Page 25 of 120
Re: Domoticz app 2.0
Posted: Thursday 07 January 2016 13:07
by galadril
thomasb89 wrote:Just wondering if your planning to add functionallity for the 'selector' SwitchType.
Selectors are implemented in one of the next releases
Posted: Friday 08 January 2016 8:44
by marcpos
RoadXY wrote:Jan- wrote:I have the same experience it is not always working correctly.
Do you experience the same issues as stated above?
I'm using your premium version from the start. Great app!!
On my phone geofence stopped working too, since last update after reboot of the phone. I hope you can find the solution for this.
Thanks for your work on this great app!
Marc
Posted: Friday 08 January 2016 8:51
by galadril
the phone.
This matter wil be solved by the next version
Posted: Friday 08 January 2016 10:54
by alfred_j_kwak
I can't see temperature trend from last couple days. Could -25 degrees Celsius cause problems?
Posted: Friday 08 January 2016 10:57
by pepeEL
I also has this problem that for some sensor temp , graph is not show. On web domoticz all works ok and graph is show ok.
Posted: Friday 08 January 2016 10:59
by RoadXY
alfred_j_kwak wrote:I can't see temperature trend from last couple days. Could -25 degrees Celsius cause problems?
There are several fixes in alpha and beta right now which could solve this issue.
Please test when you receive this update later or apply for the beta testing
*klik here*
(only for
Premium users!)
Posted: Friday 08 January 2016 11:03
by pepeEL
I am beta tester and have latest app. And problem still have. My version is 0.1.210
Next bug is that in Switches is not show Virtual Switches type SELECTOR.
Next bug:
When i delete from menu Welcome Wizard it is hide in menu. But when i close app and close from task manager and open again, after open app in menu again is show Welcome Wizard. Also when i disable in settings again come back.
Posted: Friday 08 January 2016 14:04
by galadril
Have you read my post??
Posted: Friday 08 January 2016 14:39
by pepeEL
Ahhh ok thx
Wysłane z mojego SM-G920F przy użyciu Tapatalka
Posted: Friday 08 January 2016 15:12
by maluko
hi guys
This is not a bug but can be a improvement so:
When we open any tab like switch which have a lot devices and if you want turn off and next turn on( like reboot) the screen goes alway to the begining, next have to scroll or "find".
this happen too when i want to open or close the blinds (not all because have a scene), i have ordered all next to each other.
Posted: Friday 08 January 2016 16:00
by RoadXY
maluko wrote:hi guys
Made an issue, thanks!
Posted: Friday 08 January 2016 20:32
by Alle
I really love to monitor my gas and electric statistics , but they are hard to read in the app with the current chart lines..
Is there a possibility to replace them with bars or have a choice to use lines or bars in the future?
Posted: Friday 08 January 2016 23:14
by RoadXY
We're thinking on a way how to improve the graphs.
Bars is one of the options.
Posted: Saturday 09 January 2016 11:14
by darkrain
Became a beta tester yesterday.
I want to use the geofencing option to determine if I'm home or not, but at the moment the geofencing seems unreliable.
After the update to the beta version yesterday I left the house, but the switch never switched off.
After I switched the switch myself and when I came back it did work.
I will do some more testing today.
I hope this functionality will improve in future releases.
Posted: Saturday 09 January 2016 12:31
by RoadXY
We already pushed an update which should make Geofence more reliable by starting Geofence on boot of the phone and on start of the app.
It's still not clear when the issues arise.
Posted: Saturday 09 January 2016 12:34
by darkrain
RoadXY wrote:We already pushed an update which should make Geofence more reliable by starting Geofence on boot of the phone and on start of the app.
Just now it worked fine, leaving the house switched the switch off and when I came back the switch turned on.
Just as you would expect.
Let's see what happens the next few days..
Posted: Saturday 09 January 2016 12:44
by RoadXY
It could be possible that, after this update, the fences has to be registered again to work fine
Posted: Saturday 09 January 2016 13:01
by darkrain
Just to let you know, I did that yesterday right after the update.
Posted: Saturday 09 January 2016 13:46
by RoadXY
darkrain wrote:Just to let you know, I did that yesterday right after the update.
Ok, thanks for the heads up!
Posted: Saturday 09 January 2016 14:37
by tomson
Under the server connection settings, my local SSIDs are always empty. Is this maybe a bug?
Sent from my Nexus 5 using Tapatalk
