 April 2018 10:40
by chimit
jaha wrote: Friday 06 April 2018 10:34 Oh one more "bug"
Can you try again?
Posted: Friday 06 April 2018 10:45
by jaha
chimit wrote: Friday 06 April 2018 10:40
Can you try again?
Same thing, just restarted but still blank.
Log looks good.
2018-04-06 08:43:49.958 TCPServer: shared server started...
2018-04-06 08:43:49.958 RxQueue: queue worker started...
2018-04-06 08:43:51.230 PROXY: Authenticate result: success.
Posted: Monday 09 April 2018 22:29
by jaha
Can you try again?
Plz fix :)
Posted: Monday 09 April 2018 22:45
by chimit
jaha wrote: Monday 09 April 2018 22:29 Plz fix :)
Could you PM me your api key or instance id?
Posted: Monday 09 April 2018 23:24
by Nautilus
any ideas what is causing this:
2018-04-10 00:18:41.599 Proxymanager started.
2018-04-10 00:18:42.883 PROXY: Authenticate result: Disallowing due to maxinstances (1234567890abcdefgh)..
Posted: Wednesday 11 April 2018 8:52
by jaha
chimit wrote: Monday 09 April 2018 22:45
Yes sent you a pm
Posted: Tuesday 24 April 2018 14:00
by zaakal
I have exact same problem.
If i go directly http://my.domoticz.com/my/MyDomoticz Instance ID - it works but dashboard is empty.
Posted: Wednesday 25 April 2018 12:49
by chimit
One reason can be that you have two Domoticz instances.
It's possible that they have an identical apikey, when a backup from the first is transferred to the second at some point.
Another reason can be a network hitch. When you domoticz notices a disconnect it tries to connect again.
But if meanwhile MyDomoticz didn't notice the disconnect yet, it thinks your instance tries to connect multiple times at once.
== Rene
Nautilus wrote: Monday 09 April 2018 23:24 Hi,
Posted: Wednesday 25 April 2018 20:23
by Nautilus
chimit wrote: Wednesday 25 April 2018 12:49 One reason can be that you have two Domoticz instances.
Thanks for the reply. I only have one Domoticz instance and this issue has been there for a while. I was last able to use the service on March 13th (i.e. over a month ago) and since then it has shown "red" on my.domoticz. If I disable/enable the service in Domoticz I get the mentioned errors. So it is not at least any temporary network glitch. Not sure what else I could try?
Posted: Tuesday 01 May 2018 0:10
by vivatauro
Hi chimit:
I registered in mydomoticz and I was able to see my dashboard, but now it seems not. what I see in mydomoticz.com is the user incon in red color. Before that I was able to see it in green.
If I go to my domain (vivatauro.mydomoticz.com) I get an empty screen saying "Server Offline"
Is the server down or I did something wrong?
By the way, you got a donation from me too.
Thanks in advance for your help on this
