Page 25 of 37
Re: Nefit Easy™
Posted: Sunday 05 June 2016 9:50
by jannl
Exactly, that is exactly what is stated in the conditions of Bosch. (As that it is forbidden to reverse engineer [WINKING FACE])
Nefit Easy™
Posted: Thursday 16 June 2016 23:14
by geezerrr
Finally I managed to get the easy server running the way I want, struggled with the crortab which wasn't working as it should. Now using pm2, And can confirm it works even after reboot. Thanks everyone!
Now I was trying to use the boiler status to trigger a virtual switch using block
Unfortunately I'm not able to use the sValue,
Anyone having another way to use the sValue of the boiler status?Image
Re: Nefit Easy™
Posted: Wednesday 13 July 2016 14:52
by Dutchsea
Hi, I really appreciatean updated post on how to install the Nefit Easy for Domoticz. The info is now so fragmenten and often outdated that its hard for novice user to make a start. Especially as the instruction in the initial post is not working anymore.
Also can someone explain me the pro's and con's between the 2 options: http server and php.
Many thanks.
Re: Nefit Easy™
Posted: Thursday 21 July 2016 8:23
by SweetPants
After working for several months in a row without any problems, last two nights (20/7 04:35 and 21/7 02:35), the backend stopped working (timeouts). Also Nefit app stopped working. After reset (off/on) Nefit Easy Connect adapter everything works again. Looking at the time this might be maintenance on the sever side!!!!
edit: today (22/07) 00:35 it happend again, watch the time difference (2 hours) between every day.
Re: Nefit Easy™
Posted: Sunday 07 August 2016 10:06
by noway666
Dutchsea wrote:Hi, I really appreciatean updated post on how to install the Nefit Easy for Domoticz. The info is now so fragmenten and often outdated that its hard for novice user to make a start. Especially as the instruction in the initial post is not working anymore.
I second this. As a relative newbie regarding linux I would very much like to see a comprehensive guide to make the Easy visible in domoticz. Can anyone guide us through? (I don't want to mess up my domoticz setup with wrong commands :) )
Re: Nefit Easy™
Posted: Monday 15 August 2016 11:35
by knights
Hmm... My Domoticz will stop working after some while if I enable the Nefit Easy Server. If I dont use this my Domoticz works just fine.
Anybody has some suggestions where to start with troubleshooting?
Already have the latest beta and updates/upgrades.
My RASPI is still functional when Domoticz is offline.
Re: Nefit Easy™
Posted: Tuesday 30 August 2016 15:01
by jurgen
Dear all,
Today I have installed domoticz with easy-http server on my synology. I could not find a complete tutorial so i decided to document and share the steps that I did to get this working. I hope that you can use it.
Tutorial
Nefit easy on synology with DSM 6.0.2
Install node.js v4.2.6-0158 using package center from publisher Synology.inc
Install nefit easy http server on synology nas using ssh
npm i nefit-easy-http-server -g
Run the nefit easy http server as test
easy-server --serial=serialnumber --access-key=enteryourkey --password=enteryourpassword
Check if you can reach the http server using the following command:
curl http://127.0.0.1:3000/bridge/ecus/rrc/uiStatus
Go to domoticz which is running on my synology server
Add new hardware
Nefit easy http server over lan interface
Remote address: 127.0.0.1
poort: 3000
Go to Devices and check if there are nefit devices available and add the devices to the dashboard! :D
if there are no devices available check the logging in domoticz and verify with curl if the easy http server is running.
Create Startup script called easy-server.sh and place it in the directory /usr/local/etc/rc.d/
Reboot the nas and check that the process is running.
