Try to restart your Domoticz now...jaha wrote: Thursday 08 March 2018 14:38 How can I change the MyDomoticz Instance ID ? Im sure it will work if I reset it.
MyDomoticz - Testers wanted!
- chimit
- Domoticz version: master
Re: MyDomoticz - Testers wanted!
Thanks now it shows up but when I click on it it says Server not online and have to restart domoticz for it to show up again.
Alme
can I set in "Allowed IP address(es)" of "Instance properties" my host (DDNS service) instead of IP address?
Thank a lot
Thank a lot
- chimit
No, that won't work.Alme wrote: Thursday 08 March 2018 19:35 Hi all,
Thank a lot
After clicking on the green icon on my domoticz it says server not online on the status if I check will be EXITED:
pi@raspberrypi:~ $ sudo systemctl status domoticz.service
● domoticz.service - LSB: Home Automation System
Loaded: loaded (/etc/init.d/domoticz.sh; generated; vendor preset: enabled)
Active: active (exited) since Thu 2018-03-08 22:19:07 UTC; 1min 25s ago
Docs: man:systemd-sysv-generator(8)
Process: 1282 ExecStop=/etc/init.d/domoticz.sh stop (code=exited, status=0/SUCCESS)
Process: 1292 ExecStart=/etc/init.d/domoticz.sh start (code=exited, status=0/SUCCESS)
Mar 08 22:19:07 raspberrypi systemd[1]: Starting LSB: Home Automation System...
Mar 08 22:19:07 raspberrypi domoticz.sh[1292]: 2018-03-08 22:19:07.357 Domoticz V3.8984 (c)2012-2018 GizMoCuz
Mar 08 22:19:07 raspberrypi domoticz.sh[1292]: 2018-03-08 22:19:07.357 Build Hash: 5126eb6e, Date: 2018-03-08 21:51:23
Mar 08 22:19:07 raspberrypi domoticz.sh[1292]: 2018-03-08 22:19:07.358 Startup Path: /home/pi/domoticz/
Mar 08 22:19:07 raspberrypi domoticz.sh[1292]: domoticz: Domoticz is starting up....
Mar 08 22:19:07 raspberrypi systemd[1]: Started LSB: Home Automation System.
Mar 08 22:19:07 raspberrypi domoticz[1300]: Domoticz running...
LoTheGeek
Re: Testers wanted!
Hi,chimit wrote: Sunday 24 July 2016 18:57Thanks for spotting this! You caught us a bug. A patch has been made and will be live in about 30 minutes.deejc wrote:Just tried it again after a another password reset and now it seems to work..odd
actually scratch that, 2FA is not enabled as i reset the password...reenabled 2FA, no go.
I've just setup my home domoticz server (V3.8153) on a RPI3 with Raspbian
I've created my account on myDomoticz and successfully connected my RPI to the proxy.
As described in this post, I'm not able to connect on myDomoticz Proxy each time i activate the 2 factor authentication.
If I remove 2FA user name and password are working fine.
I'm using Google Authenticator or Authy as 2fa application.
Laurent
Any suggetions why my domoticz stop working and have to be restarted after i click on the green man on mydomo?
Hi All,
I have just registered on the MyDomoticz website. But I'm not getting an Instance ID...
Log shows:
2018-03-13 20:44:41.691 Error: PROXY: timeout occurred, reconnecting
2018-03-13 20:44:41.691 Error: PROXY: Connect failed, reconnecting: Network is unreachable
Thank you for helping me out!
Kristof
Log shows:
Kristof
- chimit
It seems a network issue on your side.fechp wrote: Tuesday 13 March 2018 20:45 Hi All,
Log shows:
Kristof
KiiB
- Domoticz version: Stable
Dear Chimit,
Meybe You could help me?
I already writed in other post, but noone answered me.
I have mydomoticz instance, in properties I see it registered with 9030 version, and my actual server is updated to 9045 version.
Now i cant delete ID. even when i delete login and pass and later restart server, I cant delete instance coz it showing online one day 17 hours + (seems its waiting response from version 9030 while my server already on 9047.) I dont have older version setup
Should wait till mydomoticz server restart itself? but how long? week? month?
Instance ID A930F0CE062B697
Its on Windows version
KiiB
Ok, After 40+ hours, or mydomoticz server restarted, or Admins saw my request and kicked that instance out, I reregistred again, got new ID, works as before.
Thanks.
Thanks.
KiiB
Problem occoured again.
Looks like instance is somehow depends on network adapter mac adress? Coz now im sure it stuck after I installed new network card and server connected to internet throught it.
Instance id EA999F877E400A4.
If i connect server with old network card id doesnt bound again.
Any thoughts inplement some button to force stop instance? or just turn off protection which don't let you delete instance if its active?
Can you provide me the used port numbers? Maybe it is blocked by the firewall? Or is it using regular 443?chimit wrote: Tuesday 13 March 2018 21:13It seems a network issue on your side.fechp wrote: Tuesday 13 March 2018 20:45 Hi All,
Log shows:
Kristof
Thanks again! Kristof
- chimit
If you use a recent Domoticz version it's 443.fechp wrote: Friday 16 March 2018 12:42Can you provide me the used port numbers? Maybe it is blocked by the firewall? Or is it using regular 443?chimit wrote: Tuesday 13 March 2018 21:13It seems a network issue on your side.fechp wrote: Tuesday 13 March 2018 20:45 Hi All,
Log shows:
Kristof
Older versions use 9999.
