Easiest way to migrate Openzwave to ZWave-JS-UI
- madpatrick
- Domoticz version: 2025.2
Re: Easiest way to migrate Openzwave to ZWave-JS-UI
I tried it but broke my Zwave.
Gladly i had a snapshot to restore to
Still struggling to disable the unescassery devices
But, must i check the items i want to disable and then click on "Disable Discovery" And do i then need to click on "Store"?
Appreciate your help
- user4563
Just disable and store to save
Aeotec Z-Stick Gen5+
ZWave-JS-UI / Mosquitto MQTT
Domoticz for Android
- madpatrick
I've set all config_switch and config_number of all devices to disabled and stored them
After restart all devices are still loaded in Domoticz
Where is it going wrong for me ?
- jvdz
- Domoticz version: 4.107
Did you remove the old retained mqtt messages from mosquito?
- madpatrick
No.
Must i clear all retained messages ?
- jvdz
I'm surprised you ask this question. Try to understand how things work first so you can make that decision yourself!
zwave2mqtt sends a discovery message for each device at startup and when it gets a message that (in this case) HomeAssistant is up.
So when these messages are retained, they stay there forever until somebody removes them. So when you remove any devices in ZWAVE2MQTT for being advertised, you need to remove their discovery record from Mosquitto too when you defined to retain these messages.
Now it is up to you to see what information is contained in the homeassistant message tree and what can be deleted.
Deleting all for zwave2mqtt (subtree under homeassistant) should normally work, as it will send all messages again when domoticz or zwave2mqtt is started.
jvmaanen
I installed a new OS on my raspberry PI and followed the steps from https://wiki.domoticz.com/Zwave-JS-UI.
When I run "sudo usermod -aG docker ${USER}" I get the reponse "usermod: group 'docker' does not exist"
The next command "sudo systemctl enable docker" returns "Failed to enable unit: Unit docker.service does not exist"
I'm still not able to move from openzwave to Zwave-JS-UI
- jvdz
Is docker installed on your pi?
jvmaanen
I followed these steps:
curl -fsSL test.docker.com -o get-docker.sh && sh get-docker.sh
jvmaanen
The result from "curl -fsSL test.docker.com -o get-docker.sh && sh get-docker.sh" is:
# Executing docker install script, commit: 7d96bd3c5235ab2121bcb855dd7b3f3f37128ed4
+ sudo -E sh -c apt-get -qq update >/dev/null
E: The repository 'https://download.docker.com/linux/raspbian trixie Release' does not have a Release file.
- jvdz
I am sure that a search in chatgpt or Google AI will explain why !
- madpatrick
Maybe a bit more info on the Wiki. Nothing is mentioned about the MQTT explorer or some alikejvdz wrote: Sunday 07 December 2025 18:12I'm surprised you ask this question. Try to understand how things work first so you can make that decision yourself!![]()
Not all users a IT (like me) Some time it helps when it is in Jip & Janneke language
- Domoticz version: 2025.1
https://wiki.domoticz.com/Zwave-JS-UI#Debug_MQTTmadpatrick wrote: Tuesday 09 December 2025 12:43Maybe a bit more info on the Wiki. Nothing is mentioned about the MQTT explorer or some alikejvdz wrote: Sunday 07 December 2025 18:12I'm surprised you ask this question. Try to understand how things work first so you can make that decision yourself!![]()
Not all users a IT (like me) Some time it helps when it is in Jip & Janneke language![]()
It ihas a reference to the general MQTT wiki debug section: https://wiki.domoticz.com/MQTT#Debugging_MQTT
And in the Zwave-JS-UI documentation it is also mentioned: https://zwave-js.github.io/zwave-js-ui/ ... leshooting
- madpatrick
Fair point. Missed that completly