ps -aux | grep easy-http
@thanks to mvveelen
I edit the scriptname directory because of the change in DSM 6.0.2
#! /bin/sh
### BEGIN INIT INFO
# Provides:          nefit easy http server
# Required-Start:    $network $remote_fs $syslog
# Required-Stop:     $network $remote_fs $syslog
# Default-Start:     2 3 4 5
# Default-Stop:      0 1 6
# Short-Description: nefit-easy-http-server
# Description:       This daemon will start the nefit-easy-http-server for use by Domoticz
### END INIT INFO
# Do NOT "set -e"
PATH=/sbin:/bin:/usr/sbin:/usr/bin:/usr/local/bin
DESC="Nefit Easy HTTP Server"
NAME=easy-server
USERNAME=root
PIDFILE=/var/run/$NAME.pid
SCRIPTNAME=/usr/local/etc/rc.d/$NAME
NEFIT_SERIAL_NUMBER=enterserial
NEFIT_ACCESS_KEY=enterkey
NEFIT_PASSWORD=enterpassword
NEFIT_HOST=127.0.0.1
NEFIT_PORT=3000
DAEMON=/usr/local/bin/$NAME
DAEMON_ARGS="$DAEMON_ARGS --serial=$NEFIT_SERIAL_NUMBER"
DAEMON_ARGS="$DAEMON_ARGS --access-key=$NEFIT_ACCESS_KEY"
DAEMON_ARGS="$DAEMON_ARGS --password=$NEFIT_PASSWORD"
DAEMON_ARGS="$DAEMON_ARGS --host=$NEFIT_HOST"
DAEMON_ARGS="$DAEMON_ARGS --port=$NEFIT_PORT"
# Exit if the package is not installed
[ -x "$DAEMON" ] || exit 0
# Function that starts the daemon/service
do_start()
    nohup $DAEMON $DAEMON_ARGS &
  echo `ps w | grep ${DAEMON} | grep -v -E 'grep' | awk '{print $1}' > $PIDFILE`
wait_for_status ()
    counter=$2
    while [ ${counter} -gt 0 ]; do
        do_status
        [ $? -eq $1 ] && return
        let counter=counter-1
        sleep 1
    done
    return 1
# Function that stops the daemon/service
do_stop()
    # Kill the application
    kill `cat ${PIDFILE}`
    wait_for_status 1 20 || kill -9 `cat ${PIDFILE}`
    rm -f ${PIDFILE}
do_status ()
    if [ -f ${PIDFILE} ] && kill -0 `cat ${PIDFILE}` > /dev/null 2>&1; then
        return
    fi
    rm -f ${PIDFILE}
    return 1
case "$1" in
  start)
        do_start
  stop)
        do_stop
  restart)
        do_stop
        do_start
        echo "Usage: $SCRIPTNAME {start|stop|restart}" >&2
        exit 3
esac
Re: Nefit Easy™
Posted: Tuesday 30 August 2016 15:06
by gizmocuz
Maybe it's a nice idea to create a wiki page about this ?
I see there is already a wiki:
http://www.domoticz.com/wiki/NefitEasy
But maybe add a section for the Synology ?
Re: Nefit Easy™
Posted: Tuesday 30 August 2016 15:39
by jurgen
That would be a great idea!
Re: Nefit Easy™
Posted: Tuesday 30 August 2016 18:54
by mvveelen
jurgen wrote:Dear all,
Tutorial
Add new hardware
poort: 3000
@thanks to mvveelen
#! /bin/sh
### BEGIN INIT INFO
### END INIT INFO
# Do NOT "set -e"
NAME=easy-server
USERNAME=root
NEFIT_PORT=3000
do_start()
wait_for_status ()
    counter=$2
        do_status
        sleep 1
    done
    return 1
do_stop()
    rm -f ${PIDFILE}
do_status ()
        return
    fi
    rm -f ${PIDFILE}
    return 1
case "$1" in
  start)
        do_start
  stop)
        do_stop
  restart)
        do_stop
        do_start
        exit 3
esac
Great work on documenting it for DSM6 on the Synology. I'm still running DSM5, but maybe....someday,... :D
Are you going to add a wiki-page ?
Re: Nefit Easy™
Posted: Thursday 01 September 2016 11:09
by preetyjess01
Amazing and very informative. I try this in my Raspberry Pi robot kits project. This is very helpful for me. Thanks.
Re: Nefit Easy™
Posted: Tuesday 06 September 2016 19:24
by Kochmeister
I could not find this using the search, but is it possible to switch on and off warm water as well?
That would be great!
Re: Nefit Easy™
Posted: Tuesday 06 September 2016 19:38
by mvveelen
Hmmm, curious too.
