Python Plugin: MqttMapper
FlyingDomotic
Re: Python Plugin: MqttMapper
Post by FlyingDomotic »
Could you please copy here content of JSON configuration file?
rron
Post by rron »
rron wrote: Sunday 11 January 2026 13:47 I made a new topic in the mapper config file the SOC for my car but the error in the domoticz log is"Error: Mapper: Can't find device key wican/amperae/SOC"
The wican module of my car gives in the mqtt explorer wican/amperae/SOC. I am on Version: 2025.2 (build 16836)
And the json file is
    "amperae State of Charge": {
        "topic": "wican/amperae/SOC",
        "type": "243", "subtype": "6", "switchtype": "0",
        "mapping": {"item": "", "multiplier": 0.1}
    /code]
[/quote]
FlyingDomotic
There's a strange thing in the log. MqttMapper says it'll create "amperae State of Charge" and "amperae Hv Capacity" devices but it seems it don't. Going deeper, this message is show at each MqttMapper startup.
Would it be possible to have a look into Domoticz log, to see if "Device creation" is allowed in parameters ("Setup" > "Parameters")?
And check that devices are properly created in device list ("Setup" > "Devices"). If that's the case, check these 2 devices that they have been made available (arrow at end od line should be blue, to the left, and NOT green, to the right)?
rron
Post by rron »
FlyingDomotic wrote: Monday 19 January 2026 9:44 There's a strange thing in the log. MqttMapper says it'll create "amperae State of Charge" and "amperae Hv Capacity" devices but it seems it don't. Going deeper, this message is show at each MqttMapper startup.
I do not see Device creation in the logging. I think that should be in the begining?
There is no item created in the device list also
In the older mapper items like device 1-7 where created in a previous time, so the mapper is working.
FlyingDomotic
Is there any errors into Domoticz log related to these devices creation?
It's look like MqttMapper ask for device creation, but Domoticz don't do it. It normally should give some error messages somewhere.
Just a remark, not related to this issue: why creating a percentage device (243/6) as data seems to be a value, not a percentage?
rron
Post by rron »
No there’s no error in domoticz log i will try to investigate this in the weekend. Perhaps the log level should be higher.
I will let you know what happens.
rron
Post by rron »
This is the extended logging from domoticz. I cannot see anything weird in it.
2026-01-24 13:50:40.277  Status: Startup Path: /opt/domoticz/
2026-01-24 13:50:40.402  Sunrise: 08:33:00 SunSet: 17:11:00
2026-01-24 13:50:40.402  Day length: 08:38:00 Sun at south: 12:52:00
2026-01-24 13:50:40.402  Civil twilight start: 07:55:00 Civil twilight end: 17:50:00
2026-01-24 13:50:40.402  Nautical twilight start: 07:13:00 Nautical twilight end: 18:31:00
2026-01-24 13:50:40.402  Astronomical twilight start: 06:33:00 Astronomical twilight end: 19:12:00
2026-01-24 13:50:40.460  Status: PluginSystem: Started, Python version '3.11.2', 1 plugin definitions loaded.
2026-01-24 13:50:40.465  Status: : Using default poll interval of 10 secs.
2026-01-24 13:50:40.474  Active notification Subsystems: lms (1/13)
2026-01-24 13:50:40.517  Status: WebServer(HTTP) started on address: :: with port 8080
2026-01-24 13:50:40.529  Status: WebServer(SSL) started on address: :: with port 443
2026-01-24 13:50:40.533  Starting shared server on: :::6144
2026-01-24 13:50:40.534  Status: TCPServer: shared server started...
2026-01-24 13:50:40.535  Status: mDNS: Service started
2026-01-24 13:50:40.536  mDNS: Service: _http._tcp.local.:443 for Hostname: domoticz (1 socket)
2026-01-24 13:50:40.538  Status: RxQueue: queue worker started...
2026-01-24 13:50:42.552  Status: Motherboard: System: ODroid/Raspberry
2026-01-24 13:50:42.553  Status: Motherboard: Hardware Monitor: Started (OStype Linux)
2026-01-24 13:50:42.559  Status: Hue: Worker started...
2026-01-24 13:50:42.560  Status: Weer: Started...
2026-01-24 13:50:42.560  Status: Squeezebox: Worker started...
2026-01-24 13:50:42.567  Mapper: Worker thread started.
2026-01-24 13:50:42.574  Status: Mapper: Started.
2026-01-24 13:50:42.570  Status: anna: AnnaTherm:Worker started...
2026-01-24 13:50:42.573  Status: Slimme meter: attempt connect to 192.168.178.21:23
2026-01-24 13:50:42.570  Status: Squeezebox: 3 player-switch(es) found.
2026-01-24 13:50:42.576  Status: Mapper: Entering work loop.
2026-01-24 13:50:42.584  Status: EventSystem: reset all events...
2026-01-24 13:50:42.606  Status: dzVents: Write file: /opt/domoticz/userdata/scripts/dzVents/generated_scripts/Pvoutput.lua
2026-01-24 13:50:42.595  Status: Slimme meter: Connected to: 192.168.178.21:23
2026-01-24 13:50:42.595  Status: Telefoon: Connected to: 192.168.178.1:1012
2026-01-24 13:50:42.584  Status: NotificationSystem: thread started...
2026-01-24 13:50:42.606  Status: EventSystem: reset all device statuses...
2026-01-24 13:50:42.615  Status: Squeezebox: No playlists found.
2026-01-24 13:50:42.684  Status: Slimme meter: Meter reports as ESMR 5.0
2026-01-24 13:50:42.684  Status: Slimme meter: Current electricity tariff: Low
2026-01-24 13:50:42.864  Status: Python EventSystem: Initializing event module.
2026-01-24 13:50:42.865  Status: EventSystem: Started
2026-01-24 13:50:42.869  Status: EventSystem: Queue thread started...
2026-01-24 13:50:42.905  Status: PluginSystem: 1 plugins started.
2026-01-24 13:50:43.071  Status: Mapper: Initialized version 25.12.9-1, author 'Flying Domotic'
2026-01-24 13:50:43.075  Mapper: Debug logging mask set to: PYTHON PLUGIN
2026-01-24 13:50:43.078  Mapper: /opt/domoticz/userdata/plugins/MqttMapper/MqttMapper.json is a version 1.0 file
2026-01-24 13:50:43.260  Mapper: pluginV1::__init__
2026-01-24 13:50:43.260  Mapper: 'HardwareID': '48'
2026-01-24 13:50:43.260  Mapper: 'HomeFolder': '/opt/domoticz/userdata/plugins/MqttMapper/'
2026-01-24 13:50:43.260  Mapper: 'StartupFolder': '/opt/domoticz/'
2026-01-24 13:50:43.261  Mapper: 'UserDataFolder': '/opt/domoticz/userdata/'
2026-01-24 13:50:43.262  Mapper: 'Database': '/opt/domoticz/userdata/domoticz.db'
2026-01-24 13:50:43.262  Mapper: 'Language': 'nl'
2026-01-24 13:50:43.263  Mapper: 'Version': '25.12.9-1'
2026-01-24 13:50:43.263  Mapper: 'Author': 'Flying Domotic'
2026-01-24 13:50:43.263  Mapper: 'Name': 'Mapper'
2026-01-24 13:50:43.263  Mapper: 'Address': '192.168.178.50'
2026-01-24 13:50:43.263  Mapper: 'Port': '1883'
2026-01-24 13:50:43.263  Mapper: 'Key': 'MqttMapper'
2026-01-24 13:50:43.263  Mapper: 'Mode1': 'MqttMapper.json'
2026-01-24 13:50:43.263  Mapper: 'Mode6': 'Normal'
2026-01-24 13:50:43.263  Mapper: 'DomoticzVersion': '2025.2 (build 16836)'
2026-01-24 13:50:43.263  Mapper: 'DomoticzHash': '3b8a9cf2f'
2026-01-24 13:50:43.263  Mapper: 'DomoticzBuildTime': '2025-10-26 10:11:08'
2026-01-24 13:50:43.263  Mapper: Device count: 7
2026-01-24 13:50:43.263  Mapper: Device: 1 - ID: 867, Name: 'charge current', nValue: 16, sValue: '16.0'
2026-01-24 13:50:43.263  Mapper: Device: 2 - ID: 868, Name: 'max current', nValue: 16, sValue: '16.0'
2026-01-24 13:50:43.263  Mapper: Device: 3 - ID: 901, Name: 'evenergy charged', nValue: 12893, sValue: '12893.0'
2026-01-24 13:50:43.263  Mapper: Device: 4 - ID: 870, Name: 'evtotalenergy charged', nValue: 1043, sValue: '1043.448'
2026-01-24 13:50:43.263  Mapper: Device: 5 - ID: 871, Name: 'SmartEVSE state', nValue: 0, sValue: 'Ready to Charge'
2026-01-24 13:50:43.264  Mapper: Device: 6 - ID: 872, Name: 'SmartEVSE error', nValue: 0, sValue: '0'
2026-01-24 13:50:43.264  Mapper: Device: 7 - ID: 873, Name: 'charge current override', nValue: 0, sValue: '0.0'
2026-01-24 13:50:43.265  Mapper: Creating device amperae State of Charge
2026-01-24 13:50:43.265  Mapper: Creating device amperae Hv Capacity
2026-01-24 13:50:43.266  Mapper: MqttClient::__init__
2026-01-24 13:50:43.268  Mapper: Heartbeat interval set to: 3.
2026-01-24 13:50:43.319  Mapper: MqttClient::onConnect
2026-01-24 13:50:43.319  Mapper: MqttClient::onConnect connect to 192.168.178.50:1883, ID=Domoticz_MqttMapper_48_1769259043
2026-01-24 13:50:43.370  Mapper: onMQTTConnected
2026-01-24 13:50:43.370  Mapper: getTopics: '{'SmartEVSE-5572/EVEnergyCharged', 'SmartEVSE-5572/ChargeCurrentOverride', 'wican/amperae/HV_CAPACITY', 'SmartEVSE-5572/MaxCurrent', 'SmartEVSE-5572/ChargeCurrent', 'SmartEVSE-5572/EVTotalEnergyCharged', 'SmartEVSE-5572/Error', 'SmartEVSE-5572/State', 'wican/amperae/SOC'}'
2026-01-24 13:50:43.370  Mapper: MqttClient::Subscribe to [{'Topic': 'SmartEVSE-5572/EVEnergyCharged', 'QoS': 0}, {'Topic': 'SmartEVSE-5572/ChargeCurrentOverride', 'QoS': 0}, {'Topic': 'wican/amperae/HV_CAPACITY', 'QoS': 0}, {'Topic': 'SmartEVSE-5572/MaxCurrent', 'QoS': 0}, {'Topic': 'SmartEVSE-5572/ChargeCurrent', 'QoS': 0}, {'Topic': 'SmartEVSE-5572/EVTotalEnergyCharged', 'QoS': 0}, {'Topic': 'SmartEVSE-5572/Error', 'QoS': 0}, {'Topic': 'SmartEVSE-5572/State', 'QoS': 0}, {'Topic': 'wican/amperae/SOC', 'QoS': 0}]
2026-01-24 13:50:43.421  Mapper: onMQTTSubscribed
2026-01-24 13:50:43.424  Mapper: onMQTTPublish found SmartEVSE-5572/EVEnergyCharged, Device 'evenergy charged', message '12893'
2026-01-24 13:50:43.425  Mapper: Setting evenergy charged to 12893/12893.0
2026-01-24 13:50:43.428  Mapper: onMQTTPublish found SmartEVSE-5572/ChargeCurrentOverride, Device 'charge current override', message '0'
2026-01-24 13:50:43.428  Mapper: Setting charge current override to 0/0.0
2026-01-24 13:50:43.434  Mapper: onMQTTPublish found SmartEVSE-5572/MaxCurrent, Device 'max current', message '160'
2026-01-24 13:50:43.435  Mapper: Setting max current to 16/16.0
2026-01-24 13:50:43.439  Mapper: onMQTTPublish found SmartEVSE-5572/ChargeCurrent, Device 'charge current', message '160'
2026-01-24 13:50:43.439  Mapper: Setting charge current to 16/16.0
2026-01-24 13:50:43.444  Mapper: onMQTTPublish found SmartEVSE-5572/Error, Device 'SmartEVSE error', message 'None'
2026-01-24 13:50:43.446  Mapper: testValue="None" (str), readValue="None" (str)
2026-01-24 13:50:43.446  Mapper: testValue="No Power Available" (str), readValue="None" (str)
2026-01-24 13:50:43.446  Mapper: testValue="Communication Error" (str), readValue="None" (str)
2026-01-24 13:50:43.447  Mapper: testValue="Temperature High" (str), readValue="None" (str)
2026-01-24 13:50:43.447  Mapper: testValue="EV Meter Comm Error" (str), readValue="None" (str)
2026-01-24 13:50:43.447  Mapper: testValue="RCM Tripped" (str), readValue="None" (str)
2026-01-24 13:50:43.448  Mapper: testValue="Waiting for Solar" (str), readValue="None" (str)
2026-01-24 13:50:43.448  Mapper: testValue="Test IO" (str), readValue="None" (str)
2026-01-24 13:50:43.448  Mapper: testValue="Flash Error" (str), readValue="None" (str)
2026-01-24 13:50:43.448  Mapper: testValue="**Unknown**" (str), readValue="None" (str)
2026-01-24 13:50:43.449  Mapper: Setting SmartEVSE error to 0/0
2026-01-24 13:50:43.456  Mapper: onMQTTPublish found SmartEVSE-5572/State, Device 'SmartEVSE state', message 'Ready to Charge'
2026-01-24 13:50:43.458  Mapper: Setting SmartEVSE state to >Ready to Charge<
2026-01-24 13:50:43.570  Status: MQTT: Connecting to 192.168.178.50:1883
2026-01-24 13:50:43.580  anna: ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
2026-01-24 13:50:43.580  anna: Plugwise Plugin Version: 1.0.1
2026-01-24 13:50:43.580  anna: Notice: To change the preset by way of scripts/events, please use the following percentages levels:
2026-01-24 13:50:43.581  anna: 10% for Home, 20% for Away, 30% for Night, 40% for Vacation & 50% for Frost (Lua use 'Set Level: 20')
2026-01-24 13:50:43.581  anna: Any other value will be refused!
2026-01-24 13:50:43.581  anna: To Detect changes in scripts use 'Off, Home, Away, Night, Vacation, Frost'
2026-01-24 13:50:43.581  anna: Adjusting the Temp manually on the ANNA or via App, forces the ANNA to set Scenes to Off!!
2026-01-24 13:50:43.581  anna: KNOWN ISSUE: The Gateway will not send an correct update if the previous scene is choosen again!
2026-01-24 13:50:43.581  anna: ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
2026-01-24 13:50:43.635  Status: Squeezebox: 1 connected player(s) found.
