domoticz in synology as package! Available now.
jumbotroll
Re: domoticz in synology as package! Available now.
Post by jumbotroll »
G3rard wrote:@jumbotroll, thanks for the updates that keep on coming for Synology :D
One question, since a recent version there is a LUA editor in Domoticz available. This editor has some example scripts available when you select LUA and press new.
These examples are stored in scripts/templates (https://github.com/domoticz/domoticz/tr ... /templates).
Can you add these files to the package? Thanks.
I have updated the install script to move /samplescripts/templates to /var/scripts/templates
So hopefully this will work in next update @G3rard ;)
Jumbotroll
https://paypal.me/Jumbotroll
Jumbotroll
http://www.jadahl.com
Gravityz
Domoticz version: 2025.1
Post by Gravityz »
Hi Jumbotroll.
is it possible to downgrade to a previous package also.
i tried it and get the message that it is not possible.
i need to downgrade in case some things do not work as expected anymore
i noticed that some kwh functionality used to work in the past but now do not work corerctly anymore(i have to use polling to corect the issue)
thanks
jumbotroll
Gravityz wrote:Hi Jumbotroll.
thanks
Only way to downgrade is to take a backup of db and uninstall domoticz.
Then install an older domoticz version and restore db.
Jumbotroll
Jumbotroll
pepeEL
Post by pepeEL »
Please update your repo to 4031...
Wysłane z mojego SM-G920F przy użyciu Tapatalka
Gravityz
Post by Gravityz »
WoW 4031. That is fast
I Will try tonight
pepeEL wrote:Please update your repo to 4031...
dtech
Post by dtech »
Can you please confirm that battery meter are working on this build ?
Many Thanks
jumbotroll
Many Thanks
Still Battery meter bug with RFXcom ;)
With RFLink devices battery meter is ok.
Jumbotroll
Jumbotroll
harrytasker
Post by harrytasker »
Just got my Aeotec Z-Stick Gen5.
I plugged it into my DS415play and installed the Domoticz pkg.
My stick doesn't show up in the hardware tab.
I tried all of the USB ports (5 in total) nothing worked.
In the info center it shows: USBDevice - Sigma Designs, Inc. connected
I then uninstalled Domoticz and installed the drivers and the package manually, all downloaded from jadhal.com but still no go.
Where can i see if the USB drivers are installed correctly or which port i should use on my NAS?
Log file of the USB drivers included!
Any help much appreciated!
Log USB drivers 3.0.9
jumbotroll
harrytasker wrote:Hi,
No need for UsbSerialDrivers pack with my domoticz packages!
Uninstall domoticz and usbserial drivers and reinstall latest domoticz version for your NAS http://jadahl.dscloud.me/sspks/?arch=evansport
Reboot NAS and plug in Z-Stick and you hopfully see port ACM0 or ACM1.
Jumbotroll
Jumbotroll
harrytasker
Jumbotroll
Thanks for the quick reply!
That did it! Thanks don't know what went wrong in the first place!
Thanks for helping out!
harrytasker
Affer getting it to work i am running into a new problem.
On adding the stick from the hardware menu, i see both programmed devices that added to the stick, one a dimmer and one wall plug.
Everything fine so far. When i test both they work fine. But like 5 minutes later all the nodes go dead.
I delete the stick and add it again and the nodes work again straight away but same thing happens again, all dead nodes.
And there is no way of getting it to work again besides removing the stick from the hardware tab and adding it again.
I can choose between ttyACM0 and ttyACM1, it doesnt matter what i choose, happens on both ports.
What is strange though, i dont have to change the stick physically from the front USB port? Is that normal?
Update: I installed Domoticz on my Windows 10 PC and the stick is running fine, network health is perfect, so i guess it must be something with the installation on the NAS?
pepeEL
Post by pepeEL »
Hello
Jumbotroll can you build Domoticz with working 1-wire ? I installed latest Domoticz from you and install from spk OWFS
https://github.com/SynoCommunity/spksrc ... -169968616
and 1-wire is not appear in HARDWARE Domoticz... I have connected adapter Dallas DS9490r by USB.
gevegest
Post by gevegest »
Hi Jumbotroll, first of all I have read through this topic and you do amazing work really great, thank you! I am thinking to start using Domoticz on my synology, but I am with cwvs, for me the deciding reason would be to have the homebridge (HomeKit/Siri) support. So i really hope you decide to add it to your packages, i would be forever grateful (and off course find your Donate button ;))
Best regards,
gevegest
jumbotroll
gevegest wrote:Hi Jumbotroll, first of all I have read through this topic and you do amazing work really great, thank you! I am thinking to start using Domoticz on my synology, but I am with cwvs, for me the deciding reason would be to have the homebridge (HomeKit/Siri) support. So i really hope you decide to add it to your packages, i would be forever grateful (and off course find your Donate button ;))
Best regards,
gevegest
Sorry, I only compile spk for synology and no development.
Jumbotroll
Jumbotroll
pepeEL
Post by pepeEL »
But can you implement also 1wire?
jumbotroll
pepeEL wrote:Hello
Sorry 1-wire is for Raspberry GPIO interface and not implemented for USB devices.
Jumbotroll
Jumbotroll
pepeEL
Post by pepeEL »
No no
It also works on USB
I now use Raspberry with Domoticz and have connected to raspberry adapter 1wire usb DS9490r and it works perfect. Only Domoticz need to install owfs on raspberry.
jumbotroll
pepeEL wrote:No no
I will look into it.
Jumbotroll
Jumbotroll
pepeEL
Post by pepeEL »
Ok please
lampje25
Post by lampje25 »
I'm new on this forum.
I have a Synology DS215 with DSM 5.2-5644 Update 1.
Under community, I can see Domoticz from Jumbotroll (version 2.0.4031-7)
When i try to install then "kan "Domoticz" niet installeren"
How to resolve this?
Sorry for the bad English...
