GarbageCalendar (new version) lua scripts
jvdz
Domoticz version: 4.107
Re: GarbageCalendar (new version) lua scripts
Post by jvdz »
hoeby wrote: Saturday 04 July 2026 11:39 I updated the GarbageCalendar to the latest version.
When tested, it still didn't worked.
Dont think this is related to these script as you are using a dzvents notification.
hoeby wrote: Saturday 04 July 2026 11:39 Just a tip, don't just copy the missing types to the garbagetyp_cfg, because the type is case sensitive.
Check how it is written a few lines above the warning.
Are you sure about this? I
am pretty sure I have modified the code to cope with this and convert all to lower case and strip all none "word characters" for better comparing:
		-- Create second version of the garbagetype for better matching.
		-- Remove any none-a-z 0-9 character from the GarbageType and convert to lowercase for better matching
		local test_garbagetype = tbl_garbagetype:lower():gsub('[^%w]', '')
Let me know in case you have an example that can make this all go wrong, so i can test.
hoeby
Domoticz version: V2022.1
Post by hoeby »
I am very sure about it.
The script was saving it was missing the types.
Copy and paste the lines from the logfile. Done a new test and again the same lines in the log, that j was missing types.
Changed it from small to capital letter and the missing types notification was gone. After that everything started working again.
jvdz
Post by jvdz »
Ok, so could you pm me the details so I can have a look pls?
EDIT: Scratch that. I found indeed an issue with checking whether garbagetypes were missing and fixed that in the latest version.
Functionally all was working fine and it was indeed just the log message about missing types
Tnx for reporting!, Jos
SanderRoelofs
Post by SanderRoelofs »
Hi Jos,
I’m a big fan of your waste collection project and have been using it for quite some time. However, since updating Domoticz (Windows), I can no longer use the script.
I’m getting the well-known error regarding io.popen, which is no longer supported in Domoticz (Windows):
2026-08-19 08:53:00.454 Error: EventSystem: in C:\Program Files (x86)\Domoticz\scripts\lua\script_time_garbagecalendar.lua: ...86)\Domoticz\scripts\lua\script_time_garbagecalendar.lua:348: 'popen' not supported
With the help of AI, I modified some functions in gc_generalfuncs.lua and gc_main.lua.
io.popen has been replaced with os.execute, io.open, and os.remove. Instead of keeping the output in memory, it is now written to a temporary file, which is then read afterwards.
Perhaps this is something you could consider incorporating into a future version, so I wanted to share these modifications with you.
gc_generalfuncs.lua
-- addlogmessage function sends messages to Domoticz log
function genfuncs.domo_api_query(url, uploadfile)
	if not url then
		return nil, 1, nil
	-- GEWIJZIGD VOOR WINDOWS: io.popen omzeild via een tijdelijk bestand
	local tmp_api_log = (datafilepath or '') .. 'domo_api_tmp.json'
	local sQuery = 'curl --silent --connect-timeout 2 '
	if uploadfile and uploadfile ~= '' then
		sQuery = sQuery .. ' -F file="@' .. uploadfile .. '" '
	-- Schrijf output direct naar een tijdelijk bestand in plaats van popen te gebruiken
	sQuery = sQuery .. '"' .. url .. '" > "' .. tmp_api_log .. '"'
	Print_logfile('-> domo_api_query (Windows Exec):' .. (sQuery or 'NIL'))
	os.execute(sQuery) -- Veilige aanroep op Windows
	-- Lees het resultaat uit met het toegestane io.open
	local f = io.open(tmp_api_log, 'r')
	local Web_Data = nil
	if f then
		Web_Data = f:read('*all')
		f:close()
		os.remove(tmp_api_log) -- Netjes opruimen
	if not Web_Data or Web_Data == '' then
		Print_logfile('-< domo_api_query failed, temporary file empty or missing.')
		return nil, 2
	Print_logfile('Web_Data:' .. (Web_Data or 'NIL'))
	local JSON_Web_Data = JSON:decode(Web_Data or '')
	if (JSON_Web_Data == nil) then
		-- No data returned so API must have failed
		Print_logfile('-< domo_api_query failed, no json returned:' .. (Web_Data or '?'))
		return nil, 2
	if (JSON_Web_Data['status'] ~= 'OK') then
		Print_logfile('-< domo_api_query failed, status not OK:' .. (Web_Data or '?'))
		return JSON_Web_Data, 3
	Print_logfile('-< domo_api_query successful.')
	return JSON_Web_Data, 0
-- Do the actual webquery, retrieving data from the website
function genfuncs.perform_webquery(url)
	-- Paden Windows-vriendelijk maken met backslashes en correcte aanhalingstekens
	local base_path = (datafilepath or ((GC_scriptpath or '/') .. 'data/')):gsub('/', '\\')
	if not base_path:match('\\$') then base_path = base_path .. '\\' end
	local errlogfile = base_path .. 'webquery_err.log'
	local tmp_web_out = base_path .. 'webquery_out.txt'
	-- Zorg dat de URL geen dubbele aanhalingstekens bevat vanuit de aanroepende module
	local clean_url = url:gsub('"', '')
	-- Bouw de Windows Query op. We schrijven direct de output EN de -w metadata naar het bestand.