2026-01-24 13:50:43.657  Squeezebox: (LibreELEC) Disconnected
2026-01-24 13:50:43.772  Status: MQTT: Connected to: 192.168.178.50:1883
2026-01-24 13:50:43.971  Hue: Color Switch (Hue color spot 1)
2026-01-24 13:50:43.977  Hue: Color Switch (Hue color spot 2)
2026-01-24 13:50:43.982  Hue: Color Switch (Hue color spot 3)
2026-01-24 13:50:44.275  Status: MQTT: Discovered: Zigbee2MQTT Bridge (Restart required)/Zigbee2MQTT Bridge (Restart required) (unique_id: bridge_0x00124b002b5f63e4_restart_required_zigbeeauto)
2026-01-24 13:50:44.293  Hue: Light/Switch (ZGPSwitch Friends of Hue Switch 1)
2026-01-24 13:50:44.377  Status: MQTT: Discovered: Voordeur (Voordeur_any)/Voordeur (Voordeur_any) (unique_id: zwavejs2mqtt_0xdb22c9b0_3-48-0-Any)
2026-01-24 13:50:44.479  Status: MQTT: Discovered: Voordeur (Voordeur_battery_islow)/Voordeur (Voordeur_battery_islow) (unique_id: zwavejs2mqtt_0xdb22c9b0_3-128-0-isLow)
2026-01-24 13:50:44.565  Motherboard: Temp (Internal Temperature)
2026-01-24 13:50:44.580  Status: MQTT: Discovered: Voordeur (Voordeur_event_general_purpose)/Voordeur (Voordeur_event_general_purpose) (unique_id: zwavejs2mqtt_0xdb22c9b0_3-156-0-state-0)
2026-01-24 13:50:44.611  Telefoon: RFXMeter (Bytes Send (MB))
2026-01-24 13:50:44.613  Telefoon: RFXMeter (Bytes Received (MB))
2026-01-24 13:50:44.616  Telefoon: General/Custom Sensor (TX mbps)
2026-01-24 13:50:44.619  Telefoon: General/Custom Sensor (RX mbps)
2026-01-24 13:50:44.681  Status: MQTT: Discovered: Achterdeur (Achterdeur_any)/Achterdeur (Achterdeur_any) (unique_id: zwavejs2mqtt_0xdb22c9b0_22-48-0-Any)
2026-01-24 13:50:44.685  anna: General/Custom Sensor (burner_operation_time)
2026-01-24 13:50:44.688  anna: Lux (illuminance)
2026-01-24 13:50:44.694  anna: Temp (Anna temp)
2026-01-24 13:50:44.698  anna: Setpoint (Anna themp set)
2026-01-24 13:50:44.783  Status: MQTT: Discovered: Achterdeur (Achterdeur_battery_islow)/Achterdeur (Achterdeur_battery_islow) (unique_id: zwavejs2mqtt_0xdb22c9b0_22-128-0-isLow)
2026-01-24 13:50:44.887  Status: MQTT: Discovered: Achterdeur (Achterdeur_event_general_purpose)/Achterdeur (Achterdeur_event_general_purpose) (unique_id: zwavejs2mqtt_0xdb22c9b0_22-156-0-state-0)
2026-01-24 13:50:45.190  Status: MQTT: Discovered: Kamerdimmer (Kamerdimmer_load_error_status_1)/Kamerdimmer (Kamerdimmer_load_error_status_1) (unique_id: zwavejs2mqtt_0xdb22c9b0_23-113-1-Power_Management-Load_error_status)
2026-01-24 13:50:45.294  Status: MQTT: Discovered: Lamp vensterbank (Lamp vensterbank_over-current_status)/Lamp vensterbank (Lamp vensterbank_over-current_status) (unique_id: zwavejs2mqtt_0xdb22c9b0_34-113-0-Power_Management-Over-current_status)
2026-01-24 13:50:45.497  Status: MQTT: Discovered: Lamp wand (Lamp wand_over-current_status)/Lamp wand (Lamp wand_over-current_status) (unique_id: zwavejs2mqtt_0xdb22c9b0_35-113-0-Power_Management-Over-current_status)
2026-01-24 13:50:45.700  Status: MQTT: Discovered: Audio/video (Audio/video_over-current_status)/Audio/video (Audio/video_over-current_status) (unique_id: zwavejs2mqtt_0xdb22c9b0_36-113-0-Power_Management-Over-current_status)
2026-01-24 13:50:45.903  Status: MQTT: Discovered: Lamp overloop (Lamp overloop_over-current_status)/Lamp overloop (Lamp overloop_over-current_status) (unique_id: zwavejs2mqtt_0xdb22c9b0_40-113-0-Power_Management-Over-current_status)
2026-01-24 13:50:46.408  Status: MQTT: Discovered: Lamp kast (Effect)/Lamp kast (Effect) (unique_id: 0x00178801088713d8_effect_zigbeeauto)
2026-01-24 13:50:46.611  Status: MQTT: Discovered: Lamp slaapkamer (Effect)/Lamp slaapkamer (Effect) (unique_id: 0x0017880108a70bf7_effect_zigbeeauto)
2026-01-24 13:50:46.714  Status: MQTT: Discovered: Slaapkamer schakelaar (Device mode)/Slaapkamer schakelaar (Device mode) (unique_id: 0x001788010b001d39_device_mode_zigbeeauto)
2026-01-24 13:50:46.918  Status: MQTT: Discovered: Lamp vloer (Effect)/Lamp vloer (Effect) (unique_id: 0x001788010b281074_effect_zigbeeauto)
2026-01-24 13:50:47.021  Status: MQTT: Discovered: Temperatuur badkamer (Temperature units)/Temperatuur badkamer (Temperature units) (unique_id: 0xe0798dfffecc82ee_temperature_units_zigbeeauto)
2026-01-24 13:50:47.125  Status: MQTT: Discovered: Temperatuur zolder (Temperature units)/Temperatuur zolder (Temperature units) (unique_id: 0xf4b3b1fffe29cc78_temperature_units_zigbeeauto)
2026-01-24 13:50:47.228  Status: MQTT: Discovered: Temperatuur slaapkamer (Temperature units)/Temperatuur slaapkamer (Temperature units) (unique_id: 0xf4b3b1fffe94facb_temperature_units_zigbeeauto)
2026-01-24 13:50:47.330  Status: MQTT: Discovered: Zigbee2MQTT Bridge (Version)/Zigbee2MQTT Bridge (Version) (unique_id: bridge_0x00124b002b5f63e4_version_zigbeeauto)
2026-01-24 13:50:47.431  Status: MQTT: Discovered: Zigbee2MQTT Bridge (Coordinator version)/Zigbee2MQTT Bridge (Coordinator version) (unique_id: bridge_0x00124b002b5f63e4_coordinator_version_zigbeeauto)
2026-01-24 13:50:47.533  Status: MQTT: Discovered: Zigbee2MQTT Bridge (Network map)/Zigbee2MQTT Bridge (Network map) (unique_id: bridge_0x00124b002b5f63e4_network_map_zigbeeauto)
2026-01-24 13:50:47.635  Status: MQTT: Discovered: Temperatuur badkamer/Temperatuur badkamer (unique_id: 0xe0798dfffecc82ee_battery_zigbeeauto)
2026-01-24 13:50:47.664  Slimme meter: P1 Smart Meter (Slimme meter)
2026-01-24 13:50:47.672  Slimme meter: General/Voltage (Voltage L1)
2026-01-24 13:50:47.675  Slimme meter: General/Voltage (Voltage L2)
2026-01-24 13:50:47.678  Slimme meter: General/Voltage (Voltage L3)
2026-01-24 13:50:47.681  Slimme meter: Usage (Usage L1)
2026-01-24 13:50:47.683  Slimme meter: Usage (Delivery L1)
2026-01-24 13:50:47.686  Slimme meter: Usage (Usage L2)
2026-01-24 13:50:47.690  Slimme meter: Usage (Delivery L2)
2026-01-24 13:50:47.697  Slimme meter: Usage (Usage L3)
2026-01-24 13:50:47.710  Slimme meter: Usage (Delivery L3)
2026-01-24 13:50:47.719  Slimme meter: Usage (Actual Usage L1/L2/L3)
2026-01-24 13:50:47.734  Slimme meter: Usage (Actual Delivery L1/L2/L3)
2026-01-24 13:50:47.739  Status: MQTT: Discovered: Temperatuur badkamer/Temperatuur badkamer (unique_id: 0xe0798dfffecc82ee_temperature_zigbeeauto)
2026-01-24 13:50:47.751  Slimme meter: Current (Delivery Current L1/L2/L3)
2026-01-24 13:50:47.757  Slimme meter: Current (Delivery Current L1/L2/L3)
2026-01-24 13:50:47.841  Status: MQTT: Discovered: Temperatuur badkamer/Temperatuur badkamer (unique_id: 0xe0798dfffecc82ee_humidity_zigbeeauto)
2026-01-24 13:50:47.943  Status: MQTT: Discovered: Voordeur (Voordeur_battery_level)/Voordeur (Voordeur_battery_level) (unique_id: zwavejs2mqtt_0xdb22c9b0_3-128-0-level)
2026-01-24 13:50:48.044  Status: MQTT: Discovered: Achterdeur (Achterdeur_battery_level)/Achterdeur (Achterdeur_battery_level) (unique_id: zwavejs2mqtt_0xdb22c9b0_22-128-0-level)
2026-01-24 13:50:48.145  Status: MQTT: Discovered: Wasmachine (Wasmachine_electric_v_value)/Wasmachine (Wasmachine_electric_v_value) (unique_id: zwavejs2mqtt_0xdb22c9b0_18-50-0-value-66561)
2026-01-24 13:50:48.185  Weer: Temp + Humidity + Baro (Thermo buitentemperatuur)
2026-01-24 13:50:48.190  Weer: Wind (Wind)
2026-01-24 13:50:48.193  Weer: UV (UV Index)
2026-01-24 13:50:48.199  Weer: Rain (Rain)
2026-01-24 13:50:48.200  Weer: General/Visibility (Visibility)
2026-01-24 13:50:48.204  Weer: General/Custom Sensor (Solar radiation Sensor)
2026-01-24 13:50:48.207  Weer: General/Percentage (Cloud Cover)
2026-01-24 13:50:48.246  Status: MQTT: Discovered: Wasmachine (Wasmachine_electric_a_value)/Wasmachine (Wasmachine_electric_a_value) (unique_id: zwavejs2mqtt_0xdb22c9b0_18-50-0-value-66817)
2026-01-24 13:50:48.349  Status: MQTT: Discovered: Wasmachine (Wasmachine_electric_kwh_value)/Wasmachine (Wasmachine_electric_kwh_value) (unique_id: zwavejs2mqtt_0xdb22c9b0_18-50-0-value-65537)
2026-01-24 13:50:48.450  Status: MQTT: Discovered: Wasmachine (Wasmachine_electric_w_value)/Wasmachine (Wasmachine_electric_w_value) (unique_id: zwavejs2mqtt_0xdb22c9b0_18-50-0-value-66049)
2026-01-24 13:50:48.553  Status: MQTT: Discovered: Wasmachine (Wasmachine_electric_a_value_0)/Wasmachine (Wasmachine_electric_a_value_0) (unique_id: zwavejs2mqtt_0xdb22c9b0_18-50-0-value-66819)
2026-01-24 13:50:48.654  Status: MQTT: Discovered: Wasmachine (Wasmachine_electric_w_value_0)/Wasmachine (Wasmachine_electric_w_value_0) (unique_id: zwavejs2mqtt_0xdb22c9b0_18-50-0-value-66051)
2026-01-24 13:50:48.755  Status: MQTT: Discovered: Wasmachine (Wasmachine_electric_kwh_value_0)/Wasmachine (Wasmachine_electric_kwh_value_0) (unique_id: zwavejs2mqtt_0xdb22c9b0_18-50-0-value-65539)
2026-01-24 13:50:48.857  Status: MQTT: Discovered: Koelkast (Koelkast_electric_v_value)/Koelkast (Koelkast_electric_v_value) (unique_id: zwavejs2mqtt_0xdb22c9b0_15-50-0-value-66561)
2026-01-24 13:50:48.959  Status: MQTT: Discovered: Koelkast (Koelkast_electric_a_value)/Koelkast (Koelkast_electric_a_value) (unique_id: zwavejs2mqtt_0xdb22c9b0_15-50-0-value-66817)
2026-01-24 13:50:48.983  Status: [web:8080] Incoming connection from: 192.168.178.30
2026-01-24 13:50:49.060  Status: MQTT: Discovered: Koelkast (Koelkast_electric_kwh_value)/Koelkast (Koelkast_electric_kwh_value) (unique_id: zwavejs2mqtt_0xdb22c9b0_15-50-0-value-65537)
2026-01-24 13:50:49.161  Status: MQTT: Discovered: Koelkast (Koelkast_electric_w_value)/Koelkast (Koelkast_electric_w_value) (unique_id: zwavejs2mqtt_0xdb22c9b0_15-50-0-value-66049)
2026-01-24 13:50:49.262  Status: MQTT: Discovered: Koelkast (Koelkast_electric_v_value_0)/Koelkast (Koelkast_electric_v_value_0) (unique_id: zwavejs2mqtt_0xdb22c9b0_15-50-0-value-66563)
2026-01-24 13:50:49.365  Status: MQTT: Discovered: Koelkast (Koelkast_electric_a_value_0)/Koelkast (Koelkast_electric_a_value_0) (unique_id: zwavejs2mqtt_0xdb22c9b0_15-50-0-value-66816)
2026-01-24 13:50:49.466  Status: MQTT: Discovered: Koelkast (Koelkast_electric_w_value_0)/Koelkast (Koelkast_electric_w_value_0) (unique_id: zwavejs2mqtt_0xdb22c9b0_15-50-0-value-66051)
2026-01-24 13:50:49.567  Status: MQTT: Discovered: Koelkast (Koelkast_electric_kwh_value_0)/Koelkast (Koelkast_electric_kwh_value_0) (unique_id: zwavejs2mqtt_0xdb22c9b0_15-50-0-value-65539)
2026-01-24 13:50:49.668  Status: MQTT: Discovered: Koelkast (Koelkast_electric_pulse_count_value)/Koelkast (Koelkast_electric_pulse_count_value) (unique_id: zwavejs2mqtt_0xdb22c9b0_15-50-0-value-66305)
2026-01-24 13:50:49.769  Status: MQTT: Discovered: Koelkast (Koelkast_electric_kvar_value)/Koelkast (Koelkast_electric_kvar_value) (unique_id: zwavejs2mqtt_0xdb22c9b0_15-50-0-value-67329)
2026-01-24 13:50:49.870  Status: MQTT: Discovered: Koelkast (Koelkast_electric_power_factor_value)/Koelkast (Koelkast_electric_power_factor_value) (unique_id: zwavejs2mqtt_0xdb22c9b0_15-50-0-value-67073)
2026-01-24 13:50:49.971  Status: MQTT: Discovered: Koelkast (Koelkast_electric_kvah_value)/Koelkast (Koelkast_electric_kvah_value) (unique_id: zwavejs2mqtt_0xdb22c9b0_15-50-0-value-65793)
2026-01-24 13:50:50.074  Status: MQTT: Discovered: Koelkast (Koelkast_water_cubic_meters_value)/Koelkast (Koelkast_water_cubic_meters_value) (unique_id: zwavejs2mqtt_0xdb22c9b0_15-50-0-value-196609)
2026-01-24 13:50:50.176  Status: MQTT: Discovered: Vaatwasser (Vaatwasser_electric_kwh_value)/Vaatwasser (Vaatwasser_electric_kwh_value) (unique_id: zwavejs2mqtt_0xdb22c9b0_21-50-0-value-65537)
2026-01-24 13:50:50.277  Status: MQTT: Discovered: Vaatwasser (Vaatwasser_electric_w_value)/Vaatwasser (Vaatwasser_electric_w_value) (unique_id: zwavejs2mqtt_0xdb22c9b0_21-50-0-value-66049)
2026-01-24 13:50:50.378  Status: MQTT: Discovered: Vaatwasser (Vaatwasser_electric_v_value)/Vaatwasser (Vaatwasser_electric_v_value) (unique_id: zwavejs2mqtt_0xdb22c9b0_21-50-0-value-66561)
2026-01-24 13:50:50.480  Status: MQTT: Discovered: Vaatwasser (Vaatwasser_electric_a_value)/Vaatwasser (Vaatwasser_electric_a_value) (unique_id: zwavejs2mqtt_0xdb22c9b0_21-50-0-value-66817)
2026-01-24 13:50:50.581  Status: MQTT: Discovered: Magnetron (Magnetron_electric_kwh_value)/Magnetron (Magnetron_electric_kwh_value) (unique_id: zwavejs2mqtt_0xdb22c9b0_20-50-0-value-65537)
2026-01-24 13:50:50.683  Status: MQTT: Discovered: Magnetron (Magnetron_electric_a_value)/Magnetron (Magnetron_electric_a_value) (unique_id: zwavejs2mqtt_0xdb22c9b0_20-50-0-value-66817)
2026-01-24 13:50:50.770  Status: [web:8080] Incoming connection from: 192.168.178.71
2026-01-24 13:50:50.784  Status: MQTT: Discovered: Magnetron (Magnetron_electric_w_value)/Magnetron (Magnetron_electric_w_value) (unique_id: zwavejs2mqtt_0xdb22c9b0_20-50-0-value-66049)
2026-01-24 13:50:50.885  Status: MQTT: Discovered: Magnetron (Magnetron_electric_v_value)/Magnetron (Magnetron_electric_v_value) (unique_id: zwavejs2mqtt_0xdb22c9b0_20-50-0-value-66561)
2026-01-24 13:50:50.986  Status: MQTT: Discovered: Kamerdimmer (Kamerdimmer_power_power_1)/Kamerdimmer (Kamerdimmer_power_power_1) (unique_id: zwavejs2mqtt_0xdb22c9b0_23-49-1-Power)
2026-01-24 13:50:51.088  Status: MQTT: Discovered: Kamerdimmer (Kamerdimmer_electric_kwh_value_1)/Kamerdimmer (Kamerdimmer_electric_kwh_value_1) (unique_id: zwavejs2mqtt_0xdb22c9b0_23-50-1-value-65537)
2026-01-24 13:50:51.189  Status: MQTT: Discovered: Kamerdimmer (Kamerdimmer_electric_w_value_1)/Kamerdimmer (Kamerdimmer_electric_w_value_1) (unique_id: zwavejs2mqtt_0xdb22c9b0_23-50-1-value-66049)
2026-01-24 13:50:51.291  Status: MQTT: Discovered: Lamp vensterbank (Lamp vensterbank_power_power)/Lamp vensterbank (Lamp vensterbank_power_power) (unique_id: zwavejs2mqtt_0xdb22c9b0_34-49-0-Power)
2026-01-24 13:50:51.392  Status: MQTT: Discovered: Lamp vensterbank (Lamp vensterbank_electric_kwh_value)/Lamp vensterbank (Lamp vensterbank_electric_kwh_value) (unique_id: zwavejs2mqtt_0xdb22c9b0_34-50-0-value-65537)
2026-01-24 13:50:51.493  Status: MQTT: Discovered: Lamp vensterbank (Lamp vensterbank_electric_w_value)/Lamp vensterbank (Lamp vensterbank_electric_w_value) (unique_id: zwavejs2mqtt_0xdb22c9b0_34-50-0-value-66049)
2026-01-24 13:50:51.595  Status: MQTT: Discovered: Lamp wand (Lamp wand_power_power)/Lamp wand (Lamp wand_power_power) (unique_id: zwavejs2mqtt_0xdb22c9b0_35-49-0-Power)
2026-01-24 13:50:51.676  Mapper: onMQTTPublish found SmartEVSE-5572/MaxCurrent, Device 'max current', message '160'
2026-01-24 13:50:51.676  Mapper: Setting max current to 16/16.0
2026-01-24 13:50:51.678  Mapper: onMQTTPublish found SmartEVSE-5572/ChargeCurrent, Device 'charge current', message '160'
2026-01-24 13:50:51.678  Mapper: Setting charge current to 16/16.0
2026-01-24 13:50:51.681  Mapper: onMQTTPublish found SmartEVSE-5572/ChargeCurrentOverride, Device 'charge current override', message '0'
2026-01-24 13:50:51.681  Mapper: Setting charge current override to 0/0.0
2026-01-24 13:50:51.696  Status: MQTT: Discovered: Lamp wand (Lamp wand_electric_kwh_value)/Lamp wand (Lamp wand_electric_kwh_value) (unique_id: zwavejs2mqtt_0xdb22c9b0_35-50-0-value-65537)
2026-01-24 13:50:51.746  Mapper: onMQTTPublish found SmartEVSE-5572/State, Device 'SmartEVSE state', message 'Ready to Charge'
2026-01-24 13:50:51.746  Mapper: Setting SmartEVSE state to >Ready to Charge<
2026-01-24 13:50:51.749  Mapper: onMQTTPublish found SmartEVSE-5572/Error, Device 'SmartEVSE error', message 'None'
2026-01-24 13:50:51.750  Mapper: testValue="None" (str), readValue="None" (str)
2026-01-24 13:50:51.750  Mapper: testValue="No Power Available" (str), readValue="None" (str)
2026-01-24 13:50:51.750  Mapper: testValue="Communication Error" (str), readValue="None" (str)
2026-01-24 13:50:51.750  Mapper: testValue="Temperature High" (str), readValue="None" (str)
2026-01-24 13:50:51.750  Mapper: testValue="EV Meter Comm Error" (str), readValue="None" (str)
2026-01-24 13:50:51.750  Mapper: testValue="RCM Tripped" (str), readValue="None" (str)
2026-01-24 13:50:51.750  Mapper: testValue="Waiting for Solar" (str), readValue="None" (str)
2026-01-24 13:50:51.750  Mapper: testValue="Test IO" (str), readValue="None" (str)
2026-01-24 13:50:51.750  Mapper: testValue="Flash Error" (str), readValue="None" (str)
2026-01-24 13:50:51.750  Mapper: testValue="**Unknown**" (str), readValue="None" (str)
2026-01-24 13:50:51.750  Mapper: Setting SmartEVSE error to 0/0
2026-01-24 13:50:51.754  Mapper: onMQTTPublish found SmartEVSE-5572/EVEnergyCharged, Device 'evenergy charged', message '12893'