== Rene
KiiB
That keep alive mechanism keep my instance alive 2 days after real connection between my server and instance disconected. Im almost sure that happend after i changed my network card.chimit wrote: Tuesday 27 February 2018 11:46This could possibly be mydomoticz related. Usually offline instances get kicked. But sometimes, for some reason, they do not.YOYO wrote: Tuesday 27 February 2018 11:36 That should be great.
Although ever since last night it seems something went wrong somewhere.
I can see my instance is currently online via the mydomoticz page but when i click on it it says my domoticz is dead.
I whipped my cache to force the browser to pick up the new data.
Unfortunately it now only says Oops!
So is it something mydomoticz related or is it a local problem?
Not sure why... there's a keepalive mechanism in place.
Some logs:
2018-03-16 23:31:24.268 Proxymanager started.
2018-03-16 23:31:25.213 Active notification Subsystems: email (1/14)
2018-03-16 23:31:25.898 PROXY: Authenticate result: Disallowing due to maxinstances (EA999F877E400A4)..
2018-03-16 23:32:19.296 Hardware Monitor: Fetching data (System sensors)
2018-03-16 23:32:25.963 Error: PROXY: timeout occurred, reconnecting
And since instance green i cant remove it to get new id..
- chimit
As you can see, there is a new option in MyDomoticz: A vanity host name. This option is available to the people who are so nice to donate an arbitrary amount of euros (minimal 1).
This is to celebrate a 2500 concurrent Domoticz instances mile stone.
You can find the option in the settings screen of your instance(s).
For the people who already donated: Thanks for that!
== Rene
== Rene
- chimit
Apologies... There has been an incident with the CPU of the host machine that hosts the MyDomoticz VPS.
Therefore, MyDomoticz has been down last night from 02:40 until just now. Apologies for the inconvenience.
== Rene
== Rene
chimit wrote: Wednesday 21 March 2018 7:23 Apologies... There has been an incident with the CPU of the host machine that hosts the MyDomoticz VPS.
== Rene
2018-03-26 13:10:44.437 PROXY: Incoming connection from:XXXXXX
2018-03-26 13:10:44.438 Error: Domoticz received fatal signal 11 !...
2018-03-26 13:10:44.463 Error: /home/pi/domoticz/domoticz() [0x24eb0c]
2018-03-26 13:10:44.463 Error: /home/pi/domoticz/domoticz(_Z14signal_handleri+0x4c) [0x24ebc4]
2018-03-26 13:10:44.463 Error: /lib/arm-linux-gnueabihf/libc.so.6(__default_sa_restorer+0) [0x76be26b0]
2018-03-26 13:10:44.463 Error: /home/pi/domoticz/domoticz(_ZN4http6server20cWebemRequestHandler14handle_requestERKNS0_7requestERNS0_5replyE+0x11c) [0x5f2130]
2018-03-26 13:10:44.464 Error: /home/pi/domoticz/domoticz(_ZN4http6server12CProxyClient10GetRequestERKNSt7__cxx1112basic_stringIcSt11char_traitsIcESaIcEEEN5boost4asio17mutab$
2018-03-26 13:10:44.464 Error: /home/pi/domoticz/domoticz(_ZN4http6server12CProxyClient17HandlePDU_REQUESTEPKcR16CValueLengthPart+0x3d0) [0x6028fc]
2018-03-26 13:10:44.464 Error: /home/pi/domoticz/domoticz(_ZN4http6server12CProxyClient10PduHandlerER8ProxyPdu+0x100) [0x5fd1a0]
2018-03-26 13:10:44.464 Error: /home/pi/domoticz/domoticz(_ZN4http6server12CProxyClient11handle_readERKN5boost6system10error_codeEj+0x144) [0x601dc8]
2018-03-26 13:10:44.464 Error: /home/pi/domoticz/domoticz(_ZN5boost4asio3ssl6detail5io_opINS0_19basic_stream_socketINS0_2ip3tcpEEENS2_7read_opINS0_17mutable_buffers_1EEENS_3$
2018-03-26 13:10:44.464 Error: /home/pi/domoticz/domoticz(_ZN5boost4asio6detail23reactive_socket_recv_opINS0_17mutable_buffers_1ENS0_3ssl6detail5io_opINS0_19basic_stream_soc$
2018-03-26 13:10:44.464 Error: /home/pi/domoticz/domoticz(_ZN5boost4asio6detail13epoll_reactor16descriptor_state11do_completeEPvPNS1_19scheduler_operationERKNS_6system10erro$
2018-03-26 13:10:44.464 Error: /home/pi/domoticz/domoticz(_ZN5boost4asio6detail9scheduler3runERNS_6system10error_codeE+0x378) [0x3e75a4]
2018-03-26 13:10:44.464 Error: /home/pi/domoticz/domoticz(_ZN4http6server13CProxyManager11StartThreadEv+0x190) [0x600ff4]
2018-03-26 13:10:44.465 Error: /home/pi/domoticz/domoticz() [0x7ba650]
- chimit
Do you have any idea what request it was? Or did you just click on the green icon?
jaha wrote: Monday 26 March 2018 15:12chimit wrote: Wednesday 21 March 2018 7:23 Apologies... There has been an incident with the CPU of the host machine that hosts the MyDomoticz VPS.
== Rene