Re: Nefit Easy™
Posted: Wednesday 07 September 2016 20:01
by cvdb
Tutorial
Add new hardware
poort: 3000
@thanks to mvveelen
#! /bin/sh
### BEGIN INIT INFO
### END INIT INFO
# Do NOT "set -e"
NAME=easy-server
USERNAME=root
NEFIT_PORT=3000
do_start()
wait_for_status ()
    counter=$2
        do_status
        sleep 1
    done
    return 1
do_stop()
    rm -f ${PIDFILE}
do_status ()
        return
    fi
    rm -f ${PIDFILE}
    return 1
case "$1" in
  start)
        do_start
  stop)
        do_stop
  restart)
        do_stop
        do_start
        exit 3
esac
Hello all,
Just installed Domoticz on my Synology, and got it working with some switches :)
Now i really would like to connect to my Nefit easy as well, but after a few evenings trying, its not that easy for me... because i am not so familiar with this code.
i am glad some people are, and thanks for puting it on this forum, and i hope they can help me in the right direction.
my configuration:
Synology DS412+ DSM 6.0.2-8451
installed node.js v4.2.6-0158
I am trying to follow the steps from the tutoral, but got lost..
I am connecting to Synology with PuTTY SSH
I changed the npm install directory to ~/.npm-global ( because it generated some errors on permissions.. )
https://docs.npmjs.com/getting-started/ ... ermissions
and when i do:
admin@DiskStation:~$ easy-server
-sh: easy-server: command not found
admin@DiskStation:~$ curl http://127.0.0.1:3000/bridge/ecus/rrc/uiStatus
curl: (7) Failed to connect to 127.0.0.1 port 3000: Connection refused
Its not starting the easy server...
So please help me with where i go wrong
Re: Nefit Easy™
Posted: Wednesday 07 September 2016 21:04
by BartdaMan
Yes! Today our new Nefit Trendline has been installed, with Easy thermostat.
For installation of the easy server onto RasPi the Wiki is not 100% right, but with the help of the above posts (thank you all!) and good old friend Mr. Google, I just succeeded to get it all running in Domoticz.
I really like my new home automation hobby!
Re: Nefit Easy™
Posted: Saturday 10 September 2016 22:38
by jurgen
Tutorial
Add new hardware
poort: 3000
@thanks to mvveelen
#! /bin/sh
### BEGIN INIT INFO
### END INIT INFO
# Do NOT "set -e"
NAME=easy-server
USERNAME=root
NEFIT_PORT=3000
do_start()
wait_for_status ()
    counter=$2
        do_status
        sleep 1
    done
    return 1
do_stop()
    rm -f ${PIDFILE}
do_status ()
        return
    fi
    rm -f ${PIDFILE}
    return 1
case "$1" in
  start)
        do_start
  stop)
        do_stop
  restart)
        do_stop
        do_start
        exit 3
esac
Hello all,
my configuration:
and when i do:
Hi cvdb,
Before installing the nefit easy server using nmp, i think that you need to use the command "sudo -i" this will give you root permission.
after that try the commands again.
Greetz!
Re: Nefit Easy™
Posted: Tuesday 13 September 2016 11:15
by cvdb
Thanks Jurgen, will try that soon.
Re: Nefit Easy™
Posted: Wednesday 14 September 2016 19:36
by cvdb
Hi Jurgen,
the sudo -i did it, i have it running, and can see the new devices in domoticz :) many thanks.
I have a second question about:
I placed an easy-server.sh file (with my serial #, access key and passwd) in the /usr/local/etc/rc.d directory, and rebooted the nas, but the process is not running.. any idea ?
Kind regards
CvdB
Re: Nefit Easy™
Posted: Thursday 15 September 2016 18:25
by cvdb
I did a chmod 755 of the easy-server.sh file, rebooted the nas, and now its running :)
Many thanks to you all
Re: Nefit Easy™
Posted: Tuesday 27 September 2016 11:56
by felix63
Trying to find an answer to a simple question. Went through the wiki/forum but couldn't find a clear answer.
If I connect a Nefit Easy to Domoticz what functionality do I get?
Can anyone give me some insights?
Cheers,
Lex