2026-01-24 13:50:51.755  Mapper: Setting evenergy charged to 12893/12893.0
2026-01-24 13:50:51.758  Mapper: onMQTTPublish found SmartEVSE-5572/EVTotalEnergyCharged, Device 'evtotalenergy charged', message '1043448'
2026-01-24 13:50:51.758  Mapper: Setting evtotalenergy charged to 1043/1043.448
2026-01-24 13:50:51.798  Status: MQTT: Discovered: Lamp wand (Lamp wand_electric_w_value)/Lamp wand (Lamp wand_electric_w_value) (unique_id: zwavejs2mqtt_0xdb22c9b0_35-50-0-value-66049)
2026-01-24 13:50:51.901  Status: MQTT: Discovered: Audio/video (Audio/video_power_power)/Audio/video (Audio/video_power_power) (unique_id: zwavejs2mqtt_0xdb22c9b0_36-49-0-Power)
2026-01-24 13:50:52.005  Status: MQTT: Discovered: Audio/video (Audio/video_electric_kwh_value)/Audio/video (Audio/video_electric_kwh_value) (unique_id: zwavejs2mqtt_0xdb22c9b0_36-50-0-value-65537)
2026-01-24 13:50:52.108  Status: MQTT: Discovered: Audio/video (Audio/video_electric_w_value)/Audio/video (Audio/video_electric_w_value) (unique_id: zwavejs2mqtt_0xdb22c9b0_36-50-0-value-66049)
2026-01-24 13:50:52.212  Status: MQTT: Discovered: Lamp overloop (Lamp overloop_power_power)/Lamp overloop (Lamp overloop_power_power) (unique_id: zwavejs2mqtt_0xdb22c9b0_40-49-0-Power)
2026-01-24 13:50:52.316  Status: MQTT: Discovered: Lamp overloop (Lamp overloop_electric_kwh_value)/Lamp overloop (Lamp overloop_electric_kwh_value) (unique_id: zwavejs2mqtt_0xdb22c9b0_40-50-0-value-65537)
2026-01-24 13:50:52.417  Status: MQTT: Discovered: Lamp overloop (Lamp overloop_electric_w_value)/Lamp overloop (Lamp overloop_electric_w_value) (unique_id: zwavejs2mqtt_0xdb22c9b0_40-50-0-value-66049)
2026-01-24 13:50:52.519  Status: MQTT: Discovered: Lamp schilderij (Lamp schilderij_electric_kwh_value)/Lamp schilderij (Lamp schilderij_electric_kwh_value) (unique_id: zwavejs2mqtt_0xdb22c9b0_39-50-0-value-65537)
2026-01-24 13:50:52.620  Status: MQTT: Discovered: Lamp schilderij (Lamp schilderij_electric_w_value)/Lamp schilderij (Lamp schilderij_electric_w_value) (unique_id: zwavejs2mqtt_0xdb22c9b0_39-50-0-value-66049)
2026-01-24 13:50:52.661  Slimme meter: P1 Smart Meter (Slimme meter)
2026-01-24 13:50:52.666  Slimme meter: General/Voltage (Voltage L1)
2026-01-24 13:50:52.669  Slimme meter: General/Voltage (Voltage L2)
2026-01-24 13:50:52.673  Slimme meter: General/Voltage (Voltage L3)
2026-01-24 13:50:52.677  Slimme meter: Usage (Usage L1)
2026-01-24 13:50:52.682  Slimme meter: Usage (Delivery L1)
2026-01-24 13:50:52.686  Slimme meter: Usage (Usage L2)
2026-01-24 13:50:52.690  Slimme meter: Usage (Delivery L2)
2026-01-24 13:50:52.695  Slimme meter: Usage (Usage L3)
2026-01-24 13:50:52.699  Slimme meter: Usage (Delivery L3)
2026-01-24 13:50:52.703  Slimme meter: Usage (Actual Usage L1/L2/L3)
2026-01-24 13:50:52.708  Slimme meter: Usage (Actual Delivery L1/L2/L3)
2026-01-24 13:50:52.713  Slimme meter: Current (Delivery Current L1/L2/L3)
2026-01-24 13:50:52.716  Slimme meter: Current (Delivery Current L1/L2/L3)
2026-01-24 13:50:52.721  Slimme meter: General/kWh (kWh Usage L1 (Calculated))
2026-01-24 13:50:52.721  Status: MQTT: Discovered: Lamp schilderij (Lamp schilderij_electric_v_value)/Lamp schilderij (Lamp schilderij_electric_v_value) (unique_id: zwavejs2mqtt_0xdb22c9b0_39-50-0-value-66561)
2026-01-24 13:50:52.727  Slimme meter: General/kWh (kWh Delivery L1 (Cal))
2026-01-24 13:50:52.731  Slimme meter: General/kWh (kWh Usage L2 (Cal))
2026-01-24 13:50:52.737  Slimme meter: General/kWh (kWh Usage L3 (Cal))
2026-01-24 13:50:52.744  Slimme meter: General/kWh (kWh Delivery L3 (Cal))
2026-01-24 13:50:52.824  Status: MQTT: Discovered: Lamp schilderij (Lamp schilderij_electric_a_value)/Lamp schilderij (Lamp schilderij_electric_a_value) (unique_id: zwavejs2mqtt_0xdb22c9b0_39-50-0-value-66817)
2026-01-24 13:50:52.929  Status: MQTT: Discovered: Achterdeur (Achterdeur_config_switch_9)/Achterdeur (Achterdeur_config_switch_9) (unique_id: zwavejs2mqtt_0xdb22c9b0_22-112-0-9)
2026-01-24 13:50:53.033  Status: MQTT: Discovered: Achterdeur (Achterdeur_config_switch_10)/Achterdeur (Achterdeur_config_switch_10) (unique_id: zwavejs2mqtt_0xdb22c9b0_22-112-0-10)
2026-01-24 13:50:53.135  Status: MQTT: Discovered: Achterdeur (Achterdeur_config_switch_14)/Achterdeur (Achterdeur_config_switch_14) (unique_id: zwavejs2mqtt_0xdb22c9b0_22-112-0-14)
2026-01-24 13:50:53.237  Status: MQTT: Discovered: Wasmachine (Wasmachine_switch)/Wasmachine (Wasmachine_switch) (unique_id: zwavejs2mqtt_0xdb22c9b0_18-37-0-currentValue)
2026-01-24 13:50:53.339  Status: MQTT: Discovered: Wasmachine (Wasmachine_config_switch_3)/Wasmachine (Wasmachine_config_switch_3) (unique_id: zwavejs2mqtt_0xdb22c9b0_18-112-0-3)
2026-01-24 13:50:53.442  Status: MQTT: Discovered: Wasmachine (Wasmachine_config_switch_90)/Wasmachine (Wasmachine_config_switch_90) (unique_id: zwavejs2mqtt_0xdb22c9b0_18-112-0-90)
2026-01-24 13:50:53.545  Status: MQTT: Discovered: Wasmachine (Wasmachine_config_switch_101_1)/Wasmachine (Wasmachine_config_switch_101_1) (unique_id: zwavejs2mqtt_0xdb22c9b0_18-112-0-101-1)
2026-01-24 13:50:53.647  Status: MQTT: Discovered: Wasmachine (Wasmachine_config_switch_101_2)/Wasmachine (Wasmachine_config_switch_101_2) (unique_id: zwavejs2mqtt_0xdb22c9b0_18-112-0-101-2)
2026-01-24 13:50:53.750  Status: MQTT: Discovered: Wasmachine (Wasmachine_config_switch_101_4)/Wasmachine (Wasmachine_config_switch_101_4) (unique_id: zwavejs2mqtt_0xdb22c9b0_18-112-0-101-4)
2026-01-24 13:50:53.851  Status: MQTT: Discovered: Wasmachine (Wasmachine_config_switch_101_8)/Wasmachine (Wasmachine_config_switch_101_8) (unique_id: zwavejs2mqtt_0xdb22c9b0_18-112-0-101-8)
2026-01-24 13:50:53.953  Status: MQTT: Discovered: Wasmachine (Wasmachine_config_switch_102_1)/Wasmachine (Wasmachine_config_switch_102_1) (unique_id: zwavejs2mqtt_0xdb22c9b0_18-112-0-102-1)
2026-01-24 13:50:54.057  Status: MQTT: Discovered: Wasmachine (Wasmachine_config_switch_102_2)/Wasmachine (Wasmachine_config_switch_102_2) (unique_id: zwavejs2mqtt_0xdb22c9b0_18-112-0-102-2)
2026-01-24 13:50:54.159  Status: MQTT: Discovered: Wasmachine (Wasmachine_config_switch_102_4)/Wasmachine (Wasmachine_config_switch_102_4) (unique_id: zwavejs2mqtt_0xdb22c9b0_18-112-0-102-4)
2026-01-24 13:50:54.262  Status: MQTT: Discovered: Wasmachine (Wasmachine_config_switch_102_8)/Wasmachine (Wasmachine_config_switch_102_8) (unique_id: zwavejs2mqtt_0xdb22c9b0_18-112-0-102-8)
2026-01-24 13:50:54.366  Status: MQTT: Discovered: Wasmachine (Wasmachine_config_switch_103_1)/Wasmachine (Wasmachine_config_switch_103_1) (unique_id: zwavejs2mqtt_0xdb22c9b0_18-112-0-103-1)
2026-01-24 13:50:54.469  Status: MQTT: Discovered: Wasmachine (Wasmachine_config_switch_103_2)/Wasmachine (Wasmachine_config_switch_103_2) (unique_id: zwavejs2mqtt_0xdb22c9b0_18-112-0-103-2)
2026-01-24 13:50:54.573  Status: MQTT: Discovered: Wasmachine (Wasmachine_config_switch_103_4)/Wasmachine (Wasmachine_config_switch_103_4) (unique_id: zwavejs2mqtt_0xdb22c9b0_18-112-0-103-4)
2026-01-24 13:50:54.647  Telefoon: RFXMeter (Bytes Send (MB))
2026-01-24 13:50:54.650  Telefoon: RFXMeter (Bytes Received (MB))
2026-01-24 13:50:54.653  Telefoon: General/Custom Sensor (TX mbps)
2026-01-24 13:50:54.656  Telefoon: General/Custom Sensor (RX mbps)
2026-01-24 13:50:54.676  Status: MQTT: Discovered: Wasmachine (Wasmachine_config_switch_103_8)/Wasmachine (Wasmachine_config_switch_103_8) (unique_id: zwavejs2mqtt_0xdb22c9b0_18-112-0-103-8)
2026-01-24 13:50:54.779  Status: MQTT: Discovered: Wasmachine (Wasmachine_config_switch_200)/Wasmachine (Wasmachine_config_switch_200) (unique_id: zwavejs2mqtt_0xdb22c9b0_18-112-0-200)
2026-01-24 13:50:54.882  Status: MQTT: Discovered: Wasmachine (Wasmachine_config_switch_252)/Wasmachine (Wasmachine_config_switch_252) (unique_id: zwavejs2mqtt_0xdb22c9b0_18-112-0-252)
2026-01-24 13:50:54.985  Status: MQTT: Discovered: Koelkast (Koelkast_switch)/Koelkast (Koelkast_switch) (unique_id: zwavejs2mqtt_0xdb22c9b0_15-37-0-currentValue)
2026-01-24 13:50:55.087  Status: MQTT: Discovered: Koelkast (Koelkast_config_switch_3)/Koelkast (Koelkast_config_switch_3) (unique_id: zwavejs2mqtt_0xdb22c9b0_15-112-0-3)
2026-01-24 13:50:55.188  Status: MQTT: Discovered: Koelkast (Koelkast_config_switch_90)/Koelkast (Koelkast_config_switch_90) (unique_id: zwavejs2mqtt_0xdb22c9b0_15-112-0-90)
2026-01-24 13:50:55.290  Status: MQTT: Discovered: Koelkast (Koelkast_config_switch_101_1)/Koelkast (Koelkast_config_switch_101_1) (unique_id: zwavejs2mqtt_0xdb22c9b0_15-112-0-101-1)
2026-01-24 13:50:55.391  Status: MQTT: Discovered: Koelkast (Koelkast_config_switch_101_2)/Koelkast (Koelkast_config_switch_101_2) (unique_id: zwavejs2mqtt_0xdb22c9b0_15-112-0-101-2)
2026-01-24 13:50:55.494  Status: MQTT: Discovered: Koelkast (Koelkast_config_switch_101_4)/Koelkast (Koelkast_config_switch_101_4) (unique_id: zwavejs2mqtt_0xdb22c9b0_15-112-0-101-4)
2026-01-24 13:50:55.595  Status: MQTT: Discovered: Koelkast (Koelkast_config_switch_101_8)/Koelkast (Koelkast_config_switch_101_8) (unique_id: zwavejs2mqtt_0xdb22c9b0_15-112-0-101-8)
2026-01-24 13:50:55.698  Status: MQTT: Discovered: Koelkast (Koelkast_config_switch_102_1)/Koelkast (Koelkast_config_switch_102_1) (unique_id: zwavejs2mqtt_0xdb22c9b0_15-112-0-102-1)
2026-01-24 13:50:55.801  Status: MQTT: Discovered: Koelkast (Koelkast_config_switch_102_2)/Koelkast (Koelkast_config_switch_102_2) (unique_id: zwavejs2mqtt_0xdb22c9b0_15-112-0-102-2)
2026-01-24 13:50:55.903  Status: MQTT: Discovered: Koelkast (Koelkast_config_switch_102_4)/Koelkast (Koelkast_config_switch_102_4) (unique_id: zwavejs2mqtt_0xdb22c9b0_15-112-0-102-4)
2026-01-24 13:50:56.006  Status: MQTT: Discovered: Koelkast (Koelkast_config_switch_102_8)/Koelkast (Koelkast_config_switch_102_8) (unique_id: zwavejs2mqtt_0xdb22c9b0_15-112-0-102-8)
2026-01-24 13:50:56.109  Status: MQTT: Discovered: Koelkast (Koelkast_config_switch_103_1)/Koelkast (Koelkast_config_switch_103_1) (unique_id: zwavejs2mqtt_0xdb22c9b0_15-112-0-103-1)
2026-01-24 13:50:56.211  Status: MQTT: Discovered: Koelkast (Koelkast_config_switch_103_2)/Koelkast (Koelkast_config_switch_103_2) (unique_id: zwavejs2mqtt_0xdb22c9b0_15-112-0-103-2)
2026-01-24 13:50:56.313  Status: MQTT: Discovered: Koelkast (Koelkast_config_switch_103_4)/Koelkast (Koelkast_config_switch_103_4) (unique_id: zwavejs2mqtt_0xdb22c9b0_15-112-0-103-4)
2026-01-24 13:50:56.415  Status: MQTT: Discovered: Koelkast (Koelkast_config_switch_103_8)/Koelkast (Koelkast_config_switch_103_8) (unique_id: zwavejs2mqtt_0xdb22c9b0_15-112-0-103-8)
2026-01-24 13:50:56.518  Status: MQTT: Discovered: Koelkast (Koelkast_config_switch_200)/Koelkast (Koelkast_config_switch_200) (unique_id: zwavejs2mqtt_0xdb22c9b0_15-112-0-200)
2026-01-24 13:50:56.621  Status: MQTT: Discovered: Koelkast (Koelkast_config_switch_252)/Koelkast (Koelkast_config_switch_252) (unique_id: zwavejs2mqtt_0xdb22c9b0_15-112-0-252)
2026-01-24 13:50:56.722  Status: MQTT: Discovered: Vaatwasser (Vaatwasser_switch)/Vaatwasser (Vaatwasser_switch) (unique_id: zwavejs2mqtt_0xdb22c9b0_21-37-0-currentValue)
2026-01-24 13:50:56.823  Status: MQTT: Discovered: Vaatwasser (Vaatwasser_config_switch_1)/Vaatwasser (Vaatwasser_config_switch_1) (unique_id: zwavejs2mqtt_0xdb22c9b0_21-112-0-1)
2026-01-24 13:50:56.925  Status: MQTT: Discovered: Vaatwasser (Vaatwasser_config_switch_5)/Vaatwasser (Vaatwasser_config_switch_5) (unique_id: zwavejs2mqtt_0xdb22c9b0_21-112-0-5)
2026-01-24 13:50:57.027  Status: MQTT: Discovered: Vaatwasser (Vaatwasser_config_switch_7)/Vaatwasser (Vaatwasser_config_switch_7) (unique_id: zwavejs2mqtt_0xdb22c9b0_21-112-0-7)
2026-01-24 13:50:57.129  Status: MQTT: Discovered: Vaatwasser (Vaatwasser_config_switch_8)/Vaatwasser (Vaatwasser_config_switch_8) (unique_id: zwavejs2mqtt_0xdb22c9b0_21-112-0-8)
2026-01-24 13:50:57.230  Status: MQTT: Discovered: Vaatwasser (Vaatwasser_config_switch_10)/Vaatwasser (Vaatwasser_config_switch_10) (unique_id: zwavejs2mqtt_0xdb22c9b0_21-112-0-10)
2026-01-24 13:50:57.332  Status: MQTT: Discovered: Magnetron (Magnetron_switch)/Magnetron (Magnetron_switch) (unique_id: zwavejs2mqtt_0xdb22c9b0_20-37-0-currentValue)
2026-01-24 13:50:57.434  Status: MQTT: Discovered: Magnetron (Magnetron_config_switch_1)/Magnetron (Magnetron_config_switch_1) (unique_id: zwavejs2mqtt_0xdb22c9b0_20-112-0-1)
2026-01-24 13:50:57.536  Status: MQTT: Discovered: Magnetron (Magnetron_config_switch_5)/Magnetron (Magnetron_config_switch_5) (unique_id: zwavejs2mqtt_0xdb22c9b0_20-112-0-5)
2026-01-24 13:50:57.638  Status: MQTT: Discovered: Magnetron (Magnetron_config_switch_7)/Magnetron (Magnetron_config_switch_7) (unique_id: zwavejs2mqtt_0xdb22c9b0_20-112-0-7)
2026-01-24 13:50:57.642  Slimme meter: P1 Smart Meter (Slimme meter)
2026-01-24 13:50:57.648  Slimme meter: General/Voltage (Voltage L1)
2026-01-24 13:50:57.650  Slimme meter: General/Voltage (Voltage L2)
2026-01-24 13:50:57.653  Slimme meter: General/Voltage (Voltage L3)
2026-01-24 13:50:57.655  Slimme meter: Usage (Usage L1)
2026-01-24 13:50:57.658  Slimme meter: Usage (Delivery L1)
2026-01-24 13:50:57.661  Slimme meter: Usage (Usage L2)
2026-01-24 13:50:57.664  Slimme meter: Usage (Delivery L2)
2026-01-24 13:50:57.666  Slimme meter: Usage (Usage L3)
2026-01-24 13:50:57.668  Slimme meter: Usage (Delivery L3)
2026-01-24 13:50:57.671  Slimme meter: Usage (Actual Usage L1/L2/L3)
2026-01-24 13:50:57.675  Slimme meter: Usage (Actual Delivery L1/L2/L3)
2026-01-24 13:50:57.680  Slimme meter: Current (Delivery Current L1/L2/L3)
2026-01-24 13:50:57.681  Slimme meter: Current (Delivery Current L1/L2/L3)
2026-01-24 13:50:57.739  Status: MQTT: Discovered: Magnetron (Magnetron_config_switch_8)/Magnetron (Magnetron_config_switch_8) (unique_id: zwavejs2mqtt_0xdb22c9b0_20-112-0-8)
2026-01-24 13:50:57.841  Status: MQTT: Discovered: Magnetron (Magnetron_config_switch_10)/Magnetron (Magnetron_config_switch_10) (unique_id: zwavejs2mqtt_0xdb22c9b0_20-112-0-10)
2026-01-24 13:50:57.945  Status: MQTT: Discovered: Kamerdimmer (Kamerdimmer_config_switch_21)/Kamerdimmer (Kamerdimmer_config_switch_21) (unique_id: zwavejs2mqtt_0xdb22c9b0_23-112-0-21)
2026-01-24 13:50:58.049  Status: MQTT: Discovered: Kamerdimmer (Kamerdimmer_config_switch_22)/Kamerdimmer (Kamerdimmer_config_switch_22) (unique_id: zwavejs2mqtt_0xdb22c9b0_23-112-0-22)
2026-01-24 13:50:58.156  Status: MQTT: Discovered: Kamerdimmer (Kamerdimmer_config_switch_23)/Kamerdimmer (Kamerdimmer_config_switch_23) (unique_id: zwavejs2mqtt_0xdb22c9b0_23-112-0-23)
2026-01-24 13:50:58.262  Status: MQTT: Discovered: Kamerdimmer (Kamerdimmer_config_switch_24_1)/Kamerdimmer (Kamerdimmer_config_switch_24_1) (unique_id: zwavejs2mqtt_0xdb22c9b0_23-112-0-24-1)
2026-01-24 13:50:58.368  Status: MQTT: Discovered: Kamerdimmer (Kamerdimmer_config_switch_24_2)/Kamerdimmer (Kamerdimmer_config_switch_24_2) (unique_id: zwavejs2mqtt_0xdb22c9b0_23-112-0-24-2)
2026-01-24 13:50:58.474  Status: MQTT: Discovered: Kamerdimmer (Kamerdimmer_config_switch_24_4)/Kamerdimmer (Kamerdimmer_config_switch_24_4) (unique_id: zwavejs2mqtt_0xdb22c9b0_23-112-0-24-4)
2026-01-24 13:50:58.578  Status: MQTT: Discovered: Kamerdimmer (Kamerdimmer_config_switch_24_8)/Kamerdimmer (Kamerdimmer_config_switch_24_8) (unique_id: zwavejs2mqtt_0xdb22c9b0_23-112-0-24-8)
2026-01-24 13:50:58.681  Status: MQTT: Discovered: Kamerdimmer (Kamerdimmer_config_switch_24_16)/Kamerdimmer (Kamerdimmer_config_switch_24_16) (unique_id: zwavejs2mqtt_0xdb22c9b0_23-112-0-24-16)
2026-01-24 13:50:58.784  Status: MQTT: Discovered: Kamerdimmer (Kamerdimmer_config_switch_25_1)/Kamerdimmer (Kamerdimmer_config_switch_25_1) (unique_id: zwavejs2mqtt_0xdb22c9b0_23-112-0-25-1)
2026-01-24 13:50:58.888  Status: MQTT: Discovered: Kamerdimmer (Kamerdimmer_config_switch_25_2)/Kamerdimmer (Kamerdimmer_config_switch_25_2) (unique_id: zwavejs2mqtt_0xdb22c9b0_23-112-0-25-2)
2026-01-24 13:50:58.992  Status: MQTT: Discovered: Kamerdimmer (Kamerdimmer_config_switch_25_4)/Kamerdimmer (Kamerdimmer_config_switch_25_4) (unique_id: zwavejs2mqtt_0xdb22c9b0_23-112-0-25-4)
2026-01-24 13:50:59.095  Status: MQTT: Discovered: Kamerdimmer (Kamerdimmer_config_switch_25_8)/Kamerdimmer (Kamerdimmer_config_switch_25_8) (unique_id: zwavejs2mqtt_0xdb22c9b0_23-112-0-25-8)