	-- Let op: Geen geneste dubbele aanhalingstekens voor cmd.exe!
	local sQuery = 'curl -L -k --silent -w "\\n#@#httprc:%{http_code}#@#\\n#@#endurl:%{url_effective}#@#" "' .. clean_url .. '" > "' .. tmp_web_out .. '" 2>"' .. errlogfile .. '"'
	Print_logfile('sQuery (Windows Exec)=' .. sQuery)
	os.execute(sQuery)
	-- Lees het resultaat uit met io.open
	local f = io.open(tmp_web_out, 'r')
	local Web_Data = ""
	if f then
		f:close()
		os.remove(tmp_web_out) -- Netjes opruimen
	-- Get effective url and http response code from the output and strip it from the result output
	local httprc = Web_Data:match('#@#httprc:([^#]*)#@#') or '?'
	local redirecturl = (Web_Data:match('#@#endurl:([^#]*)#@#') or '?')
	if Web_Data:find('(.*)\n#@#httprc:') then
		Web_Data = Web_Data:match('(.*)\n#@#httprc:')
	-- Show Webdata retrieved
	Print_logfile('--- url: ' .. redirecturl .. ' rc:' .. (httprc or '?') .. '  web data:  --------')
	Print_logfile(Web_Data)
	-- Check for 301 Moved Permanently
	if (httprc == '301' or Web_Data:find('Moved Permanently')) then
		Print_logfile('### Error: Site Moved Permanently: check your hostname for changes!',1)
		local lWeb_Data = Web_Data:gsub('.-<body>(.-)</body>.*', '%1')
		lWeb_Data = lWeb_Data:gsub('[\r\n]', '')
		Print_logfile(lWeb_Data,1)
		return ''
	-- Check redirection to warn
	if (not clean_url:find(redirecturl, 1, true)) then
		Print_logfile('### warning: Site redirected from : #' ..  clean_url .. '#  to : #' ..  redirecturl .. '#' .. (clean_url:find(redirecturl, 1, true) or '?'),1)
	-- Check for Web request errors when seperate file is defined, else all output is in Web_Data
	local Web_Error = ''
	local ifile, ierr = io.open(errlogfile, 'r')
	Web_Error = ierr or ''
	if ifile then
		Web_Error = ifile:read('*all')
		ifile:close()
	if Web_Error ~= '' then
		Print_logfile('---- web err ------------------------------------------------------------------------')
		Print_logfile('Web_Err=' .. Web_Error)
	--os.remove(errlogfile)
	Print_logfile('---- end web data ------------------------------------------------------------------------')
	if (Web_Error:find('unsupported protocol')) then
		Print_logfile('### Error: unsupported protocol.')
		Print_logfile('###  This website still uses tls 1.0 and Debian Buster (and up) has set the minssl to tls 1.2 so will fail.')
		Print_logfile('###  To fix: Set /etc/ssl/openssl.cnf; goto section [system_default_sect]; Change-> MinProtocol = TLSv1.0 ;  and reboot')
		return ''
	if (Web_Data == '') then
		Print_logfile('### Error: Empty result from curl command')
		return ''
	return Web_Data
gc_main.lua i updated the first few lines from function Perform_Data_check()
	-- Do the actual update retrieving data from the website and processing it
		-- ensure the access is set correctly for data
		Print_logfile('-> Action starting, First check access to required files:')
		-- GEWIJZIGD VOOR WINDOWS: io.popen en ls volledig verwijderd om 'popen not supported' te voorkomen
		local function ListAccess()
			local files_to_check = {
				{path = Datafile, label = "Datafile"},
				{path = RunLogfile, label = "RunLogfile"},
				{path = icalfile, label = "Icalfile"}
			for _, file_info in ipairs(files_to_check) do
				if file_info.path and file_info.path ~= '' then
					local f = io.open(file_info.path, "r")
					if f then
						Print_logfile('   Access OK (Windows Native Check) - ' .. file_info.label .. ': ' .. file_info.path)
						f:close()
						Print_logfile('   File not found or unreadable - ' .. file_info.label .. ': ' .. file_info.path)
		-- show access info when debugging
		if testrun then
			ListAccess() -- Aanroep aangepast zonder argumenten omdat wildcards (*) niet werken in io.open
		-- Check for access to data & logfiles
		if not Perform_Rights_check(Datafile) then
			return
		if not Perform_Rights_check(RunLogfile) then
			return
		local missingrecords = ''
I hope you appreciate the effort I’ve put into this, even though I’m not a programmer. :lol:
Best,
Sander
jvdz
Post by jvdz »
There is an update on github that now uses os.execute() for compatibility.
mvveelen
Post by mvveelen »
Is there (I might have overlooked it in this thread) an easy way to add a text sensor that only contains the color of the bin?
What I want to do: I use the Pilot app and when I add the default 2 devices to the favorites, it shows me below icons and I want it to show the color of the bin or (if that's not possible), just in short: REST / GROEN or PLASTIC
Installing was a breeze, by the way. Love the plugin!
Schermafbeelding 2026-09-14 om 20.13.34.png (209.48 KiB) Viewed 845 times
jvdz
Post by jvdz »
You can set the content of the textbox yourself and use html. The last version also allows for a color setting of the "text". Have you tried to play with that?
mvveelen
Post by mvveelen »
“Funny” thing is, that Pilot doesn’t render the HTML unfortunately. It shows <br> for instance, so I adjusted the text to my liking. Thanks!