2026-01-24 13:50:59.203  Status: MQTT: Discovered: Kamerdimmer (Kamerdimmer_config_switch_25_16)/Kamerdimmer (Kamerdimmer_config_switch_25_16) (unique_id: zwavejs2mqtt_0xdb22c9b0_23-112-0-25-16)
2026-01-24 13:50:59.307  Status: MQTT: Discovered: Kamerdimmer (Kamerdimmer_config_switch_26)/Kamerdimmer (Kamerdimmer_config_switch_26) (unique_id: zwavejs2mqtt_0xdb22c9b0_23-112-0-26)
2026-01-24 13:50:59.409  Status: MQTT: Discovered: Kamerdimmer (Kamerdimmer_config_switch_27_1)/Kamerdimmer (Kamerdimmer_config_switch_27_1) (unique_id: zwavejs2mqtt_0xdb22c9b0_23-112-0-27-1)
2026-01-24 13:50:59.511  Status: MQTT: Discovered: Kamerdimmer (Kamerdimmer_config_switch_27_2)/Kamerdimmer (Kamerdimmer_config_switch_27_2) (unique_id: zwavejs2mqtt_0xdb22c9b0_23-112-0-27-2)
2026-01-24 13:50:59.613  Status: MQTT: Discovered: Kamerdimmer (Kamerdimmer_config_switch_27_4)/Kamerdimmer (Kamerdimmer_config_switch_27_4) (unique_id: zwavejs2mqtt_0xdb22c9b0_23-112-0-27-4)
2026-01-24 13:50:59.715  Status: MQTT: Discovered: Kamerdimmer (Kamerdimmer_config_switch_27_8)/Kamerdimmer (Kamerdimmer_config_switch_27_8) (unique_id: zwavejs2mqtt_0xdb22c9b0_23-112-0-27-8)
2026-01-24 13:50:59.817  Status: MQTT: Discovered: Kamerdimmer (Kamerdimmer_config_switch_29)/Kamerdimmer (Kamerdimmer_config_switch_29) (unique_id: zwavejs2mqtt_0xdb22c9b0_23-112-0-29)
2026-01-24 13:50:59.919  Status: MQTT: Discovered: Kamerdimmer (Kamerdimmer_config_switch_37)/Kamerdimmer (Kamerdimmer_config_switch_37) (unique_id: zwavejs2mqtt_0xdb22c9b0_23-112-0-37)
2026-01-24 13:51:00.021  Status: MQTT: Discovered: Kamerdimmer (Kamerdimmer_config_switch_46)/Kamerdimmer (Kamerdimmer_config_switch_46) (unique_id: zwavejs2mqtt_0xdb22c9b0_23-112-0-46)
2026-01-24 13:51:00.123  Status: MQTT: Discovered: Kamerdimmer (Kamerdimmer_config_switch_47)/Kamerdimmer (Kamerdimmer_config_switch_47) (unique_id: zwavejs2mqtt_0xdb22c9b0_23-112-0-47)
2026-01-24 13:51:00.225  Status: MQTT: Discovered: Kamerdimmer (Kamerdimmer_config_switch_48)/Kamerdimmer (Kamerdimmer_config_switch_48) (unique_id: zwavejs2mqtt_0xdb22c9b0_23-112-0-48)
2026-01-24 13:51:00.326  Status: MQTT: Discovered: Kamerdimmer (Kamerdimmer_config_switch_49)/Kamerdimmer (Kamerdimmer_config_switch_49) (unique_id: zwavejs2mqtt_0xdb22c9b0_23-112-0-49)
2026-01-24 13:51:00.424  Status: LUA: Fan control
2026-01-24 13:51:00.424  Status: LUA: Current humidity:44.0
2026-01-24 13:51:00.424  Status: LUA: targetFanOffHumidity:46.0
2026-01-24 13:51:00.426  Status: LUA: humidityTmin5: 44.0
2026-01-24 13:51:00.430  Status: LUA: humidityTmin10: 44.0
2026-01-24 13:51:00.430  Status: LUA: fanMaxTimer: 15
2026-01-24 13:51:00.430  Status: LUA: humCounter:2
2026-01-24 13:51:00.430  Status: LUA: fanFollowsProgram:0
2026-01-24 13:51:00.432  Status: MQTT: Discovered: Kamerdimmer (Kamerdimmer_config_switch_54)/Kamerdimmer (Kamerdimmer_config_switch_54) (unique_id: zwavejs2mqtt_0xdb22c9b0_23-112-0-54)
2026-01-24 13:51:00.437  Status: EventSystem: Script event triggered: Fan control
2026-01-24 13:51:00.538  Status: MQTT: Discovered: Kamerdimmer (Kamerdimmer_config_switch_9)/Kamerdimmer (Kamerdimmer_config_switch_9) (unique_id: zwavejs2mqtt_0xdb22c9b0_23-112-0-9)
2026-01-24 13:51:00.641  Status: MQTT: Discovered: Kamerdimmer (Kamerdimmer_config_switch_28)/Kamerdimmer (Kamerdimmer_config_switch_28) (unique_id: zwavejs2mqtt_0xdb22c9b0_23-112-0-28)
2026-01-24 13:51:00.745  Status: MQTT: Discovered: Kamerdimmer (Kamerdimmer_config_switch_45)/Kamerdimmer (Kamerdimmer_config_switch_45) (unique_id: zwavejs2mqtt_0xdb22c9b0_23-112-0-45)
2026-01-24 13:51:00.846  Status: MQTT: Discovered: Lamp vensterbank (Lamp vensterbank_switch)/Lamp vensterbank (Lamp vensterbank_switch) (unique_id: zwavejs2mqtt_0xdb22c9b0_34-37-0-currentValue)
2026-01-24 13:51:00.948  Status: MQTT: Discovered: Lamp vensterbank (Lamp vensterbank_config_switch_1)/Lamp vensterbank (Lamp vensterbank_config_switch_1) (unique_id: zwavejs2mqtt_0xdb22c9b0_34-112-0-1)
2026-01-24 13:51:01.051  Status: MQTT: Discovered: Lamp vensterbank (Lamp vensterbank_config_switch_2)/Lamp vensterbank (Lamp vensterbank_config_switch_2) (unique_id: zwavejs2mqtt_0xdb22c9b0_34-112-0-2)
2026-01-24 13:51:01.153  Status: MQTT: Discovered: Lamp vensterbank (Lamp vensterbank_config_switch_15)/Lamp vensterbank (Lamp vensterbank_config_switch_15) (unique_id: zwavejs2mqtt_0xdb22c9b0_34-112-0-15)
2026-01-24 13:51:01.255  Status: MQTT: Discovered: Lamp vensterbank (Lamp vensterbank_config_switch_20)/Lamp vensterbank (Lamp vensterbank_config_switch_20) (unique_id: zwavejs2mqtt_0xdb22c9b0_34-112-0-20)
2026-01-24 13:51:01.298  Status: [web:8080] Incoming connection from: 192.168.178.32
2026-01-24 13:51:01.356  Status: MQTT: Discovered: Lamp wand (Lamp wand_switch)/Lamp wand (Lamp wand_switch) (unique_id: zwavejs2mqtt_0xdb22c9b0_35-37-0-currentValue)
2026-01-24 13:51:01.459  Status: MQTT: Discovered: Lamp wand (Lamp wand_config_switch_1)/Lamp wand (Lamp wand_config_switch_1) (unique_id: zwavejs2mqtt_0xdb22c9b0_35-112-0-1)
2026-01-24 13:51:01.561  Status: MQTT: Discovered: Lamp wand (Lamp wand_config_switch_2)/Lamp wand (Lamp wand_config_switch_2) (unique_id: zwavejs2mqtt_0xdb22c9b0_35-112-0-2)
2026-01-24 13:51:01.663  Status: MQTT: Discovered: Lamp wand (Lamp wand_config_switch_15)/Lamp wand (Lamp wand_config_switch_15) (unique_id: zwavejs2mqtt_0xdb22c9b0_35-112-0-15)
2026-01-24 13:51:01.765  Status: MQTT: Discovered: Lamp wand (Lamp wand_config_switch_20)/Lamp wand (Lamp wand_config_switch_20) (unique_id: zwavejs2mqtt_0xdb22c9b0_35-112-0-20)
2026-01-24 13:51:01.868  Status: MQTT: Discovered: Audio/video (Audio/video_switch)/Audio/video (Audio/video_switch) (unique_id: zwavejs2mqtt_0xdb22c9b0_36-37-0-currentValue)
2026-01-24 13:51:01.970  Status: MQTT: Discovered: Audio/video (Audio/video_config_switch_1)/Audio/video (Audio/video_config_switch_1) (unique_id: zwavejs2mqtt_0xdb22c9b0_36-112-0-1)
2026-01-24 13:51:02.073  Status: MQTT: Discovered: Audio/video (Audio/video_config_switch_2)/Audio/video (Audio/video_config_switch_2) (unique_id: zwavejs2mqtt_0xdb22c9b0_36-112-0-2)
2026-01-24 13:51:02.175  Status: MQTT: Discovered: Audio/video (Audio/video_config_switch_15)/Audio/video (Audio/video_config_switch_15) (unique_id: zwavejs2mqtt_0xdb22c9b0_36-112-0-15)
2026-01-24 13:51:02.277  Status: MQTT: Discovered: Audio/video (Audio/video_config_switch_20)/Audio/video (Audio/video_config_switch_20) (unique_id: zwavejs2mqtt_0xdb22c9b0_36-112-0-20)
2026-01-24 13:51:02.380  Status: MQTT: Discovered: Lamp overloop (Lamp overloop_switch)/Lamp overloop (Lamp overloop_switch) (unique_id: zwavejs2mqtt_0xdb22c9b0_40-37-0-currentValue)
2026-01-24 13:51:02.482  Status: MQTT: Discovered: Lamp overloop (Lamp overloop_config_switch_1)/Lamp overloop (Lamp overloop_config_switch_1) (unique_id: zwavejs2mqtt_0xdb22c9b0_40-112-0-1)
2026-01-24 13:51:02.584  Status: MQTT: Discovered: Lamp overloop (Lamp overloop_config_switch_2)/Lamp overloop (Lamp overloop_config_switch_2) (unique_id: zwavejs2mqtt_0xdb22c9b0_40-112-0-2)
2026-01-24 13:51:02.677  Slimme meter: P1 Smart Meter (Slimme meter)
2026-01-24 13:51:02.684  Slimme meter: General/Voltage (Voltage L1)
2026-01-24 13:51:02.687  Status: MQTT: Discovered: Lamp overloop (Lamp overloop_config_switch_15)/Lamp overloop (Lamp overloop_config_switch_15) (unique_id: zwavejs2mqtt_0xdb22c9b0_40-112-0-15)
2026-01-24 13:51:02.689  Slimme meter: General/Voltage (Voltage L2)
2026-01-24 13:51:02.695  Slimme meter: General/Voltage (Voltage L3)
2026-01-24 13:51:02.700  Slimme meter: Usage (Usage L1)
2026-01-24 13:51:02.705  Slimme meter: Usage (Delivery L1)
2026-01-24 13:51:02.710  Slimme meter: Usage (Usage L2)
2026-01-24 13:51:02.716  Slimme meter: Usage (Delivery L2)
2026-01-24 13:51:02.720  Slimme meter: Usage (Usage L3)
2026-01-24 13:51:02.724  Slimme meter: Usage (Delivery L3)
2026-01-24 13:51:02.729  Slimme meter: Usage (Actual Usage L1/L2/L3)
2026-01-24 13:51:02.732  Mapper: onMQTTPublish found SmartEVSE-5572/MaxCurrent, Device 'max current', message '160'
2026-01-24 13:51:02.734  Mapper: Setting max current to 16/16.0
2026-01-24 13:51:02.738  Slimme meter: Usage (Actual Delivery L1/L2/L3)
2026-01-24 13:51:02.740  Mapper: onMQTTPublish found SmartEVSE-5572/ChargeCurrent, Device 'charge current', message '160'
2026-01-24 13:51:02.741  Mapper: Setting charge current to 16/16.0
2026-01-24 13:51:02.747  Slimme meter: Current (Delivery Current L1/L2/L3)
2026-01-24 13:51:02.751  Mapper: onMQTTPublish found SmartEVSE-5572/ChargeCurrentOverride, Device 'charge current override', message '0'
2026-01-24 13:51:02.751  Slimme meter: Current (Delivery Current L1/L2/L3)
2026-01-24 13:51:02.753  Mapper: Setting charge current override to 0/0.0
2026-01-24 13:51:02.758  Slimme meter: General/kWh (kWh Usage L1 (Calculated))
2026-01-24 13:51:02.761  Mapper: onMQTTPublish found SmartEVSE-5572/State, Device 'SmartEVSE state', message 'Ready to Charge'
2026-01-24 13:51:02.761  Mapper: Setting SmartEVSE state to >Ready to Charge<
2026-01-24 13:51:02.765  Mapper: onMQTTPublish found SmartEVSE-5572/Error, Device 'SmartEVSE error', message 'None'
2026-01-24 13:51:02.765  Mapper: testValue="None" (str), readValue="None" (str)
2026-01-24 13:51:02.765  Mapper: testValue="No Power Available" (str), readValue="None" (str)
2026-01-24 13:51:02.765  Mapper: testValue="Communication Error" (str), readValue="None" (str)
2026-01-24 13:51:02.765  Mapper: testValue="Temperature High" (str), readValue="None" (str)
2026-01-24 13:51:02.765  Mapper: testValue="EV Meter Comm Error" (str), readValue="None" (str)
2026-01-24 13:51:02.766  Mapper: testValue="RCM Tripped" (str), readValue="None" (str)
2026-01-24 13:51:02.766  Mapper: testValue="Waiting for Solar" (str), readValue="None" (str)
2026-01-24 13:51:02.766  Mapper: testValue="Test IO" (str), readValue="None" (str)
2026-01-24 13:51:02.766  Mapper: testValue="Flash Error" (str), readValue="None" (str)
2026-01-24 13:51:02.766  Mapper: testValue="**Unknown**" (str), readValue="None" (str)
2026-01-24 13:51:02.766  Mapper: Setting SmartEVSE error to 0/0
2026-01-24 13:51:02.772  Mapper: onMQTTPublish found SmartEVSE-5572/EVEnergyCharged, Device 'evenergy charged', message '12893'
2026-01-24 13:51:02.773  Mapper: Setting evenergy charged to 12893/12893.0
2026-01-24 13:51:02.781  Slimme meter: General/kWh (kWh Delivery L1 (Cal))
2026-01-24 13:51:02.782  Mapper: onMQTTPublish found SmartEVSE-5572/EVTotalEnergyCharged, Device 'evtotalenergy charged', message '1043448'
2026-01-24 13:51:02.782  Mapper: Setting evtotalenergy charged to 1043/1043.448
2026-01-24 13:51:02.789  Slimme meter: General/kWh (kWh Usage L2 (Cal))
2026-01-24 13:51:02.792  Status: MQTT: Discovered: Lamp overloop (Lamp overloop_config_switch_20)/Lamp overloop (Lamp overloop_config_switch_20) (unique_id: zwavejs2mqtt_0xdb22c9b0_40-112-0-20)
2026-01-24 13:51:02.796  Slimme meter: General/kWh (kWh Usage L3 (Cal))
2026-01-24 13:51:02.799  Slimme meter: General/kWh (kWh Delivery L3 (Cal))
2026-01-24 13:51:02.894  Status: MQTT: Discovered: Lamp schilderij (Lamp schilderij_switch)/Lamp schilderij (Lamp schilderij_switch) (unique_id: zwavejs2mqtt_0xdb22c9b0_39-37-0-currentValue)
2026-01-24 13:51:02.998  Status: MQTT: Discovered: Lamp schilderij (Lamp schilderij_config_switch_3)/Lamp schilderij (Lamp schilderij_config_switch_3) (unique_id: zwavejs2mqtt_0xdb22c9b0_39-112-0-3)
2026-01-24 13:51:03.102  Status: MQTT: Discovered: Lamp schilderij (Lamp schilderij_config_switch_90)/Lamp schilderij (Lamp schilderij_config_switch_90) (unique_id: zwavejs2mqtt_0xdb22c9b0_39-112-0-90)
2026-01-24 13:51:03.206  Status: MQTT: Discovered: Lamp schilderij (Lamp schilderij_config_switch_101_1)/Lamp schilderij (Lamp schilderij_config_switch_101_1) (unique_id: zwavejs2mqtt_0xdb22c9b0_39-112-0-101-1)
2026-01-24 13:51:03.310  Status: MQTT: Discovered: Lamp schilderij (Lamp schilderij_config_switch_101_2)/Lamp schilderij (Lamp schilderij_config_switch_101_2) (unique_id: zwavejs2mqtt_0xdb22c9b0_39-112-0-101-2)
2026-01-24 13:51:03.414  Status: MQTT: Discovered: Lamp schilderij (Lamp schilderij_config_switch_101_4)/Lamp schilderij (Lamp schilderij_config_switch_101_4) (unique_id: zwavejs2mqtt_0xdb22c9b0_39-112-0-101-4)
2026-01-24 13:51:03.518  Status: MQTT: Discovered: Lamp schilderij (Lamp schilderij_config_switch_101_8)/Lamp schilderij (Lamp schilderij_config_switch_101_8) (unique_id: zwavejs2mqtt_0xdb22c9b0_39-112-0-101-8)
2026-01-24 13:51:03.622  Status: MQTT: Discovered: Lamp schilderij (Lamp schilderij_config_switch_102_1)/Lamp schilderij (Lamp schilderij_config_switch_102_1) (unique_id: zwavejs2mqtt_0xdb22c9b0_39-112-0-102-1)
2026-01-24 13:51:03.726  Status: MQTT: Discovered: Lamp schilderij (Lamp schilderij_config_switch_102_2)/Lamp schilderij (Lamp schilderij_config_switch_102_2) (unique_id: zwavejs2mqtt_0xdb22c9b0_39-112-0-102-2)
2026-01-24 13:51:03.830  Status: MQTT: Discovered: Lamp schilderij (Lamp schilderij_config_switch_102_4)/Lamp schilderij (Lamp schilderij_config_switch_102_4) (unique_id: zwavejs2mqtt_0xdb22c9b0_39-112-0-102-4)
2026-01-24 13:51:03.933  Status: MQTT: Discovered: Lamp schilderij (Lamp schilderij_config_switch_102_8)/Lamp schilderij (Lamp schilderij_config_switch_102_8) (unique_id: zwavejs2mqtt_0xdb22c9b0_39-112-0-102-8)
2026-01-24 13:51:04.037  Status: MQTT: Discovered: Lamp schilderij (Lamp schilderij_config_switch_103_1)/Lamp schilderij (Lamp schilderij_config_switch_103_1) (unique_id: zwavejs2mqtt_0xdb22c9b0_39-112-0-103-1)
2026-01-24 13:51:04.143  Status: MQTT: Discovered: Lamp schilderij (Lamp schilderij_config_switch_103_2)/Lamp schilderij (Lamp schilderij_config_switch_103_2) (unique_id: zwavejs2mqtt_0xdb22c9b0_39-112-0-103-2)
2026-01-24 13:51:04.248  Status: MQTT: Discovered: Lamp schilderij (Lamp schilderij_config_switch_103_4)/Lamp schilderij (Lamp schilderij_config_switch_103_4) (unique_id: zwavejs2mqtt_0xdb22c9b0_39-112-0-103-4)
2026-01-24 13:51:04.350  Status: MQTT: Discovered: Lamp schilderij (Lamp schilderij_config_switch_103_8)/Lamp schilderij (Lamp schilderij_config_switch_103_8) (unique_id: zwavejs2mqtt_0xdb22c9b0_39-112-0-103-8)
2026-01-24 13:51:04.453  Status: MQTT: Discovered: Lamp schilderij (Lamp schilderij_config_switch_200)/Lamp schilderij (Lamp schilderij_config_switch_200) (unique_id: zwavejs2mqtt_0xdb22c9b0_39-112-0-200)
2026-01-24 13:51:04.555  Status: MQTT: Discovered: Lamp schilderij (Lamp schilderij_config_switch_252)/Lamp schilderij (Lamp schilderij_config_switch_252) (unique_id: zwavejs2mqtt_0xdb22c9b0_39-112-0-252)
2026-01-24 13:51:04.576  Motherboard: General/Percentage (Geheugen)
2026-01-24 13:51:04.577  Motherboard: General/Custom Sensor (Process Usage)
2026-01-24 13:51:04.657  Status: MQTT: Discovered: Voordeur (Voordeur_config_switch_9)/Voordeur (Voordeur_config_switch_9) (unique_id: zwavejs2mqtt_0xdb22c9b0_3-112-0-9)
2026-01-24 13:51:04.682  Telefoon: RFXMeter (Bytes Send (MB))
2026-01-24 13:51:04.684  Telefoon: RFXMeter (Bytes Received (MB))
2026-01-24 13:51:04.685  Telefoon: General/Custom Sensor (TX mbps)
2026-01-24 13:51:04.687  Telefoon: General/Custom Sensor (RX mbps)
2026-01-24 13:51:04.760  Status: MQTT: Discovered: Voordeur (Voordeur_config_switch_10)/Voordeur (Voordeur_config_switch_10) (unique_id:
FlyingDomotic
I'll made a change to trace device creation as it seems there's an not shown error. I won't be able to test it before tomorrow evening or the day after.
Stay tuned!
rron
Post by rron »
Ok thank you for the affort.
FlyingDomotic
I'm back and just tested a new version which add more trace on device creation, and checks for device just after creating it (as Domoticz Python primitive don't return any error.
Would it be possible to update MqttMapper (git pull), set debug (to "Extra verbose", restart it and send me log ?
rron
Post by rron »
Yes I will do that. This weekend I will charge my car again and send you the logging. Thank you.
rron
Post by rron »
This is the extra verbose logging
2026-01-30 14:26:29.700  Mapper: MqttClient::onDisconnect Disconnected from  192.168.178.50:1883
2026-01-30 14:26:29.700  Mapper: MqttClient::Close
2026-01-30 14:26:29.700  Mapper: onMQTTDisconnected
2026-01-30 14:26:29.799  Mapper: Worker thread started.
2026-01-30 14:26:29.937  Mapper: Debug logging mask set to: PYTHON PLUGIN QUEUE DEVICE CONNECTION MESSAGE
2026-01-30 14:26:29.938  Mapper: /opt/domoticz/userdata/plugins/MqttMapper/MqttMapper.json is a version 1.0 file
2026-01-30 14:26:29.968  Mapper: pluginV1::__init__
2026-01-30 14:26:29.968  Mapper: 'HardwareID': '48'
2026-01-30 14:26:29.968  Mapper: 'HomeFolder': '/opt/domoticz/userdata/plugins/MqttMapper/'
2026-01-30 14:26:29.968  Mapper: 'StartupFolder': '/opt/domoticz/'
2026-01-30 14:26:29.968  Mapper: 'UserDataFolder': '/opt/domoticz/userdata/'
2026-01-30 14:26:29.968  Mapper: 'Database': '/opt/domoticz/userdata/domoticz.db'
2026-01-30 14:26:29.969  Mapper: 'Language': 'nl'
2026-01-30 14:26:29.969  Mapper: 'Version': '25.12.9-1'
2026-01-30 14:26:29.969  Mapper: 'Author': 'Flying Domotic'
2026-01-30 14:26:29.969  Mapper: 'Name': 'Mapper'
2026-01-30 14:26:29.969  Mapper: 'Address': '192.168.178.50'
2026-01-30 14:26:29.969  Mapper: 'Port': '1883'
2026-01-30 14:26:29.969  Mapper: 'Key': 'MqttMapper'
2026-01-30 14:26:29.969  Mapper: 'Mode1': 'MqttMapper.json'
2026-01-30 14:26:29.969  Mapper: 'Mode6': 'Verbose+'
2026-01-30 14:26:29.969  Mapper: 'DomoticzVersion': '2025.2 (build 16836)'
2026-01-30 14:26:29.969  Mapper: 'DomoticzHash': '3b8a9cf2f'
2026-01-30 14:26:29.969  Mapper: 'DomoticzBuildTime': '2025-10-26 10:11:08'
2026-01-30 14:26:29.969  Mapper: Device count: 7
2026-01-30 14:26:29.969  Mapper: Device: 1 - ID: 867, Name: 'charge current', nValue: 16, sValue: '16.0'
2026-01-30 14:26:29.969  Mapper: Device: 2 - ID: 868, Name: 'max current', nValue: 16, sValue: '16.0'
2026-01-30 14:26:29.969  Mapper: Device: 3 - ID: 901, Name: 'evenergy charged', nValue: 9864, sValue: '9864.0'
2026-01-30 14:26:29.969  Mapper: Device: 4 - ID: 870, Name: 'evtotalenergy charged', nValue: 1053, sValue: '1053.3120000000001'
2026-01-30 14:26:29.969  Mapper: Device: 5 - ID: 871, Name: 'SmartEVSE state', nValue: 0, sValue: 'Charging'
2026-01-30 14:26:29.969  Mapper: Device: 6 - ID: 872, Name: 'SmartEVSE error', nValue: 0, sValue: '0'
2026-01-30 14:26:29.969  Mapper: Device: 7 - ID: 873, Name: 'charge current override', nValue: 0, sValue: '0.0'
2026-01-30 14:26:29.970  Mapper: Creating device amperae State of Charge
2026-01-30 14:26:29.970  Mapper: Creating device 'amperae State of Charge'.
2026-01-30 14:26:29.970  Mapper: Creating device amperae Hv Capacity
2026-01-30 14:26:29.970  Mapper: Creating device 'amperae Hv Capacity'.
2026-01-30 14:26:29.970  Mapper: MqttClient::__init__
2026-01-30 14:26:29.970  Mapper: Pushing 'ProtocolDirective' on to queue
2026-01-30 14:26:29.970  Mapper: Pushing 'ConnectDirective' on to queue
2026-01-30 14:26:29.972  Mapper: Pushing 'PollIntervalDirective' on to queue
2026-01-30 14:26:29.972  Mapper: Processing 'ProtocolDirective' message
2026-01-30 14:26:29.972  Mapper: Protocol set to: 'MQTT'.
2026-01-30 14:26:29.972  Mapper: Processing 'ConnectDirective' message
2026-01-30 14:26:29.972  Mapper: Transport set to: 'TCP/IP', 192.168.178.50:1883.
2026-01-30 14:26:29.972  Mapper: Connect directive received, action initiated successfully.
2026-01-30 14:26:29.972  Mapper: Processing 'PollIntervalDirective' message
2026-01-30 14:26:29.972  Mapper: Heartbeat interval set to: 3.
2026-01-30 14:26:29.973  Mapper: Pushing 'onConnectCallback' on to queue
2026-01-30 14:26:30.022  Mapper: Processing 'onConnectCallback' message
2026-01-30 14:26:30.022  Mapper: Calling message handler 'onConnect' on 'module' type object.
2026-01-30 14:26:30.022  Mapper: MqttClient::onConnect
2026-01-30 14:26:30.023  Mapper: MqttClient::onConnect connect to 192.168.178.50:1883, ID=Domoticz_MqttMapper_48_1769779590
2026-01-30 14:26:30.023  Mapper: Pushing 'WriteDirective' on to queue
2026-01-30 14:26:30.023  Mapper: Processing 'WriteDirective' message
2026-01-30 14:26:30.023  Mapper: Sending 47 bytes of data
2026-01-30 14:26:30.023  Mapper:      10 2d 00 04 4d 51 54 54 04 02 00 3c 00 21 44 6f 6d 6f 74 69     .-..MQTT...<.!Domoti
2026-01-30 14:26:30.023  Mapper:      63 7a 5f 4d 71 74 74 4d 61 70 70 65 72 5f 34 38 5f 31 37 36     cz_MqttMapper_48_176
2026-01-30 14:26:30.023  Mapper:      39 37 37 39 35 39 30 .. .. .. .. .. .. .. .. .. .. .. .. ..     9779590
2026-01-30 14:26:30.024  Mapper: Pushing 'ReadEvent' on to queue
2026-01-30 14:26:30.073  Mapper: Processing 'ReadEvent' message
2026-01-30 14:26:30.073  Mapper: Received 4 bytes of data
2026-01-30 14:26:30.073  Mapper:      20 02 00 00 .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. ..     ....
2026-01-30 14:26:30.073  Mapper: Pushing 'onMessageCallback' on to queue
2026-01-30 14:26:30.073  Mapper: Processing 'onMessageCallback' message
2026-01-30 14:26:30.073  Mapper: Calling message handler 'onMessage' on 'module' type object.
2026-01-30 14:26:30.073  Mapper: onMQTTConnected
2026-01-30 14:26:30.074  Mapper: getTopics: '{'wican/amperae/HV_CAPACITY', 'SmartEVSE-5572/EVEnergyCharged', 'SmartEVSE-5572/ChargeCurrent', 'wican/amperae/SOC', 'SmartEVSE-5572/Error', 'SmartEVSE-5572/EVTotalEnergyCharged', 'SmartEVSE-5572/State', 'SmartEVSE-5572/MaxCurrent', 'SmartEVSE-5572/ChargeCurrentOverride'}'
2026-01-30 14:26:30.074  Mapper: MqttClient::Subscribe to [{'Topic': 'wican/amperae/HV_CAPACITY', 'QoS': 0}, {'Topic': 'SmartEVSE-5572/EVEnergyCharged', 'QoS': 0}, {'Topic': 'SmartEVSE-5572/ChargeCurrent', 'QoS': 0}, {'Topic': 'wican/amperae/SOC', 'QoS': 0}, {'Topic': 'SmartEVSE-5572/Error', 'QoS': 0}, {'Topic': 'SmartEVSE-5572/EVTotalEnergyCharged', 'QoS': 0}, {'Topic': 'SmartEVSE-5572/State', 'QoS': 0}, {'Topic': 'SmartEVSE-5572/MaxCurrent', 'QoS': 0}, {'Topic': 'SmartEVSE-5572/ChargeCurrentOverride', 'QoS': 0}]
2026-01-30 14:26:30.074  Mapper: Pushing 'WriteDirective' on to queue
2026-01-30 14:26:30.074  Mapper: Processing 'WriteDirective' message
2026-01-30 14:26:30.074  Mapper: Sending 268 bytes of data
2026-01-30 14:26:30.074  Mapper:      82 89 02 00 01 00 19 77 69 63 61 6e 2f 61 6d 70 65 72 61 65     ��.....wican/amperae
2026-01-30 14:26:30.074  Mapper:      2f 48 56 5f 43 41 50 41 43 49 54 59 00 00 1e 53 6d 61 72 74     /HV_CAPACITY...Smart
2026-01-30 14:26:30.074  Mapper:      45 56 53 45 2d 35 35 37 32 2f 45 56 45 6e 65 72 67 79 43 68     EVSE-5572/EVEnergyCh
2026-01-30 14:26:30.074  Mapper:      61 72 67 65 64 00 00 1c 53 6d 61 72 74 45 56 53 45 2d 35 35     arged...SmartEVSE-55
2026-01-30 14:26:30.074  Mapper:      37 32 2f 43 68 61 72 67 65 43 75 72 72 65 6e 74 00 00 11 77     72/ChargeCurrent...w
2026-01-30 14:26:30.074  Mapper:      69 63 61 6e 2f 61 6d 70 65 72 61 65 2f 53 4f 43 00 00 14 53     ican/amperae/SOC...S
2026-01-30 14:26:30.074  Mapper:      6d 61 72 74 45 56 53 45 2d 35 35 37 32 2f 45 72 72 6f 72 00     martEVSE-5572/Error.
2026-01-30 14:26:30.074  Mapper:      00 23 53 6d 61 72 74 45 56 53 45 2d 35 35 37 32 2f 45 56 54     .#SmartEVSE-5572/EVT
2026-01-30 14:26:30.074  Mapper:      6f 74 61 6c 45 6e 65 72 67 79 43 68 61 72 67 65 64 00 00 14     otalEnergyCharged...
2026-01-30 14:26:30.074  Mapper:      53 6d 61 72 74 45 56 53 45 2d 35 35 37 32 2f 53 74 61 74 65     SmartEVSE-5572/State
2026-01-30 14:26:30.074  Mapper:      00 00 19 53 6d 61 72 74 45 56 53 45 2d 35 35 37 32 2f 4d 61     ...SmartEVSE-5572/Ma
2026-01-30 14:26:30.074  Mapper:      78 43 75 72 72 65 6e 74 00 00 24 53 6d 61 72 74 45 56 53 45     xCurrent..$SmartEVSE
2026-01-30 14:26:30.074  Mapper:      2d 35 35 37 32 2f 43 68 61 72 67 65 43 75 72 72 65 6e 74 4f     -5572/ChargeCurrentO
2026-01-30 14:26:30.074  Mapper:      76 65 72 72 69 64 65 00 .. .. .. .. .. .. .. .. .. .. .. ..     verride.
2026-01-30 14:26:30.075  Mapper: Pushing 'ReadEvent' on to queue
2026-01-30 14:26:30.125  Mapper: Processing 'ReadEvent' message
2026-01-30 14:26:30.125  Mapper: Received 302 bytes of data
2026-01-30 14:26:30.125  Mapper:      90 0b 00 01 00 00 00 00 00 00 00 00 00 31 2f 00 19 77 69 63     �............1/..wic
2026-01-30 14:26:30.125  Mapper:      61 6e 2f 61 6d 70 65 72 61 65 2f 48 56 5f 43 41 50 41 43 49     an/amperae/HV_CAPACI
2026-01-30 14:26:30.125  Mapper:      54 59 7b 22 48 56 5f 43 41 50 41 43 49 54 59 22 3a 32 33 33     TY{"HV_CAPACITY":233
2026-01-30 14:26:30.125  Mapper:      30 7d 31 24 00 1e 53 6d 61 72 74 45 56 53 45 2d 35 35 37 32     0}1$..SmartEVSE-5572
2026-01-30 14:26:30.125  Mapper:      2f 45 56 45 6e 65 72 67 79 43 68 61 72 67 65 64 39 38 36 34     /EVEnergyCharged9864
2026-01-30 14:26:30.125  Mapper:      31 21 00 1c 53 6d 61 72 74 45 56 53 45 2d 35 35 37 32 2f 43     1!..SmartEVSE-5572/C
2026-01-30 14:26:30.125  Mapper:      68 61 72 67 65 43 75 72 72 65 6e 74 31 36 30 31 20 00 11 77     hargeCurrent1601...w
2026-01-30 14:26:30.125  Mapper:      69 63 61 6e 2f 61 6d 70 65 72 61 65 2f 53 4f 43 7b 22 53 4f     ican/amperae/SOC{"SO
2026-01-30 14:26:30.125  Mapper:      43 22 3a 33 35 2e 36 39 7d 31 1a 00 14 53 6d 61 72 74 45 56     C":35.69}1...SmartEV
2026-01-30 14:26:30.125  Mapper:      53 45 2d 35 35 37 32 2f 45 72 72 6f 72 4e 6f 6e 65 31 1e 00     SE-5572/ErrorNone1..
2026-01-30 14:26:30.125  Mapper:      14 53 6d 61 72 74 45 56 53 45 2d 35 35 37 32 2f 53 74 61 74     .SmartEVSE-5572/Stat
2026-01-30 14:26:30.125  Mapper:      65 43 68 61 72 67 69 6e 67 31 1e 00 19 53 6d 61 72 74 45 56     eCharging1...SmartEV
2026-01-30 14:26:30.125  Mapper:      53 45 2d 35 35 37 32 2f 4d 61 78 43 75 72 72 65 6e 74 31 36     SE-5572/MaxCurrent16
2026-01-30 14:26:30.125  Mapper:      30 31 27 00 24 53 6d 61 72 74 45 56 53 45 2d 35 35 37 32 2f     01'.$SmartEVSE-5572/
2026-01-30 14:26:30.125  Mapper:      43 68 61 72 67 65 43 75 72 72 65 6e 74 4f 76 65 72 72 69 64     ChargeCurrentOverrid
2026-01-30 14:26:30.125  Mapper:      65 30 .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. ..     e0
2026-01-30 14:26:30.125  Mapper: Pushing 'onMessageCallback' on to queue
2026-01-30 14:26:30.126  Mapper: Pushing 'onMessageCallback' on to queue
2026-01-30 14:26:30.126  Mapper: Processing 'onMessageCallback' message
2026-01-30 14:26:30.126  Mapper: Calling message handler 'onMessage' on 'module' type object.
2026-01-30 14:26:30.126  Mapper: onMQTTSubscribed
2026-01-30 14:26:30.127  Mapper: Processing 'onMessageCallback' message
2026-01-30 14:26:30.128  Mapper: Calling message handler 'onMessage' on 'module' type object.
2026-01-30 14:26:30.128  Mapper: onMQTTPublish found SmartEVSE-5572/EVEnergyCharged, Device 'evenergy charged', message '9864'
2026-01-30 14:26:30.128  Mapper: Setting evenergy charged to 9864/9864.0
2026-01-30 14:26:30.128  (evenergy charged) Updating device from 9864:'9864.0' to have values 9864:'9864.0'.
2026-01-30 14:26:30.137  Mapper: Processing 'onMessageCallback' message
2026-01-30 14:26:30.137  Mapper: Calling message handler 'onMessage' on 'module' type object.
2026-01-30 14:26:30.137  Mapper: onMQTTPublish found SmartEVSE-5572/ChargeCurrent, Device 'charge current', message '160'
2026-01-30 14:26:30.138  Mapper: Setting charge current to 16/16.0
2026-01-30 14:26:30.138  (charge current) Updating device from 16:'16.0' to have values 16:'16.0'.
2026-01-30 14:26:30.143  Mapper: Processing 'onMessageCallback' message
2026-01-30 14:26:30.143  Mapper: Calling message handler 'onMessage' on 'module' type object.
2026-01-30 14:26:30.143  Mapper: onMQTTPublish found SmartEVSE-5572/Error, Device 'SmartEVSE error', message 'None'
2026-01-30 14:26:30.143  Mapper: testValue="None" (str), readValue="None" (str)
2026-01-30 14:26:30.144  Mapper: testValue="No Power Available" (str), readValue="None" (str)
2026-01-30 14:26:30.144  Mapper: testValue="Communication Error" (str), readValue="None" (str)
2026-01-30 14:26:30.144  Mapper: testValue="Temperature High" (str), readValue="None" (str)
2026-01-30 14:26:30.144  Mapper: testValue="EV Meter Comm Error" (str), readValue="None" (str)
2026-01-30 14:26:30.144  Mapper: testValue="RCM Tripped" (str), readValue="None" (str)
2026-01-30 14:26:30.144  Mapper: testValue="Waiting for Solar" (str), readValue="None" (str)
2026-01-30 14:26:30.144  Mapper: testValue="Test IO" (str), readValue="None" (str)
2026-01-30 14:26:30.144  Mapper: testValue="Flash Error" (str), readValue="None" (str)
2026-01-30 14:26:30.144  Mapper: testValue="**Unknown**" (str), readValue="None" (str)
2026-01-30 14:26:30.144  Mapper: Setting SmartEVSE error to 0/0
2026-01-30 14:26:30.144  (SmartEVSE error) Updating device from 0:'0' to have values 0:'0'.
2026-01-30 14:26:30.149  Mapper: Processing 'onMessageCallback' message
2026-01-30 14:26:30.150  Mapper: Calling message handler 'onMessage' on 'module' type object.
2026-01-30 14:26:30.150  Mapper: onMQTTPublish found SmartEVSE-5572/State, Device 'SmartEVSE state', message 'Charging'
2026-01-30 14:26:30.150  Mapper: Setting SmartEVSE state to >Charging<
2026-01-30 14:26:30.150  (SmartEVSE state) Updating device from 0:'Charging' to have values 0:'Charging'.
2026-01-30 14:26:30.154  Mapper: Processing 'onMessageCallback' message
2026-01-30 14:26:30.155  Mapper: Calling message handler 'onMessage' on 'module' type object.
2026-01-30 14:26:30.155  Mapper: onMQTTPublish found SmartEVSE-5572/MaxCurrent, Device 'max current', message '160'
2026-01-30 14:26:30.155  Mapper: Setting max current to 16/16.0
2026-01-30 14:26:30.155  (max current) Updating device from 16:'16.0' to have values 16:'16.0'.
2026-01-30 14:26:30.158  Mapper: Processing 'onMessageCallback' message
2026-01-30 14:26:30.158  Mapper: Calling message handler 'onMessage' on 'module' type object.
2026-01-30 14:26:30.158  Mapper: onMQTTPublish found SmartEVSE-5572/ChargeCurrentOverride, Device 'charge current override', message '0'
2026-01-30 14:26:30.158  Mapper: Setting charge current override to 0/0.0
2026-01-30 14:26:30.158  (charge current override) Updating device from 0:'0.0' to have values 0:'0.0'.
2026-01-30 14:26:30.350  Mapper: Pushing 'ReadEvent' on to queue
2026-01-30 14:26:30.363  Mapper: Processing 'ReadEvent' message
2026-01-30 14:26:30.363  Mapper: Received 34 bytes of data
2026-01-30 14:26:30.363  Mapper:      30 20 00 11 77 69 63 61 6e 2f 61 6d 70 65 72 61 65 2f 53 4f     0...wican/amperae/SO
2026-01-30 14:26:30.363  Mapper:      43 7b 22 53 4f 43 22 3a 33 35 2e 36 39 7d .. .. .. .. .. ..     C{"SOC":35.69}
2026-01-30 14:26:30.363  Mapper: Pushing 'onMessageCallback' on to queue
2026-01-30 14:26:30.363  Mapper: Processing 'onMessageCallback' message
2026-01-30 14:26:30.363  Mapper: Calling message handler 'onMessage' on 'module' type object.
2026-01-30 14:26:30.516  Mapper: Pushing 'ReadEvent' on to queue
2026-01-30 14:26:30.564  Mapper: Processing 'ReadEvent' message
2026-01-30 14:26:30.564  Mapper: Received 49 bytes of data
2026-01-30 14:26:30.564  Mapper:      30 2f 00 19 77 69 63 61 6e 2f 61 6d 70 65 72 61 65 2f 48 56     0/..wican/amperae/HV
2026-01-30 14:26:30.564  Mapper:      5f 43 41 50 41 43 49 54 59 7b 22 48 56 5f 43 41 50 41 43 49     _CAPACITY{"HV_CAPACI
2026-01-30 14:26:30.564  Mapper:      54 59 22 3a 32 33 33 30 7d .. .. .. .. .. .. .. .. .. .. ..     TY":2330}
2026-01-30 14:26:30.564  Mapper: Pushing 'onMessageCallback' on to queue
2026-01-30 14:26:30.564  Mapper: Processing 'onMessageCallback' message
2026-01-30 14:26:30.564  Mapper: Calling message handler 'onMessage' on 'module' type object.
rron
Re: Python Plugin: MqttMapper
Post by rron »
part 2 logging
2026-01-30 14:26:31.983  Telefoon: RFXMeter (Bytes Send (MB))
2026-01-30 14:26:31.986  Telefoon: RFXMeter (Bytes Received (MB))
2026-01-30 14:26:31.988  Telefoon: General/Custom Sensor (TX mbps)
2026-01-30 14:26:31.991  Telefoon: General/Custom Sensor (RX mbps)
2026-01-30 14:26:32.016  Mapper: Pushing 'onHeartbeatCallback' on to queue
2026-01-30 14:26:32.066  Mapper: Processing 'onHeartbeatCallback' message
2026-01-30 14:26:32.067  Mapper: Calling message handler 'onHeartbeat' on 'module' type object.
2026-01-30 14:26:32.067  Mapper: Pushing 'WriteDirective' on to queue
2026-01-30 14:26:32.067  Mapper: Processing 'WriteDirective' message
2026-01-30 14:26:32.067  Mapper: Sending 2 bytes of data
2026-01-30 14:26:32.067  Mapper:      c0 00 .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. ..     �.
2026-01-30 14:26:32.067  Mapper: Pushing 'ReadEvent' on to queue
2026-01-30 14:26:32.117  Mapper: Processing 'ReadEvent' message
2026-01-30 14:26:32.117  Mapper: Received 2 bytes of data
2026-01-30 14:26:32.117  Mapper:      d0 00 .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. ..     �.
2026-01-30 14:26:32.118  Mapper: Pushing 'onMessageCallback' on to queue
2026-01-30 14:26:32.118  Mapper: Processing 'onMessageCallback' message
2026-01-30 14:26:32.118  Mapper: Calling message handler 'onMessage' on 'module' type object.
2026-01-30 14:26:33.025  Slimme meter: P1 Smart Meter (Slimme meter)
2026-01-30 14:26:33.030  Slimme meter: General/Voltage (Voltage L1)
2026-01-30 14:26:33.035  Slimme meter: General/Voltage (Voltage L2)
2026-01-30 14:26:33.039  Slimme meter: General/Voltage (Voltage L3)
2026-01-30 14:26:33.042  Slimme meter: Usage (Usage L1)
2026-01-30 14:26:33.046  Slimme meter: Usage (Delivery L1)
2026-01-30 14:26:33.050  Slimme meter: Usage (Usage L2)
2026-01-30 14:26:33.054  Slimme meter: Usage (Delivery L2)
2026-01-30 14:26:33.058  Slimme meter: Usage (Usage L3)
2026-01-30 14:26:33.062  Slimme meter: Usage (Delivery L3)
2026-01-30 14:26:33.066  Slimme meter: Usage (Actual Usage L1/L2/L3)
2026-01-30 14:26:33.071  Slimme meter: Usage (Actual Delivery L1/L2/L3)
2026-01-30 14:26:33.075  Slimme meter: Current (Delivery Current L1/L2/L3)
2026-01-30 14:26:33.078  Slimme meter: Current (Delivery Current L1/L2/L3)
2026-01-30 14:26:35.023  Mapper: Pushing 'onHeartbeatCallback' on to queue
2026-01-30 14:26:35.073  Mapper: Processing 'onHeartbeatCallback' message
2026-01-30 14:26:35.073  Mapper: Calling message handler 'onHeartbeat' on 'module' type object.
2026-01-30 14:26:35.073  Mapper: Pushing 'WriteDirective' on to queue
2026-01-30 14:26:35.073  Mapper: Processing 'WriteDirective' message
2026-01-30 14:26:35.073  Mapper: Sending 2 bytes of data
2026-01-30 14:26:35.074  Mapper:      c0 00 .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. ..     �.
2026-01-30 14:26:35.075  Mapper: Pushing 'ReadEvent' on to queue
2026-01-30 14:26:35.124  Mapper: Processing 'ReadEvent' message
2026-01-30 14:26:35.124  Mapper: Received 2 bytes of data
2026-01-30 14:26:35.124  Mapper:      d0 00 .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. ..     �.
2026-01-30 14:26:35.124  Mapper: Pushing 'onMessageCallback' on to queue
2026-01-30 14:26:35.124  Mapper: Processing 'onMessageCallback' message
2026-01-30 14:26:35.124  Mapper: Calling message handler 'onMessage' on 'module' type object.
2026-01-30 14:26:35.420  Mapper: Pushing 'ReadEvent' on to queue
2026-01-30 14:26:35.425  Mapper: Processing 'ReadEvent' message
2026-01-30 14:26:35.425  Mapper: Received 34 bytes of data
2026-01-30 14:26:35.425  Mapper:      30 20 00 11 77 69 63 61 6e 2f 61 6d 70 65 72 61 65 2f 53 4f     0...wican/amperae/SO
2026-01-30 14:26:35.425  Mapper:      43 7b 22 53 4f 43 22 3a 33 35 2e 36 39 7d .. .. .. .. .. ..     C{"SOC":35.69}
2026-01-30 14:26:35.425  Mapper: Pushing 'onMessageCallback' on to queue
2026-01-30 14:26:35.425  Mapper: Processing 'onMessageCallback' message
2026-01-30 14:26:35.425  Mapper: Calling message handler 'onMessage' on 'module' type object.
2026-01-30 14:26:35.543  Mapper: Pushing 'ReadEvent' on to queue
2026-01-30 14:26:35.576  Mapper: Processing 'ReadEvent' message
2026-01-30 14:26:35.576  Mapper: Received 49 bytes of data
2026-01-30 14:26:35.576  Mapper:      30 2f 00 19 77 69 63 61 6e 2f 61 6d 70 65 72 61 65 2f 48 56     0/..wican/amperae/HV
2026-01-30 14:26:35.576  Mapper:      5f 43 41 50 41 43 49 54 59 7b 22 48 56 5f 43 41 50 41 43 49     _CAPACITY{"HV_CAPACI
2026-01-30 14:26:35.576  Mapper:      54 59 22 3a 32 33 33 30 7d .. .. .. .. .. .. .. .. .. .. ..     TY":2330}
2026-01-30 14:26:35.576  Mapper: Pushing 'onMessageCallback' on to queue
2026-01-30 14:26:35.576  Mapper: Processing 'onMessageCallback' message
2026-01-30 14:26:35.576  Mapper: Calling message handler 'onMessage' on 'module' type object.
FlyingDomotic
Post by FlyingDomotic »
It seems that there's no more "Mapper: Can't find device" in the log.
Is still something wrong?
rron
Post by rron »
You’re right it looks that after the git pull something went wrong
FlyingDomotic
Do you mean "everything is ok now" or "there's still something wrong"?
If something is still wrong, please describe it.
rron
Post by rron »
I think the mapper does not work anymore after the git pull. There is no update from the the devices anymore.
2026-01-31 11:30:24.376  Mapper: Debug logging mask set to: PYTHON PLUGIN QUEUE DEVICE CONNECTION MESSAGE
2026-01-31 11:30:24.377  Mapper: /opt/domoticz/userdata/plugins/MqttMapper/MqttMapper.json is a version 1.0 file
2026-01-31 11:30:24.404  Mapper: pluginV1::__init__
2026-01-31 11:30:24.404  Mapper: 'HardwareID': '50'
2026-01-31 11:30:24.404  Mapper: 'HomeFolder': '/opt/domoticz/userdata/plugins/MqttMapper/'
2026-01-31 11:30:24.404  Mapper: 'StartupFolder': '/opt/domoticz/'
2026-01-31 11:30:24.404  Mapper: 'UserDataFolder': '/opt/domoticz/userdata/'
2026-01-31 11:30:24.404  Mapper: 'Database': '/opt/domoticz/userdata/domoticz.db'
2026-01-31 11:30:24.404  Mapper: 'Language': 'nl'
2026-01-31 11:30:24.404  Mapper: 'Version': '26.1.26-1'
2026-01-31 11:30:24.404  Mapper: 'Author': 'Flying Domotic'
2026-01-31 11:30:24.404  Mapper: 'Name': 'Mapper'
2026-01-31 11:30:24.405  Mapper: 'Address': '192.168.178.50'
2026-01-31 11:30:24.405  Mapper: 'Port': '1883'
2026-01-31 11:30:24.405  Mapper: 'Key': 'MqttMapper'
2026-01-31 11:30:24.405  Mapper: 'Mode1': 'MqttMapper.json'
2026-01-31 11:30:24.405  Mapper: 'Mode6': 'Verbose+'
2026-01-31 11:30:24.405  Mapper: 'DomoticzVersion': '2025.2 (build 16836)'
2026-01-31 11:30:24.405  Mapper: 'DomoticzHash': '3b8a9cf2f'
2026-01-31 11:30:24.405  Mapper: 'DomoticzBuildTime': '2025-10-26 10:11:08'
2026-01-31 11:30:24.405  Mapper: Device count: 0
2026-01-31 11:30:24.406  Mapper: Creating device 'SmartEVSE charge current' with key 'SmartEVSE-5572/ChargeCurrent' as unit 1
2026-01-31 11:30:24.406  Mapper: Name='SmartEVSE charge current', Unit='1', Type=243, Subtype=23, Switchtype=0, DeviceID='SmartEVSE-5572/ChargeCurrent', Options='None', Used='True'
2026-01-31 11:30:24.406  Mapper: Creating device 'SmartEVSE charge current'.
2026-01-31 11:30:24.429  Mapper: Local context:
2026-01-31 11:30:24.429  Mapper:  ----> 'Devices'              '{}'
2026-01-31 11:30:24.429  Mapper:  ----> 'Domoticz'             '<module 'Domoticz' (built-in)>'
2026-01-31 11:30:24.429  Mapper:  ----> 'Images'               '{}'
2026-01-31 11:30:24.429  Mapper:  ----> 'Parameters'           '{'HardwareID': 50, 'HomeFolder': '/opt/domoticz/userdata/plugins/MqttMapper/', 'StartupFolder': '/opt/domoticz/', 'UserDataFolder': '/opt/domoticz/userdata/', 'WebRoot': '', 'Database': '/opt/domoticz/userdata/domoticz.db', 'Language': 'nl', 'Version': '26.1.26-1', 'Author': 'Flying Domotic', 'Name': 'Mapper', 'Address': '192.168.178.50', 'Port': '1883', 'SerialPort': '', 'Username': '', 'Password': '', 'Key': 'MqttMapper', 'Mode1': 'MqttMapper.json', 'Mode2': '', 'Mode3': '', 'Mode4': '', 'Mode5': '', 'Mode6': 'Verbose+', 'DomoticzVersion': '2025.2 (build 16836)', 'DomoticzHash': '3b8a9cf2f', 'DomoticzBuildTime': '2025-10-26 10:11:08'}'
2026-01-31 11:30:24.429  Mapper:  ----> 'Settings'             '{'DB_Version': '170', 'LightHistoryDays': '2', 'MeterDividerEnergy': '1000', 'MeterDividerGas': '100', 'MeterDividerWater': '1000', 'RandomTimerFrame': '15', 'ElectricVoltage': '230', 'CM113DisplayType': '0', '5MinuteHistoryDays': '1', 'SensorTimeout': '10000', 'SensorTimeoutNotification': '0', 'UseAutoUpdate': '0', 'UseAutoBackup': '1', 'CostEnergy': '2442', 'CostEnergyT2': '2442', 'CostGas': '6218', 'CostWater': '16473', 'UseEmailInNotifications': '1', 'EmailPort': '25', 'EmailAsAttachment': '0', 'DoorbellCommand': '0', 'SmartMeterType': '0', 'NotificationSensorInterval': '43200', 'NotificationSwitchInterval': '0', 'RemoteSharedPort': '6144', 'Language': 'nl', 'DashboardType': '0', 'MobileType': '0', 'WindUnit': '0', 'TempUnit': '0', 'SecStatus': '0', 'SecOnDelay': '30', 'ReleaseChannel': '0', 'RaspCamParams': '-w 800 -h 600 -t 1', 'AcceptNewHardware': '0', 'ZWavePollInterval': '60', 'ZWaveEnableDebug': '0', 'ZWaveNetworkKey': '0x01, 0x02, 0x03, 0x04, 0x05, 0x06, 0x07, 0x08, 0x09, 0x0A, 0x0B, 0x0C, 0x0D, 0x0E, 0x0F, 0x10', 'ZWaveEnableNightlyNetworkHeal': '1', 'BatteryLowNotification': '30', 'AllowWidgetOrdering': '1', 'ActiveTimerPlan': '0', 'HideDisabledHardwareSensors': '0', 'WebTheme': 'elemental', 'FloorplanPopupDelay': '750', 'FloorplanFullscreenMode': '0', 'FloorplanAnimateZoom': '1', 'FloorplanShowSensorValues': '1', 'FloorplanShowSwitchValues': '0', 'FloorplanShowSceneNames': '0', 'FloorplanRoomColour': 'Blue', 'FloorplanActiveOpacity': '25', 'FloorplanInactiveOpacity': '5', 'Location': '52.490216;4.947436', 'ProwlAPI': '0', 'NMAAPI': '0', 'PushoverAPI': '0', 'PushoverUser': '0', 'PushALotAPI': '0', 'WebLocalNetworks': '127.0.0.*;192.168.178.*', 'SecPassword': 'd41d8cd98f00b204e9800998ecf8427e', 'ProtectionPassword': 'd41d8cd98f00b204e9800998ecf8427e', 'EmailFrom': '0', 'EmailTo': '0', 'EmailServer': '0', 'EmailUsername': '0', 'EmailPassword': '0', 'UVCParams': '-S80 -B128 -C128 -G80 -x800 -y600 -q100', 'TempHome': '20', 'TempAway': '15', 'TempComfort': '22.0', 'ClickatellAPI': '0', 'ClickatellFrom': '0', 'ClickatellPassword': '0', 'ClickatellTo': '0', 'ClickatellUser': '0', 'NMAEnabled': '1', 'ProwlEnabled': '1', 'PushALotEnabled': '1', 'PushoverEnabled': '1', 'ClickatellEnabled': '1', 'HTTPURL': 'aHR0cHM6Ly93d3cuc29tZWdhdGV3YXkuY29tL3B1c2h1cmwucGhwP3VzZXJuYW1lPSNGSUVMRDEmcGFzc3dvcmQ9I0ZJRUxEMiZhcGlrZXk9I0ZJRUxEMyZmcm9tPSNGSUVMRDQmdG89I1RPJm1lc3NhZ2U9I01FU1NBR0U=', 'HTTPEnabled': '0', 'HTTPField1': '0', 'HTTPField2': '0', 'HTTPField3': '0', 'HTTPField4': '0', 'HTTPTo': '0', 'KodiIPAddress': '224.0.0.1', 'KodiEnabled': '0', 'KodiPort': '9777', 'KodiTimeToLive': '5', 'ShowUpdateEffect': '0', 'ShortLogInterval': '5', 'DisplayPowerUsageInkWhGraph': '1', 'PushbulletAPI': '0', 'PushbulletEnabled': '0', 'DegreeDaysBaseTemperature': '18.0', 'LmsPlayerMac': '00:04:20:12:65:EF', 'LmsDuration': '5', 'LmsEnabled': '1', 'MyDomoticzUserId': '0', 'MyDomoticzSubsystems': '0', 'SendErrorNotifications': '0', 'HTTPPostContentType': 'YXBwbGljYXRpb24vanNvbg==', 'SendErrorsAsNotification': '0', 'HTTPPostData': '0', 'HTTPPostHeaders': '0', 'PushsaferAPI': '0', 'PushsaferEnabled': '0', 'OneWireSensorPollPeriod': '0', 'OneWireSwitchPollPeriod': '0', 'LogEventScriptTrigger': '1', 'Title': 'Domoticz', 'CostEnergyR1': '2263', 'CostEnergyR2': '2263', 'GCMEnabled': '0', 'PushsaferImage': '0', 'WeightUnit': '0', 'DisableDzVentsSystem': '0', 'DzVentsLogLevel': '3', 'EnableEventScriptSystem': '1', 'IFTTTEnabled': '0', 'EmailEnabled': '0', 'IFTTTAPI': '0', 'TelegramAPI': '0', 'TelegramChat': '0', 'TelegramEnabled': '0', 'EventSystemLogFullURL': '1', 'FCMEnabled': '0', 'MaxElectricPower': '9000', 'Unique_ID': '20ee2d55-8d8c-4f6d-8106-97dafa47fb0f', 'ShortLogAddOnlyNewValues': '1', 'AllowPlainBasicAuth': '1', 'Domoticz_Version': '2025.2 (build 16836)', 'ForecastHardwareID': '40', 'HourIdxElectricityDevice': '624485', 'HourIdxGasDevice': '0', 'Currency': '���', 'P1DisplayType': '0', 'ESettings': '{"ConvertWaterM3ToLiter":false,"DisplayFlowWithLines":true,"DisplayOutsideTemp":true,"DisplayTime":true,"Extra1Field":"Data","Extra1Icon":"heater","Extra2Field":"CounterToday","Extra2Icon":"power","Extra3Field":"CounterToday","Extra3Icon":"other","UseCustomIcons":true,"idBatterySoc":-1,"idBatteryWatt":-1,"idExtra1":688,"idExtra2":901,"idExtra3":506,"idGas":-1,"idOutsideTempSensor":610,"idP1":619,"idSolar":919,"idTextSensor":-1,"idWater":-1}', 'events_recent_list': '12,13'}'
2026-01-31 11:30:24.430  Mapper:  ----> '_plugin'              '<pluginV1.pluginV1 object at 0xee54daf0>'
2026-01-31 11:30:24.430  Mapper:  ----> 'json'                 '<module 'json' from '/usr/lib/python3.11/json/__init__.py'>'
2026-01-31 11:30:24.430  Mapper:  ----> 'os'                   '<module 'os' (frozen)>'
2026-01-31 11:30:25.228  Slimme meter: P1 Smart Meter (Slimme meter)
2026-01-31 11:30:25.235  Slimme meter: General/Voltage (Voltage L1)
2026-01-31 11:30:25.240  Slimme meter: General/Voltage (Voltage L2)
2026-01-31 11:30:25.244  Slimme meter: General/Voltage (Voltage L3)
2026-01-31 11:30:25.248  Slimme meter: Usage (Usage L1)
2026-01-31 11:30:25.252  Slimme meter: Usage (Delivery L1)
2026-01-31 11:30:25.256  Slimme meter: Usage (Usage L2)
2026-01-31 11:30:25.260  Slimme meter: Usage (Delivery L2)
2026-01-31 11:30:25.264  Slimme meter: Usage (Usage L3)
2026-01-31 11:30:25.269  Slimme meter: Usage (Delivery L3)
2026-01-31 11:30:25.273  Slimme meter: Usage (Actual Usage L1/L2/L3)
2026-01-31 11:30:25.277  Slimme meter: Usage (Actual Delivery L1/L2/L3)
2026-01-31 11:30:25.281  Slimme meter: Current (Delivery Current L1/L2/L3)
2026-01-31 11:30:25.284  Slimme meter: Current (Delivery Current L1/L2/L3)
2026-01-31 11:30:29.303  Mapper: Pushing 'onStopCallback' on to queue
2026-01-31 11:30:29.303  Mapper: Processing 'onStopCallback' message
2026-01-31 11:30:29.303  Mapper: Message handler 'onStop' not callable, ignored.
2026-01-31 11:30:30.002  mDNS: Closed 1 socket
2026-01-31 11:31:06.824  Sunrise: 08:23:00 SunSet: 17:24:00
2026-01-31 11:31:06.825  Day length: 09:01:00 Sun at south: 12:54:00
2026-01-31 11:31:06.825  Civil twilight start: 07:46:00 Civil twilight end: 18:01:00
2026-01-31 11:31:06.825  Nautical twilight start: 07:05:00 Nautical twilight end: 18:43:00
2026-01-31 11:31:06.825  Astronomical twilight start: 06:25:00 Astronomical twilight end: 19:23:00
2026-01-31 11:31:06.907  Active notification Subsystems: lms (1/13)
2026-01-31 11:31:06.949  Starting shared server on: :::6144
2026-01-31 11:31:06.952  mDNS: Service: _http._tcp.local.:443 for Hostname: domoticz (1 socket)
2026-01-31 11:31:08.971  Mapper: Worker thread started.
2026-01-31 11:31:08.972  Mapper: Worker thread started.
2026-01-31 11:31:09.299  Mapper: Debug logging mask set to: PYTHON PLUGIN QUEUE DEVICE CONNECTION MESSAGE
2026-01-31 11:31:09.304  Mapper: Debug logging mask set to: PYTHON PLUGIN DEVICE
2026-01-31 11:31:09.305  Mapper: /opt/domoticz/userdata/plugins/MqttMapper/MqttMapper.json is a version 1.0 file
2026-01-31 11:31:09.307  Mapper: /opt/domoticz/userdata/plugins/MqttMapper/MqttMapper.json is a version 1.0 file
2026-01-31 11:31:09.451  Mapper: pluginV1::__init__
2026-01-31 11:31:09.451  Mapper: 'HardwareID': '48'
2026-01-31 11:31:09.451  Mapper: 'HomeFolder': '/opt/domoticz/userdata/plugins/MqttMapper/'
2026-01-31 11:31:09.452  Mapper: 'StartupFolder': '/opt/domoticz/'
2026-01-31 11:31:09.452  Mapper: 'UserDataFolder': '/opt/domoticz/userdata/'
2026-01-31 11:31:09.452  Mapper: 'Database': '/opt/domoticz/userdata/domoticz.db'
2026-01-31 11:31:09.453  Mapper: 'Language': 'nl'
2026-01-31 11:31:09.453  Mapper: 'Version': '26.1.26-1'
2026-01-31 11:31:09.453  Mapper: 'Author': 'Flying Domotic'
2026-01-31 11:31:09.453  Mapper: 'Name': 'Mapper'
2026-01-31 11:31:09.453  Mapper: 'Address': '192.168.178.50'
2026-01-31 11:31:09.454  Mapper: 'Port': '1883'
2026-01-31 11:31:09.454  Mapper: 'Key': 'MqttMapper'
2026-01-31 11:31:09.454  Mapper: 'Mode1': 'MqttMapper.json'
2026-01-31 11:31:09.454  Mapper: 'Mode6': 'Debug'
2026-01-31 11:31:09.454  Mapper: 'DomoticzVersion': '2025.2 (build 16836)'
2026-01-31 11:31:09.454  Mapper: 'DomoticzHash': '3b8a9cf2f'
2026-01-31 11:31:09.454  Mapper: 'DomoticzBuildTime': '2025-10-26 10:11:08'
2026-01-31 11:31:09.455  Mapper: Device count: 7
2026-01-31 11:31:09.456  Mapper: Device: 1 - ID: 867, Name: 'charge current', nValue: 16, sValue: '16.0'
2026-01-31 11:31:09.456  Mapper: Device: 2 - ID: 868, Name: 'max current', nValue: 16, sValue: '16.0'
2026-01-31 11:31:09.456  Mapper: Device: 3 - ID: 901, Name: 'evenergy charged', nValue: 10013, sValue: '10013.0'
2026-01-31 11:31:09.457  Mapper: Device: 4 - ID: 870, Name: 'evtotalenergy charged', nValue: 1053, sValue: '1053.461'
2026-01-31 11:31:09.458  Mapper: Device: 5 - ID: 871, Name: 'SmartEVSE state', nValue: 0, sValue: 'Charging'
2026-01-31 11:31:09.458  Mapper: Device: 6 - ID: 872, Name: 'SmartEVSE error', nValue: 0, sValue: '0'
2026-01-31 11:31:09.459  Mapper: Device: 7 - ID: 873, Name: 'charge current override', nValue: 0, sValue: '0.0'
2026-01-31 11:31:09.460  Mapper: Creating device 'amperae State of Charge' with key 'wican/amperae/SOC' as unit 8
2026-01-31 11:31:09.460  Mapper: Creating device 'amperae State of Charge'.
2026-01-31 11:31:09.467  Mapper: pluginV1::__init__
2026-01-31 11:31:09.467  Mapper: 'HardwareID': '50'
2026-01-31 11:31:09.467  Mapper: 'HomeFolder': '/opt/domoticz/userdata/plugins/MqttMapper/'
2026-01-31 11:31:09.470  Mapper: 'StartupFolder': '/opt/domoticz/'
2026-01-31 11:31:09.470  Mapper: 'UserDataFolder': '/opt/domoticz/userdata/'
2026-01-31 11:31:09.471  Mapper: 'Database': '/opt/domoticz/userdata/domoticz.db'
2026-01-31 11:31:09.471  Mapper: 'Language': 'nl'
2026-01-31 11:31:09.471  Mapper: 'Version': '26.1.26-1'
2026-01-31 11:31:09.471  Mapper: 'Author': 'Flying Domotic'
2026-01-31 11:31:09.471  Mapper: 'Name': 'Mapper'
2026-01-31 11:31:09.472  Mapper: 'Address': '192.168.178.50'
2026-01-31 11:31:09.472  Mapper: 'Port': '1883'
2026-01-31 11:31:09.472  Mapper: 'Key': 'MqttMapper'
2026-01-31 11:31:09.472  Mapper: 'Mode1': 'MqttMapper.json'
2026-01-31 11:31:09.472  Mapper: 'Mode6': 'Verbose+'
2026-01-31 11:31:09.472  Mapper: 'DomoticzVersion': '2025.2 (build 16836)'
2026-01-31 11:31:09.473  Mapper: 'DomoticzHash': '3b8a9cf2f'
2026-01-31 11:31:09.473  Mapper: 'DomoticzBuildTime': '2025-10-26 10:11:08'
2026-01-31 11:31:09.473  Mapper: Device count: 0
2026-01-31 11:31:09.474  Mapper: Creating device 'SmartEVSE charge current' with key 'SmartEVSE-5572/ChargeCurrent' as unit 1
2026-01-31 11:31:09.474  Mapper: Name='SmartEVSE charge current', Unit='1', Type=243, Subtype=23, Switchtype=0, DeviceID='SmartEVSE-5572/ChargeCurrent', Options='None', Used='True'
2026-01-31 11:31:09.475  Mapper: Creating device 'SmartEVSE charge current'.
2026-01-31 11:31:09.586  Mapper: Local context:
2026-01-31 11:31:09.587  Mapper:  ----> 'Devices'              '{1: <Domoticz.Device object at 0xefb535c0>, 2: <Domoticz.Device object at 0xefb53680>, 3: <Domoticz.Device object at 0xefb53b00>, 4: <Domoticz.Device object at 0xefb530e0>, 5: <Domoticz.Device object at 0xefb53320>, 6: <Domoticz.Device object at 0xee1c8920>, 7: <Domoticz.Device object at 0xee1c8980>}'
2026-01-31 11:31:09.587  Mapper:  ----> 'Domoticz'             '<module 'Domoticz' (built-in)>'
2026-01-31 11:31:09.587  Mapper:  ----> 'Images'               '{}'
2026-01-31 11:31:09.588  Mapper:  ----> 'Parameters'           '{'HardwareID': 48, 'HomeFolder': '/opt/domoticz/userdata/plugins/MqttMapper/', 'StartupFolder': '/opt/domoticz/', 'UserDataFolder': '/opt/domoticz/userdata/', 'WebRoot': '', 'Database': '/opt/domoticz/userdata/domoticz.db', 'Language': 'nl', 'Version': '26.1.26-1', 'Author': 'Flying Domotic', 'Name': 'Mapper', 'Address': '192.168.178.50', 'Port': '1883', 'SerialPort': '', 'Username': '', 'Password': '', 'Key': 'MqttMapper', 'Mode1': 'MqttMapper.json', 'Mode2': '', 'Mode3': '', 'Mode4': '', 'Mode5': '', 'Mode6': 'Debug', 'DomoticzVersion': '2025.2 (build 16836)', 'DomoticzHash': '3b8a9cf2f', 'DomoticzBuildTime': '2025-10-26 10:11:08'}'
2026-01-31 11:31:09.588  Mapper:  ----> 'Settings'             '{'DB_Version': '170', 'LightHistoryDays': '2', 'MeterDividerEnergy': '1000', 'MeterDividerGas': '100', 'MeterDividerWater': '1000', 'RandomTimerFrame': '15', 'ElectricVoltage': '230', 'CM113DisplayType': '0', '5MinuteHistoryDays': '1', 'SensorTimeout': '10000', 'SensorTimeoutNotification': '0', 'UseAutoUpdate': '0', 'UseAutoBackup': '1', 'CostEnergy': '2442', 'CostEnergyT2': '2442', 'CostGas': '6218', 'CostWater': '16473', 'UseEmailInNotifications': '1', 'EmailPort': '25', 'EmailAsAttachment': '0', 'DoorbellCommand': '0', 'SmartMeterType': '0', 'NotificationSensorInterval': '43200', 'NotificationSwitchInterval': '0', 'RemoteSharedPort': '6144', 'Language': 'nl', 'DashboardType': '0', 'MobileType': '0', 'WindUnit': '0', 'TempUnit': '0', 'SecStatus': '0', 'SecOnDelay': '30', 'ReleaseChannel': '0', 'RaspCamParams': '-w 800 -h 600 -t 1', 'AcceptNewHardware': '0', 'ZWavePollInterval': '60', 'ZWaveEnableDebug': '0', 'ZWaveNetworkKey': '0x01, 0x02, 0x03, 0x04, 0x05, 0x06, 0x07, 0x08, 0x09, 0x0A, 0x0B, 0x0C, 0x0D, 0x0E, 0x0F, 0x10', 'ZWaveEnableNightlyNetworkHeal': '1', 'BatteryLowNotification': '30', 'AllowWidgetOrdering': '1', 'ActiveTimerPlan': '0', 'HideDisabledHardwareSensors': '0', 'WebTheme': 'elemental', 'FloorplanPopupDelay': '750', 'FloorplanFullscreenMode': '0', 'FloorplanAnimateZoom': '1', 'FloorplanShowSensorValues': '1', 'FloorplanShowSwitchValues': '0', 'FloorplanShowSceneNames': '0', 'FloorplanRoomColour': 'Blue', 'FloorplanActiveOpacity': '25', 'FloorplanInactiveOpacity': '5', 'Location': '52.490216;4.947436', 'ProwlAPI': '0', 'NMAAPI': '0', 'PushoverAPI': '0', 'PushoverUser': '0', 'PushALotAPI': '0', 'WebLocalNetworks': '127.0.0.*;192.168.178.*', 'SecPassword': 'd41d8cd98f00b204e9800998ecf8427e', 'ProtectionPassword': 'd41d8cd98f00b204e9800998ecf8427e', 'EmailFrom': '0', 'EmailTo': '0', 'EmailServer': '0', 'EmailUsername': '0', 'EmailPassword': '0', 'UVCParams': '-S80 -B128 -C128 -G80 -x800 -y600 -q100', 'TempHome': '20', 'TempAway': '15', 'TempComfort': '22.0', 'ClickatellAPI': '0', 'ClickatellFrom': '0', 'ClickatellPassword': '0', 'ClickatellTo': '0', 'ClickatellUser': '0', 'NMAEnabled': '1', 'ProwlEnabled': '1', 'PushALotEnabled': '1', 'PushoverEnabled': '1', 'ClickatellEnabled': '1', 'HTTPURL': 'aHR0cHM6Ly93d3cuc29tZWdhdGV3YXkuY29tL3B1c2h1cmwucGhwP3VzZXJuYW1lPSNGSUVMRDEmcGFzc3dvcmQ9I0ZJRUxEMiZhcGlrZXk9I0ZJRUxEMyZmcm9tPSNGSUVMRDQmdG89I1RPJm1lc3NhZ2U9I01FU1NBR0U=', 'HTTPEnabled': '0', 'HTTPField1': '0', 'HTTPField2': '0', 'HTTPField3': '0', 'HTTPField4': '0', 'HTTPTo': '0', 'KodiIPAddress': '224.0.0.1', 'KodiEnabled': '0', 'KodiPort': '9777', 'KodiTimeToLive': '5', 'ShowUpdateEffect': '0', 'ShortLogInterval': '5', 'DisplayPowerUsageInkWhGraph': '1', 'PushbulletAPI': '0', 'PushbulletEnabled': '0', 'DegreeDaysBaseTemperature': '18.0', 'LmsPlayerMac': '00:04:20:12:65:EF', 'LmsDuration': '5', 'LmsEnabled': '1', 'MyDomoticzUserId': '0', 'MyDomoticzSubsystems': '0', 'SendErrorNotifications': '0', 'HTTPPostContentType': 'YXBwbGljYXRpb24vanNvbg==', 'SendErrorsAsNotification': '0', 'HTTPPostData': '0', 'HTTPPostHeaders': '0', 'PushsaferAPI': '0', 'PushsaferEnabled': '0', 'OneWireSensorPollPeriod': '0', 'OneWireSwitchPollPeriod': '0', 'LogEventScriptTrigger': '1', 'Title': 'Domoticz', 'CostEnergyR1': '2263', 'CostEnergyR2': '2263', 'GCMEnabled': '0', 'PushsaferImage': '0', 'WeightUnit': '0', 'DisableDzVentsSystem': '0', 'DzVentsLogLevel': '3', 'EnableEventScriptSystem': '1', 'IFTTTEnabled': '0', 'EmailEnabled': '0', 'IFTTTAPI': '0', 'TelegramAPI': '0', 'TelegramChat': '0', 'TelegramEnabled': '0', 'EventSystemLogFullURL': '1', 'FCMEnabled': '0', 'MaxElectricPower': '9000', 'Unique_ID': '20ee2d55-8d8c-4f6d-8106-97dafa47fb0f', 'ShortLogAddOnlyNewValues': '1', 'AllowPlainBasicAuth': '1', 'Domoticz_Version': '2025.2 (build 16836)', 'ForecastHardwareID': '40', 'HourIdxElectricityDevice': '624485', 'HourIdxGasDevice': '0', 'Currency': '���', 'P1DisplayType': '0', 'ESettings': '{"ConvertWaterM3ToLiter":false,"DisplayFlowWithLines":true,"DisplayOutsideTemp":true,"DisplayTime":true,"Extra1Field":"Data","Extra1Icon":"heater","Extra2Field":"CounterToday","Extra2Icon":"power","Extra3Field":"CounterToday","Extra3Icon":"other","UseCustomIcons":true,"idBatterySoc":-1,"idBatteryWatt":-1,"idExtra1":688,"idExtra2":901,"idExtra3":506,"idGas":-1,"idOutsideTempSensor":610,"idP1":619,"idSolar":919,"idTextSensor":-1,"idWater":-1}', 'events_recent_list': '12,13'}'
2026-01-31 11:31:09.589  Mapper:  ----> '_plugin'              '<pluginV1.pluginV1 object at 0xee1b4f30>'
2026-01-31 11:31:09.590  Mapper:  ----> 'json'                 '<module 'json' from '/usr/lib/python3.11/json/__init__.py'>'
2026-01-31 11:31:09.590  Mapper:  ----> 'os'                   '<module 'os' (frozen)>'
2026-01-31 11:31:09.603  Mapper: Local context:
2026-01-31 11:31:09.603  Mapper:  ----> 'Devices'              '{}'
2026-01-31 11:31:09.603  Mapper:  ----> 'Domoticz'             '<module 'Domoticz' (built-in)>'
2026-01-31 11:31:09.603  Mapper:  ----> 'Images'               '{}'
2026-01-31 11:31:09.604  Mapper:  ----> 'Parameters'           '{'HardwareID': 50, 'HomeFolder': '/opt/domoticz/userdata/plugins/MqttMapper/', 'StartupFolder': '/opt/domoticz/', 'UserDataFolder': '/opt/domoticz/userdata/', 'WebRoot': '', 'Database': '/opt/domoticz/userdata/domoticz.db', 'Language': 'nl', 'Version': '26.1.26-1', 'Author': 'Flying Domotic', 'Name': 'Mapper', 'Address': '192.168.178.50', 'Port': '1883', 'SerialPort': '', 'Username': '', 'Password': '', 'Key': 'MqttMapper', 'Mode1': 'MqttMapper.json', 'Mode2': '', 'Mode3': '', 'Mode4': '', 'Mode5': '', 'Mode6': 'Verbose+', 'DomoticzVersion': '2025.2 (build 16836)', 'DomoticzHash': '3b8a9cf2f', 'DomoticzBuildTime': '2025-10-26 10:11:08'}'
2026-01-31 11:31:09.604  Mapper:  ----> 'Settings'             '{'DB_Version': '170', 'LightHistoryDays': '2', 'MeterDividerEnergy': '1000', 'MeterDividerGas': '100', 'MeterDividerWater': '1000', 'RandomTimerFrame': '15', 'ElectricVoltage': '230', 'CM113DisplayType': '0', '5MinuteHistoryDays': '1', 'SensorTimeout': '10000', 'SensorTimeoutNotification': '0', 'UseAutoUpdate': '0', 'UseAutoBackup': '1', 'CostEnergy': '2442', 'CostEnergyT2': '2442', 'CostGas': '6218', 'CostWater': '16473', 'UseEmailInNotifications': '1', 'EmailPort': '25', 'EmailAsAttachment': '0', 'DoorbellCommand': '0', 'SmartMeterType': '0', 'NotificationSensorInterval': '43200', 'NotificationSwitchInterval': '0', 'RemoteSharedPort': '6144', 'Language': 'nl', 'DashboardType': '0', 'MobileType': '0', 'WindUnit': '0', 'TempUnit': '0', 'SecStatus': '0', 'SecOnDelay': '30', 'ReleaseChannel': '0', 'RaspCamParams': '-w 800 -h 600 -t 1', 'AcceptNewHardware': '0', 'ZWavePollInterval': '60', 'ZWaveEnableDebug': '0', 'ZWaveNetworkKey': '0x01, 0x02, 0x03, 0x04, 0x05, 0x06, 0x07, 0x08, 0x09, 0x0A, 0x0B, 0x0C, 0x0D, 0x0E, 0x0F, 0x10', 'ZWaveEnableNightlyNetworkHeal': '1', 'BatteryLowNotification': '30', 'AllowWidgetOrdering': '1', 'ActiveTimerPlan': '0', 'HideDisabledHardwareSensors': '0', 'WebTheme': 'elemental', 'FloorplanPopupDelay': '750', 'FloorplanFullscreenMode': '0', 'FloorplanAnimateZoom': '1', 'FloorplanShowSensorValues': '1', 'FloorplanShowSwitchValues': '0', 'FloorplanShowSceneNames': '0', 'FloorplanRoomColour': 'Blue', 'FloorplanActiveOpacity': '25', 'FloorplanInactiveOpacity': '5', 'Location': '52.490216;4.947436', 'ProwlAPI': '0', 'NMAAPI': '0', 'PushoverAPI': '0', 'PushoverUser': '0', 'PushALotAPI': '0', 'WebLocalNetworks': '127.0.0.*;192.168.178.*', 'SecPassword': 'd41d8cd98f00b204e9800998ecf8427e', 'ProtectionPassword': 'd41d8cd98f00b204e9800998ecf8427e', 'EmailFrom': '0', 'EmailTo': '0', 'EmailServer': '0', 'EmailUsername': '0', 'EmailPassword': '0', 'UVCParams': '-S80 -B128 -C128 -G80 -x800 -y600 -q100', 'TempHome': '20', 'TempAway': '15', 'TempComfort': '22.0', 'ClickatellAPI': '0', 'ClickatellFrom': '0', 'ClickatellPassword': '0', 'ClickatellTo': '0', 'ClickatellUser': '0', 'NMAEnabled': '1', 'ProwlEnabled': '1', 'PushALotEnabled': '1', 'PushoverEnabled': '1', 'ClickatellEnabled': '1', 'HTTPURL': 'aHR0cHM6Ly93d3cuc29tZWdhdGV3YXkuY29tL3B1c2h1cmwucGhwP3VzZXJuYW1lPSNGSUVMRDEmcGFzc3dvcmQ9I0ZJRUxEMiZhcGlrZXk9I0ZJRUxEMyZmcm9tPSNGSUVMRDQmdG89I1RPJm1lc3NhZ2U9I01FU1NBR0U=', 'HTTPEnabled': '0', 'HTTPField1': '0', 'HTTPField2': '0', 'HTTPField3': '0', 'HTTPField4': '0', 'HTTPTo': '0', 'KodiIPAddress': '224.0.0.1', 'KodiEnabled': '0', 'KodiPort': '9777', 'KodiTimeToLive': '5', 'ShowUpdateEffect': '0', 'ShortLogInterval': '5', 'DisplayPowerUsageInkWhGraph': '1', 'PushbulletAPI': '0', 'PushbulletEnabled': '0', 'DegreeDaysBaseTemperature': '18.0', 'LmsPlayerMac': '00:04:20:12:65:EF', 'LmsDuration': '5', 'LmsEnabled': '1', 'MyDomoticzUserId': '0', 'MyDomoticzSubsystems': '0', 'SendErrorNotifications': '0', 'HTTPPostContentType': 'YXBwbGljYXRpb24vanNvbg==', 'SendErrorsAsNotification': '0', 'HTTPPostData': '0', 'HTTPPostHeaders': '0', 'PushsaferAPI': '0', 'PushsaferEnabled': '0', 'OneWireSensorPollPeriod': '0', 'OneWireSwitchPollPeriod': '0', 'LogEventScriptTrigger': '1', 'Title': 'Domoticz', 'CostEnergyR1': '2263', 'CostEnergyR2': '2263', 'GCMEnabled': '0', 'PushsaferImage': '0', 'WeightUnit': '0', 'DisableDzVentsSystem': '0', 'DzVentsLogLevel': '3', 'EnableEventScriptSystem': '1', 'IFTTTEnabled': '0', 'EmailEnabled': '0', 'IFTTTAPI': '0', 'TelegramAPI': '0', 'TelegramChat': '0', 'TelegramEnabled': '0', 'EventSystemLogFullURL': '1', 'FCMEnabled': '0', 'MaxElectricPower': '9000', 'Unique_ID': '20ee2d55-8d8c-4f6d-8106-97dafa47fb0f', 'ShortLogAddOnlyNewValues': '1', 'AllowPlainBasicAuth': '1', 'Domoticz_Version': '2025.2 (build 16836)', 'ForecastHardwareID': '40', 'HourIdxElectricityDevice': '624485', 'HourIdxGasDevice': '0', 'Currency': '���', 'P1DisplayType': '0', 'ESettings': '{"ConvertWaterM3ToLiter":false,"DisplayFlowWithLines":true,"DisplayOutsideTemp":true,"DisplayTime":true,"Extra1Field":"Data","Extra1Icon":"heater","Extra2Field":"CounterToday","Extra2Icon":"power","Extra3Field":"CounterToday","Extra3Icon":"other","UseCustomIcons":true,"idBatterySoc":-1,"idBatteryWatt":-1,"idExtra1":688,"idExtra2":901,"idExtra3":506,"idGas":-1,"idOutsideTempSensor":610,"idP1":619,"idSolar":919,"idTextSensor":-1,"idWater":-1}', 'events_recent_list': '12,13'}'
2026-01-31 11:31:09.605  Mapper:  ----> '_plugin'              '<pluginV1.pluginV1 object at 0xee1b4910>'
2026-01-31 11:31:09.614  Mapper:  ----> 'json'                 '<module 'json' from '/usr/lib/python3.11/json/__init__.py'>'
2026-01-31 11:31:09.614  Mapper:  ----> 'os'                   '<module 'os' (frozen)>'
FlyingDomotic
Would it be possible to check that there's not the same "Mapper" hardware twice (one with hardware 48 and one with 50)?
rron
Post by rron »
The first time there were 2 mappers active, I deleted the second but still no luck.There are no devices created anymore.
026-02-01 11:32:30.032  Mapper: Pushing 'onHeartbeatCallback' on to queue
2026-02-01 11:32:30.082  Mapper: Processing 'onHeartbeatCallback' message
2026-02-01 11:32:30.083  Mapper: Calling message handler 'onHeartbeat' on 'module' type object.
2026-02-01 11:32:31.111  Mapper: Pushing 'onStopCallback' on to queue
2026-02-01 11:32:31.112  Mapper: Processing 'onStopCallback' message
2026-02-01 11:32:31.112  Mapper: Message handler 'onStop' not callable, ignored.
2026-02-01 11:32:32.403  mDNS: Closed 1 socket
2026-02-01 11:32:50.697  Sunrise: 08:21:00 SunSet: 17:26:00
2026-02-01 11:32:50.698  Day length: 09:05:00 Sun at south: 12:54:00
2026-02-01 11:32:50.698  Civil twilight start: 07:44:00 Civil twilight end: 18:03:00
2026-02-01 11:32:50.698  Nautical twilight start: 07:03:00 Nautical twilight end: 18:44:00
2026-02-01 11:32:50.698  Astronomical twilight start: 06:23:00 Astronomical twilight end: 19:24:00
2026-02-01 11:32:50.768  Active notification Subsystems: lms (1/13)
2026-02-01 11:32:50.823  Starting shared server on: :::6144
2026-02-01 11:32:50.825  mDNS: Service: _http._tcp.local.:443 for Hostname: domoticz (1 socket)
2026-02-01 11:32:52.850  Mapper: Worker thread started.
2026-02-01 11:32:53.338  Mapper: Debug logging mask set to: PYTHON PLUGIN QUEUE DEVICE CONNECTION MESSAGE
2026-02-01 11:32:53.340  Mapper: /opt/domoticz/userdata/plugins/MqttMapper/MqttMapper.json is a version 1.0 file
2026-02-01 11:32:53.521  Mapper: pluginV1::__init__
2026-02-01 11:32:53.522  Mapper: 'HardwareID': '50'
2026-02-01 11:32:53.522  Mapper: 'HomeFolder': '/opt/domoticz/userdata/plugins/MqttMapper/'
2026-02-01 11:32:53.522  Mapper: 'StartupFolder': '/opt/domoticz/'
2026-02-01 11:32:53.522  Mapper: 'UserDataFolder': '/opt/domoticz/userdata/'
2026-02-01 11:32:53.522  Mapper: 'Database': '/opt/domoticz/userdata/domoticz.db'
2026-02-01 11:32:53.522  Mapper: 'Language': 'nl'
2026-02-01 11:32:53.523  Mapper: 'Version': '26.1.26-1'
2026-02-01 11:32:53.523  Mapper: 'Author': 'Flying Domotic'
2026-02-01 11:32:53.523  Mapper: 'Name': 'Mapper'
2026-02-01 11:32:53.523  Mapper: 'Address': '192.168.178.50'
2026-02-01 11:32:53.523  Mapper: 'Port': '1883'
2026-02-01 11:32:53.523  Mapper: 'Key': 'MqttMapper'
2026-02-01 11:32:53.523  Mapper: 'Mode1': 'MqttMapper.json'
2026-02-01 11:32:53.523  Mapper: 'Mode6': 'Verbose+'
2026-02-01 11:32:53.524  Mapper: 'DomoticzVersion': '2025.2 (build 16836)'
2026-02-01 11:32:53.524  Mapper: 'DomoticzHash': '3b8a9cf2f'
2026-02-01 11:32:53.524  Mapper: 'DomoticzBuildTime': '2025-10-26 10:11:08'
2026-02-01 11:32:53.524  Mapper: Device count: 0
2026-02-01 11:32:53.525  Mapper: Creating device 'SmartEVSE charge current' with key 'SmartEVSE-5572/ChargeCurrent' as unit 1
2026-02-01 11:32:53.525  Mapper: Name='SmartEVSE charge current', Unit='1', Type=243, Subtype=23, Switchtype=0, DeviceID='SmartEVSE-5572/ChargeCurrent', Options='None', Used='True'
2026-02-01 11:32:53.525  Mapper: Creating device 'SmartEVSE charge current'.
2026-02-01 11:32:53.643  Mapper: Local context:
2026-02-01 11:32:53.644  Mapper:  ----> 'Devices'              '{}'
2026-02-01 11:32:53.644  Mapper:  ----> 'Domoticz'             '<module 'Domoticz' (built-in)>'
2026-02-01 11:32:53.645  Mapper:  ----> 'Images'               '{}'
2026-02-01 11:32:53.645  Mapper:  ----> 'Parameters'           '{'HardwareID': 50, 'HomeFolder': '/opt/domoticz/userdata/plugins/MqttMapper/', 'StartupFolder': '/opt/domoticz/', 'UserDataFolder': '/opt/domoticz/userdata/', 'WebRoot': '', 'Database': '/opt/domoticz/userdata/domoticz.db', 'Language': 'nl', 'Version': '26.1.26-1', 'Author': 'Flying Domotic', 'Name': 'Mapper', 'Address': '192.168.178.50', 'Port': '1883', 'SerialPort': '', 'Username': '', 'Password': '', 'Key': 'MqttMapper', 'Mode1': 'MqttMapper.json', 'Mode2': '', 'Mode3': '', 'Mode4': '', 'Mode5': '', 'Mode6': 'Verbose+', 'DomoticzVersion': '2025.2 (build 16836)', 'DomoticzHash': '3b8a9cf2f', 'DomoticzBuildTime': '2025-10-26 10:11:08'}'
2026-02-01 11:32:53.646  Mapper:  ----> 'Settings'             '{'DB_Version': '170', 'LightHistoryDays': '2', 'MeterDividerEnergy': '1000', 'MeterDividerGas': '100', 'MeterDividerWater': '1000', 'RandomTimerFrame': '15', 'ElectricVoltage': '230', 'CM113DisplayType': '0', '5MinuteHistoryDays': '1', 'SensorTimeout': '10000', 'SensorTimeoutNotification': '0', 'UseAutoUpdate': '0', 'UseAutoBackup': '1', 'CostEnergy': '2442', 'CostEnergyT2': '2442', 'CostGas': '6218', 'CostWater': '16473', 'UseEmailInNotifications': '1', 'EmailPort': '25', 'EmailAsAttachment': '0', 'DoorbellCommand': '0', 'SmartMeterType': '0', 'NotificationSensorInterval': '43200', 'NotificationSwitchInterval': '0', 'RemoteSharedPort': '6144', 'Language': 'nl', 'DashboardType': '0', 'MobileType': '0', 'WindUnit': '0', 'TempUnit': '0', 'SecStatus': '0', 'SecOnDelay': '30', 'ReleaseChannel': '0', 'RaspCamParams': '-w 800 -h 600 -t 1', 'AcceptNewHardware': '0', 'ZWavePollInterval': '60', 'ZWaveEnableDebug': '0', 'ZWaveNetworkKey': '0x01, 0x02, 0x03, 0x04, 0x05, 0x06, 0x07, 0x08, 0x09, 0x0A, 0x0B, 0x0C, 0x0D, 0x0E, 0x0F, 0x10', 'ZWaveEnableNightlyNetworkHeal': '1', 'BatteryLowNotification': '30', 'AllowWidgetOrdering': '1', 'ActiveTimerPlan': '0', 'HideDisabledHardwareSensors': '0', 'WebTheme': 'elemental', 'FloorplanPopupDelay': '750', 'FloorplanFullscreenMode': '0', 'FloorplanAnimateZoom': '1', 'FloorplanShowSensorValues': '1', 'FloorplanShowSwitchValues': '0', 'FloorplanShowSceneNames': '0', 'FloorplanRoomColour': 'Blue', 'FloorplanActiveOpacity': '25', 'FloorplanInactiveOpacity': '5', 'Location': '52.490216;4.947436', 'ProwlAPI': '0', 'NMAAPI': '0', 'PushoverAPI': '0', 'PushoverUser': '0', 'PushALotAPI': '0', 'WebLocalNetworks': '127.0.0.*;192.168.178.*', 'SecPassword': 'd41d8cd98f00b204e9800998ecf8427e', 'ProtectionPassword': 'd41d8cd98f00b204e9800998ecf8427e', 'EmailFrom': '0', 'EmailTo': '0', 'EmailServer': '0', 'EmailUsername': '0', 'EmailPassword': '0', 'UVCParams': '-S80 -B128 -C128 -G80 -x800 -y600 -q100', 'TempHome': '20', 'TempAway': '15', 'TempComfort': '22.0', 'ClickatellAPI': '0', 'ClickatellFrom': '0', 'ClickatellPassword': '0', 'ClickatellTo': '0', 'ClickatellUser': '0', 'NMAEnabled': '1', 'ProwlEnabled': '1', 'PushALotEnabled': '1', 'PushoverEnabled': '1', 'ClickatellEnabled': '1', 'HTTPURL': 'aHR0cHM6Ly93d3cuc29tZWdhdGV3YXkuY29tL3B1c2h1cmwucGhwP3VzZXJuYW1lPSNGSUVMRDEmcGFzc3dvcmQ9I0ZJRUxEMiZhcGlrZXk9I0ZJRUxEMyZmcm9tPSNGSUVMRDQmdG89I1RPJm1lc3NhZ2U9I01FU1NBR0U=', 'HTTPEnabled': '0', 'HTTPField1': '0', 'HTTPField2': '0', 'HTTPField3': '0', 'HTTPField4': '0', 'HTTPTo': '0', 'KodiIPAddress': '224.0.0.1', 'KodiEnabled': '0', 'KodiPort': '9777', 'KodiTimeToLive': '5', 'ShowUpdateEffect': '0', 'ShortLogInterval': '5', 'DisplayPowerUsageInkWhGraph': '1', 'PushbulletAPI': '0', 'PushbulletEnabled': '0', 'DegreeDaysBaseTemperature': '18.0', 'LmsPlayerMac': '00:04:20:12:65:EF', 'LmsDuration': '5', 'LmsEnabled': '1', 'MyDomoticzUserId': '0', 'MyDomoticzSubsystems': '0', 'SendErrorNotifications': '0', 'HTTPPostContentType': 'YXBwbGljYXRpb24vanNvbg==', 'SendErrorsAsNotification': '0', 'HTTPPostData': '0', 'HTTPPostHeaders': '0', 'PushsaferAPI': '0', 'PushsaferEnabled': '0', 'OneWireSensorPollPeriod': '0', 'OneWireSwitchPollPeriod': '0', 'LogEventScriptTrigger': '1', 'Title': 'Domoticz', 'CostEnergyR1': '2263', 'CostEnergyR2': '2263', 'GCMEnabled': '0', 'PushsaferImage': '0', 'WeightUnit': '0', 'DisableDzVentsSystem': '0', 'DzVentsLogLevel': '3', 'EnableEventScriptSystem': '1', 'IFTTTEnabled': '0', 'EmailEnabled': '0', 'IFTTTAPI': '0', 'TelegramAPI': '0', 'TelegramChat': '0', 'TelegramEnabled': '0', 'EventSystemLogFullURL': '1', 'FCMEnabled': '0', 'MaxElectricPower': '9000', 'Unique_ID': '20ee2d55-8d8c-4f6d-8106-97dafa47fb0f', 'ShortLogAddOnlyNewValues': '0', 'AllowPlainBasicAuth': '1', 'Domoticz_Version': '2025.2 (build 16836)', 'ForecastHardwareID': '40', 'HourIdxElectricityDevice': '624485', 'HourIdxGasDevice': '0', 'Currency': '���', 'P1DisplayType': '0', 'ESettings': '{"ConvertWaterM3ToLiter":false,"DisplayFlowWithLines":true,"DisplayOutsideTemp":true,"DisplayTime":true,"Extra1Field":"Data","Extra1Icon":"heater","Extra2Field":"CounterToday","Extra2Icon":"power","Extra3Field":"CounterToday","Extra3Icon":"other","UseCustomIcons":true,"idBatterySoc":-1,"idBatteryWatt":-1,"idExtra1":688,"idExtra2":901,"idExtra3":506,"idGas":-1,"idOutsideTempSensor":610,"idP1":619,"idSolar":919,"idTextSensor":-1,"idWater":-1}', 'events_recent_list': '12,13'}'
2026-02-01 11:32:53.646  Mapper:  ----> '_plugin'              '<pluginV1.pluginV1 object at 0xf0f7e090>'
2026-02-01 11:32:53.647  Mapper:  ----> 'json'                 '<module 'json' from '/usr/lib/python3.11/json/__init__.py'>'
2026-02-01 11:32:53.647  Mapper:  ----> 'os'                   '<module 'os' (frozen)>'
2026-02-01 11:32:53.851  anna: ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
2026-02-01 11:32:53.851  anna: Plugwise Plugin Version: 1.0.1
2026-02-01 11:32:53.852  anna: Notice: To change the preset by way of scripts/events, please use the following percentages levels:
2026-02-01 11:32:53.852  anna: 10% for Home, 20% for Away, 30% for Night, 40% for Vacation & 50% for Frost (Lua use 'Set Level: 20')
2026-02-01 11:32:53.852  anna: Any other value will be refused!
2026-02-01 11:32:53.852  anna: To Detect changes in scripts use 'Off, Home, Away, Night, Vacation, Frost'
2026-02-01 11:32:53.852  anna: Adjusting the Temp manually on the ANNA or via App, forces the ANNA to set Scenes to Off!!
2026-02-01 11:32:53.852  anna: KNOWN ISSUE: The Gateway will not send an correct update if the previous scene is choosen again!
2026-02-01 11:32:53.852  anna: ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
2026-02-01 11:32:53.913  Squeezebox: (LibreELEC) Disconnected
2026-02-01 11:32:54.217  Hue: Color Switch (Hue color spot 1)
2026-02-01 11:32:54.226  Hue: Color Switch (Hue color spot 2)
2026-02-01 11:32:54.233  Hue: Color Switch (Hue color spot 3)
2026-02-01 11:32:54.523  Hue: Light/Switch (ZGPSwitch Friends of Hue Switch 1)
2026-02-01 11:32:54.855  Motherboard: Temp (Internal Temperature)
2026-02-01 11:32:54.914  Telefoon: RFXMeter (Bytes Send (MB))
2026-02-01 11:32:54.919  Telefoon: RFXMeter (Bytes Received (MB))
2026-02-01 11:32:54.924  Telefoon: General/Custom Sensor (TX mbps)
2026-02-01 11:32:54.928  Telefoon: General/Custom Sensor (RX mbps)
2026-02-01 11:32:54.972  anna: General/Custom Sensor (burner_operation_time)
2026-02-01 11:32:54.978  anna: Lux (illuminance)
2026-02-01 11:32:54.986  anna: Temp (Anna temp)
2026-02-01 11:32:54.992  anna: Setpoint (Anna themp set)
2026-02-01 11:32:57.430  Slimme meter: P1 Smart Meter (Slimme meter)
2026-02-01 11:32:57.437  Slimme meter: General/Voltage (Voltage L1)
2026-02-01 11:32:57.442  Slimme meter: General/Voltage (Voltage L2)
2026-02-01 11:32:57.449  Slimme meter: General/Voltage (Voltage L3)
2026-02-01 11:32:57.454  Slimme meter: Usage (Usage L1)
2026-02-01 11:32:57.459  Slimme meter: Usage (Delivery L1)
2026-02-01 11:32:57.464  Slimme meter: Usage (Usage L2)
2026-02-01 11:32:57.469  Slimme meter: Usage (Delivery L2)
2026-02-01 11:32:57.475  Slimme meter: Usage (Usage L3)
2026-02-01 11:32:57.482  Slimme meter: Usage (Delivery L3)
2026-02-01 11:32:57.488  Slimme meter: Usage (Actual Usage L1/L2/L3)
2026-02-01 11:32:57.494  Slimme meter: Usage (Actual Delivery L1/L2/L3)
2026-02-01 11:32:57.501  Slimme meter: Current (Delivery Current L1/L2/L3)
2026-02-01 11:32:57.506  Slimme meter: Current (Delivery Current L1/L2/L3)
2026-02-01 11:32:58.391  Weer: Temp + Humidity + Baro (Thermo buitentemperatuur)
2026-02-01 11:32:58.398  Weer: Wind (Wind)
2026-02-01 11:32:58.404  Weer: UV (UV Index)
2026-02-01 11:32:58.411  Weer: Rain (Rain)
2026-02-01 11:32:58.414  Weer: General/Visibility (Visibility)
2026-02-01 11:32:58.419  Weer: General/Custom Sensor (Solar radiation Sensor)
2026-02-01 11:32:58.424  Weer: General/Percentage (Cloud Cover)
2026-02-01 11:33:02.014  Mapper: Pushing 'onHeartbeatCallback' on to queue
2026-02-01 11:33:02.065  Mapper: Processing 'onHeartbeatCallback' message
2026-02-01 11:33:02.065  Mapper: Calling message handler 'onHeartbeat' on 'module' type object.
2026-02-01 11:33:02.402  Slimme meter: P1 Smart Meter (Slimme meter)
2026-02-01 11:33:02.410  Slimme meter: General/Voltage (Voltage L1)
2026-02-01 11:33:02.417  Slimme meter: General/Voltage (Voltage L2)
2026-02-01 11:33:02.423  Slimme meter: General/Voltage (Voltage L3)
2026-02-01 11:33:02.429  Slimme meter: Usage (Usage L1)
2026-02-01 11:33:02.436  Slimme meter: Usage (Delivery L1)
2026-02-01 11:33:02.442  Slimme meter: Usage (Usage L2)
2026-02-01 11:33:02.448  Slimme meter: Usage (Delivery L2)
2026-02-01 11:33:02.454  Slimme meter: Usage (Usage L3)
2026-02-01 11:33:02.460  Slimme meter: Usage (Delivery L3)
2026-02-01 11:33:02.467  Slimme meter: Usage (Actual Usage L1/L2/L3)
2026-02-01 11:33:02.473  Slimme meter: Usage (Actual Delivery L1/L2/L3)
2026-02-01 11:33:02.479  Slimme meter: Current (Delivery Current L1/L2/L3)
2026-02-01 11:33:02.484  Slimme meter: Current (Delivery Current L1/L2/L3)
2026-02-01 11:33:02.492  Slimme meter: General/kWh (kWh Usage L1 (Calculated))
2026-02-01 11:33:02.499  Slimme meter: General/kWh (kWh Delivery L1 (Cal))
2026-02-01 11:33:02.506  Slimme meter: General/kWh (kWh Usage L2 (Cal))
2026-02-01 11:33:02.512  Slimme meter: General/kWh (kWh Usage L3 (Cal))
2026-02-01 11:33:02.519  Slimme meter: General/kWh (kWh Delivery L3 (Cal))
2026-02-01 11:33:04.972  Telefoon: RFXMeter (Bytes Send (MB))
2026-02-01 11:33:04.975  Telefoon: RFXMeter (Bytes Received (MB))
2026-02-01 11:33:04.978  Telefoon: General/Custom Sensor (TX mbps)
2026-02-01 11:33:04.981  Telefoon: General/Custom Sensor (RX mbps)
2026-02-01 11:33:07.416  Slimme meter: P1 Smart Meter (Slimme meter)
2026-02-01 11:33:07.424  Slimme meter: General/Voltage (Voltage L1)
2026-02-01 11:33:07.430  Slimme meter: General/Voltage (Voltage L2)
2026-02-01 11:33:07.437  Slimme meter: General/Voltage (Voltage L3)
2026-02-01 11:33:07.443  Slimme meter: Usage (Usage L1)
2026-02-01 11:33:07.447  Slimme meter: Usage (Delivery L1)
2026-02-01 11:33:07.451  Slimme meter: Usage (Usage L2)
2026-02-01 11:33:07.455  Slimme meter: Usage (Delivery L2)
2026-02-01 11:33:07.460  Slimme meter: Usage (Usage L3)
2026-02-01 11:33:07.464  Slimme meter: Usage (Delivery L3)
2026-02-01 11:33:07.468  Slimme meter: Usage (Actual Usage L1/L2/L3)
2026-02-01 11:33:07.472  Slimme meter: Usage (Actual Delivery L1/L2/L3)
2026-02-01 11:33:07.476  Slimme meter: Current (Delivery Current L1/L2/L3)
2026-02-01 11:33:07.479  Slimme meter: Current (Delivery Current L1/L2/L3)
2026-02-01 11:33:12.032  Mapper: Pushing 'onHeartbeatCallback' on to queue
2026-02-01 11:33:12.082  Mapper: Processing 'onHeartbeatCallback' message
2026-02-01 11:33:12.083  Mapper: Calling message handler 'onHeartbeat' on 'module' type object.
FlyingDomotic
Did you authorize Domoticz to create new devices before restarting MqttMapper ?
